Visitor Agreement.
Your Information is very helpful, I am having the same problem but also the car will not start until the light switch is pulled on what are the chances that could be all tied together?
Scot Savitch
Have you had a chance to have the vehicle looked at by a dealer? If not, I would recommend doing so. I am unsure if they are linked. This is a great question for your service staff. Please keep me updated on your situation. I look forward to your update.
Christina
GM Customer Service
The car has been working fine since. Good luck!
Did any of you experience not being able to take the key out of the ignition before all of this happened?
For over a year now sometimes the key will not release when I park (have to wait until it clicks and releases, can sometimes take several minutes). Just wondering if replacing the ignition switch also solves that issue. Maybe this was an early sign that the ignition switch is going bad?
2 days later I was driving in a heavy rain storm. That night I noticed I had no dash lights & no parking lights. The parking light fuse was blown. I replaced it & it blew again so I tried upgrading to a 20 amp from a 15 amp so I could troubleshoot looking for a damaged wire.
I had no luck finding a damaged wire. The next day when I opened the driver door I had a fast warning chime. When I put the key in the warning chime slowed to the normal & stopped when I closed the door.
Any ideas out about what the fast warning chime means with no dash nor parking lights?
Much obliged.
Here is the fix: Youtube video
Your dealer of choice would be a good resource for information on this concern. Please let me know if you plan to take the vehicle into the dealer. Please feel free to email me directly.
Christina
GM Customer Service
SocialMedia@GM.com
This product is a fit for your:
2002 Buick Regal 3.8L SFI SC OHV 6cyl
Part Number: LS927
Warranty: Limited Lifetime
I had success with the odometer problem & youtube fix described above. Thanks for the posts.
Hoping someone can help with this set of electrical issues:
1) My 02 Regal has always had electric windows that intermittently refuse to respond. On the same trip, we can roll the windows down one minute and then not be able to roll them up the next. There doesn't seem to be any trigger or cause and also no fix. We just have to wait it out. Stopping/restarting does nothing.
2) Occasionally, there is a fairly loud clicking sound that comes from the back of the engine, passenger side after the engine is off. Kind of behind the glove box. It doesn't always start right away and has drained the battery before. Sometimes we can prevent this by ensuring the key is in the "steering wheel lock" position before we remove the key.
3) We just started having the engine fail symptom others have described, where the throttle becomes sporadically unresponsive and then the engine dies. After the car rolls to a stop we can turn the key off and then start it again.
I hope that replacing the ignition switch at least fix #3. Maybe more? Has anyone had experience with #1 or #2? I will report what happens after I replace it.
