1500 rpm at 55mph in overdrive sounds about right to me, but normally it would engage overdrive around 40mph unless your pushing it hard.
Here is the text of the letter he sent me.
I can't afford to give you as much as I would like to, but your information was the greatest of help to me. I was working on my daughter's car. I am just one of the many struggling Americans right now. But thanks for all your help, hard work, and research!!!
C.S. I want to thank you for your kind note, which I appreciate more than any amount of money you could have sent. It pleases me that on these forums, we can be of some help to others who are experiencing problems with their transportation. I hope that our posts can be of help to many more people just like you.
Dick
MODERATOR /ADMINISTRATOR
Review your vehicle
Since you now have shop manuals for 97 and 98 Grand Ams, I wonder if you would mind taking a look at the wiring diagram for the security system of the 98 grand am, and let us know the difference between that circuit, and the one posted on my website, bergerweb.net/PasslockWiring It could be of some help to people who own earlier model Grand Ams.
By the way, I have no qualms about posting wiring diagrams of GM cars that are no longer built by the NEW GM, since the company that built them went bankrupt. That GM no longer exists, therefore, no "rights" are being violated by copying those service manuals. Just sayin'
The problem is I cannot locate the 3 wires to the left of the radio. I have the Haynes Manual for the 2003 Grand Am and the wiring diagram does not show the 3 wires. I am an electrician so I do have knowledge on reading diagrams and working with this type of stuff. I also do most of the repair and maintenance work on our cars. I am very disappointed to not be able to do the repair tonight.
Does anyone know if the wiring is different in the 2003 Grand Am? I know the diagram on the web site is showing a 2002 but was it changed for 2003?
I really do not want to go to the dealership for this repair. Any help would be appreciated.
1999 - 2004 Oldsmobile Alero
1997 - 2003 Chevrolet Malibu
1999 - 2004 Pontiac Grand Am
I am informed by someone who did the mod on a 2000 Saturn that there are slight differences in the wiring. The colors of the wires are different, as follows:
Grand Am . | Saturn
Yellow . . . . | Yellow
Black . . . . . | Orange/Black Stripe
White . . . . .| Red/White Stripe
Thanks to Ron B.
Dick B.
You might try to access the wires at the BCM, which is located behind the kick panel, under the glove box. See the instructions on my website at
http://www.bergerweb.net/grandamsecurityfix.htm
You can use the "no-solder" technique there also.
Dick
Here's the specs: 2003 Pontiac Grand Am SE, 3.4L, V6, automatic, standard radio/cd/cassette that came with the car when purchased.
I also found this diagram through a link posted earlier in this thread.
http://www.bulldogsecurity.com/bdnew/newsite/pictures/instdiagrams/46.jpg
Very few of the manuals available at Auto Parts Stores contain any information about the Security Systems. I think for some reason, they think they might run into legal problems if they publish the information, even though every car thief in the world already knows more about these systems than the average mechanic. That said, if you don't mind spending $28.00 for a subscription to the shop manual for your 2003 Grand Am at http://www.alldatadiy.com/ here is how to get to the BCM connector diagram in their online manuals.
Go to ...
Vehicle » Diagrams » Connector Views » Body Control Module
and you will see the wiring list for the three connectors of the BCM. The Passlock wires are probably on connector C2. The two wires to cut are circuit #1835 (black wire), and circuit #1836 (yellow wire).
Once you cut the wires, connect your resistor between the two ends that go into the BCM. Just insulate the other two wires (black and yellow) and leave them disconnected.
If you think it's any help, you can look at the connector diagram for my 2002 Grand Am here:
http://www.bergerweb.net/PasslockFix/BCM-Connector-C2.gif
Note that the two wires you need to cut are on pins A6 and B6. I cannot guarantee they are on the same pins on the 2003 Grand Am GT, but it's a good probability, because GM liked to make their expensive parts like BCMs interchangeable.
Hope this helps.
Dick B
I don't know if this will help, but here is what I have on my BCM (central connector):
Row A (1-12): Pink, X, X, Lt. Blue, X, Black, Black, Pink, X, Yellow/Black, White, X (X means it is empty)
Row B (1-12): Green, Black/White, Lt. Blue, Pink, Brown, X, Yellow, X, Dark Blue, X, Green/Black, Orange
Any more thoughts or ideas?
Here is the connector wiring, along with the color codes to help you figure out which end to work from. Connect your resistor from the yellow wire to the black wire directly across from it.
Right click on the image and choose "Save Image as" to get a full size copy. Hope this helps.
Here is a close-up of the receptacle, with the pins numbered. Take notice of the locations of the guide notches along the bottom of the connector.
I have the same diagram you posted. But for some reason it never clicked that I had it backwards. Thank you so very much. Now it makes sense and I should be able to do it without any trouble. Still can't find any of the 3 wires near the ignition. Couldn't even find them by looking up from under the dash. Very strange.
I feel so stupid now. lol. But thank you.
Did you get it to work? If so, we know that the 2003 is wired the same as the 2002.
It's running now and everything seems to be okay. What do you think?
Dick B
Well, now the car got caught in a flood
I'm fighting to get it running again, the Airbag computer and the BCM was under water and someone told me the lights were flashing on car while in water, so pulled the BCM and its bad looking, like years old green corrosion and rust everywhere.
I removed the BCM.
got fuel tank cleaned out fresh fuel, car starts and stalled in seconds, once it stayed running, sounds great! then doe not start again, hmm.
I had it running for at least a minute, but I turned off because fuel return line was filling up a jug. can the car run without the BCM?
just found out about the security and its relation to the BCM.
Turn the key on, no Security light, try to start it and it stalls, then the security light is on steady. the security light does not go out after 15 min wait. of course the BCM is not connected.
any way to bypass BCM?
"The BCM contains the logic of the theft deterrent system. The BCM provides the battery positive voltage to operate the Passlock(TM) Sensor. The BCM also measures the voltage of the security sensor signal circuit. The voltage measured will indicate whether the Passlock(TM) Sensor has been activated and whether the resistance value from the sensor is a valid value or the tamper value. If voltage measured is in the valid range, the BCM compares this voltage, voltage code, to a previously learned voltage code. If the voltage codes match, the BCM sends a class 2 message containing a password to the PCM. If the voltage codes do not match, or the voltage is in the Tamper range, or there is a circuit fault, the BCM will not send the correct password to the PCM, and the vehicle will not start."
So, you see, the BCM translates the analog voltage from the passlock sensor into a coded digital signal to tell the Powertrain Control Module that it's OK to let the engine run.
Your cheapest alternative is to get a salvaged Body Control Module, take it to a GM dealer and have them re-program it for you. Note that everything to do with the body of the car is controlled by the BCM.... I.E. The Power Door Locks, The Trunk Latch, Headlights, Taillights, Brake Lights, Door Chimes, Horn..... You just can't drive the car without it.
Before going to the dealer, make sure your connectors are corrosion free. Clean them with a mild solution of naptha soap in distilled water, and then rinse with denatured alcohol. Good luck.
Dick B
it just threw me off when the car actually started and ran, must of been luck.
now I just have to wait till the new BCM arrives.
Dick B
To find out if you have a passlock problem, as opposed to a bad starter.
It's normal for the dealer to charge for diagnostics, but when the diagnostics turn up nothing, and the problem is still there, that reveals that the diagnostics they performed was ineffective... a sure sign of dealer incompetence. I'm assuming that you described your problems and demonstrated what was not working when the write-up tech checked you in.
Good luck
I apologize for your frustrations. Did the dealer involve Technical Assistance? Have you spoke with Customer Assistance? I look forward to your response.
Christina
GM Customer Service
The chime remains on all the time for several possible reasons, including
* headlights on
* Key in Ignition
* interior lights on
It sounds like you may have a shorted switch in your ignition module. If you follow the diagnostics in the following two figures, you should find out whether or not that is your problem. Previous postings here have referred you to my website, where you can find the location of the Body Control Moudle.
Pay particular attention to steps 3, 8, 10, 12, and 14, which refer to the key warning switch. I've also included a diagram of the audible alarm system to help out. If you can't do the diagnostics yourself, any good service technician should be able to find and fix your problem if you print out this post and bring it with you. Please let me know if this helps...
Below is a schematic of the audible alarm circuits. If you right click on the diagram, you can view a larger version of it.
You may also find these diagrams useful.
BCM Schematics 1
BCM Schematics 2
BCM Schematics 3
I won't get started on the issue of how financially needy the dealers act ( worked there for decades) , but if the relearn worked, then save your cash. I replaced the passlock sensor AND instrument panel for under $60 with used stuff & my GA always starts now.
And most towns have repair shops that have ex-dealership mechanics who pride themselves on being car fixers rather than parts replacers. Need to call around to find the honest and competent ones. They are getting rarer every week.
There is no secret stuff inside the passlock sensor module. It consists of resistors, a hall-effect transistor, and a three-pin connector. When you cut the yellow and black wires, you take it out of the circuit and replace it with a resistor, which eliminates the variation in value caused by the connector pins and the hall-effect transistor. The BCM then will learn the value of the resistor you substituted into the circuit, and since the resistor is a stable value, you will never have the passlock problem again..... Unless.... you have corrosion on the pins of the center connector of your BCM.
In other words, you have ALREADY replaced the Passlock Sensor.
Perhaps the reason your car would not start after you did the bypass, was because of the fuel pump being stuck. Then you re-wired it to the original configuration, took it to the dealer, and they managed to fix (temporarily) both problems?
Now that your fuel pump is working, try the bypass again and see if you can get it to relearn, and turn out your "Security" light forever.
Dick B
as for the passlock stuff, we did undo the rewiring that we had done before having it towed. so, you think that if i have them put the car back together, tow it home (they said it wasn't drivable without getting the sensor replaced), redo the sensor bypass, it should work? when we did the bypass originally, we did the version where you go through the glove compartment, and we double checked the BCM, which seemed to be free of corrosion and/or water. after doing the bypass and doing the longer relearn technique, the security light never went off and the car wouldn't start. if i do the bypass again, and it still doesn't start, do i need to have it towed yet again (3rd time) and have someone do the dealer relearn? how do i get the dealer/technician to do the relearn without wanting to do the full passlock replacement?
i'm sorry for all the probably obvious questions, but i really want this to get fixed quickly, easily, & (reasonably)cheaply. i really do appreciate all of you guys' advice and help!
At home, make the bypass module I describe in the first few steps of http://bergerweb.net/PasslockFix. Take that module with you to the dealer, and do the rest of the mod yourself in their lot. Then have them do the relearn.
Ill keep this post updated to see if all the bypass and re wiring tutorials work for the 2005 model.
all i have seen is for cars older than 2004 so I am not quite sure if it will but ill still check out the BCM and buy some resistors to try and by pass it. I might use a terminal through the radio to prevent the need of soldering any wires while I'm stuck at a gas station.
but all in all it was easy. :shades:
I have completed the latest bergerweb passlock fix, the no-soldering method.
So the car ran great with no problems for a few months and the security light is off and still is.
Lately the car began to act up again and the car would crank and crank but no start. After a about 10-30 minutes of doing nothing and letting the car sit it would kick over and run fine. This problem recently has become more frequent.
So where do I go from here? any suggestions would be much appreciated.
The car in question is a 2002 pontaic Grand AM GT.
thankyou in advance.
Dick B
