Visitor Agreement.
If you believe, as I do, that using synthetic is just a good thing to do, then OK. Ford will not cut you any slack regarding extended mileage between changes. They have only ONE process, and it applies to EVERY Expy. No exceptions.
Thanks for the input.
FYI, the oil filter is pretty hard to get to for me. You have to be patient to remove it bit by bit.
The usual disclaimer: All above is my own opinion, which should not be confused with actual facts or knowledge : )
shopping for tires could use some insight
i have the goodyears on now
looking into michelin or bf goodrich any ideas please let me know
Article No
01-12-2
06/25/01
ENGINE - OIL LEAK FROM RIGHT SIDE HEAD
GASKET AREA - VEHICLES EQUIPPED WITH
4.6L/5.4L WINDSOR ENGINE ONLY - SERVICE TIPS
ISSUE
On some vehicles there may be an oil leak from the right hand head gasket at the rear of the block/head joint. This may be caused by metal chip debris lodged between the head gasket and the block.
ACTION
Verify oil leak. Inspect for metal chips, impressions or dimples in the metal at the right bank cylinder head and block deck areas behind cylinder 4 at the area of the cast triangular recess in the cylinder head deck. Also inspect around the oil hole breakout in the block deck. Refer to the following Service Procedure for details.
CYLINDER HEAD DECKS
If such damage is spotted, check for flatness with a straight edge over the dimple or impression. If the dimple or impression on the head measures over .025 mm (.001 ") deep, the cylinder head, gasket and bolts should be replaced with new. Refer to the parts listing table that follows.
CYLINDER BLOCK DECKS
Check for flatness with a straight edge over the dimple or impression. If the dimple or impression measures over .025 mm (.001") deep, the engine should be replaced.
Thanks for the TSB. I mentioned my problem at one dealer a few weeks ago and they said that Ford would never be replacing a motor for an oil leak and there hasn't been any problems reported. I wanted to ask if they ever read the TSBs, but since I hadn't read it yet, only heard of it, I thought I should bite my tongue at the time.
Where are these two bad dealers?
First Drive: 2003 Ford Expedition
http://www.edmunds.com/reviews/roadtests/firstdrive/59644/article.html
It may not look much different, but the 2003 version of Ford's Expedition is practically a whole new vehicle from the ground up. But is it enough to overtake the competition?
tidester
SUVs
thanks in advance
As for the dealers I have had some trouble with... both on the south side of metro Denver. Courtesy Ford has no concept of service in their service dept. Not only that, the service writers tend not to come across as knowledgeable. The technicians seems to know what they are doing, but ... The quick lube has good service and does a good job. This is just my experiences, but I have tried them several times and service has been terrible.
Medved Ford is relatively new. I have only had an oil change and tire rotation there, but when I looked over and saw all my tires in a pile I knew I had problems. The technician had no idea which location they came from or where to put them. Not much to go on for the overall all dealership, but... A friend with Chevy to her Trailblazer in for an oil change with the adjacent Medved Chevorlet and after the oil change it wouldn't start. Three weeks later she got her vehicle back. While we would like to blame this on it being a Chevy, there were too many unanswered phone calls, forgetting to order parts, etc. for my comfort. Not much experience here, but I would take my vehicles to either.
Just my opinions above. Courtesy does have some of the best prices around. Largest Expedition dealership there is. Good deals, poor service (in sales and service departments).
Steve
I have owned multiple Fords and have never had this much problem with a new truck.
Q: Will it need premium gas?
Quote 1: $612 over TMV. The dealer indicated this quote was $400 over invoice.
Quote 2: -$262 below TMV and any additional applicable incentive (if available) once the vehicle is deliver. The dealer indicated this qoute was at invoice.
how to spot the right side head gasket problem
TSB: 01-12-2 JUN 01 Head Gasket - Right Hand Side Oil Leak .
The truck came off lease with 47k and I should be able to spot any oil leaks by now. I noticed that 'alwaysford' posted a partial cut/paste of the TSB in a post but I am looking for more detailed info on reconizing the problem myself (photos?). Anyway let me know, I'm taking out the truck tomorrow afternoon and would like to get some insight if this truck has the defect.
Thanks in advance!
Scott
No hassles at all, the dealer was more than willing to work off of the invoice I had downloaded from consumer reports. They even acknowledged the $1236 dealer holdback from Ford and gave me some of that to close the deal.
Now, I just have to wait to see how long it takes to get the thing built & delivered. Can't wait!
Would be interested to ask if service troops has checked for high parasitic current levels. They should at the least monitor current drains immediately after motor shut down and again after 30 minutes, Strongly suspect you have a unusual permanent current drain from some defective device. If so they can remove a fuse at a time to see what circuit is causing the drain.
There are some very sensitive clamp type current meters which work with a fluke or other good multimeter. Of course the advantage of clamp meters is that you don`t open the circuits which could allow the condition to change.
Don`t shoot me for my name on this board. Since no one else seemed to help I thought I would add my 2 cents.
Will test drive a new Ford SUV since I am very unhappy with the lack of options from Chevy. May even buy a NAV. At least will try several brands. Just thought I would check out this site to see what concerns your gang.
Steve
The 2003 does not offer satellite radio.
It uses regular gasoline.
Some dealers have received vehicles.
Component Description:
ENGINE:GASKETS NHTSA Number: SB612444
Bulletin Number: 13846
Bulletin Date: FEB 2000
Vehicle: 1999 Ford Expedition
Summary:SOME VEHICLES BUILT 7/1998 TO 6/1999 EQUIPPED WITH A 4.6 / 5.4L WINSOR BUILT ENGINES MAY EXHIBIT AN OIL LEAK FROM THE CYLINDER HEAD GASKET AREA. ENGINES MAY EXHIBIT AN OIL LEAK FROM THE CYLINDER HEAT GASKET AREA.
So the question is how do I determine when the EXP was built? Thanks in advance...
Here in Denver at 5000+ ft elevation, the 4.6 engine is woefully underpowered compared to the 5.4, especially in a 4x4 configuration. Every time we drive our Expy into the mountains, I'm glad we bought the 5.4.
It all depends on what you intend to use your Expy for.
