Sean
2) Gas Mileage. I have seen several posts, but nothing real consistent. What are you getting on the highway and the city?
As for fuel mileage...if you're a lead foot, 12-14 MPG is possible, maybe less. But average driving (with an occasional fast pullout into traffic) you can average 15-16 MPG combination city/highway. On a recent trip from NJ to Cape Cod, 3 adults, 2 kids, a back filled with luggage and stuff, averaging 68-72 MPH, fuel economy was 17.2 MPG!!!
You might get slightly better mileage with higher octane ratings, but you need to do the arithmetic to see if it is worth the added cost.
Andrew
roane3@hotmail.com
Andrew
Raleigh, NC
Andrew
Raleigh, NC
Steve
Paul
Thanks for your help on this in advance.
mkwame@yahoo.com
tidester
SUVs
The usual time frame that it takes to get to 6 digit mileage @ 15k a yr would be 6.7 years. While I have had 6 digit mileage, (250k app ) this was on a 1987 TLC, FJ60 series. So as you can see, the series as a tendency to change. This particular model before it was sold had app $2,200. in unscheduled maintenance.
#1631
The recommended fuel is the premium fuel or 91/92 octane. The truth is that since the engine is computer controlled, it will run on 87 octane, obviously with correspondingly almost imperceivable loss of power and performance.
If you plan on owning this car for awhile, more frequent oil changes are the best long-term powertrain warranty money can buy, IMO.
Dealer charges me $60 for an oil change with Mobil 1. Not bad for 8 quarts, plus they lube the diffs and top off other fluids. Do it every 5k. Sleep well.
HiC
Can someone recommend a good way of removing rust spots/streaks around the front and read wheels' "brake covers" (I hope I've described this part correctly).
I drive 2000LC and live in Midwest. Needless to say, there is a lot of salt on the road during winter. I noticed a lot of 98-01 LC's have these surface rust spots near the callipers on the "round part" that is made of what looks to be an aluminum and looks like it can be open with a key. It probably stores an ABS or VSC mechanism inside. Please note: The callipers do not have rust spots on them.
Anyhow, these rust spots look really bad and I was wondering if there is a way to remove them, preferably without taking the wheels off. Perhaps there is a chemical solution someone is aware of. I realize, one has to be careful not to damage alloy wheels.
I have a 94 TLC, (original owner)absolutely no rust. (CA)Tire changes @85k. Brake changes at 45k, oil change intervals 15k with synthetic mobil one since new. NO unschedule repair problems to date.
Pirate 4x4.
what year did they go to discs up front, and when did they get rid of the parking brake off the transfer case?
thanks for th input ref pirate 4x4
http://groups.yahoo.com/group/80scool/ or
http://www.crusherworld.com/ or
http://www.tlca.org/ or
http://www.sleeoffroad.com/
Discs in '76, and parking brake went to rear axle in '80/'81 with the introduction of the fj60 wagon. Easy to do the mini disc brake conversion and get larger birfields to boot. Search on pirate forum, and check out Brian Swearingen's site (www.ih8mud.com).
For my 2001LC, my questions are:
1. I'm in Northern CAL and would like a shop name or someone who can professionally bypass the DVD safety features. Any news?
2. How do you get the NAV DVD to eject out of the under-passenger seat player? I figured that the dealer would charge me a mint for the update and wanted to scour the Internet for an update myself. Problem is that I can't find an eject button.
This is a great site and has provided me with a ton of valuable information in the past; including the boomy BASS fix for my stereo.
Thanks everyone
1. I bought the beast not running, now the motor will crank but no spark. my plan is to go thru the standard points, cap, rotor.... but my concern is the wiring. it appears that thru the years my beast has been "modified" from the original configuration. i've pieced it together best i can with a haynes manual but to no avail yet. there is also what appears to be a series of parts above the coil, i'm assuming voltage regulator and something else. any ideas on wading thru this mess to get spark? are there certain things that i should look for or a way to simplify it? the thing (for lack of a better term) above the coil is original and does not look good, what is the best option for replacement, toyota or aftermarket?
2. i had to drain the fuel tank and system, the previous owner had replaced fuel line with an air hose (a technique maybe, but i'll stick to fuel hose) does the pump need to be primed or should it draw from the tank?
