What is this thing worth?
1131416181923
  • parmparm Member Posts: 724
    Happened to run across both of these ads and at first glance thought they were both for the same car. Talk about seeing double.
    '56 Belair in Oregon
    '56 Belair in Iowa
    Neither car has power steering. But, both have pretty stock looking interiors (except for a few add-on gauges) and 2nd generation motors. And, both have pretty similar asking prices. Guess both dealers were signing out of the same hymnal when it came to giving them a price tag.
    Of the three tri-year Chev's, the '56 doesn't get much love, but it's my favorite.
    20K--$25K should do it for either one. Dream on, Duffy. These are modified cars.
    Here's a '56 with 327, 4-speed and claims to be show quality for $25K
    http://cars-on-line.com/46680.html
    You should be able to buy a restored, correct '56 Chevy 2D HT for the money they are asking for resto-rods.
    Sounds like a good plan for summer cruising in a low option, mild engined 60s Detroit vert: buy to drive, use it up, and enjoy.
    If I were open to that plan, I might look at these two: The GTO needs to show some interior shots but seller is offering more pics on request. The Firebird could be fun because that 3-speed is just begging to be replaced by a Muncie 4-speed.
    Spend no more than you would on a 2 y/o Camry, and inspect carefully for rust, damage, etc...just like you would on a used Camry! :P
    Even if depreciates like a modern Detroit car there's not a whole lot of risk up front since neither car is a rare minty collectible.
    Exactly---some Escalade t-bones you (hopefully on the passenger side at low speed), you throw it away, get your check from Hagerty insurance and go buy another one. Clones are plentiful because they are built from higher production lower-optioned models in most cases.
    I think the passion for "matching numbers" and correct bolt-head patterns and "only 2,542 made of which only 647 are known to exist" is all fading away--many new collectors want to drive these cars and not have to worry about them. Repo parts are fine with them, as are various modifications. They want safe, reliable vintage cars, not authentic ones.
  • garv214garv214 Member Posts: 162
    I have 2 cars that have captured my attention
    Car #1: 1968 442 (W30?)
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160442924854&ssPag- eName=STRK:MEWAX:IT
    Pros: Real 442 with a 4 speed, completely done, 4:33 rear end gear
    Cons: Will never ever be able to prove its a W30, have to live with the side stripe being mispositioned (my pet peeve on these cars), 4:33 rear end gear
    E-mailed the owner, seems like an honest guy. This car came up on E-Bay before and it topped out in the middle upper teens if I remember correctly.
    Car #2: 1972 Buick Skylark
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220617485226&ssPag- eName=STRK:MEBIDX:IT
    Pros: Completely and nicely done, I am a sucker for this color...
    Cons: Not a real GS, but I don't think that bothers me too much...
    Any thoughts on what these beasts are worth?">link title
    The '72 shows some overspray on the driver's side window A-pillar rubber molding. I only mention that because it suggests a quickie paint job which, in turn, might lead one to believe the car may not be done quite as nice as it initially appears. Also, I don't recall ever seeing that color on a '72 Buick. But, that's just a gut observation and I've been wrong once before . . . . . . :P
    edited June 2010
    1969 442 convertible
    Here's one you might want to look at. It's a column shift automatic, but it's fairly well loaded and has factory A/C. This car is offered by the same dealer that has the '65 Tempest and '67 Firebird. So, if the prices on those two are high, then I suspect we'll find out the $34,900 asking price (ironically the same as the Firebird) for this 442 is in rarefied air too.
    BTW, the ad shows this car has a 350 motor. Was that correct for a 1969 442?
    Nope something's wrong here. If he meant "350 HP" through the original 400 cid motor, that's still not right because a 350HP option only came with a manual transmisson. The automatic trans took a 325 HP or a 360 HP motor, also a 400cid. There was no 350 cid in a 69 4-4-2
    If the car were "real" and very very sharp, the price would be about market correct.
    If it's the wrong motor, then you have to deduct whatever it would cost to find, date code and rebuild a correct motor. That would probably be at least a $5000 enterprise.
  • euphoniumeuphonium Member Posts: 3,425
    As for the Oregon Bel Air, Memory Lane Motors has been in business for over 20 years and the firm is known for selling very solid vehicles. :)
    Just based on what I've seen of the two '56 Belair's, I think the one in Oregon would be the one I'd want. This car has power front disc brakes, but "arm-strong" steering. If you could have only one power assist feature, not sure which would I would prefer (brakes or steering). Anyone driven a non-power steering Tri-Y Chevy lately? Once you got underway, I wouldn't think the steering would be too bad - especially on the highway (actually might even be better than having power assistance), but I'm guessing manuevering it into a parking spot might result in a bit of a workout?
  • andre1969andre1969 Member Posts: 26,109
    Other than a 1980's Dodge Colt, I don't think I've ever driven a car that didn't have power steering. Now, I've driven a few that had failed power steering, but that's a different story, and requires MUCH more effort than simply not having power steering, as you have a different ratio, usually a smaller steering wheel, and I swear that when the steering fails, that pump actually fights against you!
    I drove my '68 Dart for years with failed power steering...didn't mind it at the time, but when the power steering in my '79 New Yorker went out, I had it fixed immediately! That thing was a brute, thanks to the extra weight and bigger tires.
    I've had a few cars without power brakes (the two Darts and a '67 Newport) and didn't find the lack of a power boost to be a problem. However, if you convert to disc brakes, a power assist is almost mandatory.
    As an Alpine skier, my legs are stronger than my arms so I'd chose power steering.
    I believe power steering can be added to the Oregon Chevy.
    I'd choose power steering as well. I wouldn't even consider a 50s car without it.
    Really, that bad? I wonder why someone who would put that much money into re-doing one of these wouldn't go the extra mile and upgrade to power steering - particularly since they opted to install disc brakes? Is it that big of a deal (aka. expensive) to add power steering to a Tri-year Chev.?
    Not a big deal to install, no.
    On a big heavy V-8, lack of power steering would be a deal-breaker for me. On a sports car, of course, not.
    That's why the old cars had such huge steering wheels you know.
  • fintailfintail Member Posts: 58,668
    In the mid 90s my dad bought a car out of an estate...68 Fairlane, white on white, no power steering, no power brakes, 3 on the tree. That was fun to drive!
  • morin2morin2 Member Posts: 399
    The latest car I've owned without power steering was an 87 VW Golf, one of the last built in PA. It was totally a non-issue and never a problem. Of course, I never parallel park, so even my old pickups and 68 Dart (yes, me too Andre) were fine without power steering - to me!
    All well and good considering you could hang that Golf on lifeboat davits off the trunk of most 60s cars. :P
    True enough, the Golf was so light, power steering would have been silly. Still, I never felt that I "needed" power steering on my full-size 65 and 66 Ford pickups. I believe that power steering has allowed the development of the bad, careless habit of turning a wheel when the vehicle is not in motion which leads to increased tire and steering component wear. I wonder if power brakes have helped to foster this epidemic of reckless tailgating.
    I guess there is some subjective preference there, but in terms of market value, two cars, entirely similar except that one has PS and one doesn't, will show different values. The PS car should bring a 5% premium at least.
    Wouldn't it be ironic if it ended up being the same '68 Dart? :shades: How long ago did you have yours? I bought mine back in 1992. I remember letting one of my friends take his driver's test in it. He screwed up almost immediately, and the cop he rode out with made him get in the passenger seat, and then the cop drove the car through the whole course. My friend said the cop was cursing my car the whole time for not having power steering. He also whined about it idling too fast.
    I had mine from 1978 to 1981 - basically it was my daily transportation. I bought it for $400 when I was a grad student at Rutgers and used it to collect fish samples from every little cove from northern Maine to FL. That car saw a lot of salty environments. It had the slant-6 and 3 on-the-tree and manual roll-down AC. I duct taped several DC air pumps to the dash and ran the elec. lines out the vent window to the battery to keep fish alive on trips - with aquarium tubing running to coolers on the passenger side and back seat.
    On those collecting trips, I fell in love with the Chesapeake Bay and accepted the lowest paying job of those offered - just to live here. Since then, the population has more than tripled (Calvert Co). Sometimes when we love an area, others discover it too.
    The Dart would never have passed MD's tough inspection, so I put it for sale and a waterman bought it for $250 with the intention of using the slant-6 in his workboat.
    The body was pretty beat by then - so I hope its not the same car you bought in '91! I've always liked Dodge Darts and the slant-6.
    No doubt convenience features have made many drive worse - especially the automatic transmission. It's usually not the more manual-driver involvement focused cars I see out there cutting people off, pulling out in front of fast moving traffic, dawdling around at 10 under the flow, phone yapping, etc.
    Black one
    Blue one
    Hope there are some 442 experts (I'm not) out there. The black one was presented earlier. It's an automatic (column shift at that) with a bench seat, but it has received some new bits and pieces (bezels, wheel well chrome and side moldings, door panels, seat covers, carpet, top) rechromed bumpers, new brakes rebuilt front suspension (no idea what all that entailed) and new exhaust with Flowmasters. Plus, it has factory A/C, power windows and it's riding on spiffy Torque Thrust wheels.
    The blue one appears pretty stock/original and stirs the gears with a Hurst 4-speed. It too has factory A/C and the original AM/FM radio (which is a nice touch). Manual crank windows, but a tilt steering column and a working tic-tock-tac.
    Given the amount of work and replacement parts it has received, the black was probably a former quasi basket case. Whereas, the blue one has apparently been fairly well maintained. So, I guess it comes down to, do you like the "new" and "glitz" of the black one or the "faithfulness" of the blue one?
    Both cars have power steering and power brakes. I'm going to contact both dealers to discuss their power trains and what they were born with. Since neither ad says "blows cold", I'm going to assume neither of the A/C's work. Asking price of the black one is $34,900 and $28,900 for the blue one.
    OK. Which would you want and how much would you pay (aka. what's it worth)?
    Yeah, different Darts. Mine was a 2-door hardtop, the 270 series. Originally had a 273 V-8/automatic, but the guy I bought it from said it had a rebuilt 318. It was primer black when I bought it, and the only places where it was really bad, rust-wise, was in the rear quarter panels. It had about 253,000 miles on it when I bought it (rebuilt engine went in at 242,000, and a replacement transmission/rear end soon thereafter, when the added power pretty much shredded them) It quit running in late 2001 with around 338,000 miles on it, but I think it was just the fuel pump. But I didn't have the time or the money to mess with it at the time, so I unwisely just let it sit. The guy who bought it from me got it to run for a few seconds by pouring gas in the carb and messing around with the contact points. It actually sounded pretty sweet. I was surprised, as that was the summer of 2008, and at that point, it hadn't been run in about 6 1/2 years!
    Before that one, I had a '69 Dart GT with a 225 slant six. Had that one from late 1989 to early 1992, when I got run off the road and hit a traffic light pole. I still miss that car. It was pretty nice, and only had about 78,000 miles on it when it got wrecked.
    I think I'd go for the blue one, even though ideally the blue one with an automatic would be my first choice. Pushing those huge boats around with a 4-speed gets to be a chore IMO (it's more fun to drive a slow car fast, then drive a fast car slow); other considerations--- a black car is torture in hot weather, especially a 'vert, and the black car is probably priced too high. Of course, all this depends on an eyeball inspection.
    A whole lot on these old cars depends on how they actually drive. They can all look nice, but when I get into one of these 60s cars, I'm always amazed how differently two identical cars can feel on the road. I look for a certain smoothness, not too many rattles, good straight tracking, easy shifts, lack of vibration in the drivetrain, etc.
    You can always tell a "cosmetic" restoration by the test drive---they look great, they drive like crap. :(
    I like the Blue one as well. One troubling item on the black one is that the seller claims that it is powered by a 350 and not a 400. The engine pictured is painted gold (the standard color of the 350) and not bronze (the standard color of the 400), so either they were a bit careless in the restoration process, or it may in fact be a 350. If it is a 350, then that car is WAY overpriced. The blue one might have had a repaint as well, as the SSIIs should be gray, not body colored.
    If you are serious, I would lay hands on both cars to see which you like better. I have driven both 4 speeds and automatics, and I prefer the automatics simply because I tend to treat these cars as cruisers vs high performance machines. Mine was a turbo 400 on the column with a shift kit, and it did just fine (it wouldn't white smoke the tires, but it would bark the 1-2 upshift).
    They are fun cars and heck of a lot more interesting (to me at least) than a corvette, camaro, or mustang because there a far fewer of them on the road.
    The consensus is for the blue one. That was my choice too, but wanted to see what everyone else thought. Even though their website shows this car "just arrived", I found out today from the dealer that this car has sold. I wasn't too concerned about rowing through the gears because this would be a weekend toy and not a daily driver. But, I understand the issue. I wouldn't expect very quick or snicky-snick throws. I used to have a 4-speed '77 Trans Am some which didn't very quick throws and was fine with it.
    As other cars fall by the wayside, this 1965 Tempest convertible seems to have the most staying power on my shopping list.
  • russell24russell24 Member Posts: 1
    I am looking to sale my classic jeep and need to know where to start. What is the best way to go about selling it and how can I find its value?
  • texasestexases Member Posts: 11,161
    Take a look at 'completed items' for CJ5s on ebaymotors, see what one like yours got bid up to. Looks like they go from $2000 to $12,000 (show winner). As always, it depeds on condition and equipment.
    edited June 2010
    Talked to the dealer today about gettng some additional photos. I told him I'm serious (I am) and if I liked what I saw in these additional photos I'd be calling him again to discuss price. At that point, the dealer immediately piped up to say he wouldn't budge much at all on price. He's curently asking $23,900 and said he started out (a year ago) at $29K. He feels he's already dropped his price. While he said he'd be willing to sell and ship it to me (I'm about 8 hours away) at his price, he said he wouldn't sell it for $20K and probably not even for $21K - though he didn't say if that included shipping. At $23,900, he felt compelled to share with me that "he wasn't making any money" because he'd already dropped the price so much (paaaalleeeezz!). He bought this car about a year ago. A YEAR AGO! And, he had the guts to tell me he's sold several cars (I think he said 15) this month and "doesn't need to sell this car". :confuse: The car now has 15" wheels. He said if it doesn't sell fairly soon, he'll put on 17" wheels (which he said are more sexy) and will bump his price back up. I felt like saying, "Jeeeezus are you on crack or something???" But, I just let it pass. Personally, I like the 15" wheels. To me, that's the size you would've put on the car back in the day and look great to my eye. Anything larger would look stupid. Couldn't tell if he made that statement to pull my chain and provoke me to "save" this car from that unfortunate fate or not.
    In my head, I was thinking around $17K or $18K and that's assuming the car looks as good in person as it does in the photos - and that's at the TOP end of the CPI/Hemmings value guide. Figured if I threw out my figures at this stage in the game, it would've just pissed him off (he's kind of arrogant if you hadn't figured that out yet), so I didn't push the issue of price yet.
    I'm not brave/stupid/trusting enough to buy a car without looking at it in person (at least at his price) and seeing how it drives. And, I don't expect this guy to negotiate seriously unless I'm sitting in his office with my checkbook in hand. On the other hand, I don't want to make the trip if he still won't come off his price much. Obviously, we need to settle on a price before I make the trip out there. So, I'll be uttering the phrase, "If I come out there and like the car I'll buy it for $_____.
    OK. This is where you guys come in. Help me fill in the blank. What do you think is a fair price to pay? And, at what price or above would I be considered the Village Idiot? :surprise:
  • qbrozenqbrozen Member Posts: 33,803
    edited June 2010
    My number hasn't changed. Maybe shifty's has. (?)
    But I was at $18k before and he was $17,500. I believe you said before it "wasn't perfect." Correct? Sounds to me like he's looking for show car money (seems like so many classic car sellers are, doesn't it?).
    If it were a show car. Like.... ya know... one of those perfect, just restored, examples on Barrett Jackson .... I could see $22k-$23k. So that's a #1 car. If this is a #2, as previously described, you'd be "the village idiot" at anything over $19k, IMHO. And, even then, you ain't typically turning a #2 into a #1 for $3k. So maybe you SHOULD look for a #1. (?)
    edited June 2010
    When I talked to the dealer today, he told me he bought this '65 Tempest convertible in Minnesota and that it came from North Dakota. The dealer's ad shows the car's mileage to be 76,000.
    For grins, I happened to seach Mecum's auction results a bit ago. Here's what I found. At Mecum's St. Paul, MN auction on June 20, 2009 (almost exactly one year ago), they show the following '65 Tempst convertible sold for $18,250.
    - Restored in 2006
    - New heater core
    - New 5 spoke aluminum wheels with redline tires and two spare redline tires
    - Runs good uses no oil
    - New shocks and exhaust
    - Will be driven from Minot North Dakota
    - Power steering
    - Electric top
    - 2-speed automatic transmission
    - 326 CI engine
    - 74,000 miles believed to be actual
    Based on what I know, this HAS TO BE the same car. So, it sold a year ago for $18,250 which I'm pretty sure includes an allowance for the buyer's premium. Good call gbrozen. Uncanny!
    So this [non-permissible content removed] bought the car at an open, public, well-known auction with the plan of MAKING A PROFIT? How the hell is this person in business?? :sick:
    Apparently, he thought $18,250 was a great deal. :P
    edited June 2010
    So with a 7% buyer's premium he paid $17000 for the car, which is retail market. And that was last year, before things have drooped further in the lower end of the collector car market.
    I don't know what he thinks he has here---it's just a Tempest 326.
    OK, I outlined to the dealer the values listed in the CPI price guide (good = $8,675. excellent = $16,475). I also shared with him that I found on Mecum's website the fact that he paid $18,250 ($17,000 w/out buyer premium) almost exactly one year ago. I told him the market for a car like a '65 Tempest has, at best, held steady over the last 12 months, but has probably declined somewhat. Bottom line, I told him I would buy the car for $17,000.
    His entire response? I appreciate the offer. I've never been a big fan of Hemmings or NADA price guides. That's it! . . . . . . I couldn't make this stuff up. Whoever said, "no man is an island" apparently never met this guy. :P
    As a comeback, I should've said, "If you're going to keep your head buried firmly in the sand like that, while you're down there, you might as well look for the Lindbergh baby."
    Actually he should be a fan of NADA, since it posts the highest values by far of any price guide I subscribe to----and I have 6 of them + auction databases.
    I'm not sure what he's waiting to hear on the small shortwave radio he has in his bunker. The war is over, and the collector car market has surrendered 20% of its profits to the economic downturn
    In short, he wants a 2007 price in 2010. Do homeowners get a 2007 price nowadays? In 95% of cases, absolutely not.
    If you want, I'll email the guy and offer him $12K for it. Then, maybe he'll take your $17K! :P
    Doesn't stop 'em from trying, though! My old condo, which I sold for $185K back in December 2004, got sold again in March 2007 for $245K. Right now, there's an equivalent unit for sale, for $237,500. It's only been on the market now for 348 days! I guess one of these decades, prices will come back up.
    As for collector car prices, at the Spring Carlisle swap meet back in April, I did notice that asking prices were finally starting to get more reasonable. Or, less ridiculous, depending on how you want to look at it.
    edited June 2010
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170498124062&ssPag- - eName=ADME:X:RTQ:MOTORS:1123
    Shifty
    I am going to look at this car tonight. I e-mailed the seller asking if the engine was original to the car. He was not aware of any way to determine that for the early model Camaros. As I am sure you have seen one or two of these in the past, is there a way to match the numbers? Also, he claims the engine is an LT1. The block casting decodes to a 1969 350 4 bolt main block either 300hp or 350hp application. How would I determine if it is an actual LT1 engine?
    Your thoughts on the car and its value?
    edited June 2010
    OK, the story continues . . . The dealer emailed me a copy of his invoice from the Mecum June 2009 auction. The hammer price was actually $18,250. The buyer's premium was 6% ($1,095) resulting in a total sale price of $19,345. The invoice is itemized, so it shows "hammer price" and "premium". Thus, there's no mistake on how the math was calculated. During the past few Mecum auctions, the sale price on their website has included the buyer's premium. Apparently, back in 2009 they hadn't started doing that yet.
    He also included the following: "Maybe you can run your business at a loss but I don't. I haven't sold a car at a loss in eight years. This won't be my first.
    2009 was our best year so far. We exceeded five million in sales. It's not because our prices are too high. If you watch the market and the auctions you will have a better understanding of the actual market. I buy 200 cars a year. You just need to buy one. Good luck in your search."
    His advice is for ME to watch the market? Gee! Why didn't I think of that? Duhhh, I've only been watching the market for the last 15 years or so. Still, I gotta admit, I've never had a dealer send me his purchase invoice before. What's more, this "sharing of information" was unsolicited. I never even asked for it. Not sure why he'd do that, other than to shoot down my claim he bought the car for $17,000. So, I give him credit for full disclosure.
    So then, the price was really $18,250 (or $19,345 - depending on whether you include or exclude the buyer's premium). Alrighty gang, what do we think of this car's value now????
    edited June 2010
    Well now, I think I'll offer the guy $11,000, because I think he's a [non-permissible content removed] :P
    Seriously though, I'd tell the guy thanks but no thanks, and good luck holding out on the price, and that one day, with inflation, the market WILL recover enough where that car will be worth what he's asking. And by then, I'll be retired and my $349.22 non-COLA'ed monthly pension check from my years at Boeing might just buy me a case of Ice-House!
    Just like someone who pays too much for a house in an up-market, its the "greater fool theory". It works while prices are going through the roof, but its not realistic or sustainable when the market corrects. I don't believe the guy for a minute. An honest dealer will admit that they can make mistakes when they buy cars and some have to be sold for a loss. The cars sold at a profit make up for it, but the assertion that he hasn't ever sold a car for a loss really rings untrue to me. Occasionally, it makes sense to sell a car at a loss to generate some cash flow (to use for smarter buys).
    IMO - Let him keep the car. What he paid in the past is irrelevant to its value today and should not even be an issue.
    And, again, he paid AT LEAST FULL VALUE when he purchased the car at a public and popular auction. He most certainly did not get a deal on it, so padding it with profit and expecting an informed buyer to pay that price is ridiculous.
    Put it this way... Mom & Pop Hardware cannot buy all of their inventory at Home Depot and expect to sustain their business.
    It's not an LT1 with that casting number, and besides, they didn't make a LT1 in 1970 in a Camaro that I'm aware of. This came out in the Corvette in 1970. So no cigar on that claim until I'm shown otherwise. If it's a Corvette LT1, then the casting # ends in the number 10.
    You can't "match the numbers" without a factory build sheet, but you can tell if it's the right TYPE of engine and the right YEAR (that is, you can tell if it's a correct engine but not if it's the exact one they put in at the factory).
    What you need is the SUFFIX letters after the engine # on the right front cylinder head machine pad. So a 1979 350 would have a suffix code of CNA, or CNJ, or CNI, CNK, CNM, CNN, CRE. That's what you need to ask him.
    I'd treat the car as either a fake or as a NOM engine. If it's really sharp, price seems okay. But it's not an SS, and it's not a big block, there's no build sheet, no block ID suffixs, so neither is it a high dollar car, therefore.
    Thanks Shifty
    The paint was driver's quality at best (some orange peel, some rust bubbling in the typical locations, and some bumps and bruises around the nose piece). Needs a new dash, headliner, and rear package shelf (as advertised) as well as some window trim pieces and all new rubber required for the front end (not mentioned). I haven't checked to see how the auction went, but the bidding was around $9-10K when I last looked, and I'd say that is about right. It's an RS, but as you say, it's not a Z28 nor is it an SS. I told the guy I was going to keep on looking.
    1965 LeMans convertible
    This dealer won't go away. He sent me this Ebay link to a '65 Lemans convertible. It's basically just a classified ad with an asking price of $21,900 which is wishful thinking, and that's being kind. Apparently, the dealer's thinking is, "Asking price = sale price. And, if this car is worth $21,900 then mine has to worth that, if not more."
    The fact that the dealer has had this '65 Tempest sitting in his warehouse for a year now is all the proof you need that it's priced too high. And, the more birthday cakes he buys for it, the less money it's making for him.
    BTW, the Home Depot and the mom & pop hardware store is a great analogy. Hard to believe this dealer doesn't "get" that.
    edited June 2010
    I think the only way I'd take that '65 "comp" is if you gave it to me! I don't like the non-original color, I don't like the wheels, it looks like somebody just took some gray spraypaint to the trunk floor to hide something, the seats don't look so great, the heater core looks like it's disconnected, and it's just a 6-cyl. Not even the OHC-6, which came out for 1966. This thing is just a 215 CID pushrod.
    Yeah, your dealer's '65 with the 326 is worth more. But that doesn't mean this thing is worth $21,900. My guess is that if the 326 really is worth $17K, this one's worth less than half that? And I'm sure if you looked closely, you'd find all sorts of things wrong with it.
