Visitor Agreement.
The DXL does come with Michelin 265's on 17" rims which I believe fills out the wheel well more than a Sub with 245's which I believe is standard. In fact I've heard of 275's actually fitting and not interefering with the front wheel well on turning.
Has anyone else installed 275's and did you have to have the computer upgraded to accomodate the speedometer?
To install, turn off the overhead dome lamps at the dash. The old lamp is easily removed by using a small screwdriver to open the lens of the existing lamp (look for the small notch to pry the lens open). This will enable the light to simply be pulled down from the ceiling. Disconnect the wire plug from the old lamp.
Next take a pair of strong scissors and simply cut the ceiling along the lines impressed into the ceiling by the original lamp (the old lamp is smaller than the new lamp). Plug the wire connector into the new lamp and test the lamp briefly by turning on the overhead lamp switch at the dash. Reinsert the new lamp into the larger opening with the lens open. Once the lens has been closed, the new lamp with switches will be locked into place.
Its an inexpensive upgrade that will enable your third row passengers to do some reading or coloring on any long trips at night. Unfortunately, you can't perform the same upgrade on the cargo area lamp unless you run a ground wire from the third row lamp and change the wire connector to incorporate this extra ground wire.
It seems to be a trend. Getting vehicles taller and taller. I do not like it and think that there is a center of gravity penalty, and a gas mileage penalty.
I think the extra height is great. I like being up high so that I can see what is going on in front and around me. I checked out your profile and see that you currently own a 2001 Impala and post to to Cadillac board. Looks to me like you are spouting sour grapes and may be one of those who do not like those of us who drive SUV's because they are too big. My 2001 Yukon XL is great and yes there is about a foot clearance between the top of the tire and the body. I love it. I can look down into those Impalas and see everything going on. Most of us that own SUV's are not into lowriders.
Merry Christmas!
http://www.offroadwarehouse.com or autozone has them the cheapest
I replaced the stock tenneco (Z71) shocks on my silverado at 21K with bilstein HD's and they are a good shock. Paid $49.99 a piece
Does anyone know [where and if] there are
"Bra's" available for the side mirrors ????
Im gonna be adding a Nice tinted bug deflector also and would really appreciate if anyone here has a Manufacturer suggestion on those also.
The first one I looked at today was made by "EGR" and the EGR's hace two little holes
[One at each end] to keep the tips of the deflector from flapping in the wind.
I'm really not sure if I like that feature - so I'm looking for suggestions.
My next question for anyone who knows - Is - Will the front grill of the Yukon Denali fit
and can one be mounted on the Yukon XL.
I like that purforated grill so much I'd kinda like to one day consider putting one on my
Yukon XL.
Oh yeah & BTW - I still haven't figured out where GMC put that Sub-Woofer they talked about in the Brochure
Anyone know where it's located ?
I obviously didn't get the Premium Sound System.
I've found out real quick that you have to turn the Bass On full and then take the Treble down almost on the low side of it's Zero settings to start getting that mysterious Sub-Woofer to get in.
One problem I see with the ability to put a good sound system in these vehicles - is the front dash design.
To get music up to your head height - you almost always have to bounce it off the front window via a dash mounted set of speakers.
You'll notice one side of the Yukon XL
Dash board is Cupped and not very suitable to mount a set of speakers on the front dash.
I mean what would the alternative to getting music up at head level in these SUV's ????
Overall I'm really pleased with the vehicle and looking forward to adding a few finishing touches.
One word of advice !
Go out to your garage "If you have garage doors"
and check to see if you have a "spring arrestor"
kit on those large springs hat assist your garage
doors to lift them.
I've had first hand experience with one letting go. The first thing it attacks is the side of your car's paint job and will gouge the vehicle down to the bare metal.
I'm putting on new ones this weekend over my New Yukon and adding a Spring Arrestor kit - so if they do break the arrestor system hold them
at bay.
Looking forward to dropping by in the future!
Later On
Anyway, I'm now considering a product called PriorityStart which is supposed to remove the load whenever the battery voltage falls below 11.9V. Has anyone had any experience with this product on their Burb or Yukon?
As far as the speakers go I use the auto tone to get the best sound from the stock system. The sub woofer is on the left side of the Yukon in the rear cargo wall, it's where the spare tire went on the old ones. Now for the front speakers I would look into getting some A-pillars form the dealer for a Denali, they have the tweeters built into them. That should bring the sound field up to ear level.
1. In the Dallas area, what's the best price you've seen on a Yukon XLT w/ luxury pkg (compared to dealer invoice)?
2. Sewell sells a "dual vision" or "double vision" tv/vcp/dvd system with 2 screens mounted from the ceiling. Anyone seen this, have an opinion, or know where to find it aftermarket?
3. How hard is it to install a wood trim kit? They're $350-$400 online vs $700 from the dealer.
4. How hard is it to install a billet grill?
4. Where's the best place online to buy aftermarket wood trim, grills, tv's, etc.?
At the moment, our search facility leaves a bit to be desired but Edmund's is working on improving the system! Meanwhile, enjoy the boards!
tidester
SUVs
http://www.coolwheels.com
http://www.gm-trucks.com
I leased my first Suburban, a '97, which I had planned to keep at the end of the lease, but was unable to negotiate a decent price for a buyout. I wasn't ready to buy new again, and found a '98 LT that was loaded and with low miles. Since the drivetrain supposedly hadn't changed between 97 and 98 I expected the performance and mileage to be the same. It hasn't been.
1.) First thing I noticed was different mileage. My 97 would get 17+ on the highway and around 14 in town. Towing would drop the mileage 2 to 3 mpg. The best mileage that my 98 has yielded has been 15 on the highway and about 12 in town. Towing drops the mileage into the single digits. My dealer said that it was probably the autotrac that was dropping the mileage, but I've monitored the mileage long term now, in warm weather and no autotrac usage, and the mileage hasn't improved. The engine in the 98 doesn't seem as strong, either. Same 5.7 Liter, same 3.42 rear end.
2.) The ride quality is not as good. The 98 came equipped with the touring suspension (46mm Bilstein shocks) and wheels seem to get an excess of hop over bumps, and I will get rear wheel hop sometimes if the rear wheels are slipping in snow. The 98 still only has about 32,000 miles on it, and this was present from the early 20,000 mile range. Could the factory shocks really wear out that quickly? Or could it be the cheesey Firestone tires? I noticed that the specs for these tires show a much higher psi requirement.
3.) The engine knocks when it's cold. The dealer said it was normal, and handed me a TSB for the big block engines. I found the correct TSB for the 1998 5.7 engine that stated some engines had miss bored main journals, and the noise was caused from crankshaft flex. Anybody else ran into that? My dealer can't give me the same explantion twice, from "they all do that", (no they don't; my 97 didn't), to the wrong TSB, to finally he was going to have to call GM about that one.
I really loved my 97, but I didn't really want to make the investment in such a large, expensive to operate vehicle again. I tried to find something else when it was time to trade, but found I couldn't get by without a Suburban. 4 kids, a 100 lb yellow lab, 24' cabin cruiser in the summer and a 4 place enclosed snowmobile trailer in the winter made me rule out just about everything else.
By the way, used Excursions are a hell of a value right now. Just looked at 2001 XLT premium with 19000 miles for only $25,000. Vehicle was in excellent condition. I'm just too attached to the 'Burbs to make the switch, even though I'm not as happy with the one I have right now.
They had the Black Vinyl Fabric Style
{i.e. Le Bra] with flannel linings.
$34.95 a pair (includes shipping)
The site check out basket says [quantity-1]
and that does mean - 1 pair
Jim
-- don
tidester
SUVs
http://www.woodtrim.com/
I live in upstate New York and am considering a remote starter for it. Does anyone have any experience with this accessory on new Yukons? The dealership does not install this equipment and said if a problem was diagnosed that was traced to the remote starter it would void the warranty on this system. Any advice? Thanx.
Before I forget, check with your local Police Dept to find out if there is an ordnance that prohibits leaving a running car unattended. In my ares there are several cities that have these old laws and they are now capitalizing on them to make money by writing tickets.
Please use this add on responsibly, if you park in a garage, especially if it's attached to the house DO NOT RUN THE VEHICLE IN THE GARAGE!! Even with the door open, save yourself and your family the health problems.
I am a newbie at this site, just got a 2002 yukon XL and am wondering what type of engine oil to use. Not sure whether to go for the synthetic type or regular petroleum.
I posted this the other day in the wrong area so sorry for the repeat message. Have to look over us new folks.
-- don
Which to buy?
Need Large tow vehicle, trying to decide between bottom level 4x4 'burban vs yukon xl.
3/4 ton ver. 6.0 liter.
will get 4.10 rear gear, lock diff, few comfort features, dont like leather (too sticky in So Fla).
dont need/want 3 row seat, leather, confort features,
looks like yukon is a little cheaper?
comments ? thanx! (and GO CANES!)
Has anyone had a DIY fix of tracing or repairing the Cruise Control.?
Thanks in Advance.
I do think however since you have decided on the 3/4 ton chassis that you might want to consider the 8.0L engine instead of the 6.0L. Nothing wrong with the 6.0L and in fact its a tremendous engine. I own a Denali XL (which comes standard with the 6.0L) and love the pulling power but I prefer the comfort of the 1/2 ton chassis.
I've owned two previous 3/4 ton Subs before the DXL and chose the largest power available with 4wd.
Given your needs for heavy towing, I would go with the max power available which would be the 340hp and 455ftlbs of torque with a 12,000lb tow rating. There is nothing rated higher and if heavy towing is the requirement, nothing with 4 tires can match the towing capabilities of a 3/4 ton Sub or Yukon XL with the 8.0L engine.
Mike
tidester
SUVS
Mark
If the oil is too heavy a grade on a very cold morning there will be limited oil reaching the heads and lifters until the oil "thins" out from heating.
owners. I'm going down on Monday to order a new
2500 Yukon XL, God willing. This is the deal I was offered: Invoice, plus $500, plus .5% advertising fee.
I need answers! And I know you guys have them!
How long for a truck to be delivered from the time of order? Is it possible it could be here within 8 weeks; want to get the $2,000 incentive.
How can I check progress on the production of my truck? And the shipping?
Is there anything I should be asking the dealer or having him do to stay on top of things and speed things up?
What about restrictions?
Any and all advice is greatly appreciated! Thanks in advance for your help.
Stan the Car-buyin' Man (my daughter's weird sense of humor)
The dealership can give you all the information on where your order is in the build process. Once it gets a build date assigned to it, it usually takes 3-5 days for assembly/testing. From there it depends on where you are in relation to the plant the truck is built at. Mine was built in Mexico and it took 1 week to get to Detroit,MI. Somewhere in this topic someone posted a way to track your vehicle on the railroad using the vin #.
The dealer sales manager gets a list of thing on restrictions, so if you are concerned about that ask him about it. Remember the list is a weekly list and what's on this week might not be on next week, and vice versa. I had problems with the rims, and liftgate.
Sounds like you got a fair deal. My DXL took about 4 months from the close of the deal to delivery but that was at the launch of the Denalis. The distribution system has likely caught up with demand and should result in a much shorter delivery time. Eight weeks seems possible.
I went into two show rooms and got that deal at the second one. On
Saturday I remembered what one of the web sites said on buying cars; not to go down to the dealer but to use the fax or phone. So, I called all the dealers on Long Island, and offered to pay invoice with no advertising fee. Well, two dealers accepted my offer, and said come down Monday and buy the car. So, we'll see what happens tomorrow........
Most dealers are saying 12 weeks to delivery. Some say possibly 6 to 8. Maybe GM will extend the rebate offer. The sales people said no
restrictions at this time. I now have to decide which one to go with.
I tow a travel trailer about 6,000 lbs. loaded. I want the extra power and durability of the 2500. I'll be ordering the 6.0 motor with the 373 rear end. Most of the people on this site are
happy with the performance of that truck. I think I will be too.
Although the 6.0 is more powerful it is offset by the extra weight of the 3/4 ton truck. The 5.3 has 18 lbs. per H.P., and the 6.0 has 18.3 lbs per H.P. If you look at the gearing in the transmission the 2500 has longer gears in 1st & 2nd which will further help reduce power, the same 1 to 1 ratio in 3rd and a slight advantage in 4th. The 6.0 "should" out perform the 5.3 once it gets rolling up to highway speed. We'll see.
If I had to guess, I'd say it was for the OnStar system....
Campo57
what are Burbs getting for MPG with the 8.1 and 4:10's..
- Tim
