Visitor Agreement.
The milage is lower yes but it is cheaper to drive than 100% gas.
I have a 2001 YXL with 8.1 and 4.10 axle. My mpg varies between 12 and 13. My driving is mixed suburban driving. No towing.
seems some people with the 8.1 and Allison 2500HD Crew cabs get the same 12-13....while some get 9!..
I had plans for a 2500 Burb around age 40...(just turned 35).....but perhaps I may jump that plan up 5 years?
who knows....
so yeah Ryan.....I may not be in the market for a 2500HD CC. I keep stressing inside space needs...so why not go with the ultimate for inside space?....although I still like my pick-em-up bed...and feel I may still have more need for it than I think?
I drove a 2001? Burb 1500 for 4 days a while back....and loved it.....although seemed too washy being a 1500 for me...?....but still a fine ride and maybe it was just the moonroof I loved so much?..LOL....
be it a 2500 HD with an aftermarket ASC moonroof or a 2500 Burb with a factory (ASC) moonroof.....Tim is gonna have one...
just thinking...
in a few more months I can order a 2003 2500HD if need be?
thanks again for the MPG info....not that it really matters.......but thanks
...also I really don't feel the need for an Allison tranny.(one of the hold ups for not getting a 2500HD ordered in June 2001)..and the Burb with an 8.1 would solve that problem....(in an auto trans at least...which I would only have for my daily vehicle)
..any more input is great appreciated.
- Tim
so that means your gonna get a carmine burb now?
We will all miss you on the silverado page
Still got an Ado with no for sale signs as of this day....
- Tim
I drove it into our Chevy dealer and he would not even write up a service ticket on it. His exact words were "We get this complaint all day long". He as well as GM think it is OK to consume this much oil. I told him I think GM has brain washed these dealers. I cannot believe that they would consider this acceptable.
After 3 rear window motor replacements, a heater problem, a recall for the brakes, a clunky drivetrain and now oil consumption, I know to dump this vehicle before the 36,000 mile waranty runs out. (The vehicle is a 2000 Suburban- 2WD 1500 series).
In reading other arc hived posts, I still see this complaint on the 2001 models.
Any perspective buyers beware.
Now the window motors were taken care of with a TSB and ALL dealers were instructed to replace BOTH motors upon customer complaint to the new motors that GM designed to get rid of the defect that kept popping up. Your first 2 trips to the dealer must have been before GM had the new motors available so the dealer installed the next best thing, the original problematic ones.
The brake recall was not anything that would have caused a problem in real life, they re-positioned a bracket on the frame because when people were replacing the tires with larger ones the bigger tires were hitting the bracket in a tight turn causing more tire damage than anything else.
Not sure what the clunky drivetrain issue you have is. I remember someone mentioning changing the rear end oil to a thicker oil got rid of this problem. Another possibility is bad U-Joints, but at your mileage I would not expect that to be the case. I think GM went to 80-90 rear end dope to get the clunk out.
BTW - I was the one who had the trans blow up at 20K. Dealer replaced it with a new one no problem...we're very happy with the service at Gallucci in Medina, Ohio. Anyway, they think the valve body failed, built up too much pressure in the trans, and cracked a sprag. Funny thing is, the car sat over the weekend before they looked at it and drove it around for 45 minutes without duplicating the problem. This after the tow truck operator had to drag it out of the garagew because it was locked, and the Service Manager could barely get it into the service bay Friday afternoon.
'burbs are still the best SUV on the planet... not exceptions.
Does anyone know anything about this stuff?
Thanks in advance.
davigf
Thanks again.
- Tim
Many people have taken them off with no holes left after...
Good Luck
- Tim
tidester
SUVs
http://store.summitracing.com/default.asp?target=search.asp%3FType%3Dbysummitpart%26Part%3Dder-14104%26Search.x%3D1%26SearchType%3DBoth
Have you had the tires balanced? If it is only in the range you said it is probably that. While they have the tires off have them checked out to make sure you don't have a bent rim. I would try these things before sending the drive shaft out to be balanced. If you end up doing that though, have them replace the u-joints before balancing, and make sure the shop balances the drive shaft with the slip yoke attached, it makes a difference.
are so concerned about the tranny temp? This is a
very overlooked subject. The #1 cause of tranny
failure is HEAT! It's good you are addressing it.
Along with your tranny cooler I recommend a tranny
temp gauge be installed also. The best place
according to GM is in the trans. pan. The parts
most likely to be destroyed first are the delicate
valve body and associated parts.
There is a special bolt & nut sold for this
purpose with a hole drilled & tapped in the center
to accept the sending unit. I made my own using a
3/8 in. NPT tap.
Summit racing sells nice gauges,I like the digital LED readout type. This will tell you if
your cooler is effective or if you even need one.
It is amazing to see the difference in trans temp from NY to Fla.
Well, enjoy your new truck & your doing the right thing by covering all the bases!
Ken
My price 59.00 + freight - any better deals out there? It is my understanding "Trenz" is the company making them. Wanting to put one on my 01 YDXL & 97 P/U.
Why are they so expensive when the sticker price is $180 ?
I'm currently checking out aftermarket flares and have looked at Bushwacker and Xenon. Anyone have an opinion on the best aftermarket flares ? The closer to looking like original equipment the better..
Thanx much in advance..
I Have had an oil consumption test done and according to dealership it was determined that during that test the Suburban was burning 1 quart per 1,000 miles. They told me this was normal. BullS!!!
Researched on the internet and found 2 GM Service Bulletins that address oil consumption.
Bulletin No. 01-06-01-011 Engine Oil Consumption Guidelines. Summary-The accepted rate of oil consumption is 1qt per 2,000 Miles
Bulletin No. 01-06-01-029 Higher than Expected Oil Consumption(Replace PCV Valve)
After presenting these bulletins to the service advisor He had a new style PCV Valve put on my engine. It took 5 minutes.
Have started new oil consumption test to see if new style PCV Valve solves problem. I don't think it will work.
I found that GM and its dealership will tell you anything to make you go away. For example a dealership in writing stated that 2quarts per 1,000 miles is acceptable oil consumption. When I questioned this with GM a GM Lawyer backed up that ludicrous statement.
Hope this helps any other 2001 Suburban owners who may have an oil consumption problem.
Suburban Driver 12Years
2500 with the 6.0 engine. Has GM solved this oil
consumption thing yet? Is it only on the 2000-2001
models?
Those who have the problem is it possible that
the problem is due to improper break in? I'm going to be very careful about how I break in
this thing. I find burning a quart every 1,000
miles extremely unacceptable! I have had alot of
cars in my time & the only ones that burned more
than 1/2 quart between oil changes had "extremely
high" mileage on them.
GM better watch their step or they will find
themselves in the same boat that Ford is in!
And they've been in it before.
Having a problem is one thing, but trying to sweep it under
the rug is another. Ford has been doing this for years and now
it caught up with them. Seems GM's attitude is the same.
Buyer Beware.
If you'd like to see what they look like, check out this web page (I also had it 2 toned):
http://www.picturetrail.com/gallery/view?p=999&gid=491096&uid=433071&members=1
Campo57
I think if you do one early oil change to get the metal shavings out and then regular 3,000 mile intervals with regular oil, you'll be quite satisfied with the performance and overall maintenance needs of this motor.
Fender flares OEM from http://gmpartsdirect.com are cheaper than dealer and come already painted (white).
Chevrolet 2500 vehicles come with flares. Added set to a '00 K1500 Silverado for $390. (when truck was ordered in Jan '00 flares were on national backorder so I took the truck without flares (they were unpainted from the factory).
certain to get a lemon. I feel alot better now,
but will still be careful about the break in.
KThomp100 how is the oil pressure with the
synthetic? Is it much lower at idle? I hear that it is so slippery that if used before the engine is broken in it will not allow the rings to seat.
A rebuilder said he has seen it where the cross-
hatch in the cylinder walls is still in tact.
By the way, I got my order number and a build
date of the week of January 28. But an estimated
delivery date of March 3rd. Sounds like a long
time for delivery to me, four weeks!
What do you think?
Boco
You'll pay about $3-5K more for a DXL over a fully loaded 2500 with the 6.0L but you'll get the following standards on the DXL that aren't even offered as options on the 2500.
300 watt Bose sound system with 11 speakers
6 CD in-dash changer
steering wheel controls for the sound system
in dash computer for computing fuel and trip info
focussed beam headlights with Denali grill
17" alloy wheels with Michelin Cross Terrains
2" shorter turning radius (DXL 42.3' vs 2500 44.3')
AWD with rear and center limited slip differentials
self-leveling rear suspension (which is very nice when towing but not available on the 2500)
The only benefits you'll gain on the 2500 are the heavier payload, 1600lb (depending on rear ratio) heavier tow capacity with 6.0L and having 4wd Low which is not available with the DXL's AWD.
I think those are the major differences however if I've missed something I'm sure someone will add to my list. Good luck!
Greg
Also when might the new Duramax/Allison package be available in the Yukon XL?
I am researching ways to put a slider on the rear seats for fore/aft adjustments also. I am 6'6" and the rear passenger behind me gets very little leg room right now.
As of 2001, they discontinued the 2 tone option so if you seen any 2 tones, more than likely it's a 2000.
Campo57
