Visitor Agreement.
You know it's interesting to consider the capabilities and potential of my Bonneville in this manner. I do not have the SLE or SSEi model - just a lowly SE that has had a rear stabilizer bar installed to tighten up the cornering a bit. Since that addition, I have noticed that the Affinities are now the limitation for cornering at speeds that I will call 'assertive' but not 'aggressive'. I do occasionally cruise Maine to PA on biz at 75-85 mph in addition to my 100 mile round trip daily commute and am looking for a long lasting, quiet and smooth riding highway tire that will handle the wet weather travel well and get me through this winter for snow and ice fairly decently.
I'll check out Tirerack and the mfg sites for the tires mentioned above and see if one of them grabs hold of me. Thanks again for the great response.
Ken
Ken
Someday I'll need to replace the Bridgestone Dueler H/Ts 215/70x16 on my '01 RAV (currently have 16.5k mi). Already I'm thinking Michelin in general. LTX (I think that is the line), is that the one I should be looking at? My radio tastes run to non-commercial rock/folk/blues.
Thanks for the help.
-ss4
If you wanted to go a smidge wider, Michelin offers the new Cross-Terrain in 225/70-16.
I forgot to mention that we get occasional snow, but sounds like the Michelin M/S's are fine for that. Negligible off-road service (occasional unmaintained fire roads).
Re the OEM Bridgestones, it is good to hear they are considered decent. I'll keep an eye on their treadwear.
-ss4
What are your opinions?
TIA
The Dunlop is a good choice and would work well for your Jeep.
Initial reaction is that they are quiet, smooth and reassuring in cornering etc. The Generals on the back will be replaced next year with two more of these T/As. I paid $243 mounted and installed for the pair.
Hope this helps.
Ken
I agree wqith HP on which side out: Put the side that has the DOT specs out so they can be read.
At 25,000 miles, the treadwear lines appeared; the tire was then useless.
Other consumer and CR testing found the same: this is NOT a tire for most of North American winter weather. Plus: 25,000 mile wear on any non-performance tire is unacceptable. Subaru and Bridgestone should at least warn consumers that their Dueler is not safe for any winter use.
They were replaced with Michelin Symmetry's.
Handling wise, don't see much diffrence. Now I have a 97 Accord rides more like a luxury car than my 2000 V6.
I'm not sure about my H/Ts, but bretfraz and juice (on his Forester) seem to think they're decent, and they are pretty knowledgeable posters. At 16.5k miles and little snow (so far), my jury is still out.
What tire would you recommend for a Jaguar X-Type 3.0 Sport (225/45-17) if you had to choose between Pirelli P Zero and Continental ContiSport Contact.
Thanks for your input!
-SSB
Check the consumer reviews on tirerack.com
Woody in interior British Columbia, Canada
I drove the QX4 with the Bridgestones thru the winter of '97 without a hitch. I experienced very little slippin' and slidin' in AWD mode. Even in 2WD it was pretty solid but needed more care in driving, obviously.
Having said that it always seems Consumer Reports rates Bridgestone poorly in snow traction. "A good choice where winters are mild" I think is the statement they use.
IMO, the smartest thing to do is use your own judgement. There's nothing like a snow tire to provide the ultimate in traction. I believe that Infiniti with a snow-only tire would be almost unstoppable in the winter.
There are some LT tires that perform better in the snow according to CR. Or you could always install a set of Nokian all-season tires knowing that even their basic tire will perform great in snow.
My experiences with the Bridgestone H/T was very good. But your mileage may vary.
Skipdog: Cooper Lifeliner Classic IIs used to appear near at the top of Consumer Reports ratings until a few years ago. Other tires now surpass it on handling, but that tire is very good in snow. A lot of the dealers in this area have Classic IIs on their own cars. It's a decent tire;it just depends on what you expect from your tire -- snow traction, wet traction, cornering, etc. It's also reasonably priced.
By the way, I have no qualifications as a tire expert or anything. Its just that a lot of research has gone into my most recent tire search and I thought I'd pass it along. I was also helped a lot by Bret (bretfraz) and Ken (kens).
Noelle
Lifeliner Classic II.... 60,000 mile treadwear protection limited warranty..... excellent all season performance and enhanced gripping ability in diverse weather conditions..... A specially formulated tread compound helps provide long, even treadwear and excellent traction... Engineering data, page 12
Alrighty. Lots of size available, from 175/70-13 to 235/75-15. S-rated tire. Comes in whitewall and blackwall versions. Whitewalls are almost all 70 & 75 series tires. Blackwalls are mostly 65 & 70 series with a couple 55 & 60.
So it looks like your standard all-season passenger car radial. Not too fancy but will do the job. Like Noelle said Cooper tires do perform well in adverse weather so that may be a bonus. If you're looking for a good value in a basic tire this one looks fine to me. I say buy three more.
Sounds like a cheap way to improve tire performance, if it works.
Dan
Bretfraz, last winter I had that problem with bald tires on a Dodge Neon!
Thanks in advance.
K
kcreature: With the number of people that have had trouble with them and the fact that contrary to the way they are advertised, they are not good in snow or ice, I wouldn't drag an Aquatred III behind a U-haul with 30 feet of rope. Which Forester do you have, the L or the S? I think you may have more choices in the L (205/70/15), but there are a few (very few) good all weather choices for the S (215/60/16). Check out Nokian, Cooper Lifeliner Classic II and Lifeliner SLE (new, but getting decent word of mouth), BF Goodrich T/A M80. And, like Topsea says, you might like the Les Schwab version of the Toyo 800.
If the quality and performance are the same, I don't have a problem if it does not say X One on the side.
Thanks for any thoughts you might have.
Terry
Michelin Radial X plus. The Affinty tires lasted about 68K miles and
were OK but the Michilen X Plus are quieter, the Saturn seems to
track and grip the road better, and Sam's Club has an 88,000 mile
treadwear warranty on them. The price was about $87 for the 185/65X15
Mounting, balancing, new stems, free tire rotations and a road hazard
warranty cost another $9.00 a tire. Out the door with tax they were
just over $100 a tire. I really like these tires and I will get them
for my other cars as needed. They are a little more expensive than
some others but I think they're worth it.
Thanks for any comments on this,
Dan
... what is 'siping'?
I did a search on the web and found mostly references to off-road tires and 4WD'ers who need big tire blocks for mud traction, then add sipes to get wet pavement and snow traction.
The tire dealer that I talked to raves about how it improves traction on ice and snow etc, but I haven't heard from someone unbiased about it.
The tire manufactures put more sipes on their winter tires (e.g. Blizzaks and Arctic Alpins), so I guess it must work.
Anyone with experience with siping on all-season street tires? Tire dealers charge about $10/tire for this.
Just acquired my 3rd set, for our Mazda MPV. The other two sets are on my 87 LeSabre with some 16" Caddy DeVille pulloffs (from Tirerack.com) and my SVT Contour has a set on the factory wheels. (FWIW, I put a set of 17" O.Z. Racing Superleggeras with Firestone Firehawk SZ50EP's on the SVT Contour, those are some insanely grippy dry/wet summer tires!)
HTH
TB
Where were you thinking of having them done? Is having the tires siped by the tire dealer popular in Colorado? I'm in big snow country here in Minnesota and I'm not sure I've heard of them doing that here. But, of course, when it comes to trends (or any new stuff for that matter) we're about two years behind the rest of the country. I did a lot of research locally for my recent tire purchase and nobody suggested that to me, including my mechanic, who'll always tell you how to save money.
Just a little note about the Michelin X-One vs X-Radial Plus discussion:
Everyone is correct; Michelin private-labels the X-One for the warehouse clubs. The tread design might be slightly different but it's the same tire.
One thing to be aware of is if you buy the X-Radial Plus from a warehouse club, that club is the only place you can get warranty service. So if you have a problem you have to take them back to that particular club (any store, of course). If you take the tire to a Michelin dealer, they cannot help you as you have a tire they do not offer. Don't bother trying the old, "it's the same thing as the X-One". That doesn't fly. Michelin Corporate will not support the dealers who try to warranty the X-Radial Plus.
There seems to be a noticeable added traction in the rain and less hydroplaning. I haven't driven this car in the snow yet.
No disclosures? Not a great marketing methodology here.
And, both those brands get also poor wear: hearing barely 30K for the treadwear indicators to say: "replace."
Before I did it, I read some comments that it would reduce the tire life. but strangely when I was having it done, the salesperson told me that it would increase the life of the tire (still skeptical). Like you, I also felt that it was a waste to replace the OEM tires, which were fine in good weather. If this did not work I was willing to shell out the $$ for a better tire, and if it wears out faster, the same thing applies.
