Visitor Agreement.
I got a 1993 Cherokee Sport (this time without 4x4, unfortunately) last August with only 84k miles on it. Although the great I6 engine still runs true, I miss some of the amenities of the higher-class Laredo (cargo cover, chrome trim, flip triangle windows, and of course 4x4).
What is amusing is that we've encountered almost the exact same problems in each Jeep. I can almost predict what will happen next, whether it be some type of leak (on the 92 it was the oil, now its the steering fluid), a broken door hinge (trying to defy fate now using some lubricant so I won't have to replace a hinge part, like in the first one), or the EXACT same starter problems (sometimes won't start unless you put it in neutral). However, in the 93 Sport we've had some major transmission problems. It turns out that for some reason it was without transmission fluid for a while, so we got a custom job at Jiffy Lube and some fluid put in. It improved for a while, but then began to deteriorate again. We checked it again today just out of curiosity, and it appeared to have no fluid this time either! We just got back from the Lube again, they put some fluid in. In the 93 Sport model was there a problem with transmission fluid leaks? This problem and the recent development has just blown us away.
Besides the phantom transmission fluid, we've had good luck with both Cherokees. They are durable, roomy (in the front at least) yet compact, and useful to haul cargo. What say you?
-Langley, a young Cherokee fan
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
The particulars are as follows: 4.0L I6, 126,000km
At highway speeds (110km/h or 70 mph)it develops a rather loud moan that really isn't noticeable at lower speeds. The vehicle seems to run fine and the problem is more annoying that anything (for now anyway...)I took it into my local Chrysler dealer who suspects it is noisy front differential bearings (apparently a chronic problem from a poor design from the factory) but isn't sure. Apparently the tires look good and the u-joints are okay. His suggestion is to keep driving it until the problem is better defined. Driving the vehicle until the front diff implodes doesn't sound like a good (or cost effective) solution to me. When asked if I could replace this frontdiff with a scrap one I was told that I would likely inherit the same problem from another Dana 30 axle and it should be rebuild special by the dealership. Until I know the problem, I don't want to dump tons of money for a possible hit and miss scenario. I also understand that this problem may be covered by TSB 03-001-01A but I don't have access to this info (read this in Phil Edmunsons Lemonaid). Can anyone confirm or shed any light on any of the above?
SS
The NHSTA Item Number is 625612, but says it concerns the Grand Cherokee, not the Cherokee (nhtsa.org).
You can also try an Advanced Search here from the link on the left sidebar for Cherokee Whine - you'll get a couple hundred posts about whine, but many are about a whine from the rear (and quite a few are about whining passengers <g>).
SS
-Change engine oil and oil filter
-replace air cleaner filter
-replace spark plugs
-Inspect and adjust drive belt
-Lube steering linkage
-Drain and refill Auto transmission fluid
-drain and refill transfer case fluid
-Inspect brake linings
Additional services at 120 are to replace the ignition cables and to change the front and rear axle fluids. I have a '98 so there may be some differences, but they should be generally the same. Good Luck.
Looked that the jeep site before posting, had to buy a book for the info.
Most of the work has been done in the past 2 months, just need the cap/rotor, spark/wires and transfer case work. Attempting to do it this weekend. Thanks again!
Recently my wife and I set out looking for a new vehicle to replace our '94 Blazer and considered both a Wrangler and a Liberty. The Wrangler was out as a family vehicle, at least for now. It's more for fun. But the Liberty caught our eye. After doing extensive research and shopping I decided we'd have to order one to get it the way we wanted it. If I'm going to buy a new car I want it the way I want it. My son and I both test drove a Liberty with a V-6 and a std. tranny and though the ride was fun, we both got out of it saying to each other it wasn't what we expected. You're supposed to get excited and want one. He was more excited about his $1500.00 Cherokee. So I started looking and searching the web for a Cherokee. There are no new ones available and it's a shame. The Liberty is no replacement. It doesn't have the space in the rear and I didn't think 16 miles to the gallon sounded like what I wanted from a new $21,000 auto. The Cherokee was the answer. A good practical SUV without all the BS. I found a beauty. Slate Blue, Aluminum Wheels, Auto (I'd rather'd had a standard) 36,000 miles, clean and polished. The dealer was about 1.5 hours away and I decided on a Friday to just go look. I looked, test drove it, bought it and drove it home that day. Now we have two. All the shopping paid off with a good decision.
I had the dealer send me the printout of standard features and options and I'm confused as to what the Up Country package includes. It doesn't list it specifically but has the following as options: a 3.55 axle ratio, L&R front and L&R rear spring (upgrade I assume), two customer preferred packages 2TJ and 26J and TZAP Goodyear Brand tires. I know these options come a la-cart, but does anyone know the specifics on this?
It rides good but it's stiff. I paid a little more than I had planned $14,500, but if this has everything on the list he provided, it explains it - along with 1 owner and a 3 month bumper to bumper warantee. The vehicle had been serviced and gone over, including new brakes and nice tires. I'm happy the shopping is over and that the dealer was so accommodating. I just hope it makes the 245,000 miles our '96 has got.
Next is the Wrangler. We're already looking and with 3 Jeeps I'm sure there'll be nothing but a big fight over who who gets to drive the Wrangler. Good luck out there. This is a great site and I'll be sure to visit it often.
I did changed out the spark plugs/wires, cap and rotor myself and worked on one wire at a time. From here on out, I'm changing my own plugs/wire and cap/rotor. Yes, they wanted $275 for the work.
Agree with tolincjrs. The Liberty is no replacement for the jeep, I rented one for a week.
Another question. The past 2 weeks my temp gauge has gone a tad beyond 210, I open up the heat vend and the temp drops down. The only time the temp has gone up was on the freeway either moving slow on a hot day or accelerating to pass or going up a slight incline. Never had this problem before.
I will try and change the thermostat this weekend, if thats not the problem the next thought was to flush the radiator, but figure it might not be the problem because last Dec. I had the changed the water pump upper/lower radiator hoses due to a slow leak.
Any thoughts on determining the possible causes for the temp to rise? Thanks.
Recently had some weird noises start, First one is a loud screeching sound that comes and goes when driving, and for some strage reason it stops when I slow down, It is not my brakes I checked them, maybe a wheel bearing?
The other is a constant low rumbling coming from the engine compartment,this noise is their all the time, seems to be on the passenger side. Anyone have any ideas what these could be ?
I personally don't own a Jeep, but I wish I did. Another friend of mine has an '01 Sport in that gorgeous and rare "Amber Fire" orange color. She hasn't any a single problem out of it in nearly 30k miles. More than I can say for the '99 Explorer I settled for. Oh well, to each his own!
Got opportunity to buy a 2001 Cherokee Limited 4Door 2WD from company fleet, under 70K mile for less 7K. There is no accident or major repair from its maintenace history. What I should looking for during my test drive? Any recommended checkup? Else...? Thanks.
Does anyone out there know if there is a relay or switch for the dimmer under the hood, or anywhere else, or know the cause of this problem.
I have been given the suggestion of a valve cover gasket (not leaking) and I checked around the oil filter in case of a sloppy job no signs of new oil. As another note there seems to be NO new oil on the bell housing of the transmittion, looking from the top.
Any suggestions on what it could be?
anyway, on the 2000 and 2001 Cherokees - are their any differences between the two? looking at 4 liter automatics? are the automatic in the Cherokees that same crappy 3 speeds in the Wranglers from the same years?
how are the 2000-2001 Cherokees holding up? i know they are full of rattles and noise, but are the mechanical components holding up? i saw on MSN that those years have Camshaft Sensor issues? anyone experienced that?
buying a 2000 or 2001 is scary - no warranty.
anything specific to have checked out? why are they so rare with ABS???
all of the V6 models can tow a light boat or jetski no prob, right?
THANKS for your advice!
The tranny on the Cherokees is a Aisan-Warner (japanese built) 4-speed auto that is extremely reliable. Not the best shifting thing, but a good package. I bought my '01 new in December of 2000 and sold it with 75k miles in November of 2003. I had very few problems in that amount of time, mainly just drove it and bought gas. I sold it to a neighbor girl, so I see it regularly. She hasn't had any problems with it and last I heard it was approaching 90k miles.
ABS is rare because it was a very expensive option. I'm thinking it was way over $1,000 and only sold as a free-standing option so no package discounts. When my dealer was searching, there was only a couple withing 200 miles that had ABS.
The 4.0L will easily haul a boat/jet ski. It's a very torquey engine and moves pretty well. If you have a hilly area, it won't stay in overdrive much because 4th gear is very tall on these trannys. I towed around 3500# fairly regularly with no issues.
there are a couple of them at my Jeep dealer, but honestly, don't trust them to tell me exactly everything about the vehicles....
It starts up and runs fine, however the voltage meter is low. When the AC is turned on, the voltage gets lower. If the headlights are turned on, the voltage will decrease until the Jeep dies and has to be jump started. The battery and alternator have been tested, and both are good. What else could be causing this problem?
kirstie_h
Review your vehicle
