Visitor Agreement.
This is just winter up here, though. It is NOTHING like the snowfall you experienced recently! And, I mean to say that it is way more significant down there.
My sister just traded her '05 Forester with 202,000 miles on it and the dealer supposedly has already sold it (my guess is that they really just sent it to auction). It would have been a real project....
What did she buy?
She got a 2015 Crosstrek demo.
Isn't she also the one who is kind of an iffy driver, at least in the city? Was it dented or scuffed up too?
And yeah, the mouse eaten wiring harness was fixed a few years ago, but she had a ~$2,000 ding right before the front door and the inside was well trashed.
I think she got ripped off a bit - kind of funny, I have way more buyer's remorse about the deal than she does.
Cheapest 05 Forester on Seattle CL - and it sounds like a bit of a risk too.
I bet my brother would have given her $800 for it
I'd be very leery of selling there.
Speaking of trucks, mine is back in commission! And, it stops now, too! Sadly, I think the wear and tear on the drivetrain will soon find the next weakest point in the chain, but so it goes... projects will be projects! The front locker is pretty impressive, though! I drove up into my unplowed yard with no issues at all, then backed out in the same manner. The downside? I need to get the power steering fixed! It was a chore before to steer it, but now it is a CHORE! The truck loves to drive straight, but isn't so much a fan of low-speed turning.
I imagine it would be much less of a challenge if I didn't have chains on it. Actually, I might just remove those to see how well it performs now without them, and just keep them at hand for when all else fails. I'll have to see how much work the next plowing turns out to be (on my arms, that is!).
Such a beauty... don't you agree?!
Are you going to plow that Chevy under until the spring?
Good thing we've got a new one ... if the wife ever decides to give it up I'm sure we'll get a great trade value.
“Maybe someday I’ll have enough saved and I’ll see what I can get,” said starting quarterback Kirk Cousins, who drives a dented GMC Savana passenger van to work. “But it’s better to buy appreciating assets than depreciating. No yachts, no sports cars.”
The surprise team of the NFL playoffs is comprised of highly compensated pros who drive beat-up cars and share apartments. (WSJ, may be a registration link)
First Subaru I remember was always parked at a neighbor's house when I was 4 or 5, one of the "new" style ~1980+ GL wagons. They were always around WA even then.
also test drove my English teachers Datsun 610. I remember that thing would backfire on every down shift? Didn't buy it.
the one I wish I had was the 1970ish Datsun 510 another kid had. I remember he replaced the clutch a lot (like to put in used parts I think?) Ah, the good old days.
[FWIW I think it's a stupid mascot, but right on the money in this case
Go Green!
-Mathias
Also, if you need to move it off the trailer for some reason before you get the system working, a simple way I found to do this is to run a tow strap under the blade and connect it to the machine. Then, with a tow vehicle, just pull on the rope and it will lift the blade off the ground as you pull the unit forward. If the unit runs on its own (which sounds like the case for you) and is tall/sturdy enough, you can also run the strap back up over the top of the machine, connected to a ratchet on the back side, and just crank it a few times until the blade lifts a couple inches off the ground.
I had to do this once with mine, thought it was simpler because I have the old-style unit where the hydraulic pump just has an arm above the system that lifts and lowers a chain attached to the blade armature. I put a cargo strap between the lift and the armature, then just pulled it up with the ratchet.
I think that may have been a 1978 only thing, as I believe they went to rectangular headlights for '79.
But, nowadays, I guess most people, if they want to fit more than two people in a truck, go for the extended or crew cab models, so there's really no pressing need to make a single-cab truck with decent 3-across seating anymore.
Ah, I found the pic. This is with the bucket installed. I have a simple plow blade on it now.
That Deere looks pretty handy too, though. I know I wouldn't mind having one! I have a good friend who owns a Craftsman lawn tractor (smaller than that Deere, but still the largest Craftsman they made at the time) with a really impressive snow thrower attachment on the front. He's had it nearly ten years and never used it due to some sort of part that doesn't work right and wasn't available from Sears (or some such nonsense).
I'm still trying to convince him to give it to me. I'm sure I could sort it out.
Current odometer reading is 315,000 miles.
I had a friend in high school whose family had a 70-something (75 maybe?) Oldsmobile Toronado. It was one of those loooong-hooded boat cars, two-door, and had been her mother's primary driver for a long, long time. When we graduated from HS in 1995, the car had about 370,000 miles on it....
A miled up Chevy doesn't faze her at all.
Typically, by the time we get to April, plowing starts to get a little interesting in terms of where to put the snow. It definitely gets more time-consuming because the areas are tighter and I often have to make more passes to get it all cleaned out.
Used pickup buyers in snow country always check carefully for evidence that the truck was used as a plow. If it was, the price was whacked big time or they just moved on to the next truck.
Ran sweet as can be today, a pleasure to have on the road.
You can actually get a crate wankel for not too much money. Modernize it but keep all the character.
Are those actually Mazda OEM wheels? Look like Whitney specials!
Speaking of old Japanese cars, I like these too but the seller is wacky even with the devalued Loonie.
Oh, that is so tempting a challenge.....
