The reason I am interested is because they have, besides a 5W-30 synthetic, a 5W-30 synthetic with moly added. A well known guru, Bob Sikorsky (author of "Break it in Right" and weekly newpaper column "Drive it Forever") has stated that it is the only additive he endorses as having any value.
Never heard of the company in question, you did not give their web site of the cost of the product!
Later,
Al
Another idea is to check the automobilia section of antique shops or flea markets and look for those galvenized containers that were used when all motor oil was sold in bulk.
The dealerships have NO REASON to turn away your service business for the first 5,000 miles ... unless the stories about break-in oil are true.
--- Bror Jace
as for the moly in amsoil, your correct, last time i looked i saw about 5ppms of mos2 in the 20w50 amsoil., in schaeffers the basic ppms of moly is approx 130 to 159ppm's. the mos2 is one of 2 ep/antiwear/friction modifiers in the schaeffers lubricants.
what schaeffers has done is designed thier synthblend's with such high quaility base stocks and robust additive package, that they hold up as well as most all full synthetics. that is one of the main reasons you wont see much in the way of a full synthetic on thier site. ok amsoil guys, i know, it can't be as good as yours, well, if you want there is a company that does indepedent testing with off the shelf products at a cost of $10.00 per report that will give you actual numbers. i would suggest you order those from VOXPOX and see for yourself. thats one of the things i did. and as i speak i have got one of the most advid amsoil believers testing the schaeffers oil and so far has found out some real interesting things for himself. once his scientific tests have been done, he will be posting so others can see.
anyway, schaeffers been in the oil biz since 1830's. ??? oil wasn't around to the 1840's. well sorry, been in the lubricating biz, animal fats and candle waxes back then. i figured they must know a little somthing about oil by now, don't you agree? anyway as a member of STLE and having done many years of research and learning about lubricants i have settled on this company and what they have.
mobil1's grease.... i have some interesting information about grease and motor oils in general and if you want go to my web site which i recently started and will be working on for quite a while. there i have some good information about lubrication and hope to enhance it continually. i also have a forum on oil, FAQ's (which i'm slowly working on adding to everyday) classified section and of course basic general FYI stuff about oil.
enjoy your comments, and thanks for your time.
bob in jville fl.
http://www.bobistheoilguy.com
No reply to date!
Simply put the reason the OEMs tell you to leave the oil in til the 1st recommended oil change is because the fine metal particles circulating around the engine are acting as a lapping compound to help finish the cylinder walls so that the rings will seat properly and minimize blow by. By changing the oil out too soon you actually increase the risk of future engine problems.
Basically a high detergent oil is used to better suspend the particles so they can do a finer lapping job.
Machinists who build engines have known this for years.
Think about it this way, you can machinne an item to a certain precicion. After that it takes unusal steps top get it finer. It would be way too costly to hand lap all the engines. In the long run it works better this way because you can "break in" the engine to your style of driving (within reason).
You will find references to this in most basic texts on engine building used in college auto tech classes.
I doubt that you would permanently screw up the engine doing the oil change sooner. You just wouldn't get the best ring sealing therefore engding up with higher oil consumption and premature valve seal failure. How premature? Who knows, hard to estimate but definitly sooner than if the engine was properly broke in.
Even in the Viper and Vette with Mobile 1 there is still a break in period and a recommendation as to how long to keep the OEM oil in. Since I do not own either one I do not have the manual so I don't know what they specify.
Even with the vast improvements in today's machining, there is still some ring sealing that needs to occur. There is no way to substitute any machine or hand operation to the fine lapping you will get with microscopic metal particles in the oil going between the rings and the walls with the pressure the rings have. This wear will give virtually a perfect seal.
Again I am not saying changing early will cause any damage. just that changing early will not give you the extended life you think it will give you. You may actually shorten the life to some degree. How much is too subjective to say.
Mobil has (had?) two different formulations of their Mobil 1 5W30 listed in the MSDS sheet section of their site. I suspect one was modified to have a higher coefficient of friction to allow proper break-in (seating of the rings, etc ...).
As I've said before. Your motor MIGHT live a perfectly happy and long life without this stuff left in for a long time ... but I'd leave it in as long as they say (or real close) just to be safe.
--- Bror Jace
This amount never changed over the life of the vehicle and my neighbour who now own this truck has since put another 120k miles on it and it is still in great condition. This truck was switched to syn oil at 20 miles!
Most probably, with these cars oil can be changed immediately after purchase, either to dyno or synthetic. On the other hand, it would not hurt to switch to synthetic after 5k, or 10k. Just in case, personally, I decided to use dyno oil /cheap filters / short intervals for the first changes with the Regal, than switch to synthetic. Changed oil at 2k and 5k, and will switch to Mobil-1 and Pure-One filter soon, at 8k.
On the other hand, according to the first message of the tread, if I remember it right, the Honda(?) manual explicitly state not replacing the factory oil before explicitly indicated mileage. I would not second-guess the manufacturer.
bob in jville fl
I change factory oil at 500 miles, change again at 2500, and begin extended drains at 5000. However, I've never had a vehicle that said to maintain the factory oil for any length of time. I think that if the manual states this, I would heed the advice if only to keep within warranty.
Dear Tom:
Schaeffer Mfg. has various engine oils that are petroluem based and synthetic blends. they are available in SAE Grades 5W-30, 10W-30, 10W-40, 15W-40, 20W-50 and in Straight Grades.
Schaeffer Mfg.'s website has technical data sheets on all of these
products.
Sincerely
Lawrence G. Ludwig, Jr., OMA, CLS
Chief Chemist/Technical Director
Schfer@aol.com wrote:
Even the Dodge 5.9L Magnum engine, which is comparatively rough in casting as compared to the OHC high-revvers, does not have a break-in recommendation. Does anyone know of a specific make that claims to add a special oil or break-in component that needs to be maintained for a specific amount of time?
This FAQ seems to indicate that they may not exist?
http://www.citgo.com/Products/Lubricants/brochures/brochures.asp
Here is an engine rebuilding guide that recommends removing the first oil at 30 to 50 miles, then again at 300 to 500:
http://www.sdpc2000.com/htm/techtip.html
BTW -- I know some of you feel that changing to synth. doesn't cause leaks in high milage cars, but mainly I want to see what those of you that feel it can does.
I would not switch oil, but I would go a minimum of 5000-7500 with your dino as your driving is mostly highway and in CA.
As for the sludge: I can say the little four banger in my van has gone 10k before a change (opps!), the oil came out pretty dark, but it flowed easily enough. Also. considering how many Toyotas there are on the road (how many times was Camry best-selling car?) and the first time I heard this problem was here....
Good luck with the Sienna and use synthetic!
--- Bror Jace
I'd best most oils now "tout" Group II in some way or use it anyway.
--- Bror Jace
