Synthetic motor oil
18586889091175
    While I have never had to fulfill on ANY warranty for engine problems, both warranty's were/are in writing. My local Toyota dealership is really to die for. I once wanted some minor work done and mentioned casually that I could not drive the car down to the dealership (7 miles)to get the work done. The service and assistant service manager dispatched a flat bed tow truck to pick up the car!!!! So no gambling is not even on the radar!!
  • 4apexs4apexs Member Posts: 36
    Thanks for both of your comments. Next stop is Toyota dealership to see what they will put in writing. Motor has 500 miles with synthetic and runs quieter and slightly cooler.
  • adc100adc100 Member Posts: 1,521
    I use 10W-30 Mobil and if you are planing on going that distance I would use 10W-30. The reason is that the polymers used shear down (lose viscosity) under high speed and heavy load. 10W has fewer polymers. I have only seen one oil analysis where the 10W sheared down and I don't really believe that one.. Second- I would not go beyond say 7.5K without an oil analysis. Take an analysis at say 5 or 6K and then if OK put on a new filter and run til sat 10-12K. If you have another car keep your oil receipts and just write up your records to indicate you changed oil and filter. The truth does not always pay as you may have learned in 1 st grade. Don't go poking a hornet's nest.
  • eric105eric105 Member Posts: 8
    I have a toyota corolla '97 which I have been using Mobil 1 in since 8900 miles. I have 62k now and have varied my oil changes to 10k, 12k, and 15k. I also believe these engines run hotter on regular oil and will run cooler with synthetic. I use 5w-30 and change filters and top off at 5-6k depending on when I plan on changing out the oil. I would also start changing out the trans fluid if you have an auto trans to Mobil synthetic ATF.
    #4355
    I also use the Mobil One ATF in the 6 speed transmission.( ATF is specified) Again I noticed that the transmision runs smoother. The gears and the gear shifting feels less notchier (yes I know this is not very precise) I also noticed that I get app 1 mpg better.
  • fleetwoodsimcafleetwoodsimca Member Posts: 1,518
    adc100 I agree strongly with you on the 7.5K limit without analysis. But I would personally be more comfortable with not exceeding 10K regardless of analysis.
    4apexs I would get analysis on the first round at or near 7.5K miles, and if all results were very strong for predictable satisfactory continuance, I'd go on out to 10K. I would then change oil and filter. Let me confess that I went out to 10K one time on synthetic. I never did it again, because I was willing to pay for the reassurance that changing my synthetic between 6K and 8K gave me.
    ruking1 Hey, if your Toyota dealer was here, I'd be shopping there for my next car! I do not have a good feeling about my local Toyota outfit, and I do not know anyone here that does.
    A friend has a distribution business using 1/2 and 3/4 ton delivery vans (Ford and Chevy with 305 and 350 V8's) averaging 200 miles a day all in town. For the last 15 years he has used Mobil 1 with 15k intervals. He buys vans new, sells them with 150k. Never had an oil related problem. Any comments on any differances between these V8's and the Toyota 4cyl?
    #4358
    This makes all the sense in the world. Imagine trying to keep the 3000 mile interval schedule with commercial trucks!! If an oil change costs say 30 bucks and now you have your crew taking one hr each to get the deed done, How much more now is a 3000 mile interval oil change? I would say this is a good use of Mobil One and the ability to let you do a 15k oil change interval. Basically you save 5x the product and 5 manhours per 15k interval. Do the math and see if it is worth it or not.
    Seriously, isn't that 4 cyl the one which has had sludge problems? (real or imagined) You can check the Toyota boards or the sludge topic in the maintenance section. Again I would not go to 15K without oil analysis to support it. I know that Mobil has run lots of tests with 15K oil changes and a filter inbetween. and the vehicles lasted 200K. And while I have no reason to believe that the TriSyn and Super Syn are not superior to the 90's version, neither do I know they are. I have seen posts on other boards where the limit of the mobil (additive package) is getting pretty weak at beyond 10K. Viscosity stability appears to hold up very well as mentioned previously. I am a very easy driver and from (only 2) analysis on two different vehicles the additive package will be shaky at 15K (I'm pulling the plug at 10K. So if you drive very hard or expect to keep the vehicle 300K, I wouldn't push it.
    Instead consider the Delvac 1 5W-40 or the Rotella T 5W-40 syn.
  • armtdmarmtdm Member Posts: 2,057
    I tried 15k once with a filter at 7500 and did not like the analysis results. A few of the wear metals skyrocketed. Returned to my 7500 schudule ever since although I think that 10,000 would be acceptable. Toyota engines just seem to beat up the oil more then others.
  • jeffmust2jeffmust2 Member Posts: 811
    Although a few 4s have shown some sludge, the primary problem has been the V-6 3.0L.
    This V6 is in the Sienna, Camry, Avalon, Lexus RX300 & ES300, etc. It really is Toyota's workhorse power plant. Earliest examples came from the Sienna where the engine runs hotter because of poor airflow characteristics.
    Some of the more expert posters believe the sludge forms in the top of this engine because of the shearing effect of some internal gears at high RPM causing the oil to breakdown at relatively low mileages. Add in the 5k-7.5k recommended change interval in the Toyota's owner manuals plus a lot of buyers that might skip a change...or two...and you have the end result of sludge or "gel" as Toyota terms it.
    Toyota extended their liability to fix these puppies to 8 yrs upon proof from the owner that they changed their oil/filter at least ONCE PER YEAR.
    This new extended coverage shows what the power of bad publicity and wide-latitude, over-eager manual recommendations on a high-performance V-6(to help sales) can do... By the way, Toyota's only modification to date on their V-6 is to slightly increase the oil tube passage diameters in the head.
    I really think adc100 is on track, stating in effect that going beyond 10K is risky on Mobil syn. I'd go shorter yet, and on any syn, let alone a petroleum base-- including syn-equivalent SLs. None of these oils is so expensive that you couldn't justify an 8K ceiling, are they? And as for "suspect" engines, I'll tell you that I go 3K on my Toyota 1.6L I4 engine in my Geo Prizm. It is one of the best little engines (my motorcycle is about the same size!) I've ever had. I won't risk sludging it or any other engine I own, by trying to prove that somebody's brand of oil can be pushed further than the other guy's.
    #4363
    I really have nothing to prove! I ran a Toyota 1987 TLC to app 250k miles with 15k oil change intervals. It ran just fine with NO sludge! If anything Mobil One proved to me that it does work!? To boot I ran mostly FRAM oil filters! :):(
  • kirbstoykirbstoy Member Posts: 53
    Thought I'd add my 2 cents worth...After 3K miles on the original break-in oil, I began using Mobil-1 5W-30 and a metal conditioner called Militec. To assure I keep to the terms of my extended warranty, I change the oil & filter with 5K miles between changes. The engine runs perfectly, the temp. gauge never moves off its normal running position even in 110* weather and I've never needed to add even an ounce of oil between changes. Current mileage is 38K. During a recent trip to the coast, we averaged 32.5 mpg with the A/C running and cruising around 65-70. At its next routine major service, I'm going to convert the auto. trans to Mobil-1 ATF. Bottom line: I couldn't be happier with Mobil-1.
  • pulgopulgo Member Posts: 400
    I do not know if the ATF in your Camry is compatible with the Mobil 1 ATF. I found out that for my ECHO there is no synthetic oil that would be compatible (T IV standard). Please verify compatibility because of warranty purposes.
  • thewolverinethewolverine Member Posts: 111
    Like you I'm running Toyota w/ M1 - I have two Siennas running the Oil with smooth operation and good mileage (5K changes) - evetually I'll get around to an oil analysis but expect no problems.
    The Sienna is built on the Camry chassis so the two are similiar although the engine in my 2001 XLE is borrowed from Lexus while the 1998 engine is the same as Camry.
    Right now only the 2001 has M1 ATF - runs great but I plan on going to it for the 1998 shortly.
    I've verified with my dealer M1 ATF is fine for both the 1998 and 2001 Siennas - I'm sure it will work for Camry.
    BTW - how long have you been running Militec? - I'd always filled it under snake oil but I'm still curious.
    Hi..thanks for the information. I've been using Militec in different vehicles during the past 3-4 years. Its the only "additive" I've ever used where I can feel the improvement in engine smoothness. I also believe it helps the engine run "cooler" in Sacramento's very hot weather and the near-gridlock commute conditions. That said...I've never used Militec over a long period of time/distance in a specific vehicle so I don't know if there's a potential long-term downside to its use. The engine in my Focus(DOHC)was very smooth from the factory but using Militec enhanced its smoothness. Good luck.
    Not sure about 2001 0r 2002 models but everyhting before that is regular Dexron II or III. In my 92 Camry I have used Amsoil synthetic ATF since 25,000 miles (calls for Dexron II) I also use the same ATF in my 2000 Buick, Isuzu Rodeo, Mercury Mystique and have used in a Chevy and Nissan.
    Mercon V is not less than "semi-synthetic" in base materials, and it has a LONG list of tranny fluids it supersedes. I have stocked some up to act as a universal replacement for my vehicles, except for my Chrysler that requires ATF+3.
  • mrdetailermrdetailer Member Posts: 1,118
    During the warranty I would not exceed the motor oil change intervals specified in the owners manual, and even though it's a 2002 I wouldn't go over 5000 without an analysis. Viscosity is the main thing to watch out for. Then if it's OK, go to 7500 and see if it's OK at that level. And keep it at that for the guarantee interval.
    In spite of Toyota's declaration I believe that if you had a sludge problem they would certainly question your intervals.
  • aurora5000aurora5000 Member Posts: 168
    Where can you buy it? Is it sold locally or do you have to buy it online?
    Bobistheoilguy did an barrier additive analysis with his timekin machine and found that the later versions of sypersyn had sufficient barrier additives. He figures that the first batch he got when it was just out was bad.
    He now recommends Sypersyn again.
  • bigorange30bigorange30 Member Posts: 1,091
    That's why I didn't pay a whole of attention when he knocked it after his first test. They do millions of dollars worth of research. Would they actually introduce something they call new and improved (and dropping the former product) unless they had done EXTENSIVE testing. They have much more resources than Bob does. It could cost them their reputation and a whole lot of business. I don't think they would risk it. Its kind of like doctors and the tests they do on drugs and food. First it is good for you and then it is bad and then it is good again. I never left Mobil1's side.
    #4374
    I have app 1k miles on the new Mobil One Supersyn. In terms of seat of the pants difference, I can honestly not discern,
    (other than the car runs better after a wash and gets 50 more horsepower when you change the oil!)
    In this case I will have to rely on the R&D that has gone into this new product. I did cut open the oem oil filter after 14500 miles and did take an extended look at the Mobil One trisynthetic. Besides the oily mess, there were hardly any particles and NO sludge!
    Oil analysis on a 2000 Buick GSE 3.8L V6, Supercharged. Three samples reported, first column with OEM fill at 4365 miles, second at 12,190 miles and third at 12,947 miles. Oil and filter changed at each sample and for the last two samples the filter was also changed at about 6000 miles into the interval. Oil added in last two samples is about a quart including the filter change. No nitration or oxidation and the TBN and visc. available only for the last sample. Total engine mileage is 29,487 miles. Total sump capacity is 4 quarts 20 ounces. Oil in engine about 8 months. Filters were the Amsoil SDF 29
    Note two things on these samples. The silicon level which has dropped to normal ranges after about 20,-000 miles on the engine from a high of 173 to 18 ppm. Copper which is still too high for me but reduced considerably from 423 to 194 ppm. Note that on a per 1000 miles basis this went from 97 ppm/1000 miles to 15ppm/1000 miles., quite a decrease. Either the copper components in question are wearing very quickly and the engine will blow soon or the abnormal manufacturing of components has worn down to acceptable levels in the future. May never know. Does show the value of trend analysis and using the same oil over time to evaluate engine wear. .
    Oil used in the last two samples was Amsoil 10W30 full synthetic, not the XL series. However, based upon the TBN of just under 5, I would say I could probably go 15,000 on this oil but very doubtful it would make 25,000. I am going to stick with the 12,000 mile change on this engine, which is about 60% interstate use.
    Miles 4365 12190 12947
    iron 29 21 18
    chromium 4 4 5
    nickel <1 <1 1
    aluminum 8 7 6
    lead 14 13 16
    copper 423 306 194
    tin <1 <1 2
    silver <1 <1 <1
    titanium <1 <1 <1
    silicon 173 47 18
    boron 61 9 3
    sodium 11 7 7
    potasium 15 <10 <10
    moly <5 <5 <5
    phosphorus 1067 1283 1215
    zinc 1023 1502 1655
    calcium 233 2575 3373
    barium <10 <10 <10
    magnesium 977 457 355
    antimonty <30 <30 <30
    vanadium <1 <1 <1
    fuel % vol ? ? 1.0
    total solids .3 .3 .3
    water <10 <10 <10
    visc 100C ? ? 11.5
    SAE Grade ? ? 30
    TBN ? ? 4.99
    The lab is Analysts Inc. out of Hoffman Estates, IL. for all three samples. No oil additives used, gas additives are Amsoil PI, Schaeffer Neutra and Chevron Techron at various intervals.
  • larieblarieb Member Posts: 12
    I have a newer Ford van , pull heavy loads , anybody have any experience with synthetic blended oil , will it decrease the heat on the fluid , any other comments would be appreciated ... Larry
    I have found in the past that Redline polyol ester synthetic oil will reduce operating temperatures. The barrier protection was absolutely top notch, as well.
    #4377
    I would go with a straight synthetic or a straight conventional. You pay way more for a blended that is not worth the extra cash.
    I would like to say that I have some synthetic blend transmission oil made by pennzoil , it cost $2.75 / quart , could not find anybody that makes straight synthetic , except mail order at about $7/ quart .. anybody ever use this synthetic blend ? wondering if warranty will be affected and if it will actually bring temperture down ?
    Larry
    You should be able to find Mobil 1 synthetic ATF in auto parts stores. RedLine and Amsoil are mailorder or find a local dealer. All three are worthe the price, been running it in every transmission I have had for past 10 years
    Check my post, #4370 (:o]
    Local Wal-Mart has the synthetic Rotella, 5W40 only, for $12.83 a gallon.
    The same Wal-Mart has the SuperSyn (SL-rated) Mobil 1 synthetic for $3.58/qt.
  • mdecampsmdecamps Member Posts: 115
    I've noticed by reading some of your posts that you go 15K between changes using Mobil. Is this 5W30? Have you ever checked this via oil analysis to make sure it is holding up (including TBN). Also, from what I gather you have kept the same filter in for the whole 15K. I know a lot of people preach against this, but I'm wanting to extend the intervals in my new truck(1999 Chevy Silverado 4X4 w/4.8L V8) to 10K using Mobil SuperSyn 5W30 and use a Mobil 1 filter without changing the filter in between oil changes. Please share your experiences.
    Thank You,
    Mark
    #4384
    Yes I do use Mobil One 5w-30.
    (and occassionally 0w-30, or 10w-30. hard to pass up the sales)
    I would recommend if you have any doubt, to use the oil analysis both to establish a baseline and monitor trend analysis. I do not do the oil analysis for several reasons, 1. I dont have any doubt 2. The DIC in my machine (computer) calculates the circumstances in which I drive 3. The manufacturer (of one of my machines specifies up to 15k and/or per year. Realistically, I change the oil and filter between 13.5k to 15k. I do use oem AC Delco PF-44's and in TLC's OEM Toyota brand, filters. I have full confidence that Mobil One oil filters ARE better than the AC Delco PF-44, but in my mind the bang for the buck doesnt justify its use.
    I have use Mobil One with 15k oil changes in TLC's for a lot of miles (app 700k)on several vehicles of course, the longest being app 250k . When I bring it into the dealers for each 60k valve checking, all I get from the dealer is how clean and how little wear the engines show. I fully expect to keep ea of the current vehicles to 200,000 and beyond or until boredom sets in! :)
    If you want to step up the fastidious level it would be with an Amsoil or Redline product with their recommended filters.
    I just got my oil analysis back on my first batch of Mobil1. It was on my '02 QX4. It was 10w30 with TriSyn. The oil was used for 6841 miles and was changed with 10,205 total miles on the engine. Blackstone Labs tested it.
    Aluminum = 8
    Chromium = 3
    Iron = 23
    Copper = 30
    Lead = 9
    Tin = 5
    Molybdenum = 3
    Nickel = 1
    Manganese = 4
    Silver = 0
    Titanium = 0
    Potassium = 0
    Boron = 42
    Silicon = 21
    Sodium = 8
    Calcium = 879
    Magnesium = 1203
    Phosphorus = 620
    Zinc = 760
    Barium = 1
    TBN = 8
    SUS Visc. @210 F = 62.2 (59-65 is what Mobil1 10w30 is supposed to be)
    Blackstone says that this is normal for an engine wearing in. They say that after the wear-in, I should be able to take the oil longer as evidenced by the TBN results. I am rather satisfied with this and expect the metals to come down on the next test.
    Like Ruking1, I will buy the Mobil1 that is on sale. I put 5w30 for newer engines in the engine this time. I since found a 5 qt. jug at Wally World for $17.88 of the 10w30 with TriSyn. I expect that it was a closeout price since Mobil1 is repalcing TriSyn with SuperSyn. I couldn't pass up the price.
    These are excellent for an engine with only 10,000 miles. My experience is that it takes over 20,000 miles to get the copper and silicon levels down from the breakin status, seals wearing in etc.
    Ruking 1:
    I'm assuming that one of your vehicles is a BMW. I think you are on the right track keeping the same filter in the whole time. My VW recommends 10K for the oil and filter using synthetic. I am much more confident now that SuperSyn is out. I had a couple of analyises done using TriSyn on my S-10 and I was not pleased at all with the wear metals (ie iron and lead). This was a major weak point for the Trisynth formulation. The new SuperSyn has some moly in it to make up for the lack of zinc. I looked at a couple of analyises on Bob's board and it looks very promising. It is MUCH better than Trisyn, which, in my opinion, was Mobil's worst formulation. More results will come out of the woodwork.....
    #4388
    Yeah, I agree that they have a much better formula in the new SL rated synthetic, Super Syn. I have read the writeups on the new formula and it is better in almost every category! As you have indicated domestic as well as import manufacturers have gone to the longer drain intervals; specifically from every 3k to app 12-15k or a yrs time. BMW, MB, Porsche, Corvette, to name some that I am familar with all have gone to 10-15k intervals.
    according to the new test reviews on the 2003 Accord.
    I still just don't like dirty looking oil pumping around my various power plants.
    #4391
    I can understand and respect this personal preference. However for a few dollars more (200 on up) you can also do a 2 filter with bypass situation and also a preoiler. There are many aftermarket vendors for this very preference. Amsoil makes 2 filter bypass products and I have seen preoilers in the Summit Racing catalog! Again for me what is important are dualfold 1 what is your goal? 2. price/performance
    As you probably know a preoiler prelubricates the engine based on the premise that 50% of the engine wear occurs at start up. The 2 filter bypass products are self explanatory in that one filter filters the gross volume of the oil and the other filter takes a much smaller % and fine filters the oil with the dual end goal of oil where and when you need it. cleaner oil and lasting longer for roughly a 30-40% reduction due to particulate wear! Combined with synthetic oil man oh man!!! Shoot now I am on a roll, lets us put in oil coolers which would add more oil and drop operating temps app 20-50 degrees.
    Where did you read the write-ups on the new SuperSyn? I'm interested in reading about it.....the only thing I've read is the "rave" oil analysis reviews.
    www.mobil1.com (is only one source)
    Every point you make in #4392 is good and meaningful. Another approach, based only on personal preference or even whim, is to buy top brand name petroleum motor oil on sale, stockpile it, and change it often, along with top manufacturer oil filters also bought at reduced prices. I recognize that for me, acquisition of the goods is gamesmanship. Yeah, I'm easy to entertain, as the old joke goes! <:o|</b>
    #4395
    Actually not much difference: I buy Mobil One synthetic on sale, change it at 15k or so, buy OEM filters (on sale) and I think we are both thankful that on this thread we have discussed that Champion Labs makes a 98% filter sold by WalMart for 1.97 under the house SUPER TECH brand name! When I run out of the OEM filters, I sure am going to give them a try! :)
  • sgrd0qsgrd0q Member Posts: 398
    Guys,
    How about just driving up to the dealer and letting them change the oil at the frequency specified in your manual?
    Let's see - you can spend money and time researching what the best oil and filter is. Then you can spend time trying to get those items at a sale. Then you try to extend the oil change interval and send oil for analysis. Well, you send it for analysis anyway, just out of curiosity. And then you spend your time reading my post, and everybody else's posts.
    Why don't you just let the dealer handle it, and forget about it? Most charge only $20-$30 for an oil change. And the job they do is totally adequate, IMO.
    Just out of curiosity - when you take a taxi, or take the bus, or take a flight with an airline, do you worry about the oil in the engine(s)?
    #4397
    Actually being a former bomber,tanker, fighter, etc etc maintenance officer, actually I do!
    For many of us, it's a subject of interest and a form of hobby. I enjoy changing my own oil and have never had anyone else do it. It gives me a chance to see what'sgoing on by observation. If you think the open mouth air breathers at the dealer do a better job be our guest. Many of us prefer to extend our oil drains in order to preserve the enviroment, thus the need for oil analysis. I go 15k on Mobil 1 myself, and the analysis can also tell you what is wrong with the engine before it blows up sometimes. I hardly ever bother with the analysis though. We're just another sub group of humans "doing our thing", don't like it, hit the x button in the right hand corner.
    ruking1 - what is JP4?
    eric105 - I didn't mean to sound critical, but after rereading my post - yes, maybe I did sound critical - I apologize! It's not that I don't like the discussion - I am just amazed that you guys take this subject so seriously. I think most people don't know a thing about oil, and get along just fine. By the way do you really believe in oil analysis? When was the last time the analysis told you what was wrong with your engine before if blew up? As to extending drain intervals and preserving the environment - that is commendable.
    Oil analysis is really useful to people who run fleets. The people who actually do the analysis collect data on many vehicles and can corelate the information sometimes. Currently, a guy who runs a company which does analysis, has a theory that a certain Chevy engine has problems showing up as an elevated copper level. If he proves it out, you might want to avoid that engine in your vehicle.
      The internet has had some interesting effects. World wide, people can get together and form small sub groups for interests most might find at least slightly eccentric. For example:
    http://www.operagloves.com/glovmain.html
      If the above site gets 100 dedicated viewers who partake, it lives. But imagine where we now have 100 people getting together world wide out of the billions living here, as well as the millions on the net.
      As for our subject matter, you are obviously not an engineer!! :-) Motor heads and such eat this stuff up... we are everywhere, be on your guard sir, be on your guard!! Oil neurotics are everywhere; call an Amesoil rep and get your ear bent. hehehe...
