Untill I started reading up on oils on the net I was thinking about synthetic blended oils. With it being unclear what oils are really synthetic and the low ammount of synthetics in blended oil I am not sure what to use. Leaning more toward all synthetic with a 5000 mile interval. Or 1qt syn and 3.5qt dino changed every 4000.
Just did the first oil change today at 950 miles. Used Castrol GTX 5w-30. Got 3000+ miles to decide.
http://forums.stangnet.com/showthread.php?s=&threadid=181031
The comments I have seen about oil blackening being an indication suspending of contaminants. I guess that means that Mobil1 just has less contaminants (ie. less wear of the metal parts) and the contaminants must have all went out with the oil and were not left on these engine parts. Blackening engine parts a good thing? How can that be?
I considered not mentioning we owned a Kia but decided to do so as a sort of test. Seeing someone (you) make such an uninformed comment, and even somewhat of a personal attack, was disappointing. Something like 'Kia sure has a poor reputation around the U.S. Why did you buy a Sedona?' would have been totally reasonable and acceptable. Instead, you said "Well, I guess that fits with a 'buy things with cheapest initial cost and don't worry about the long term costs' attitude. Do you shop for doctors like that too? Do you buy your dishes at the Dollar Tree?"
In reality, I am a pretty discriminating vehicle buyer. When I started my minivan search, I was very skeptical of the Kia. 2 years ago I never would have bought a Kia. But I conducted the research process with an open mind and performed due diligence on the Sedona and determined it was the best choice for our family. We could have afforded a much more expensive competitor but it wasn't necessary.
Conventional motor oil is not a 'cheap product' either. 99.9% of the motoring public uses it in their vehicles. I am not convinced that these folks are shortening the life of their vehicles' engines by using conventional motor oil and changing oil and filter every 3000-5000 miles. If this is one of the arguments you are trying to make, good luck. I do not believe that most synthetic lubricant proponents would agree with you.
It is very disappointing and befuddling to see someone like you, who obviously has some good thoughts and can express them in writing, to think of me as someone who buys 'cheap stuff' based on my Town Hall posts. My posts do not support your conclusions, and I'm having a hard time figuring out why and how you are drawing those conclusions.
By the way, have I mentioned recently that I am using Mobil 1 synthetic lubricants in the front and rear differential, transfer case, and 4WD unit in my Isuzu Trooper? I decided on these synthetic lubricants because I felt they were better performers than conventional products and were worth the extra cost (appx 3 times more). This, and other things such as my willingness to try synthetic motor oil in the past and consider it for the future, really should show I'm not someone who 'buys cheap stuff.'
The bottom line: You may be right that synthetic motor oil is clearly the better choice for all right-minded automobile owners; how can anyone really know for sure? But the reason I've decided on conventional oil instead is not because I can't afford synthetic or am too stupid to understand its superiority. Calling me someone who 'buys cheap stuff' has nothing to do with the discussion about synthetic and conventional oil.
"Why can't we all just get along?".....Rodney King
My take on this? A good dino such as Chevron, Castrol GTX, or Pennzoil, etc, and a good oil filter every 3 - 4k fits most vehicles.
Why go to syn? As an example, my wife's car seemed noisy at startup at about 40k. I switched to syn and it quieted the engine at startup. I change oil at 5k, so I pay a little more this way. But, the car now has 192k and runs great. I can easily justify the small additional expense.
My 4 Runner is a pain to do change oil changes on because the filter is mounted upside down in a hard to reach area, and there is a skid plate that collects the dripping oil. I went to syn oil to stretch the drain interval from 4k to 8k. I am not comfortable going past 8k without an oil analysis. I just changed to a blend, Schaeffers 7000, because I believe that an 8k drain interval will work with this oil.
Just use a good dino at 4k. If you have issues that syn will solve or improve, use syn. This isn't rocket science.
Jack
To me, I think the improved dino oils HAVE closed the gap. Do they go 10k miles easily? I don't think so. But are they signicantly better than dino oils of the past? My impression is yes. Just as my impression is that the current true synthetics are better than their predecessors. For me, they've closed the gap enough that it does not make sense for me currently to use synthetic engine oil.
I don't see people around here claiming or expecting the group III conventional oils as some magic bullet or anything like that. I.e. I don't think the claims/expectations are in the 'too good to be true' category.
As for the Corvette, I personally wouldn't buy one - don't feel the quality is there. But it does have a reputation as being a great value among performance cars - outstanding performance at a bargain price vs. other cars of similar performance.
Currently, I change oil/filter every 4k miles with a quality dino oil. I am sure that my engine is well protected and in my case I would see zero benefit from using a synthetic. If I ever wish to move to extended drain intervals I will switch to a group IV+ synthetic like Mobil 1.
My 98 SVT Contour is typically only driven on weekends, and when it is driven, it is typically driven hard (after a warm up, of course) sees the redline, as well as some track time and Autocrossing. I change the oil every 6 months, regardless of mileage. Mobil 1 5W30.
Same interval on my wife's Mazda MPV, but for different reasons. Yes, it is a high reving engine with the same Ford Duratec, but without the SVT enhancements, but it sees about 10K miles /year. So two annual oil changes, one in the spring and one in the fall are sufficient. I get to do oil changes during typically good weather and protect the engine.
My Buick. I've just switched to Shell Rotella T 5W40 (A fleet oil with the SL automotive rating, after all, the car is a 1987 so I doubt a 5W40 synthetic designed for fleet use will hurt this car much if at all.). I figure that engine and that oil will probably go 10K easily. However, 10K miles will occur somewhere around every 4 months. So that should keep me out from under the car during the cold and snow doing an oil change. I'll probably finish off the Vavoline 5W30 Maxlife I have in the spring, and then in the fall go back to the Rotella T.
But I choose the synthetic to:
A) Extend drain intervals.
C) I believe it will hold up better in severe duty (two of my three cars)
I do believe that a good quality conventional oil will do an adequate job of lubrication.
I just believe a good quality synthetic will do an even better job at the extremes.
So currently, I use 24 quarts of oil for the two Duratec vehicles per year and probably another 16-18 quarts for the Buick with this schedule, including 1 quart makeup oil every 5K.
If I used a 3K or 6 month schedule with conventional oil, I'd probably use 30 quarts for the two Duratec vehicles (I figure I'd still only do two changes on the SVT, but 3+ for the Mazda) 4.and I'd do 8+ changes on the Buick at roughly 4.5 quarts/change and 5 quarts of makeup oil over the 25K, totalling 43 quarts.
If we assume $1/quart for conventional oil and about $3.50/quart for synthetic (Wally World has 5quarts M1 at $17.88 and 1 gallon jugs of Rotella T for under $13) then I am spending $73/year for conventional oil, and about $140-150/year for synthetic.
However, it only takes a few hours of my time not spent changing to oil, for it to be worth that extra $70-80 in oil costs for it to be worth it. Especially when we are talking about 8+ changes a year for the Buick on conventional oil.
TB
Still has at least a year's supply of oil in the garage.
P.S. - Hope your Contour is treating you well - I gave up on my 95 SE after one too many significant mechanical problems and sold it a few months back.
I think I commented on your thread regarding resale value over at Contour.org
It seems you did pretty good selling it.
I've driven Contours in various flavors for the past five years, so I'm itching to get something else.
Wifey's MPV should be paid off Spring 2004 (or even earlier if SUNW posts some great gains on the NASDAQ.) and that will also be close to 160K on the Buick.
Of course, even with the repair history on the Buick, it only costs about $0.15-0.16/mile to drive. Of course 27-28K/year makes that money add up.
Have my heart set on something sedan like, RWD, and a stick.
However, the realities of a currently nearly 13y.o. daughter, impending college, and such will probably burst any dreams of a high end sedan.
So it is more likely a Mazda 6 or Protege. Maybe an RX-8 on a stretch.
Well, that's off in the future. But I'll probably still run synthetic, for the reasons previously stated.
FWIW,
TB
"...Of course, even with the repair history on the Buick, it only costs about $0.15-0.16/mile to drive. Of course 27-28K/year makes that money add up.
Have my heart set on something sedan like, RWD, and a stick...."
Fret not and keep the fire burning! I have been more than pleasantly surprised at the operating costs of an American Sports car: The Corvette.
Synthetic oil and filter, scheduled maint., Gas, tire wear, and insurance comes to a per mile cost of .1085 cents.
Incidently because this is a synthetic oil topic, the cost per mile lubricated has been .00181056 cents.
A neat thing is that I have changed the oil 3 times!
If I had used a Qwikie Lube and provided my own oil and filter, the cost per mile lubricated would be .002458 cents.
If I had used the 3000 mile changes and conventional oil like Chevron Supreme (which is an unfair comparison because the manufacturer requires GM 4718M specified oils, of which synthetic Mobil One meets this standard)
the cost per mile lubricated: .0029347 cents
which is 1.6209334 times more than using synthetic.
I would have changed the oil 15 times !
If I had used a Qwikie Lube (which research has suggested this as fairly common) the cost would have approached .0097826 cents per mile lubricated
While an unfair comparison, Lubrication whether you use a synthetic or convention oil is an absolute bargain !! The use of synthetic is even more so!
I would suspect that when you go shopping for a car after you send your offspring through college, that sports cars will be better still (that is if the environmentalists don't succeed in killing off this market segment or lack of market demand [strange bedfellows, eh?] ) , and synthetic oil will remain a bargain !
Personally I would not get a Viper so I could use conventional oil!?
You will not find out what high maintenance means until you get a Viper!!! By then, it will be WAY too late!!!
While this is off topic, the Viper is WAY harder to drive WELL than a "Zoramobile." Without a doubt it is truly a 10 cylinder BEAST.
It is more than difficult to beat the P/W ratio of currently available motorbikes!!!
(read this: faster, quicker, faster quicker, quicker faster, even better (absolute) gas milege, higher top end speed etc. WAY cheaper in an absolute sense, outside of the fact that you are at a higher risk exposure!)
So that we are on topic: Bikes ARE WAY harder on oils, synthetic or convention!!
I changed oil and filter every 1000 miles for 5K, and then moved up to 1.5K-- That was on my Valkyrie. I used "real" motorcycle oil through 5.5K and then switched to Valvoline 15W-40 All Fleet. I used several Purolators, and now have a batch of Honda filters to last a long while.
So we are talking sedans or wagons, not sports cars.
The Corvette was used as an antedotal comparison for your Buick's .15-.16 cents a mile operation. The fact of the matter is that the operating costs if you are so inclined to track it (as I am)So whether you chose a sports car or a sedan or wagon as you have mentioned twice that you favor, the .15-.16 per mile and the .11-.12 cents per mile at some point will be a yardstick for your new sedan or wagon. Best of luck !!
TB
I would do a lookback (depreciation) of .10875 cents per mile. So adding that to ops cost of .11-.12 cents a mile =.22875 cents.
The Z06 Corvette seems to depreciate even in this down market at 4-6% annually.
Changing oil at 3750 miles does nothing to change the underlying condition that causes the oil to "cook" at specific places in the Toyota engine. If one uses synthetic oil the oil will still "cook" but at a higher temperature. If that temperature happens to be within the higher tolerance side of the synthetic there will be less residue than the conventional oil.
Seems like certain Toyota engines have a design flaw, and if there is no other fix than change the oil more frequently, knowing this that would degrade the value and in my mind the viability and price of buying one of those cars with those affected engines.
If you said that, I think you are on the beam. While it would be tempting to say that synthetic oil would be a cure, the fact that conventional oil cooks would indicate that that "cook plate area" would put it beyond 455 degrees F, which is the upper limit for Mobil One synthetic. The "cooking" of synthetic would leave less sludge residual, but as you had inferred, whatever oil you use will still be cooked unless there is a design change that lowers the temp of the "cook areas" within the operating parameters of engine oil. Bad design is bad design whether or not an 8 year warranty is proferred.
No admissions, no recalls, no further problems?
To give the appearance of swerving back on topic, I'll add that I have not placed either on a synthetic oil regimen.
This all seems to have nothing to do with synthetic motor oil, so count me out of the brand and model follies as of now!
