Visitor Agreement.
I almost never stay awake till 2 am to post about oil!
Bobstheoilguy has many VOA's and more importantly UOA's posted. So if you want stimulating real world experiences, a good read to bone (bore) up on the subject!!
Actually Shiftright, from a devils advocate point of view, does right to present the other side. I have used synthetic (specifically Mobil One products) for so long that really A/B testing is not on my mind (694,000 miles) The reality is most of my later model cars came with synthetic oil. In those cases there really was no change of mpg, except for when I changed the conventional ATF to Mobil One ATF on my Corvette Z06. Just this one change garnered app .5-1 mpg better. So I am glad that the Honda Civic does have conventional oil so I will indeed see if I do get the 1-3 mpg better that research as indicated might be true.
I did not notice any improvement in fuel consumption with my 2000 Buick Regal GS after flushing old ATF by Mobil 1 at about 35k miles. However, it would be hard to notice the small improvement. I do not record how much fuel I am buying.
My wife and I notice, however, that with both our cars we have to brake often when following other cars in traffic. I mean, while we are moving on idle, on flat terrains or downhill. Often when following cars of the same model. It clearly shows that our cars have lesser friction.
The other car was a 98 Chevy Malibu, recently sold. Engine was filled by Mobil 1 motor oil for years, but transmission had factory ATF.
I believe, the reason for lesser friction with our cars is/was not a better oil, but better tires. Firestone Firehawk SH-30 with the Malibu, Bridgestone Potenza RE950 with Regal. In addition, we are/were inflating the tires a bit higher than recommended by GM.
As some other posters have noted, the drive train components work in tandem and works to give you a fairly consistent parasitic drive train loss. As is fairly obvious there are wide ranges of variables and perceptions. So when one is trying to narrow down what is causing the changes, it helps to really isolate the variables.
When it comes to gassers fuel mileage, the oems have pretty much picked all the low hanging fruit. An example might be the new 5w20 standard down from 5w30, which is down from 10w40. So for example the conversion from conventional ATF to synthetic atf is on the order of between 1.5 % to 3%, really not much to speak of. But I think ultimately we are dealing with a host of goals, compromises, etc. For example if mph was really a big priority then why are the majority of passenger cars automatic transmissions that get way less mpg? You can contrast this with the European passenger fleet (it is monolithic in some senses) where the majority of the passenger cars run manual transmissions, which of course get better mpg.
So you don't have to be concerned about my being over passionate about oil.
Oh, and I do think it is that good.
Do they make synthetic transmission fluid for Crown Vic and Ram 1500, or, for that matter, synthetic power steering fluid, synthetic rear end gear oil (regular and/or posi)...
A 10% increase in fuel mileage from using synthetic oil would be an astounding, inexpensive, unobstrusive and simple alternative to the hundreds of millions of dollars automakers' spend for increases in fuel economy.
I don't believe that sucha figure would hold up to rigorous scientific testing for that very reason---the automakers know it won't give that type of a result.
Of course, there are many other benefits and other reasons for using synthetics that do bear up under scientific scrutiny.
On the foreign car side, the Michelin MX?? Energy is almost a OEM staple at least on MB E20 and VW Jetta as an illustration. The tire is known as an fuel saving tire, i.e., 1-5 mpg over any number of replacement tires. Specificially, it is known to have "less rolling resistance". Oxymoronically, there are no real published standards for this "less or more rolling resistance") and in fact, no basis of comparison among and between tires. Yet this oem tire is hard riding (per se) and up to 2-4 x more expensive than other tires and does not last very many miles for its cost and lacks performance also, comparatively.
At least with synthetics you can see testing standards.
So as you probably would agree, synthetic is not all things to all people. Or, not the perfect application for everything.
Beernut, nice handle.
Actually, it's great for racing--all my friends who race (seriously race I mean) use it.
I'm not putting it in the current older Porsche though---I am still leery of oil leaks, especially with an engine known for oil leaks to begin with, which doesn't have any at the moment.
When very experienced engine builders caution about leaks, I'm not saying I believe them outright, but it does make me hesitate. I'd love to try it, but...
There is an uglier side also. I have read in several places that folks without a "convenient" place to dispose oil do so directly to the environment! This of course "pollutes" the environment. i.e., finds it way to the water supply, etc. etc. The estimate is 2-4x the crude oil lost during the Exxon Valdez accident PER YEAR!!!!
It took me several years of synthetic use and used oil analysis reports to get to feeling really comfortable with it and using it for extended drains, up to about 12,000 miles per change depending on vehicle and usage.
Stuff works
I was an early adopter of synthetic oil (late 1970s), and I'm sticking with it, slippery though the topic may be.
Best Regards,
Shipo
In days past, sometimes 3000 miles was PUSHING IT! The problem then was there was no economically viable option to verify it. So as a "policy" one changed it! So a lot of unsubstantialed hype grew up around 3000 mile OCI's. So it is not surprising whole industries grew up around this multi billion dollar potential! Qwiky Lube statistics, as reflected in industry rags, point to the average car owner doing 5,000 mile OCI's. The research, the write up points out shows the average owner has done an average 2000 mile drift to (oblivion) 5000 mile OCI's due mainly to lifestyle choices of the owners and not the vehicle requirements. This continental plate drift really punches holes in the qwiky lubes numbers. So goal is to "beat back the OCI's from 5000 to 3000 miles. Also not many folks know that buried in those SJ/SL/GF-2 standard drifts, is the fact the oil is designed to last longer between OCI's. But then again, to me; the major point about mineral oil: the major data point was (and for most folks STILL is) the mantra of 3000 miles.
Again to me major data points SHOULD be UOA's of conventional oil!!! So if I was a qwiky lube owner, why would I want a test to verify that ExxonMobil 5w20 oil is still good to go at 9100 miles when my whole business is built around 3000 mile oil changes????!!!
I had also been skeptical of 0w20 Mobil One and other oems' 5w20 viscosities. So there are data points both VOA and UOA demonstrating the robust nature of both these viscosities and oem products.
So for example a very good 5w20 conventional ExxonMobil Superflo was taken to 9100 miles and had plenty of chemical vim and vigor left!!! So I would be remiss if I said that conventional oil is no good! It is very good!! And the research shows it.
The interesting thing here is the (Mobil 0w20) synthetic does indicate a stronger additive package than the conventional. The other thing is combined with that the lower viscosity does indicate better fuel mileage. (est 1-3 mpg with most folks getting 1-2 mpg better)
This might not mean much gal to gal, but over a 10,000 mile OCI, we can be talking 8-23 gals. So at 2 dollars a gal from 16-46 dollars in fuel cost savings or 288 miles-874 miles MORE.
Two of my current vehicles actually specify "synthetic", or more technically have specifications that many synthetics meet!
I sailed the flat earth and my ship fell off the edge:) (remember the joke about how there were originally FOUR ships with Columbus?)
We are testing in part to see what the real numbers are (for your specific car, operative parameters yada, yada,) The test was really designed to show engine operation trends, but make no mistake you can get the status of your oil!! So really the individual or YOUR test is the individual verification or vilification or anecdotal (ness) of the advertising metric!!! So conversely why would you tend to believe the qwiky lube's mantras of 3000 miles??? On testing? They do not offer testing? Marketing? etc, etc,?
..."I sailed the flat earth and my ship fell off the edge:) (remember the joke about how there were originally FOUR ships with Columbus?) "...
The one that almost never fails to give me a chuckle is the Mel Brooks schticked, where he plays Moses bringing down the three tablets of stone with the (15 commandments, ie 5 per stone) to the people.
He starts off saying: I bring to you the FIF commandments, (drops one tablet and corrects himself), I bring to you the 10 commandments!
So the good news is there are only 10, the bad news is we are inadvertently violating 5 unknown ones!!!
Some/many of us who change our oil at 3000 mile intervals began doing so prior to the marketing novelty of quick lubrication merchants surfaced in America. I'll let this soak in for a while, and see if it takes, or if I'll be forced to expand the topic.
In days past, sometimes 3000 miles was PUSHING IT!"...
I said the above in a prior post.
..."So for example a very good 5w20 conventional ExxonMobil Superflo was taken to 9100 miles and had plenty of chemical vim and vigor left!!! So I would be remiss if I said that conventional oil is no good! It is very good!! And the research shows it. "...
Would an anti conventional oil person say this?
..."Some/many of us who change our oil at 3000 mile intervals began doing so prior..."...
So if you are including me in your population then I would say I was "one of those"!
So am I hung up ? NO ! I have scrapped sludge from more engines that have had religious 3000 mile or less OCI's than I care to remember!
Relieved or grateful is more like it!
I think the good old days of lubrication ARE actually NOW !!!
In a few hours, I will crawl under my daughter's 2004 Jeep Grand Cherokee and perform the "mandatory" 3000 mile oil and filter change, just as it states in the owners manual. And yes, these are the grand old days of engine lubrication compared to the goo scooping days of early engine rebuilds. I haven't split any engine cases in a very long time...
The real kicker is the OEM has placed the oil filter cartridge and designed the dipstick TOPSIDE; in such a way where a suction evacuator can be used to swap out oil and filter cartridge and not go under the vehicle!!!
While any number of CI-4 CF-4 and Euro rated so called "conventional synthetic" oils (hydrocracked PAO III) will do well, (i.e.,Shell Rotella T and/or full synthetic) I have opted for (PAO IV) Delvac One 5w40 aka Mobil One Truck & SUV. Other UOA's have indicated this can be good to 25,000 miles. Being the belt and suspenders guy I am, 20,000 miles is almost like falling off the flat earth!
At 48,000 miles, this puppy will see break-in (or full compression) at app 60,000 miles.
Ditto on the filter cartridge, my car has that too, all I need to do for a change is to pull out the dip-stick, screw off the cap to the filter, suck out all of the oil (almost 8 quarts), swap the filter, put the cap back on, and dump in 8 quarts of Mobil-1 0W-40. ;-)
Best Regards
Shipo
Another thing that folks might be interested is European cars have been on so called "extended" OCI's for a few years. To use one example; Mobil One 0w40, 5w40 etc sells for the outrageous everyday USA price of 4/5 dollars per qt. European versions of the same stuff goes for 10-15 dollars per qt!!
(32oz) (liter really(33.8 oz) but for comparison purposes)
Best Regards
Shipo
Formerly, I would not have thought I would see the day when a big vender such as Mobil go to an EP type of at need or on demand type of oil product. They have just recently announced this new type system (products are stratified) and the new products are hitting the retail markets.
Only time will tell which elixers will tough it out and emerge as the "go to" oil. I was bummed to see that Mobil One 0w20 is discontinued in favor of the new Mobil One 5w20. The verdict is still out whether 0w20 or 5w20 is better for mpg. (among other improved parameters)
Best Regards,
Shipo
Indeed, if you stay with conventional oil, the 5w20's; Motorcraft, Honda oem and ExxonMobil Superflo, all have higher concentrations of moly than other vendors. This is not to say that other vendors products will not work, however it would seem these engines are more "slap happy" with higher moly dosed products. (as each oem recommends: Ford, Honda.) My oem Honda owners manual goes so far to say the oem fill needs to be in there the "full" term (10,000 miles, normal) to take advantage of the unique properties of the oem blend.
Now I will be the first to admit that it does not SPECIFICALLY say the ingredient is moly but once the oem fill is drained, practically speaking the oem has little to NO control over what brew the owner may use next.
So to keep into nexus with our thread subject, synthetic oils like Mobil One 0w20, 5w20 use a far different (approach) additive package where moly is in far less concentration.
OR 5W-20 oil, per se, would have been a disaster (might have been a disaster?) if Ford and Honda hadn't demanded special engineering way beyond the old SF oil spec.
Along the same logic, 5W-30 Mobil 1 is probably a better choice for cars that call for 10W-40 conventional oil; it may not start quite as thick, but it retains its viscoscity (rumor has it, no viscoscity index improvers are required for that grade). Incidentally, Mobil 1 5W-30 used to be reported as a slightly "lighter" viscosity than other 5W-30 oils, closer to a 20, but since the advent of true 20 oils, has been "thickened" a little.
On a similar "what's the real viscoscity" note, I was going to run Rotella 5-40 in my 2.0 VW, until I studied the specs on Rotella vs. VW spec'd 5-40. The VW spec is for 5-40, but at the relatively "thin" end of the 40 spectrum, actually closer to a 30 weight - which is probably why I get the same mileage with 5-40 as I did before with Mobil 1 5-30. The diesel 5-40's really are at the thicker end of the spec.
I remember reports on "high mileage" oil formulations freely admitting that they were "thicker" than other 5-30 oils....
I still don't trust oils or filters beyond 5,000 miles. I suppose if I ran a whole fleet of high mileage vehicles the net savings would outweigh an occasional incidence of unexpected wear or bearing scuffing, etc., but I don't feel like being a guinea pig for an entire industry that claims it wants to save natural resources (oil), and admirable goal, but can't build relatively defect free cars.
As for the Mobil One 5w40 aka Delvac One 5w40 (synthetic or PAO IV) I use it in a VW Jetta TDI. It is also backwards compatible with the SL/SJ (gasser) standards (among) others). However as the 5w40 viscosity indicates, you would have or have had to decide if you want to use the 5w40 viscosity. It is a superb synthetic oil capable of going 20,000-25,000 miles between OCI's in a TDI application no less! It will probably need to be said that the TDI IS harder on engine oil than a gasser. As for me, I am saving natural resources (oil) and decreasing the cost per mile lubricated.
When they finished with the car I looked in the back seat - there's the Castrol. So much for reading the work order. They said it would be taken care of immediately - I also inquired and was told they would start over with a new filter. End of story is that I am absolutely certain they did not remove the filter and used only 4 quarts & about 2 drops of the Castrol. So now I have at least a half a quart of dino Quaker State 5w-30 ( their standard) mixed in with the synthetic oil. Does anyone know what effect this might have?? I'll change it myself to get it right and obviously won't be going back for any more oil change adventures. I just don't want to risk problems with the mix.
Let me hear from the guys who really know this stuff -
Asking the dealer to think is a mistake. No offense to dealers, everyone falls into the trap of "routine". Asking them to use your own oil which can only be found in your back seat - and THEN don't use all of it - well, that's just too non-routine.
In terms of sludging based on a portion of the crankcase being conventional oil, I would go ahead and redo the oil change. VW/Audi has one engine that is such an oil cooker that they give a quart of full synthetic for top-offs in the glove box - it isn't a matter of lack of ability to lubricate, so much as microscopic sludging of those portions of the conventional portion of the oil - the synthetic won't cook until really high temperatures, but conventional portion, mixed in there, will.
