Synthetic motor oil
1138139141143144175
    For me, it has distilled into a few issues.
    First of all even on such an august thread as bobistheoilguy, there is not logitudinal study or experiment comparing oil analysis on the variable: oil filters. As a contrast there are numerous comparos on construction and so called quality differences. More importantly there is also no evidence of any statistical correlation as to whether those differences making measurable filtering differences. Another way to express this if a Pure One costs 8 dollars and the WallyMart SuperTech (made by Champion Labs) @2.07, which means one costs 3.86 x more: does it perform 3.86 x BETTER? AND what is the statisitical significance of BETTER-even 3.86?
    Another is the oil filter is FIRST and foremost designed to be a bypass valve. This would imply in the worst case MAX oil flow is the FIRST priority. So really if one wants need to filter small/smaller the emphasis should be on bypass filters.
    MY UPSHOT is along the consumer reports line of thinking, buy the reputed best on price. (commoditized)
    Tell you what...if you can put A multiple 30W in a big pickup truck, and then calculate the mileage, and then put in a multiple 20W and we drive around and I get one more 1 mpg with that same truck, same day, same road (25 more miles on the tank fill-up), I will drink that quart of oil. ;)
    Why don't all the world's truckers do this and gain 100 miles per fillup?
    Or every car manufacturer and thus add 1 mpg to their EPA sticker?
    Don't make sense that this is anything more than a clinical possibility, not a real world event. At least not to me (yet). :P
    I think if one is looking for a guarantee, one is almost certain to be guaranteed disappointment. I think the way the question is posed, really puts the light on MULTI variables.
    So for example, my 2004 Civic gets 29/38 epa. The 2006 Civic is 30/40 epa. Yet on another one of these boards, I get far better mpg on a lesser rated epa machine. I also go 20,000 miles between oci's with synthetic oil.
    If one were to imply anything from the questions it is it next to impossible to make mpg gains. This is clearly not true.
    Want an example? Race cars that use synthetic/conventional oil still get app 4 mpg. A trucker example most get 6 mpg. .5 mpg better which is considered by most to be immeasurable or just normal variation is indeed an 8% rise. What is a 4% rise? .25 mpg, again CLOSER to the thought of immeasurable or normal variation?
    That's why talking in terms of "gallonage" rather than MPG helps to clarify the reality of such claims for consumers.
    5% rise in MPG means nothing to me in a Scion xA. It's like the nickel I wouldn't bend down to pick up off the sidewalk, much less spend extra $$ for special oils, filters, etc. or even change my driving habits.
    But to a trucker, the gallonage is significant from a 5% rise.
    I am a little confused. The percentages remain the SAME REGARDLESS of the volume!! (gallonage as you call it)
    If I am making a 5% gain in mpg (in the case of 6 mpg (.3 mpg) I say WOO HOO. If I make a 5% gain in my TDI (50 mpg or 2.5 mpg) again WOO HOO!
    Well then you are a lot more easily excited than I am. 5% MPG to me is about 18 gallons a year, or a whopping $3.75 a month. Yippee
    But if I was a trucker that's 200 gallons of extra fuel a year, or $500 bucks in my personal pocket.
    so gallonage varies with the vehicle, whereas percentage does not...percentage is too abstract to grasp (which suits marketers), but gallonage is very real for people.
    You can see that in my numbers. If I tell you...you'll gain 5% in MPG if you switch to AMAZING OIL and our special ULTRA-CLEAN filter system! But if I tell you you'll saving 1.5 gallons of fuel a month, you wouldn't buy it.
    Then I take it you agree with my post #7143! :) 75.04 saved per 20,000 miles 6.25 per mo. :)
    Also the interesting (non) point I see in your overt point is the deck is almost totally stacked against the average driver if one goal is to decrease the cost per mile driven.
    Well I agree that money is saved but what I always speculate about is whether certain sums of money are even worth the trouble of achieving those savings. Am I spending more money to "save" money? Am I expending labor better spent elsewhere? Blah, blah.
    If for instance, as you say, I just rode my bike every Tuesday I could beat any gas saving product on the market by a wide margin! :P
    You dont have to convince ME to save money. I can stretch a buck until it screams for mercy.
    But what I was driving at here is this:
    Any call for conservation needs to be expressed in terms that are readily digestible to the average car owner, and saying "gallons" rather than MPG is one way I was suggesting that. The only problem with that is sometimes it works against the marketing hype of "gas-saving" products.
    What if I tried to sell a Prius with this pitch:
    "Hey, typical car owner. For only $28,000 you can save 16 gallons of gas a month!"
    You know, I really do not know.
    I think I have clearly said ONE oil change, when 4 will do?
    Most folks chose 4 !?? :)
    AND
    at higher cost, more resources, more time, more work,..... yada, yada.
    Is it 4 to 1 though? I'm on a 5K OCI, so you're on 20K?
    Anyway, just for fun let's calculate the savings differential on going 5K on conventional oil and 15K on Mobil 1, okay?
    Lessee...let's price it out for a 5 quart capacity.
    One 15K oil change with Mobil 1 + filter, DIY, equals say $43 ($6.99/qt for oil, + $7.99 decent filter).
    3 oil changes (5K interval) with reg. oil at $3 quart + $7.99 filter = $68.97
    So at the average of 12,000 miles per year, the savings is:
    $69 minus $43 = $26 X .8 (12,000 miles per annum) = $20.80 per year or $1.73 a month using synthetic.
    If we were to allow that alleged 1 mpg synthetic oil benefit on a car getting 30 mpg, we can add an additional $2.70 a month in gas savings.
    Now if we add our time (labor) at say $25 an hour (what a mechanic might make) for a year, and if we say it takes a coherent intelligent person 1/2 hour to do an oil change, the person on a 15K OCI spends 30 minutes every 15,000 miles and the person on a 5K OCI spends 1.5 hours every 15,000 miles, so over a year there is a saving .8 of 1 hour or 48 minutes and thus $1.66 a month.
    So given every possible benefit of every possible doubt, it looks like $6 a month is about all one could argue as the cost benefit of using synthetic, if we pay ourselves for our labor. In actual hard cash, it looks like we'd be lucky to save $5 a month.
    That's okay but it's so small an amount that I tend to be apathetic about it, speaking for myself. It's hard to motivate oneself just on the money saved criterion.
    Yes. And yes. (for one) two others are on 15,000 but 20,000 is looking better all the time. Another is at 15,000 and still another is on 25,000 miies and 30,000 is looking better.
    So yes the qwiky lubes indicated that is 2k past their magic 3k cycles. Avg car is on the 5k cycle.
    The real issue is the relatively inelastic need which translates to a higher over all demand for crude oil. As you know, a barrel of oil yields only so much lubricant. Using your 15,000 mile example you use 15 qts or 3.75 gals vs 1.25 gals or 3x more resources. If there are 235.4 M cars... that is a savings of 588.5 M gals of finished product SAVED per year, as a point of discussion. Given the ratios to crude that is a whole lot of barrels LESS
    In case someone really wishes to see the ratios
    http://www.sanjosegasprices.com/crude_products.aspx
    Lubricants= .46 gal per 42 gals of crude oil. (process gain of 2.47 gal)
    This would 8.1521739 barrels of oil for 3.75 gals of finished lubricant product.
    SAVED is 2.5 gal/.46= 5.4347826 barrels of finished lubricant.
    No Way Out?
    ..."Today's reality is that vested interests in oil reserves and intangible costs rapidly increase threshold petroleum prices to more than $150 per barrel. Indeed, we found that the ownership of oil reserves was the biggest barrier to a corporation's investment in synthetic fuels. Oil corporations will invest in a U.S. alternative fuel industry only when their petroleum reserves are depleted to about the time it takes to build the alternative fuel infrastructure, or about two years of reserves."...
    http://www.memagazine.org/supparch/pefeb05/nowayout/nowayout.html
  • chikoochikoo Member Posts: 3,008
    I have done the same too.
    Now I just go to Walmart, pick out my choice of semi-Synthetic oil(Motorcraft) and Motorcraft filter and get it changed for only $24.99
    It is well worth it.
  • blufz1blufz1 Member Posts: 2,045
    Sounds like a good deal,thanks.
    yeah well keep a close eye on those folks during oil changes, please!
  • mickeyrommickeyrom Member Posts: 936
    Would it make sense to start using Mobil 1 in my old Chrysler,148K.Would it do any harm?
    I think that the consensus was that while Mobil 1 (or any other high quality synthetic for that matter) wouldn't cause any harm, there'd be no benefit either, errr, unless that is, you were going to extend your OCI to once per year.
    Personally, I'm a "died in the wool" fan of synthetic oil, however, if I had your driving profile and was going to use your six month OCI, I'd use Havoline oil and save my money.
    Best Regards,
    Shipo
    Ford dealers around here usually have a coupon for anwhere from $16.99 to $22.99 for oil change (of course they add back in a buck or two for environmental fees and/or shop charges). Semi-synthetic is now routinely used by Ford dealers.
    I am with YOU on this point!!! There are only two things that scare me in life, a software upgrade and someone else changing oil on my vehicles !!!
    EVERYONE who I know who has used a qwikie lube type place has had at least one major issue!!! This is really hard for me to understand. (as I DIY) But I have seen the puddles under folks cars' too many times to ignore it.
    Good lord, could you imagine downloading a software upgrade WHILE you were getting a qwik-lube oil change! I'd be in deep stress. I wouldn't know which thing to worry about first!
    YUP! Also don't pass by the staging area where the technicians jockey the (customers) cars to get them into the lube bays. I went by the local WalMart (staging area) and almost got wacked by a car that was laying down rubber till he saw me pass. :( Sure glad I narrowly missed getting wacked and sure glad that wasn't my car the technician was driving.
    First they strip your oil pan plug, THEN they kill you....no witnesses....smart.... :P
    I always watch the Honda techs at my dealer. 'Course I can't see down in the pit. Always check/top up the oil to upper mark when I get home. Another good reason to extend oci,less chances to make mistakes doing the changes.
    Yes my Toyota dealer (despite all that insurance boiler plate) lets me in the bay when I do the quickie oil change procedure. I have watched it over 20 years and from what I can tell, they seem to follow the appropriate safe and efficient and accurate procedures. I even took my Corvette Z06 there once and they did a fine job. All the 30 or so mechanics came by to gawk at the car (when it was new in 2001) but I think that was part of the fun.
    Next time, I'm going to have them top up the Honda atf to the upper mark. Topping up the oil and atf is my "southern engineering" engine and transmission cooler for pulling my little 650# bass boat,motor,and trailer.
    Yeah that is not a bad idea. Especially in a Honda with probably a small sump (mine is app 3.4 qt with an oil changewith some still in the system) every little bit gone is worse than right at the top.
    I figure that if the topping up saves me 1-2 degrees those are the most wearing(hottest) 1-2 degrees. Wish these cars had actual engine temp and trans fluid temp gauges. Maybe in a few years.
    It also fortifies the chemistry of the sump. This is and should be very obvious, but what happens is most folks discount this. Mine is app 1/4 to 1/2 qt per 10,000 miles. It serves to replenish the chemistry.
    Maybe you should check it and top up once a month.
  • james27james27 Member Posts: 433
    As I understand it, the CAFE tests are run with the engine hot (i.e., already warmed up). Therefore, the cold start advantage of quicker starting and warmup would not show up as much.
    Well lets see given my apparent rate of consumption app 6/7 month from the time of oil change.
  • avalon02whavalon02wh Member Posts: 785
    Was your mileage change really due to the Mobil One? If I read your post correctly you used conventional oil during the break in period. Cars typically get better mpg after xx,xxx miles. I had an Accord that did not hit peak MPG until 25K. The best mileage was in that 20 to 40K range. After that mpg dropped slowly. Did you go back to conventional oil at some point?
    Are you comparing the Mobil One to a plain oil, Energy Conserving or Energy Conserving II oil?
    The additives are what gives the oil the extra mpg. The additives can be put in regular oils. So I am not sure we can say it was the "Synthetic" that made the difference. See the links below.
    If Mobil One gets better mpg, why doesn't Mobil advertise that on their web site?
    When did you change tires? If you kept the original tires the entire test, the circumference of the tire would have changed. Your tires would need more revolutions to go the same distance. The odometer would have recorded the extra revolutions as extra miles. If you have 205/65/15 tires with a diameter of 25.6 inches, a loss of 5/32" in tread would result in a 10/32" change in diameter. That is about a 1.2% change. Thus it would appear that you gained 1.2% in mpg when in reality the only change was your tires got smaller. Or at least that is the way I remember it working in the good old days :) Somebody should probably check my math too. Entering 3.14159265358979323846 in the calculator took a long time!
    http://www.calsci.com/motorcycleinfo/Oils1.html
    http://www.peterverdonedesigns.com/motoroil.htm
    Those may be your assumptions, but have you really tested and quantify that?
    If you read what I actually did, it was not as you described. It was... as I described. This of course does not mean you can not conduct your own (lab) experiment IAW your stated protocol. So would this mean you would want to conduct your own test and post the results? Indeed it would be interesting to hear your results!
    I am now on the down side of 40,000 miles and the mpg is slightly better. On another car I am on the down side of 90,000 miles and the mileage is ACTUALLY better!! On this car I use 25,000 mile OCI's.
    I have no intention of going back to conventional oil. Even I would have questions about running conventional oil to 20,000 miles. So indeed I do not know what the mpg would have been with an additional 10,000 miles on conventional oil (to make 20,000 miles OCI) . And I would SWAG I would get 1-3 mpg less,and probably less mpg between 10,000 and 20,000 miles! :( So if we could run conventional oil to 20,000 miles in your car perhaps we would have a conventional 20,000 mile OCI vs a synthetic 20,000 mile OCI?
    To answer your question about the additives, I do knot know why the do not put the additives they put in synthetic oil in conventional oil. But until they do it would be hard to separate them, don't you think? Nor do I know any one who markets them differently so you can blend them. Do you?
    As to mpg and why Mobil One does not advertise it, I truly do not know. I have no affiliation with them at all.
    Tires are oem 185/70/14.
    "Was your mileage change really due to the Mobil One? If I read your post correctly you used conventional oil during the break in period. Cars typically get better mpg after xx,xxx miles. "
    I think if you read the new car sticker on (your/mine) car, the actual mileage is based on conventional fill. The epa is 29/38. It was NOT based on Mobil One (synthetic)
    The range is thus: 24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,
    So the tank to tank performance in the bandwidth I operate in has been between 38-42 in the everyday commute. In the same commute using conventional oil, it was -2 mpg (average) less. At the FIRST tank full (10,000 miles plus) which continues all the way to over 42,000 miles the mpg jumped. So if what you are implying is true, then there is some magic thing going on at 10,000 miles going on that only you know about. So spill! :) The only thing that changed was the switch to Mobil One. The filter was not changed.
    On the thread Honda Civic, Real World MPG there are folks that report anywhere from 22 mpg-41 mpg. My swag since the majority do not report synthetic vs conventional are probably using conventional oil.
    ..."When a synthetic oil or synthetic fuel is made as a substitute for petroleum, it is generally produced because of a shortage of petroleum or because petroleum is too expensive. When synthetic oil is made as a substitute for lubricant refined from petroleum, it is generally to provide superior mechanical and chemical properties than those found in traditional mineral oils."...
    ..."Advantages
    The technical advantages of synthetic motor oils include:
    Measurably better low and high temperature viscosity performance
    Better chemical & shear stability resulting in improved lubricating film strength
    Decreased evaporative loss
    Reduced friction
    Resistance to oil sludge problems
    Reduced engine deposits in some applications (Turbos)
    Possibility of extended drain intervals
    [edit] Benefits
    Use of synthetic lubricants gives benefits such as:
    Better fuel efficiency
    Instantly lowered engine temperature for ~ 30 deg. F
    Diminished engine 'cold start' and improved overall wear protection
    Reduced exhaust emissions
    Natural resource preservation and monetary savings due to extended drains and less energy used
    [edit] Disadvantages
    The disadvantages of synthetic motor oils include:
    Initial costs are usually multiplied by 3 compared to petroleum based oils
    Potential decomposition problems in certain chemical environments
    Potential stress cracking of plastic componentry like POM (polyoxymethylene) in the presence of PAO's.
    Initial costs are usually mitigated by extended change intervals, but each particular user may find as useful confirmation of that through used oil analysis (UOA).
    http://en.wikipedia.org/wiki/Synthetic_oil
    Nothing really new here. Synthetic oil and fuels were done by the Germans before the start of WW2, min of 70-87 years or app 3.5 generations ago. Thankfully, the technology has gotten better.
    How I get involved with it was synthetic oil use in bombers, tankers and fighters. I had a NDI shop (non destruct inspection shop) reporting to me, where we did analysis on (among other things) used oil. The data of course was uploaded into a fleet wide data base for the obvious and not so obvious purposes.
    "Nothing really new here. Synthetic oil and fuels were done by the Germans before the start of WW2 67 years or 3.5 generations ago."
    I wouldn't even go there. What the Germans called "Synthetic Oil" in WWII and what we currently call Synthetic Oil are two very different things. If I remember correctly, the Germans were essentially "Making" conventional lubricating oil out of a particularly rich coal. It was considered "Synthetic" because it didn't come via the conventional crude refining process. A far cry from the PAO based oils that we today consider "Synthetic".
    Best Regards,
    Shipo
    I realize this might not be PC,but my thought was this was the so called "grand daddy". Indeed there are many "sidebar" topics if folks are truly interesting in the discussion of the science behind synthetic oils and fuels. GQQGLE ON!! :)
    http://en.wikipedia.org/wiki/Polyalphaolefin
    I didn't know "increased fuel efficiency" was ever a laboratory-proven claim. I'd like to read that study or field test if anyone can link me.
    Well you know the longer term controversy about EPA city/highway ratings and the resultant so called "correction" might be an interesting bellweather about fuel efficiency. I sort of detailed some of the issues; using the Civic as an example: 2004 EPA of 29/38, and the 2006 EPA of 30/40, BUT (the BUT really should be bigger {as in font size}) with a RANGE of 22-44 mpg. (detailed more in Honda Civic Real Worl MPG)
    Why Honda? Well it does have the reputation (on edmunds.com and many others) of being both an economy AND economic "small" car to own and operate. My nexus being, I actually own one :) Other than that, pick a car, oem, etc, ANY OTHER, no real matter here.
    You would think most folks really should understand fuel MPG parameters "in the real world vs laboratory or test conditions (EPA ratings)" is really between the headsets or probably more correctly between the right and left feet, but I am beginning to think that assumption is/has been false. :(:) Why most folks REALLY see the EPA rating as a rock solid guarantee is WAY beyond me. It IS as billed; a set of (epa) test protocols. Now if most folks don't understand ONE set of test protocols, why are they giving them multiple sets more!!?? THIS isnt a Rorschach ink blot TEST or testing procedure where you show pictures and anyone can see what they want in them!!??? The range is already there so I really see no need to change much other than reverse the font sizes.
    So as an example epa 29 city /38 highway RANGE of between 22-44 MPG
    So the nexus with synthetic oil is: no rock solid gurantee!? So when I post 1-3 mpg range with an average of 2 mpg, it is as posted, what I got. Why folks attack it is another thing beyond me. They should just post theirs and we can SWAG the variables.
  • sandman46sandman46 Member Posts: 1,798
    And when people want to go sue the manufacturer or accuse them of fraud over these numbers, it always makes me laugh. These figures are only estimates taken from drives with very strict variables...unlike what is found in the REAL world with REAL drivers. Those numbers aren't what normal diving will bring...only under controlled situations. I've always used them as a guide as to what my mileage should be near.
    I have read that the EPA is going to come out with new numbers that more closely reflect actual driving. Probably long overdue. I know with my '06 Civic, I'm on the low end of the city numbers as I hardly do any highway driving and my commute is about 10 miles of stop and go, not optimum driving conditions to get the 30 mpg's the EPA figure says on the sticker. But I knew this going in when buying my Civic.
    The Sandman :)
    People will complain about the "actual driving" ratings as well, because conditions are so variable. And then you have people posting crazy highs and lows on the Internet and that further fuels people's fears or expectations.
    If you just split the difference in EPA ratings and include a plus or minus fudge factor for your own driving, you'll be darn close to what you're really going to get. You live in Kansas? You'll probably do better than someone in San Francisco or LA. Lead foot? Deduct accordingly. Short commute? Frigid weather most of the year? Multiple drivers?
    See what you make of this.My new KIA Optima is EPA rated at 24/34 city highway,yet my real world city mileage was as low as 12.2.I live in a small town,not many stop lights and it is perfectly flat.On a long trip,I managed around 31 MPG(Hwy)I can accept that,but my other car, a pretty large one by todays standards,gets almost as good or even better mileage driven in town.(97 Chrysler town and country)Is my disgust with my 4 cyl KIA justified?I really think it is.If the EPA estimates are so far off reality,why bother posting them on the sticker. :confuse:
    My take, sans all the other ramifications, you do not drive your KIA Optima in "the design sweet spot", power curve, etc. of your engine and drive train. Will it do it? Most certainly, as you demonstrate, but at mpg as low as 12.2 mpg. Also again, the RANGE on the new car sticker might be a better indicator.
    Another take; your drive is VERY VERY VERY tough on almost all parameters, the nexus being the oil. I would swag your oil hold a lot of water and unburnt byproducts vs a Kia Optima that sees more highway miles. A very good reason to go to a synthetic oil like Mobil One, Redline, Amsoil, ELF, to name a few. Indeed my daughters drove 2 miles R/T to school as one of the tasks and got better mileage than 12.2 in a Toyota Landcruiser and it is a I6 :(:) I have let Mobil One oil go 3 years to get 15,000 mile OCI's. Again it passed all smog only tests. The innards have been looked at by Toyota dealer mechanics and pronounced pristine with factory adjustments and original machining markings, in trying to secure a couple hundred dollar valve adjustment at 60k miles recommended intervals. Given the results, it makes sense to keep the Lincoln (I swag it is a V8?) to do those very tough miles.
    Yhat does seem awfully low actually. Is it a 4 or a 6? I know the sister car, the Sonata comes in both a 4 and a 6 and am wondering if the Optima does also.
    The Sandman :)
    To add:
    Indeed, my daughters' drove 2 miles R/T to high school as one of the tasks and got better mileage than 12.2 mpg in a Toyota Landcruiser and they are I6's :(:)
    to clarify:
    I have let Mobil One oil go 3 years (in one recent instance) to get 15,000 mile OCI's. Again it passed all "smog only" tests. The innards have been looked at and pronounced pristine by Toyota dealer mechanics. They stated it had factory adjustments and original machining markings, in trying to secure a couple hundred dollar valve adjustment at 60k on one and 60 and 120k miles on another at the recommended intervals.
  • imidazol97imidazol97 Member Posts: 27,735
    Can you explain to me what these are. Are they required? Under warrranty? I'm not sure what you're saying.
    Yes, history. Not required. No not under warranty. Older TLC's (1987 in my case) need valve adjustments at 15,000 mile intervals. In the course of ownership @ app 250,000 miles with Mobil One 5w30 with 15,000 mile OCI's I had app 17 done by the dealership.
    Newer I6's again in my case, 91,94,96,97, need valve checks and if necessary valve adjustments at 60,000 mile intervals.
    I'm so used to hydraulic lifters I didn't realize mechanicals were still around.
    Oh yes! Since one is at 75,000 and the other at 136,000 miles I see absolutely no reason why each cant go to 250,000 miles.
    The new V-8 Lexus engines, i.e. hydralic lifters, in the TLC's are really NEAT. I have also heard they are relatively bullet proof. I have driven a few (app 500 miles) and do like them.
  • altair4altair4 Member Posts: 1,469
    Well, my '03 Passat (1.8T with Tiptronic transmission) is rated 21/30 by the EPA. My overall local average is around 21, although my driving is really suburban.
    On the Interstates, though, I'll easily exceed the rated 30 by 2 to 4 miles per gallon, at a steady indicated 73 (actual 70) mph. Any interstate trip longer than about 30 will show this kind of result.
    Interestingly, the last three cars starting with a 91 Mazda Protege all pretty much fit this type of real world experience - our local suburban equals the urban rating and our interstate driving always exceeds the EPA rating. If I had your Kia, I would be unhappy with those results.
