Visitor Agreement.
I've been beyond busy for the last several months and haven't hit BITOG probably since January. Why did AutoZone drop GC?
Best Regards,
Shipo
Best Regards,
Shipo
No, haven't changed my mind at all, I'm still a fan of Mobil 1 0W-40 and still use it in our cars. What gave you the idea that I'd changed my thinking?
Best Regards,
Shipo
Best Regards,
Shipo
-mike
I have tried Mobil 1. In my particular case Amsoil works better.
I understand that most folks don't buy Amsoil because of their marketing method. Nevertheless I would suggest giving it a try and have the oil analyzed after the oil change and decide based strictly on the results of the analisis.
Best Regards,
Shipo
I compeletly agree with shipo. You are wasting a valuable resource and should be using any cheap brand oil. Even the worst of them will go past 2500 miles and provide more than adequate protection.
Why do you think a company like Quaker State will warrant any engine for 250k miles with regular (i.e. every 3000 miles) oil changes? And I am not saying that Quaker State is a bad oil, just a normal oil that matches or exceeds the lates API standards.
I was wondering what you experts think if it'd be safe to keep going for another 3 months and 3K miles before chaning it. Maybe I should add half a quart to help out the engine, but I don't want to skew the eventual oil analysis with the addition of new oil. Does anybody know if similar oil analysis has been done on bobistheoilguy website--Mobile 1 5W30 in a Quest for ~10K miles/1 year changes?
Logic dictates that it should be fine, but the "approved for 5w20 applications" is conspicously absent from the container, although the website mentions it should be OK.
Said another way, if I had an Accord, I'd be sure to use 0W-20.
Best Regards,
Shipo
I know 0 is the cold number, but doesn't it start out with a lower viscosity and just has more stabalizers.
Yes, 0W-20 flows better when cold, however, its stability has more to do with the higher quality/more stable PAO base oil than it does with the additive package. My understanding is that the 0W-20 (like the 0W-40 that I use) is so stable that zero viscosity improvers are required to achieve the multi-grade rating.
Best Regards,
Shipo
I would submit it DOES suffer from the idea that the only reason for its existence is the "mpg" requirement. My take is this is more myth than truth.
There are indications (on bobistheoilguy.com) if one wants to self warrant and also ready to "pay" the mileage penalty, that Mobil One 0w40 gives even BETTER oil analysis numbers.
While indeed I do know how superb Mobil One 0w40 performs, I will stick with the 5w20 and 0w20 Mobil One for the Honda Civic where the oem specifies 5w20 and 0w20.
I don't plan to keep this engine much beyond 420,000 miles anyway. :)That would be 21 oil and filter changes and 4 timing belt changes.
Thanks again
On the other hand, ExxonMobil is THE largest hydrocracker, in the USA and probably the world. Coming and going eh?
Best Regards,
Shipo
Doesn't make sense to me though that you would market an oil as "Extended Performance" and have it not be at least equivalent base stock as your basic (Mobil-1) product.
IHO, i wouldnt pay higher prices for a fully synthetic oil that is not mostly PAO or grp IV or higher.
From Bitog, i assume that not all "fully synthetic" like Mobil 1 syn oils are 100% PAO, i believe they're mostly PAO with some grp III or grp V?? Percentage of what part of PAO or grp III/V etc is up in the air as to what it actually are. The term synthetic can include some hydrocracked grp III because of the court ruling when Mobil sued over Castrol for their term of synthetic as i recalled... If someone can point me in the direction as to whether or not Mobil clearly says that their syn oils are 100% PAO, i'll put my mind to rest about the whole "fully synthetic" issue.
Formulations always can change without consumers ever noticing without getting a sample of a UOA or a VOA (not saying we'll know for sure that it's synthetic or not but we can look for signs of formulation changes)...
One thing oil companies would love is to make more money, that could mean that they can formulate an oil with more grp III instead of the more expensive PAO and that they could still coin the term synthetic on their labels and could make more profit. Nowadays, some grp III oils may perform just about the same and in some cases outperform some grp IV oils. Just a thought, but some oil companies can look at the similar performance of grp III vs grp IV and may develop their oils with more of grp III since performance is of the same. If one is to go for longer OCIs or have high performance vehicles, i would definitely use a quality synthetic oil.
IHO, i wouldnt buy into much of the noise that one would read about the Mobil 1 EP products being mostly grp III. Most of the noise they brought up about it hasnt been proven yet. I'd still buy the mobil 1 products.
I do not use the EP, for it does not meet the above standard. Even if it did, the premium does not justify the guarantee of 15,000 mile(s) OCI, as the Mobil One 5w30 will do the job.
In addition none of this stops the dealers from recomending 3 mo./3000 mile intervals. Our VW dealer put a sticker on after our synthetic oil change, specifying the next oil change in 3 mo. or 5000 miles. Well 3 mo. for us is probably going to be less than 2000 miles...so I don't think so...but I know an Audi owner that actually seems to do whatever dealer says, meaning synthetic oil changes every 3 months.
Mazda dealer said we should follow the 4 month/5000 mile interval when we bought the car. Then less than 3 months later they send us stuff recomending 3 mo./3750 mile OCI.
I think the majority of owners do whatever the dealer suggests, not what the mfr maintenance schedule says.
BUT I noticed today that WalMart now offers a store-brand synthetic motor oil, $15 or so for a 5 quart jug. It's much less expensive than Mobil 1, etc.
I change my oil 3 times/yr, or every 4500 miles. I'm surely switching to synthetic. At that price, I have nothing to lose.
Best Regards,
Shipo
Best Regards,
Shipo
Now that's the response I was expecting to see
not sure if this is the place to post this but i was wondering, i have a 1999 Jetta with 108000 miles on it, and i have been using regular 10w30 oil in it because i am told i have "noisy" lifters and 10w coats a lil better then 5w, i was wondering, would making the switch to a synthetic oil make an improvement in my lifter noise, would it quiet them down or make no difference at all?
Now, as to the notion of switching to synthetic oil, hmmm, I guess before I make a suggestion I'd like to know why you are considering the switch and what benefits you think you will gain.
Best Regards,
Shipo
I think there had been sludge problems with conventional oils in their engines.
For current cars, I believe that you are correct, even the normally aspirated engines require synthetic oil.
Best Regards,
Shipo
Considering your OCI of 3k miles it is just a waste of money.
You can go back to regular oil anytime with no ill effects.
IF you had an older engine and IF said engine had a lot of gunk/crud due to infrequent oil changes you COULD see some of this stuff in your used filter and oil at your next oil change.
That is not your case so do not worry and either keep doing your oil changes as usual or try using a "real" synthetic oil like Mobil 1, Amsoil and a few others, for truly extended OCI's, say for at least 7500 miles or more. Otherwise you are wasting your money and precious (non renewable) oil.
Best Regards,
Shipo
