1126312641266126812693236
  • breldbreld Member Posts: 6,964
    Car and Driver had a road test of the Si this month, that I read last night. made me want it more actually. I was never big on high revving engines that needed to be wound real high to get any power, so the new motor suits me. The rest of the car sounds like a dream.
    I agree - the likelihood of me getting into a Civic Si is very strong.
    So @kyfdx - how serious are you about the right of first refusal on the GTI?
    2025 BMW i5 - 2017 911 C4S - 2025 BRZ - 2025 MB GLE450e - 2024 Genesis GV60 - 2019 Cayman
  • xwesxxwesx Member Posts: 17,801
    You're still doing far better than me. At least you're in one piece!
    My back spasm from Sunday has turned into nearly intolerable pain as of last night. It's hard to even think. :(
    edited July 2017
    breld said:
    Boy, I wish I had your know-how (and courage I suppose) to work on a car. Even if you choose not to do the work yourself, at least you're aware of what needs to be done and won't be taken by a mechanic (which I'm somewhat susceptible to).
    Yeah, right! When is the last time you needed to take a car to a mechanic?! :p
    Uh oh.
    Gingham seats? Will you ever drive it?
    Only if he turns in his man-card first. ;)
    If it's blue, does that help? ;)
    Silk Blue Beetle Convertible
    Update on the weekend work on the Coronet:
    In any case, I figured I was OK to start her up. No go. Lots of cranking, but nothing happening. I could not smell fuel, so I pulled the lines and checked for fuel when cranking. Nothing. Ugh. So somehow while sitting still, my fuel pump gave up the ghost. Purchased a $45 electric pump from Autozone yesterday but have not had a chance to put it in yet.
    And, you are officially initiated. That actually didn't take as long as I expected it would..... B)
    Initiated into ...?
    edited July 2017
    Some photos from the weekend's activity. These are a couple shots of the circulating block heater on the Q7. I took these to demonstrate just how tight the clearance was, but they actually make it look roomy! This is from under the vehicle (the shaft on the left side is the front drive shaft, next to the transmission (which is out of frame)). These are looking up and toward the back of the engine.
    This photo shows the connection points I used for the block heater:
    Yesterday (Tuesday) proved a bit more frustrating of an experience. First, the new FB25 engine block has some major design differences from the old EJ25 in terms of how things connect and where they're located. One distinct change is the location of the freeze plug to install the block heater! I quickly started thinking about how nice it would be to install an external heater on this unit as well.... !
    Turns out, the old style heater won't fit on this vehicle due to clearance issues with the exhaust system, so I have the engine drained of coolant and the exhaust headers w/ front cat removed, but now have to find a compatible heater. And, my special 14mm hex tool for removing the plug, which I last used in 2009 to install the heater on our 2010 Forester, has gone AWOL in the intervening years. Figures....
    I did manage to get the oil changed (no surprises from the oil filter this time!), replaced the gear oil, and installed the oil pan heater, though. That's at least something.
    See that big round plug on the far right? That's the little devil!!!
    New oil pan design requires attaching the pan heater to the side rather than the bottom:
    So, that was phase one. Second phase was replacing the trailer hitch (it had a little class I/II on it, so I installed a class III) and putting my King springs on. I didn't make it through the springs before my back was hurting so badly that I just couldn't walk anymore.
    Springs:
    My wife hates seeing her car like this (hehehe):
    Initiated into ...?
    The constant needs of the "classic" hobby car! If it isn't one thing, it's a half-dozen others....
  • stickguystickguy Member Posts: 53,855
    This all makes leasing look better and better. Plus not living in an extreme cold climate. I could never do it now.
  • ab348ab348 Member Posts: 20,497
    breld said:
    Uh oh.
    Makes it worse, actually. :disappointed:
    Typical targa maladies there---the wind turbulence can really be bothersome, as can the noise.
    breld said:
    Uh oh.
    There's a new accessory for men driving VW convertibles:
  • kyfdxkyfdx Moderator Posts: 269,455
    Maybe serious... the Tacoma lease makes it a little more complicated. ;)
  • Sandman6472Sandman6472 Member Posts: 7,284
    X, welcome to the club! Dealing with that 24/7 and some days can not get out of bed. Been bad lately which has me thinking of retiring earlier than I had planned. Without my meds, I am useless!!
    The Sandman.  :)B)
    Oh, and I completely spaced the fact that my son installed the subwoofer into the car while I was working on the trailer hitch. He did it completely solo, which was pretty cool for me because it involved a lot of trim removal and install, driver seat, etc. Just turned thirteen, and I am completely confident in his ability to do this sort of thing.
    The Sandman.  :)B)
    That sounds like a horrible hand, Sandy. Life takes its toll on the spine, that's for sure!
    I used to have chronic back pain from the time I was in my mid teens, but I managed to kick it with lifestyle changes about ten years ago. Overall QoL is way better now, but bouts like this are just difficult to manage.... :(
    Initiated into ...?
    Oh, I've been a member of that club for a long time. ;)
    This just happens to be the most valuable one I've ever had.
    So what exactly are you towing with that poor little 4-cyl?
    Oh, it doesn't tow much. We mostly use the hitch for a cargo tray, and the 1.25" hitch receivers are particularly ill-suited for that duty because they aren't designed to handle much "tongue weight." This Class III receiver is designed for 400# tongue weight, which works great with the cargo tray.
    We do have a little 8'x8' ATV trailer, but it is also pretty light duty, so it definitely doesn't stress the car on the few occasions we use it (usually for trips to The Home Despot).
    Ah. Got it.
    My F150 has that backup trailer assist or whatever it is. Probably something I'll never use.
    edited July 2017
    Ah. Got it.
    Never say never! I think your Coronet is pretty light weight, so I could see you trailering it for a track day down the road.... Even the 1/2" tons have pretty decent towing capacity for stuff like that.
    I can't speak for the towing performance of the 2.7L but I've used my father's F-150 with the 3.5L Ecoboost for towing firewood and fully loaded U-Haul trailers and I have had no problems in Western PA's hilly terrain.
    breld said:
    Uh oh.
    :D
  • cdnpinheadcdnpinhead Member Posts: 5,631
    Wow. When I did my circulating block heater on the MGB, it was back in the days of heater hoses that could easily be tapped into with the heater. I loved the thing, since it made it possible for the heater to begin working immediately, even at 20 or 30 below.
    When I realized that the block heater I had on-hand was not going to work for this car, I briefly thought about doing a circulating heater instead, but figured, "naw; I already have it torn apart." Then, I bought the new heater this morning to the tune of $150!!!! Yeah, definitely should have done the circulator.
    I have high hopes for the circulating heater on the Q7. I tested it on Tuesday morning, and it had the hoses warm enough within about 20-30 minutes that I nearly burned myself when I touched one. I assumed it would feel warm; this puppy was flat out hot!!! When I started the car, it initially showed the temperature as being close to operating, but then dropped off rapidly as the fluid started flowing through the radiator. However, it only took a couple minutes to rise back up again. Granted, it was about 55 degrees outside and not 100 degrees colder than that, but it is a start, anyway! :D
    @qbrozen slolly getting done. want to come and help out hear to! could use the help big time. might get my selfe an elictrick fule pump to. to go along with the fule injection system I have summing ordered it on munday! edalbrock is way to much money this one is almost the same price as the holy system!
    @breld sounds good the mosda
    @xwesx feal better man! you will get it all done just might take an bit longer! than could use the help hear! have to take an road trip to new York one day!
    Switching to FI is a big move. More than I want to spend right now. Good luck with it.
    the fule injection system I am getting is bye an company y called fioteck did hear of this one before! looks like an carb but is not has an controller plug and play!
    @xwesx all looking good from the little little little I can see! lol lol lol
    What.... DRIVE all the way to New York? I can't imagine such a feat..... :p
    I'm really not sure what the plan is for our next trip, but I suspect it will be a visit to Pennsylvania (and the surrounding area).
    Yup, throttle body injection. My dad's '87 Blazer had that. It is an easy add on. I do wonder what it would do for performance and efficiency. Oh well, still about another $700-$800 over what I paid for my carb, so I can survive for now. :)
    Well, we at least know it is an R design, which means leather and t tec comination seats in 1 of 2 color combos.
    edited July 2017
    all nice. But how many pedals and how many shekels? Probably too few of the first, and too many of the 2nd.
    @xwesx yes! lol lol I no that is sum crazy trip! was just throwing that out there for an road trip lol lol! PA sounds nice when you do go! injoy your day talk later on.
    @qbrozen yes bit mor money than just the carbe that is for shore. thaught about it for quite sum time! yes you can alwas get it down the road. if not the electrick fule pump and carb will be fine. now are you going to mount the new electrick fule pump you got near the carb or near the fule tank? just wondering. injoy your day
    @stickguy wow lo miles!
    Going to mount it on the inner passenger fender close to stock location, which is just behind the alternator, to avoid needing new fuel lines.
    You have a lovely day as well.
  • MichaellMichaell Moderator Posts: 266,454
    Speaking of warranty extensions, I got a letter from Subaru this week.
    The warranty on the CVT has been extended to 10 years / 100,000 miles. From what I can gather, this is purely preventative.
    Well, they're not doing that out of the goodness of their corporate heart. I suspect they have had enough problems with them to force their hand.
    In the paperwork, there was a form you could submit for reimbursement if you had spent money on CVT repairs.
    edited July 2017
    Hmmm -- wonder if the rubber band transmission extended warranty is across the board for Subaru, or model-specific. I've always been a bit leery of them. Considering that the vehicle that the Forester replaced had 177K miles on it when it was totaled and that my TSX has 134K miles on it, a warranty that goes 100K is a step in the right direction, but possibly not sufficient for those of us who plan to go well over that mileage.
    Here are the models and years that are covered:
    2010-2015 Legacy & Outback
    2012-2015 Impreza
    2013-2015 Crosstrek
    2014-2015 Forester
    2015 WRX
    Thanks for the quick information. Looks like we're okay for now -- probably takes a few years to determine whether they have an issue or not.
    I will be paying a lot closer attention to the behavior of the transmission going forward, now that Subaru has implicitly admitted there might be an issue with it.
    It just turned over 21,000 miles this past weekend, so I suspect we'll run out of time before we run out of miles.
