Visitor Agreement.
So @kyfdx - how serious are you about the right of first refusal on the GTI?
My back spasm from Sunday has turned into nearly intolerable pain as of last night. It's hard to even think.
Silk Blue Beetle Convertible
This photo shows the connection points I used for the block heater:
Turns out, the old style heater won't fit on this vehicle due to clearance issues with the exhaust system, so I have the engine drained of coolant and the exhaust headers w/ front cat removed, but now have to find a compatible heater. And, my special 14mm hex tool for removing the plug, which I last used in 2009 to install the heater on our 2010 Forester, has gone AWOL in the intervening years. Figures....
I did manage to get the oil changed (no surprises from the oil filter this time!), replaced the gear oil, and installed the oil pan heater, though. That's at least something.
See that big round plug on the far right? That's the little devil!!!
New oil pan design requires attaching the pan heater to the side rather than the bottom:
Springs:
My wife hates seeing her car like this (hehehe):
The constant needs of the "classic" hobby car! If it isn't one thing, it's a half-dozen others....
The Sandman.
I used to have chronic back pain from the time I was in my mid teens, but I managed to kick it with lifestyle changes about ten years ago. Overall QoL is way better now, but bouts like this are just difficult to manage....
Oh, I've been a member of that club for a long time.
This just happens to be the most valuable one I've ever had.
We do have a little 8'x8' ATV trailer, but it is also pretty light duty, so it definitely doesn't stress the car on the few occasions we use it (usually for trips to The Home Despot).
My F150 has that backup trailer assist or whatever it is. Probably something I'll never use.
I have high hopes for the circulating heater on the Q7. I tested it on Tuesday morning, and it had the hoses warm enough within about 20-30 minutes that I nearly burned myself when I touched one. I assumed it would feel warm; this puppy was flat out hot!!! When I started the car, it initially showed the temperature as being close to operating, but then dropped off rapidly as the fluid started flowing through the radiator. However, it only took a couple minutes to rise back up again. Granted, it was about 55 degrees outside and not 100 degrees colder than that, but it is a start, anyway!
Switching to FI is a big move. More than I want to spend right now. Good luck with it.
I'm really not sure what the plan is for our next trip, but I suspect it will be a visit to Pennsylvania (and the surrounding area).
https://www.subaruofcherryhill.com/used/Chrysler/1994-Chrysler-Lebaron-Cherry+Hill+NJ-edd103ed0a0e0a6b406901004246c47b.htm?searchDepth=4:52
https://www.subaruofcherryhill.com/used/Volvo/2012-Volvo-C30-Cherry+Hill+NJ-11bf77bd0a0e0a171b325feb69a3dbe0.htm?searchDepth=51:52
Well, we at least know it is an R design, which means leather and t tec comination seats in 1 of 2 color combos.
Going to mount it on the inner passenger fender close to stock location, which is just behind the alternator, to avoid needing new fuel lines.
You have a lovely day as well.
The warranty on the CVT has been extended to 10 years / 100,000 miles. From what I can gather, this is purely preventative.
2010-2015 Legacy & Outback
2012-2015 Impreza
2013-2015 Crosstrek
2014-2015 Forester
2015 WRX
It just turned over 21,000 miles this past weekend, so I suspect we'll run out of time before we run out of miles.
