Visitor Agreement.
I thought it was gimmicky back then, but I love the no-key feature now! Haha; I'm such a softie.
the starter and battery in a vehicle with autostart/stop are designed for the feature and are more robust than those in a vehicle without the feature. Or so I read.
I can control the feature with my foot, so when I know I'll be stopped for just a few seconds, I simply don't let the vehicle turn off by feathering the brake.
I have to believe all of that stuff increases fuel economy, because it can't be cheap to engineer/add to the design.
We had a rental Escape for ten days down in the northwest last week. I think it was probably a 2016; maybe 2017. Anyhow, it had this auto start/stop feature, and it freaked me out the first time it happened. I was fiddling around trying to restart it (put it in park, etc.), and then lifted my foot.... startup! LOL I was way too tired when we picked that thing up at 0500 on a Sunday morning.
As noted, it will only work under certain conditions, including a heavy pressing of the brake pedal. If you are only holding it enough to just keep the car stopped, auto S/S will not engage. I got used to it after a while, but still am not sure that it was actually beneficial. It certainly made the vehicle slower to leave stops, and I only averaged 26.8 on the trip for a small AWD vehicle with lots of highway cruising. My Forester would have done better (without auto S/S).
I didn't mind the Escape, but it sure did feel wonderful to get into the Q7 again yesterday!
http://www.thedrive.com/watch-this/16435/watch-thieves-steal-this-mercedes-by-hacking-its-keyless-start-system
My 2016's auto stop\start was turned off [ for ever ] upon delivery...?
When did that change ?
- Ray
Off when I turn it off...
The car was generally cranking in the process of me moving my foot, and was likely "running" by the time I added gas, but if I pressed the accelerator without a pause, it would pause, then jump into action rather than a smooth transition. I typically go with the vehicle ahead of me, then spread my distance from them as I accelerate, while I noticed with this car that it exhibited the more typical "next car goes after the first car has gone" process. The unnecessary pause is the reason for the rubber banding effect of traffic jams and stoplights.
This is, actually, the only real positive aspect of fully networked autonomous cars; they won't have this same flaw in timing as people typically do.
It's not just timing though. Sometimes the Prius's fail to keep up and accelerate adequately. So even if they had good timing, they'll be many car lengths behind in seconds.
If yours is going downhill quickly, then I would think that it probably has a torn boot. If it does, this is pretty easy to verify on visual inspection, both with grease tossed on your undercarriage near the boot, and by feeling/locating the tear. If you cannot get under it to inspect, then I renew my suggestion to take it to a shop for an inspection.
so, will be making an appointment tomorrow to get it into the dealer. Not what I needed now. Hopefully nothing or minor, but mostly, if it is something that requires work, that it is covered under the powertrain warranty (we are passed the BtoB portion, but still under powertrain).
This must be some kind of karmic payback for being happy to have finished the payments. Downside I guess to owning an "old" car. I also have no tolerance now for dealing with problems, so if any car is going to start having them, it won't be around long!
Though, I'm pretty sure that if this continues, the wife will demand a change. Better start thinking about possible replacements - you mentioned the CR-V at one point, right?
A second payment is not in the budget, so would be tricky. But, if the car stranded her, would be told it has to go! I could pull a Mike. Sell it, pay off the Elantra loan, then lease a replacement.
This plan, of course, has as much chance of working as mrs Iluv signing off on a new iA.
Fingers crossed - I know how much you and the Mrs. like the RDX, would hate to see you have to replace it now.
I’m also noticing as I get older, I have much lower tolerance for hassling with problems.
Also made appointment to get Jetta in right before Christmas when the kid is next home. Will be close to 10k miles in just 7 months on that one.
Car has less than 24K on it, so I think I'll pass this time around. Even though they were offering a free rental if I scheduled something before 12/15.
