And Congrats!!
So they upsell me the 15K service which includes a cabin filter and a fuel induction carbon-build-up cleaning fuel service. Strange to do that at at 15K (or 18K) miles, even my old '06 Direct-Injected A3 didn't need that more often than every 30K miles.
Perhaps turbos running on low octane dirty 87 gasoline need this? There goes your 87 vs. 91 gas savings out the window!
Also, they did a quick mobile Hunter alignment check, and told me 3 of the 4 listed settings were off. I again said, never had to do an alignment at 15K miles before, but go ahead and do it.
Now I know why they offer the super cheap 3 oil change packages! They are not selling oil!
So I'm starting to think a Kia is more expensive to maintain than an Audi on average.......
And no, I didn't hit any particular pot holes or bumps extra hard in the Kia.
However, maybe all of this fuel system cleaning and induction cleaning and alignment will get my fuel economy closer to the EPA figures? It was lower than EPA numbers when it was brand new, but I wouldn't be surprised if Tennessee USA sold me a car with bad alignment off right from the factory floor.
If I was at 30K miles just before lease return I'd agree with you 100%. However, I got 18K miles to go on my lease and the "sub-par fuel economy" issue makes me suspicious on the car. Had I been getting the EPA numbers (or within 15% of them) I'd have told them NO on the fuel system cleaning.
Same with the alignment (though I'd probably still do it, but with a 2nd opinion to verify it was needed, only because I have 18K miles to go; halfway point).
I told them based on the vehicle's current value being about the residual value (or even less than), I would most likely not buyout the vehicle, and look at the remainder of my lease as "free miles."
Seems like they saw you coming...
Had the car been performing correctly, they would have seen the wrong guy coming!
That's why I like my independents. Giving an Audi only what it really needs seems to be a lot cheaper than following "service writer" recommendations.
I think false recomendations hurt the brand in the long run, because I take the innocent until guilty approach to the recommendations, therefore:
It's Kia's fault for recommending cheap gas in a turbo motor.
It's Kia's fault for building a dirty running motor.
It's Kia's fault for making such a maintenance heavy vehicle.
It's Kia's fault for building something so loose and weak it needs an alignment at 18,000 miles.
Honda's and Audi's haven't needed this (although Honda did try and recommend fuel cleaning at 30K; which I said no to unless the tech recommends it upon visual inspection). They never came back with the recommendation.
For example, when the "4X4 Fault" light illuminated on our olds X3 my advisor told me, "The system only stored one isolated fault- the steering angle sensor. I would not suggest replacing it- it's most likely just an isolated glitch." No charge for that diagnosis, either. And when my Club Sport was in for an Oil Service he told me, "The power steering return hose is slightly damp, but I wouldn't replace it until it starts to drip, and that probably won't happen for another 40,000-50,000 miles."
Only other difference vs. the base non-turbo engine is shorter recommended intervals (6 mos or 6k normal I think, 3/3 severe). I am fine with the 6 months, which for me now is still just 3k or so.
If your getting the power and gas mileage you expected, there's no reason to do the service.
It's a very competent vehicle which probably explains why I see so many on the roads down here. Have to assume it's also competitively priced as I think it competes against the Hyundai Tucson, Kia Sportage and the Honda CR-V among others. This seems to be a hot market still though have read that the smaller sub-compact CUV's are also red hot right now. Was reading an article about them earlier today and it said at the end that the Golf had better mpg's and just as much cargo space, if not more. Continue to read good things about the Golf from different places and I do agree with most of what they've said.
The Sandman
I'm going to play with the seat position, but I'm all but certain that I won't be driving it to Omaha in May. That leaves a couple of options:
1. Continue using it as a short trip vehicle and/or maybe start doing HPDEs and use it as a track rat; or
2. Trade it for something with similar performance that is more comfortable. By "more comfortable," I'm thinking it would have to sit higher off the ground and have more of a sedanlike seating position.
I'm thinking of the first option at this point, since that's the default option (basically doing nothing). I never intended to put very many miles on the Mustang anyway.
But, when I picked up my car, I remembered why I liked mine so much. It felt almost as good as that new 2-Series. Minus 100 HP and 115K miles.
We drove my wife's X3 to Nashville, a week ago.. Just over four hours, each way. It was pretty comfortable, but not like mine. I am no fan of her 19" wheel option. Tends to wander and tramline more, even though the tires are all-seasons, and relatively tall, compared to a sedan. I'd swap even up for a set of stock 18" wheels, in a minute.
If they claim to meet Top Tier, all grades have to meet Top Tier. I didn't mind the premium when I got the Volvo 11 years ago, and the price difference was 20 cents a gallon. But now with a 60 cent spread, my checklist for my next ride will include the Elwood Blues "runs good on regular gas."
I prefer the "Stinger" rear badge, but in order to get that you have to get the blackout package
Very Good Michelin tires. Great Brembo brakes.
The interior was a bit of a let down though. There are nice parts, but somehow they let a few Optima-like bits and pieces make their way into the mix, and they don't mix well (for example, the center armrest cover material).
The gray and dark red (almost purple/maroon) interiors were OK. I'd prefer more like magma red.
At 50K I think you'd be insane not to just get a stripped S4 negotiated and grinded down hard.....
- Safety Nannies and Wizards and Gizmos
- Upgraded Audio
- Settle for Alcantara rather than Napa Leather
- Nav
- hot spot internet stuff
- whatever bells and whistles they've thought of since 2016
- The sport diff might be extra.....
- upgraded wheels and tires (huger)
2017 Nissan Sentra
Hey, sandman, what's your impression of the Nissan Sentra? I have read some online comments about the car that state that it's overall impression is underwhelming and that the car isn't getting the 35 mpg top-end mileage that Nissan says it's supposed to get.
The same guy said that he tried to push the car a bit and it didn't respond at all, and in fact, it almost caused him to lose control and go out of his lane.
OK, then another guy's comment is like total night and day difference - he got the 35mpg top-end ghastly mileage and found the interior materials superior to the Toyota Corolla and the dash layout better and the seats better. I came out of a furniture store to scope out possibilities for our new abode the other day and saw a silver Nissan Sentra sitting right by the door and got a glimpse of what Nissan's design team was going for...sometimes it takes weeks for it to get across to me as I look at the car I am starting to like and see it in real action on the streets. It can be an appealing thing.
Our '11 Kia Soul is at 98,544 miles and we still owe on it, nothing's changed as far as that goes, except we owe a bit less and our Soul has a few thou more miles on it. I just love the hunt, though!
Perhaps the alignment will last longer than 15K miles
S3/S4/Stinger: Yeah, my budget for a second car isn’t that high. The Tahoe is easily in the last half of its lifespan—I knew that when I got it, but still have to account for its eventual replacement as a daily driver, preferably with something similarly large and comfortable.
Tomorrow it goes in for a new serpentine belt and tire rotation.
SHHHHHHHHHHHHHHHHH! Don't say the "H" word! Use Sport Back, 5 Door, Liftback, or SBUCSC (Segment Busting Utility Crossover Sport Coupe), but DO NOT use the H word (unless you are Honda of course
Premium gas - if you drive premium brand German cars, you are used to it. The car will run on watered down RUG, but when the documents say "required" and not "recommended", you reap what you sow. It never fails to amuse me when someone lays down 60K for a car and complains about premium. Reminds me of those in bloated SUVs and big trucks during the late Bush era gasoline spikes complaining about running costs.
Hatchback to A5 is like calling a pseudo-butch CUV a lifted wagon or minivan without sliding doors - the ego of the buying demographic won't stand for it.
My ex has been renting cars to get to China Lake for work. This week she's going there, then to San Diego for recruiting. Her "mid size" this week was a Sentra.
Right now the only vehicle I have that runs on 87 is the Wrangler; the Club Sport originally dedent require 91/93, but the Turner/Conforti Chip I installed does require it.
Oh well, pay to play methinks...
And I'm still drawn to the Disco - the seating position, taking into account the placement and comfort of armrests, is the most comfortable for me out of the three, and the seats themselves, while trailing the outright comfort of the Volvo seats, are still great. And I'd probably go for the diesel option with the Land Rover, which has its own appeal.
Join the Blue Square Club. We have cookies.
Since I have Volvo on the mind, I've taken notice of some XC70's recently and thought of you. They continue to be very handsome vehicles.
Odd that I didn't see the word "Kia" anywhere on the exterior of the Stinger. Did they forget or is that on purpose? --or did I miss it?
Around here, if you drive a half hour and only mess up your alignment, and don't blow a tire or bend a wheel, you had a good trip. The roads are a total mess. I drive the Sport, with the skinny little sidewalls, like a drunk granny. Really slow, and rarely in a straight line. A Ram PU is starting to seem like a better idea. Maybe a new Wrangler.
The Sandman
I do not want a newer vehicle right now, the timing is just off! One good thing is that at least I got about 15 months with the new run flats which I really like. Would I buy again? Possibly.
Stopped by the Buick store and drove an Encore. Very nice but it was a base model and I think I want all the safety nannies now as the accident scarred me a bit. Saw the G M before I left and he said, don't know if he was bull [non-permissible content removed] me, but with the end of their fiscal year in March, I could possibly save a good few thousand on it. Just for kicks, I said, "on this unit that $25K and change, you're saying I could get it for around $21K and change before taxes"? He said yep! Now, personally, think he was bull [non-permissible content removed] me. I left but really liked the Encore. Wife thinks it's too tall and just like my Tucson but she's uneducated on this so I figured not get into a discussion quite yet. But, I'm getting what I want, if it comes to that!
Next went to Hyundai with my $40 Amazon gift card app I got from Hyundai in my email the other day. A lady drove up in a new white Kona, the one I like, and we started to talk. She loves it, loves her sales guy and gave me a slip with his name on it. We talked for a minute or two and said I'd be back for a test drive on the Kona and Elantra GT. They also have a Elantra "Special Edition" which comes with a lot of stuff for around $21K, something I could actually do!
The Sandman
