2020 Toyota Corolla Lease Deals and Prices
kyfdxkyfdx Moderator Posts: 275,635
edited March 2019 in Toyota
Ask your 2020 Corolla lease questions here! Get info about prices, money factor, deals, incentives, and payments.
Check out the 2020 Toyota Corolla here.
«13456716
  • anthony713anthony713 Member Posts: 29
    Hi - 2020 Corolla LE Hybrid in zip code 19372
    Money factor and Res plus, any incentives?
    36 months 12 K
    Thanks !
  • kyfdxkyfdx Moderator Posts: 275,635
    36 months 12 K
    Thanks !
    .00285 MF and 57% residual
    No incentives.
    I think I'd wait until next month on the hybrid, to see if they come to their senses.
  • jliles528jliles528 Member Posts: 16
    Can I have the numbers for a Toyota Corolla XLE, 3/15k year in the 20723 zip code
  • MichaellMichaell Moderator Posts: 270,753
    .00139 and 51%
  • avisetiaavisetia Member Posts: 4
    Can I get the numbers for 2020 corolla se, 36 months/12k miles. zip code - 94132
  • zliuzliu Member Posts: 14
    edited April 2019
    Can I have the numbers for a 2019 Toyota Corolla SE, 36Month/10k in the 06850 zip code? Thanks!
    .00139 and 59%, assuming automatic
    36/12 (no 10K)
  • Russ421Russ421 Member Posts: 1
    Can I get the numbers for 2020 Corolla SE, 36 months/12k miles. zip code - 89044
    .00090 and 59%, assuming automatic
  • nhomonkonhomonko Member Posts: 1
    Hello!!
    I'm looking at a 2020 Corolla SE
    36/12k
    78229 (San Antonio, Texas)
    Thank you!!
    nhomonko said:
    Hello!!
    36/12k
    Thank you!!
  • MocarMocar Member Posts: 4
    Hi, Can I get the numbers for Corolla SE 36/12k, zip codes: 38501 and 30308, please?!
    TN - .00139 and 59%
    GA - .00172 and 64%
    If you live in GA, you may not be able to lease in TN; the SE Toyota region has some very strict rules about shopping out of the region.
    TN - .00139 and 59%
    GA - .00172 and 64%
    Thanks, I am living in TN right now but I am moving to GA in a couple of weeks. So, I was wondering if it would be better to lease a new car over there.
    Mocar said:
    TN - .00139 and 59%
    GA - .00172 and 64%
    Let's plug in some mythical numbers and see what we get.
    Assuming an MSRP of $23K, and a net cap cost of $21K, the pre-tax payment in each state:
    TN - $254/mo
    GA - $236/mo
    In GA, you pay tax on the sum of the payments, up front. TN taxes the monthly payment.
    You'll also need to do some research on dealer fees and state fees, to see if there is an advantage to one state or the other.
  • yongmingyongming Member Posts: 90
    Can I have 2020 hatchback manual numbers on different trims?
    36/12 98148
    36/12 98148
    There are no 2020 Corolla Hatchback lease numbers, this month .... only sedan.
  • TSHANTSHAN Member Posts: 2
    Hello, looking for MF, residual, and incentives for 2020 Corolla LE, and SE for 36/10k in Minneapolis (55422). Thanks in advance!
    Also, are there typically incentives for 2020 models this early, or would I be better off with 2019?
    .00139 MF
    57%/59% residual for LE/SE
    10K/yr is not offered
    No support for the 2019 model lease.
  • Jesusx1Jesusx1 Member Posts: 1
    Hey hi hello,
    I'm looking for 2020 Corolla hybrid numbers and possibly incentives.
    I'm thinking 36/12 in MA
    Thank you in advance
    Jesusx1 said:
    Hey hi hello,
    .00285 and 57%
    33/12 is much better - .00139 and 59%
  • ash88ash88 Member Posts: 2
    Requesting numbers for a 2020 Corolla LE CVT and XLE CVT. 36/15k and zip 76006.
    .00124 MF
    55%/51% residual for LE/XLE
  • vandi100vandi100 Member Posts: 8
    Requesting numbers for 2020 Corolla Hybrid at Zipcode 77450.
    .00124 and 55%
    Need your help for 2020 Corolla SE at Zipcoe 77450 for both 36/12 and 36/15
    .00124 MF and 57% residual
  • m_l_rm_l_r Member Posts: 2
    Hi can I get the MF and RV for 2020 SE? Zip code 93012, 36/12k.
    .00066 and 59%, assuming automatic
  • dandan1138dandan1138 Member Posts: 60
    I'm looking for the MF and Residual for L/LE/SE/XLE in 99203 for 36/12k.
    .00112 and 55% / 57% / 59% / 53%
  • alkamanalkaman Member Posts: 14
    Looking for MF/Residual/Incentives for 2020 Corolla XSE for 36/15 in 07645.
    .00124 and 54%
  • SEMSEM Member Posts: 49
    Looking for MF/Residual/Incentives for 2020 Corolla SE/Hybrid/XLE/XSE for 36/15 in NJ and NY please thank you
    .00124 MF
    57%/55%/51%/54% residual
  • sjeedsjeed Member Posts: 141
    Could I please get the current MF, Residual (12K), and Incentives for a 2020 Toyota Corolla Hybrid, 36 month lease. Zip Code = 94025 (Northern California), although I sometimes source cars from Southern California if that makes a difference. Thank you!
    edited May 2019
    Hi kyfdx:
    Thank you for the information.
    I saw somewhere in this thread reference made to some alternative lease structures such as a "33/12." Are these still available and, if so, how would these be priced (MF & Residual)?
    Also, what is Toyota's Lease Acquisition Fee and is it the same across all Toyota Leases for any model?
    Hi kyfdx:
    Same MF, and residual is 2% higher than for 36 months.
    TFS acquisition fee is $650, and is the same regardless of model.
  • hilary4477hilary4477 Member Posts: 19
    Would you please tell me the MF and RV for LE and Hybrid models, 36/12k? Zip code 85040. Any lease incentives? Also, 2019 LE numbers please.
    2020 Hybrid - .00115 and 57%
    2020 LE - .00090 and 57%
    No 2019 Corolla sedan numbers for your region
    Hi kyfdx:
    Thank you, again.
    A few more questions, same info for a non-hybrid version of the Corolla, Trim levels LE and XLE?
  • KK19KK19 Member Posts: 2
    Hi can I get the MF and RV for 2020 L and LE Zip 76208, 36/10k
    sjeed said:
    Hi kyfdx:
    Thank you, again.
    .00124 and 57% (LE) or 53% (XLE)
    .00124 and 55% (L) or 57% (LE)
    No 10K from Toyota
  • RebuiltAzRebuiltAz Member Posts: 22
    Can I get the MF, residual, and incentives for SE and XSE? Zip is 85301 12/36. Thank you in advance.
    .00090 MF
    59%/56% residual for SE/XSE
    My dealer said the sales price for LE is non-negotiable for leases, the MSRP is at $21,800. The edmunds leasing guide says the selling price is negotiable? What would be a good MSRP to ask?
    All sales prices are negotiable.
    Find another dealer.
    Use this link to help with your target:
