Visitor Agreement.
. Mounting mistake: Inserting the bead breaker the wrong way.
If you don't insert the bead breaker closely enough, you run the risk of damaging sidewall plies. Wheels also can be damaged by an incorrectly inserted bead breaker.
Mounting mistake: Holding the bead in the drop center by using hand-held bars.
"If the bar slips and the tire comes up, you're going to rip the tire bead," says Fred Ison, a McCourt trainer. You also may damage the rim.
"You may get away with (using bars) 100 times in a row, but that 101st time when you damage a $2,000 wheel negates all of that."
Techs also can be hurt if a bar suddenly breaks loose. Use a mechanical or pneumatic assist to hold the tire into the drop center while mounting the upper bead,
"With most changers, you can place the bottom bead on the rim without difficulty. But you must get the upper bead into the drop center of the wheel without damaging the tire and rim.
"As we get into 30- and 40-series tires, sidewalls are fairly stiff, so it's difficult -- if not impossible -- for a tech to drop that bead using only hand pressure.
FULL ARTICLE
driver, they do not look like Canadian geese.
The wild life is great....probably little gators in that pond behind them too.
Now I’m down to one fun car.
I was having lunch out iwth friends this afternoon and the Greek Restaurant was right next door to an Xfinity Store. So went in and checked out their plans. My brother was correct - 1 gig for $12.00 a month + tax, or about $14.00 total for their Mobile Phone Service. That would be a significant savings each month over my T-Mobile service. So I went ahead and transferred my service to Xfinity. I pay $12.00 a month for 1 gig of data with unlimited calling and texting. Xfinity uses Verizon's towers throughout the US.
For people like me who rarely use LTE data (under 1 gig), it sure is a cheap wasy to have mobile service. It's called Mobile Phone by the Gig. 2 gigs would be $24.00, 3 gigs would be $36.00, etc. Even if I useed 4 gigs a month, it's still less than T-Mobile's unlimited, which I really don't need. 95% of the time, I am using WiFi.
We'll see how things work out - no contract and no minimums. I can cancel at any time.
Still cheaper to pay occasional overage than unlimited on 2 phones.
we have the 8 gig plan for me, the wife, and our daughter we still have on it. a couple times a year go 1-2 over and pay the penalty, and I yell at the princess (who normally uses 2/3 of the data) about using wifi whenever possible.
2018 430i Gran Coupe
This was the view from my garage on Monday. We got another 6” since then.
I love the cold, but hate snow. Unfortunately usually they go hand in hand.
as for the non content permissible tree, I cut off the main branches and dragged them into the back yard last night. This weekend I'll be busy making firewood.
I hate being cold even more than snow.
Not in the mood to be hot!
It's an unusually brutal cooling end to the summer season. I saw lots of local classic cars
out being driven during the last two weeks. And it's depressing to know that most of
those have now been put to be--up on blocks to prevent flat spotting tires, preservative in the gasoline in the
tank, fresh oil in the sump, winter air in the tires. etc.. I'm going through a depression
because car show and cruise season has ended. A couple of last gasps: a Hollow Ween trunk
and treat by a tough old man's group that hosts a local cruise through end of
October into November IIRC and a Saturday truck or treat postponed from last
Saturday because of rain for a group that appears to have a lot of customized (ruined)
old cars that show up. But many cars are already in their cocoons. They won't be showing up.
Please send condolences. :'(
I've learned that the Outback has just enough RWD bias in their system to coax a small drift out of it when turning corners on packed snow. Wheeee!
Maybe I'll go out as a chronic car buyer.
Mrs D went as Wonder Woman.
Found a picture of it!
Did you get them after I told you what we were wearing?
