Insurance, I did not see a noticeable increase over the newer Elantra it replaced. But you would need to check your company. if there is a difference compared to any other new car, likely marginal, since it is not a high performance classification model.
Maintenance and repair, not an issue. It is basically a Honda. I used to take my 3.2TL to the Honda dealer for service since it was more convenient. Every 7,500 miles or so when it tells you, take it for an oil change. Usually $30-40 with a coupon. Very little other maintenance required. 4 banger has a timing chain too.
the 9 speed was a bit problematic originally I think. But that is only on the V6. When the DCT first came out (2015) there were some complaints about low speed harshness (I think that was the condition). But it was not mechanical, just software tuning. That got tweaked by 2016 and I have not seen of any issues since. Mine shifts great under every condition. And at least Acura comes with a 6 year, 70,000 mile powertrain warranty. Of course you can get an extended one if you want.
Maybe you will like the Camry too. That was a nice car in the latest iteration. Especially the SE or XSE version. Might be cheaper too.
Premium fuel will probably cost you about $300 more a year. The engine is designed to get its best power and mpg from premium fuel.
The 8-speed dual clutch transmission with unique torque converter has gotten mostly very good reviews. So far I've not heard about any problems with it (knock on wood). It's an in-house Acura transmission, designed and built for this car. I hope and think that they have "overbuilt" this transmission for long life. I did once see a TLX with over 100k miles for sale by a dealer and apparently everything was fine with the 8-speed DCT.
Acura, as you probably know, is the upscale brand of Honda, which is known as a good brand. Having owned 4 Honda Accords before the Acura, I can tell you that everything seems to be of higher quality, down to the battery, which is a bigger and higher grade than you get in an Accord. Should be reliable, but parts will be more expensive than for a Honda Accord, but less than for a BMW etc.
"Its aging seat leather took on a shiny patina that looked a lot like vinyl. Creaks in its structure and suspension appeared that weren't present at 20,000 miles."
Now, CAR in England also had one for a year, but put less than 10,000 miles on it. They liked it as well.
Automobile had a long term GT for 19,000 miles and absolutely loved it- more than an M550i that had been in their fleet.
So I'm extremely conflicted, the 540i is a known quantity, and with the non-adjustable M Sport suspension it handles better than any other 5er save the M5. It also has a few more bells and whistles. Then I read an article like this: Automobile reviews a Stinger GTS. I just wonder if the inherent goodness of the car will be more than offset by having to deal with the Kia Store in Louisville.
And saw this rare beast. It had GTI seats, yes the TL in the background. Had to stretch its legs a bit.
They also wouldn't allow test drives of the Supra when I looked at one last year. And at Oxmoor Hyundai where I was considering a Veloster N(until the excruciatingly low-rent interior put me off), they were hawking the "Pulse" ripoff. Just what I want, paying a tech who probably can't spell "Veloster"-or count to 20 without taking off his shoes-to hack into the factory wiring harness.
I suspect all the safety features will take time getting us to. The car was beeping and alerting me quite bit(Cross traffic monitor a couple of times, drifting out.of my lane) ....duties that use to belong to my wife (jk) ;-)
Of course you’ll have to go a ways to beat GG’s $17k discount.
I have seen few of those in this area that didn't have rust, but were still running.
The standard seats on the base TLX are vinyl. They aren't called that, but that's what they are. But it's a deluxe vinyl, similar to what Mercedes and BMW use on their cars before you get the optional leather.
The advantage of vinyl is that it will last a very long time, much longer than leather. If you've ever seen pix of the seats of a 15-year old luxury car with leather, often it's a sad picture, while the vinyl in the same model of car will still look almost new at 15 years. With cleaning and moisturizing every couple of years, however, I do think leather can last for at least a dozen years, which is as long as I'm likely to own my TLX.
Since you're into the details, here's more detail that you can possibly imagine on the TLX—from Acura's tech heavy press release for the car....
https://acuranews.com/en-US/releases/release-4ab1e0fb10674d7791526ba08c42d93f-2018-acura-tlx-overview
Move your cursor to the left to see the separate entries for chassis, powertrain, interior, etc.
Here are several paragraphs on the engine, which by the way is almost certainly the last of the naturally aspirated engines from Acura. Acura is probably going all-turbo soon.
"The TLX's direct injected (DI) 2.4-liter DOHC i-VTEC® 4-cylinder engine features a host of intelligent technology. The engine's i-VTEC system combines VTC (Variable Timing Control), which continuously adjusts the intake camshaft phase, with Variable Valve Timing and Lift Electronic Control (VTEC), which changes valve lift, timing and duration of the intake valves. The direct injection (DI) system, dual-stage intake manifold and other technologies combine to produce 206 horsepower and 182 lb.-ft. of torque.
The TLX's 2.4-liter engine has a lightweight die-cast aluminum block with a single main-bearing cradle design that creates a rigid assembly to help minimize noise and vibration. Cast-in iron cylinder liners provide long-lasting durability. Each journal on the forged-steel crankshaft is micropolished to reduce internal friction. To improve smoothness throughout the rpm range and help lower noise levels, the engine is fitted with an internal balancer unit. Consisting of a pair of chain-driven counter-rotating shafts located in the lower block and integrated into the oil pan, the balancing system helps quell the inherent second-order harmonic vibrations that normally impact inline 4-cylinder engines.
To reduce piston-sliding friction, the cylinder bores are offset by 8.0 mm from the crankshaft. This gives the connecting rods a more favorable angle during each power stroke, which reduces side loading on the pistons and in turn, improves efficiency. The engine features a forged crankshaft for high rigidity and low friction. Lightweight pistons have a carefully optimized skirt design to minimize reciprocating weight, and reduced weight minimizes vibration and increases operating efficiency. The piston crowns are dished, to help maintain stable combustion and to optimize distribution of the stratified fuel charge from the direct injector in each cylinder. This close control over the combustion process boosts overall operating efficiency.
To maximize power output, the 2.4-liter engine has a dual-stage intake manifold has two different intake runner lengths that are selected based on the operating conditions. An actuator and a set of four butterfly valves control the intake runner switching process. At low engine speeds, the long runners are used to improve low-end torque. At higher engine speeds the system switches to the short intake runners for greater high rpm power. The result is intake tuning that is optimized for the engine's entire operating range....
To help boost fuel efficiency and power, the combustion chamber shape and valve angles have been optimized. The included valve angle is a narrow 35 degrees, which decreases the surface-to-volume ratio and helps create a flatter, more compact combustion chamber that reduces unburned hydrocarbon emissions. With this combustion chamber shape and the precise control of direct injection, the compression ratio set at 11.6:1...."
And it goes on and on even from there!
Roadburner, not sure what was going on with Oxmoor. At first, Oxmoor Hyundai said I needed a signed buyers.order before test.drive. I balked, then they came back and said I could test.drive, which I did. Oxmoor Mazda.said no test drive, but Oxmoor Toyota said they were too busy, call back.and.schedule a test drive. The Hyundai salesman did say their.offer wasn't that "aggressive" , suggested they could do better if I was still in after.completing my other test drives.
I don't understand why videos from the other countries had everyone wearing masks and here we were told they don't do any good. Now they've decided maybe they do help. I've been wearing one after the first few weeks; earlier I went to grocery when the people count was low.
People can use disposable plastic bags from the grocery to handle the gas pumps when they fuel up.
https://www.caranddriver.com/reviews/a15108541/2015-acura-tlx-24l-test-review/
"The trans incorporates a torque converter to smooth out operation and to permit torque multiplication from a standstill, and it otherwise does all the things that make dual-clutches good dance partners. It holds gears to redline, matches revs on downshifts, and rewards tugs on the appropriate wheel-mounted paddle with near-instantaneous downshifts; in short, it does a damn good job of almost making you forget about the lack of a third pedal. Almost."
And here's what Acura says about it:
"The ultra-thin torque converter complements the efficient operation of the DCT by providing exceptionally smooth operation in stop-and-go situations, plus it offers off-the-line torque multiplication for improved initial acceleration that a DCT alone can't equal. In an aggressive standing-start launch, the torque converter substantially improves acceleration in the first 1.4 seconds, or about the first 60 feet (compared to a DCT alone)."
At first they thought there wouldn't be enough masks for medical staff...so didn't want the public trying to buy them up and horde them.
Some medical people think masks could be misused and cause more of a problem. If you get COVID on your hand (which can happen easily), you could get it on your face when you go to remove your mask. That is less likely to happen, if you get it on your hand, and wash your hands...before accidentally touching your face.
New thinking is it is probably best to use a mask....if, you use it properly, and medical people have them.
Guess I'll need to find masks now, of course there's no plan for people to acquire these. Maybe I'll wear my hockey helmet with shield as well to keep my eyes and hair protected, and to give kids a laugh.
If anything, maybe this will spur some decomposable disposable bag tech, looks like plastic bags aren't all evil after all.
2018 430i Gran Coupe
There is no vaccine, there is no cure other than time and the human immune system, although some drugs devised for other conditions may help some. The current testing is unpleasant and time-consuming so it is being used only where there is some reason to think a person has been exposed. Universal testing may be coming with newer, easier methods but how would that work? Get tested today, get exposed next week, then what? It is surely not a panacea and you cannot test constantly. The models the Public Health types have come up with are very scary but they are based on a set of assumptions that may or may not be true. Knowing Public Health as I do they are probably variations on worst-case scenarios. One interesting one I read about said that doing what we are doing will lead to a lot fewer deaths but will do more social and economic harm because we could need to do this for the next 18 months. It was contrasted with a less intrusive model that had far more deaths in a short period of time but which according to them meant that the whole crisis played out in just a few months, after which things quickly went back to normal. I don't understand how that works but that is what was reported. I don't think anyone has the answer. I found this Korean doctor useful to listen to (note his comments on masks). The intro is in English but the rest is subtitled.
Full Disclosure: I'm sure the reason I haven't seen a dollar or a decision from USAA on my claim from mid-December is that COVID-19 is slowing them down ..................NOT!
P.S. Anyone craving Corona Beer?
A. Shunned
B. Ignored
C. Rejected
D. Kicked out of the dealership with your tail tucked between your legs.
https://gearsmagazine.com/magazine/acura-dct-8-speed-transaxle/
"....Common complaints regarding the traditional DCT involve the quality of low-speed engagements, harshness, and shudder. Honda addresses these issues with a design modification that provides the smoothness of a traditional automatic with the efficiency of a DCT.
The Acura DCT8 uses a conventional torque converter with a torque converter clutch. The dual clutches sit at the end of the mainshaft and the secondary shaft (figure 3). Both the mainshaft and secondary shaft consist of an inner and outer shaft assembly. When applied, the clutches lock the inner and outer shaft assemblies together.
The DCT8 attempts to improve upon the traditional DCT design by using a torque converter to provide smoother operation during vehicle launch and low speeds, but then apply the torque converter clutch once the vehicle reaches the proper speed....
The DCT8 internals look like a smashup of a manual and an automatic transmission (figure 7). There are four shift rails with permanent magnets attached. The magnets act on Hall Effect sensors to inform the control module of shift rail position...."
There's much more, but honestly I don't understand most of it. But there are some nice pix.
Insurance and premium fuel are negligible when your talking about a car over $30K?
I also think a torque converter would be harmful to acceleration and economy, but improve smoothness. There's almost always a trade-off. The manufacturers tend to talk about the pros, without mentioning the cons.
It’s interesting that the ad that comes with that site shows two wallets. One looks fat and full while the other looks skinny and empty. Are those before and after pics when buying a BMW?
My suspect Mercury Mariner has running well the past 4 days. So, I'm in no hurry to buy. But, I've walked plenty of times before. Sometimes the salesman will come after me, sometimes he dont.
Chronic car lease buyers feel free to offer any advice. I leased a Honda Civic in 2012. $3,000 down (Got $2,000 for my trade in) and $79 a month for 3 years/12k miles a year. Had planned to buy it out when lease wss up, but just didn't like the car that much.
also, do the math (I believe it is impossible to buy a car without doing a spreadsheet!) if you really intend to buy at the end. It does not always work out cheaper once you factor in all the lease fees, extra DMV and dealer fees to buy it out, etc. It can just be cheaper depending on interest rate, MF, residual, etc. If they have a bunch of lease cash good chance there is enough trunk money to make the purchase price tasty too.
the real benefit to leasing first when you really mean to buy, is in case it turns out after 3 years you would really rather just give it back!
So let’s say that MSRP is $37,725. You get a $2500 discount (very fair) and are eligible for the $8700 in lease cash and $750 conquest. That puts you at a sale price of $25,775. Figure $1500 in fees (bank fee, doc fee, plates) for a net cap cost of $27,275. Not knowing your tax rate, on a lease that would come out to $353 plus tax with 0 due at signing (literally sign and drive) for 35 more payments, 10k miles per year - 36 month lease.
The money factor on this lease is .00215 which is an equivalent of 5.16% interest. The residual at lease end is 49% (18,485.25). You could choose to sign the lease and after it funds, immediately buy it out and not have to pay the 5.16% interest - you’d pay $18,485 + ($251 pretax x 35 remaining payments) = $27,270 + sales tax. $251 is your lease payment without the interest component and without tax, which would be how they calculate your buyout.
You could then finance the buyout at 2.39% for 60 months through PenFed and voila you bought the car for 28% off.
I feel I'm a bit out of my element with the lease terminology. With that Civic I leased, I had a good discount off the price, dealership gave me as much as I could have gotten private party on my trade in. Only $79 a month. Total payout was around $6,400.
Here's a video of the non tech package TLX I'm looking at. Don't know if I like that red. Looks to be the same red as what was on the Sonata,, Mazda, and the Toyota.
https://click.drivecentric.com/?c=1435B0D1-10F3-4E15-BDA4-BADF84F5A1D4&stre=457401ce-ed7a-4b4b-af9e-8fce4e088617&r=3868050&i=Video&u=InternalLink&l=1882&v=e731538f-baf4-403f-9564-40535d32846f#videoimage
$1,000 down
36 month/12,000 miles
Comes out to $420 a month
Residual is $18,108
Rebate for Healthcare professional: $750
Market Value $37,725
Discount $9,995
Selling Price $27,730
Total monthly payment $420
First Payment $420
Fees $0
Down Payment $1,253.80
Tax on down payment $0
Lease fees $0
Upfront sales tax $0
Balance due $1,000
All under "Essential Terms of 3rd Party Lease Agreement" .
Not sure why down payment starts out as $1,000, then turns into $1,253.80...then back down again to $1,000
