I always liked the Seville instrument panel--scaled-down version of the '74-76 big Caddy panel I think.
My friend who bought the white Seville with white vinyl top and greenish cloth interior, was having it pinstriped today since when it was previously repainted, the prior owner left the pinstripe off.
But, you gotta give GM credit...there is very little, if anything, on that Seville that looks like it came straight out of a Nova!
As for gauges versus idiot lights, I don't know how much truth there is to this, but I've heard one reason they started switching to idiot lights, is that drivers wouldn't pay attention to the gauges! An oil pressure gauge could read low, temp could read high, and drivers wouldn't necessarily notice until it was too late. And the amp gauge was a story in and of itself...sometimes reading a bit high, sometimes low, and if you're stopped with your turn signal on, it would often bounce in rhythm with the signal light...not exactly imparting a high quality feel. But with an idiot light, when that sucker came on, you knew it was time to pay attention!
And, it seemed like it was the nicer cars, where they started phasing the full gauges out sooner. At least, I can remember with a '67 Newport I had, it only had the speedo, fuel, and amps. Idiot light for oil. And interestingly, for temp, there was a "cold" light and a "hot" light. But then, the '68 and '69 Darts I owned had a temp gauge.
I think DeSoto started phasing in idiot lights for '59. My '57 and the '58's I've seen have a full complement of the typical gauges, but all the '59's I've seen had idiot lights for oil and amps.
I always liked the Chrysler Three-Hundred series....seems like seen less-often than Newport and New Yorker models. Struck me odd (at least in 'GM think' which I had then) that it was available in a four-door hardtop.
I liked the interiors--luxurious, but not panty-cloth like New Yorkers and other cars of that ilk.
I remember, also, Chrysler using gauges longer than the other members of the Big Three.
Did Chrysler use gauges in combination with warning lights? For some reason that is ringing a bell. That is the best of both worlds I think.
I was out for a walk recently, and his 27 yr old son was driving it down the street, with a passenger! I was stunned. Not something you just hop in for a drive. And, like most kids his age, he never showed a lot of interest in the Brass Era cars, when he was younger.
Gauges - fintail has oil pressure, temperature, but only a light for the generator (along with parking brake and high beams). However, the original owner installed an aftermarket ammeter (put a hole in the dash), but it is a period gauge and actually looks fine. The owner's manual calls the temperature gauge a "tele-thermometer", which is a name directly from 1959.
https://www.motortrend.com/news/2000-honda-civic-si-auction-result-photos/?wc_mid=4035:19291&wc_rid=4035:1076571&_wcsid=5F38EB4024F1A174126522EAB2C8C7A99428C6DE81D71C55
I just finished a WWII book that reminded me, as this car did for some reason, that Hirohito was Japan's Emperor until 1989. That is mind-blowing to me.
The car certainly looks clean, but I don't know a single thing about them.
I love how the seller is in Renton - not too long ago, that thing would have been stolen in a hot minute parked on many Renton streets.
Time moves on, and these are old cars now. Even that Civic is 20 years old.
Speaking of "modern" cars, Can't get this out of my head - usually not a fan of such colors, but it works so well here. Seller is sometimes optimistic with his cars, but I don't think this is insanely priced given the condition.
People have waited a year for C8's; then production stopped due to Covid, and this happened at a factory-authorized dealership!
https://carbuzz.com/news/owner-furious-after-dealership-drops-c8-corvette-from-lift?fbclid=IwAR0DY4T1b2xh3A9qUzKuCq6Ze96gmUgg0cwrP3sY_N6N9iMRjse7qowOXow
The owner makes some comments, which change the slant of the story.
Still, I'm surprised that Benz would use something that tall. Domestic makers would usually take a 2.24 or so and use it with a relatively large engine, in lieu of a 4-speed overdrive automatic. For instance, Mopar started using something like a 2.24 in their 318 cars starting in 1981. It ended up causing problems with the transmission, putting a strain on the lower gears, so they had to change first and second gears to compensate.
I have a 1985 Consumer Guide that has a test of a Cutlass Supreme coupe with a 307 and a 3-speed automatic. It has the axle listed as a 2.14:1! I used to think that was a transposition error in the typing as they also tested a Regal with the 231, and it had a 2.41:1. But in later years I found out there was a 2.14:1 offered in some cars.
I think GM was sort of able to get away with that extra tall gearing, because the THM 200 used slightly quicker first and second gears than older transmission. I seem to recall first gear for the THM 200 was 2.74:1, while it was 2.48:1 on the old THM 400 and 2.52:1 on the THM350? Mopar had used a 2.45:1 first gear in the Torqueflite for ages, but with the extra tall differential, they went to a 2.74:1.
"My '92 Neon isn't nearly the car my new Audi is!!!".
I feel quite sure there were C8-specific lift instructions, which obviously didn't happen here.
Funny to have read here before that problems due to suppliers aren't the fault of the automakers who test, purchase, and install their products, but a dealer screw-up is the fault of the manufacturer.
As always, people think what they want to think, and nothing anyone says ever changes that.
I think the federalization then was little more than turn signal colors and rudimentary emissions stuff, That was a great time for Euro imports, before M-B realized how the golden rule works here, and bought the 25 year rule. Someone probably laid down around 55-60K for that car in 1983/84 dollars.
Back when I had my '68 Dart, one time I had it in a tire shop, to get new tires on the rear, and they couldn't figure out how to get access to the rear tires. I had over-sized 225/70/R14s on the back, and when they put it on the lift, in the back the lift was raising it by the rear axle, rather than the sub-frame. I had to explain to them that on older cars like that, you had to raise it by the frame (or, sub-frame on a unitized car) and let the rear axle hang down, to get full access to the rear wheels.
Oh, and try explaining what a "left hand lug" or "reverse thread" lug is, to people nowadays. Hell, that's an adventure, in and of itself! Actually, that got me thinking...my '57 DeSoto originally had the left hand threads on the driver's side wheels, but since it came back from the mechanic, it now has the rear end from a '70-74 E-body (to get rid of those annoying rear brakes that needed a wheel puller) and it has front disc brakes from something like an F-body (Aspen/Volare) police car, so I guess if I ever need to change a tire, I'd better pay attention to that...it probably doesn't have reverse-thread lugs on it anywhere, any more.
I've also seen a picture floating around where something like a Tahoe/Yukon, or maybe a Suburban, had gotten lifted improperly, and it managed to rip the body from the frame!
That said, I would gladly own a GSX, Grand National, GNX, or another 1967 Riviera- like the one I bought for $5 in 1979.
Similarly, the recently-discontinued Regal and LaCrosse don't seem like bad cars, but they just don't stir any desire in me to own one. If I was in the mood for a new(ish) car right now, I'd probably go for a Charger. Although, I do like the Impala.
I think the last Buick car that I really liked was the Lucerne, but I was always a bit worried about the engine choices. By that time, the 3.8 probably wasn't enough engine to move that much car, and I've always worried about the 4.6 Northstar, and its reliability/repair costs. The Buick 3.8 ultimately gave way to a 3.9 Chevy V6 which, if I'm not mistaken, is traceable all the way back to the old 2.8 Citation engine! It did have more power than the 3.8, but I don't know much about it. And, in later years, the Lucerne got facelifted, and I didn't care for the grille/headlight treatment, which seemed a bit overdone and ill-proportioned.
I drove the Lucerne when it came out. Nice car, but I preferred the Avalon at the time and I got that instead. My comments on the Lucerne and the weak engine choices (for the same reasons you just stated) here got me pretty well flamed back in the day. I’m sure the thread is still here somewhere. That was in early 2006.
That second-generation Avalon was a pretty impressive car, too. I think I've seen road tests that put its 0-60 at around 6.6 seconds. I don't think any Lucerne was ever able to do that. The LaCrosse with the 3.6 looks pretty good, though. I did a quick search, and found 0-60 times around 6.4-6.6 seconds. And heck, I saw one quote, for a 2018 Avenir, listed at 5.6 seconds!
I've noticed that, as time goes by and I get used to faster and faster cars, instead of the faster car feeling like a big improvement, I notice that I soon get used to it and it just feels "normal". And then, when I have to drive something that's slower, that I never had an issue with before, suddenly it feels like a dog. I think my Ram is good for 0-60 in about 7 seconds, and my '03 Regal, about 8 seconds. But damn, what a difference that second makes! Still, the Ram just didn't feel like that big of a deal, a few months after I bought it and I got used to it. I wonder, if I ended up with a car that could do 0-60 in around 5-6 seconds, or even quicker, if eventually I'd just get used to it and get that same "meh" feeling about it?
My E24 M6 was the fastest car I had owned when I bought it in 1992. It was fast for its time- 0-60 in 6.0 seconds and a 1/4 mile time of 14.6 seconds. I shaved a few tenths off those numbers with a Dinan chip and a track pipe that replaced the catalytic converter. I then went to my 140 hp Club Sport, which was 2 seconds slower. I didn’t mind it as much because the CS was nearly 800 pounds lighter and much more nimble.
The Mazdaspeed 3 was about 0.5 seconds faster than the M6, but being FWD getting that power to the ground could be tricky at times.
I’d say that the acceleration of my M235i is about average for a modern performance car- a 0-60 time of 4.3 seconds and a 12.9 second 1/4 mile. What makes it fun is the torque delivery- maximum torque is available just off idle, so wheel spin can be even be coerced in third gear.
My wife’s X1 is certainly not quick by modern standards- even though its acceleration mirrors that of my old M6. How times change.
A female friend of mine just bought an Envision last week. I didn't even know what that was. She is loving it so far and either doesn't know or doesn't want to mention to me that it was built in China, LOL.
Ours is extremely quiet. I think the laminated glass (which there is a lot of) has something to do with it.
My dad had a "full acre" Econoline around the time I started to drive - I didn't like that thing, no windows, and I was always afraid of cutting corners in it. I think I only drove it a couple times as it was eventually traded away.
Not quite ready for a road trip.
I'd say probably a '19, as it was a rental at the San Luis Obispo airport.
Tire noise bugs me, but that vehicle had none if very little. We've had this discussion before but my '08 Cobalt XFE was quieter, and idled like it wasn't running, better than more-expensive cars I've owned of-late.
As for engine noise, in the 2er I can run silent in Comfort mode or get some nice burbles and pops in Sport mode.
