2021 Porsche Lease Deals and Prices (All models)
2456718
  • Love2Lease8888Love2Lease8888 Member Posts: 4
    Any lease numbers yet on a 2021 992 Turbo S Cabriolet?
    Looking for MF/RV/MRM 24/36 5k, 7k zip 92821.
    Thanks as always! Car arriving Mid December. :smile:
  • kyfdxkyfdx Moderator Posts: 273,936
    .00200 MF
    59%/52% residual
    $244,700 MRM
  • thomasctt1thomasctt1 Member Posts: 8
    Can I get the MF and Res for a 2021 Cayenne SUV? Both 36/15k and 36/12k in South Florida
    .00200 MF and 57% residual
  • alabicoalabico Member Posts: 3
    Can I please get November residual/MF/MRM for below please and if possible for SF Bay Area?
    2021 C2S coupe for 36/10K
    .00200 MF and 60% residual
    $143,900 MRM
  • jjeffrey03jjeffrey03 Member Posts: 18
    Hi guys, looking for RV on a 2021 Macan Turbo for 36/39/42 mos at 7.5k/year. Zip 27703. Thanks as always.
    .00200 MF
    59%/57%/55% residual
  • jodi77jodi77 Member Posts: 16
    MF and RV for 2021 Cayenne Base Model
    36/12, 36/15, 39/12
    Zip 63011
    What is the MRM for the 2021 model.
    36/12, 36/15, 39/12
    Zip 63011
    .00200 MF
    59%/57% residual for 36/39 mo, 12K/yr
    $83100 MRM
    Thanks. what is the RV for 36 m 15k/year
  • MichaellMichaell Moderator Posts: 269,760
    Subtract 2%
  • auberonauberon Member Posts: 37
    Hi! Could I please get the numbers for a:
    2021 718 Boxster base model
    manual transmission
    24 months
    lowest mileage allowance available
    95112
  • zjh08177zjh08177 Member Posts: 3
    2021 Cayenne
    MRM?
    zip code:94587
    manual transmission
    24 months
    95112
    .00200 MF and 68% residual
    zjh08177 said:
    2021 Cayenne
    MRM?
    zip code:94587
    .00200 MF and 59% residual
    $83,100 MRM
  • Forester084Forester084 Member Posts: 14
    Hi can you please provide for 2021 Cayenne Coupe Turbo
    24/12
    30/12
    zip 33160
    MF, Residual, MRM
    TYIA!
    24/12
    30/12
    zip 33160
    MF, Residual, MRM
    TYIA!
    .00200 and 60% / 56% / 53%
    $155,200
  • dngcordngcor Member Posts: 2
    2021 Cayman base 39/10 36/12 MF and Residual
    .00200 and 60% / 58% for 36/39 and 12K
  • x_mzx_mz Member Posts: 6
    zjh08177 said:
    2021 Cayenne
    MRM?
    zip code:94587
    $83,100 MRM
    Can you confirm this is for '21 base model & applies to 07024? Are there any incentives this month? Thank you!
    x_mz said:
    zjh08177 said:
    2021 Cayenne
    MRM?
    zip code:94587
    $83,100 MRM
    Base model.
    Porsche numbers are national.
    No incentives.
  • truk1llatruk1lla Member Posts: 12
    718 GTS 4.0. and 36/7500 30078
    .00200 and 55%
  • formula1fan5formula1fan5 Member Posts: 50
    Hello can I get the MF, Residual and MRM on a 2021 911 Turbo Coupe (not the "S") for
    36/39 months and 5000 miles. Thanks
    Sorry, I only have numbers for the Turbo S coupe, right now.
    Ok thank you, would it be possible to post them when you have them? I can keep checking every so often.
    Porsche updates their numbers quarterly; it may be January before we see them.
    Ok thanks for the info. Any guess as to how they might compare to the "S"? Where the residuals on the 991.2 Turbo's any worse than the "S"? It's ok if they are the same but any worse and I may as well spring for the S!
    Thanks again.
    edited November 2020
    Thanks again.
    No information to share with you, though you could review the posts in the 2020 Porsche lease thread and see if there is anything there.
  • samsoccer7samsoccer7 Member Posts: 12
    2021 Macan S
    2021 Macan GTS
    36/10 each please in 60559
    Also incentives?
    Thanks great idea! I should have thought of that.
    2021 Macan S
    2021 Macan GTS
    Also incentives?
    .00200 MF
    61%/60% residual for GTS/S
  • JohnRSJohnRS Member Posts: 11
    Looking for RV, MF and any incentives on 2021 718 Boxster GTS 4.0. Zip is 45227, thanks.
    36 months, 7,500 miles per year if possible (if not then 10k)
    36/7.5K
    .00200 and 55%
  • DaddyO4uDaddyO4u Member Posts: 1
    Looking for RV, MF, MRM and any incentives on 2021 911 carrera 4s cab
    Zip is 20143
    24 mos / 10k
    36 mos / 10k
    Zip is 20143
    24 mos / 10k
    36 mos / 10k
    .00200 MF
    65%/58% residual
    $166,400
    I may switch to a 911 Turbo S Coupe. Can get the residual for 36 months and 5K miles.
    I assume the MF is .002. Thanks!
    .00200 MF and 55% residual
  • vertigo1vertigo1 Member Posts: 59
    Hi! Could I please get three money factor and residuals from you for 2021 cars in the 95032 zip code. In each case could I please have the 24 month and 36 month rate for 7.5k per year?
    (1) Boxster T
    (2) Boxster S
    (3) Carrera Coupe (base)
    (I don't think it matters, but looking at the Manual transmission for the boxsters)
    (1) Boxster T
    (2) Boxster S
    (1) & (2) - .00200 and 65% / 58%
    (3) - .00200 and 63%
    Hi! For the Carerra coupe, the 63% is for 24 months, correct? What about 36 months? Thank you for your help!!
    56%
  • shadowshadow Member Posts: 4
    Hi, what is the MF and residual for a 2021 Cayenne Base and S in 94061? 36/45k. Any incentives? Thank you!
    .00200 MF
    57%/53% residual for Base/S
  • anguyen33anguyen33 Member Posts: 3
    911 base and 36/7500 36/10k
    718 s 36/7500 36/10k
    30096
    30096
    718? Is that a Boxster or a Cayman?
    911: Coupe or convertible?
    Just checking back, are the numbers for the 2021 911 Turbo coupe out this month? If so 36/5k please. Thanks!
    What is your location?
    Zip is 11209
