It's not very old so things haven't started giving him problems - not that it is a requirement.
I used to marvel at the windows on a TTS owned by a middle-aged guy who gets coffee at the same quick market store I do. It lower the windows a 1/4 inch when the doors are being shut, then puts them back up to seal...
He replaced it with a more dependable vehicle, CTS. Both purchased on the internet. He's had the CTS for at least 4 years.
Some E-class from 03+ also have this, but it seems to fail less on those cars. S-class since then also have it, but it fails far less often.
It was to get a really good seal around the door frame.
According to the National Hurricane Center in Miami, the storm is strengthening and could become a category 1 hurricane after passing Cuba. The "Cone of Uncertainty" shows the southeast coast of Florida (Miami, Ft. Lauderdale and Palm Beach) in the storms path. This storm is not going to skirt us - they are expecting a direct hit. The scout planes they use to determine strength of a tropical storm/hurricane collected data showing wind gusting over 80 mph as it continues to strengthen. Pressure (millibars) is dropping rather quickly showing that strengthening.
I just put my hurricane shutters down on my terrace and will eventually place a half dozen towels up against the bottom of my front door just in case the winds come from the southwest. This is not much fun, guys!
Of course, we all know DIY automotive work is extremely dangerous, so I kept this close by during the entire process:
Before:
After:
We will see.
I sold the Fit, so there is that. lol
I did it without a safety net. Turns out our fire extinguishers are expired.
Just set aside a couple of hours to do both headlights. Follow the directions and you should achieve the same results. I didn’t have to mask any bodywork so that saved me some time.
This weekend I rebuilt the bottom of one of the van doors that had pretty much disintegrated. It was a challenge to reform the bottom 4 inches with Bondo and spray foam as backing. Looks like a hillbilly hack job but it keeps the critters out.
I’d post pics but ever since Apple installed a software update I can’t use Edmunds system.
I found what works best: I bought new headlamps out of the multitude of choices on Ebay. They're lasted years now without clouding up.
Funny thing: I noticed over the last year or so that the ride height on it up front had finally come back to normal. Even since some front end work got done a number of years ago (10?) it had sat a bit high up front. For whatever reason it has now come back to where it should be. The downside to that is that doing an oil change without putting it up on stands is now a lot more difficult, but I got it done.
Big difference in cost for Clubman vs Cobalt in aftermarket. But they came wired and with bulbs.
F150 is so good for what it does. I don’t need or want one. But, if you need a full size pickup, it’s the best of the bunch that I drove.
There is such a big difference in driving the RDX vs a Chevy Traverse, it’s not even close. Yet, the couple of Traverse’s I transported had MSRPs that were equal to, or exceeded the RDX. Again, material quality, driveline, etc on the RDX were head and shoulders better than the Traverse.
Just some of the examples.
Yay!!!!! Congrats!
b) I like the comments like comparing the Tranverse to the RDX or the comments about the Camry. Opinions from a knowledgeable but average person (you know what I mean....common, normal person etc.) probably mean more to me than a paid reviewer. If I was in the market for a truck I would definitely keep in mind what you said about an F-150, and same with the other cars mentioned. Maybe your next profession could be giving 5 minute comparison reviews.....kinda like Scotty but with a lot more polish.
Like @snakeweasel
The cosmetics didn't bother me, but it was cloudy enough that it affected the headlight quality.. Not my problem, now!
Other Forum technical questions...
a. when posting a link, how do you shorten it and put in different words for the link?
b. How do you change a string of quotes making it shorter but still able to display if desired?
Like @snakeweasel
Thanks for the tip!
"The brilliant blacks and captivating colors of the 65-inch TCL QLED TV offer a spectacular, immersive viewing experience. The Quantum Dot technology includes 1.07 billion colors which creates a strikingly lifelike picture with stunning richness and clarity. The TCL 8-Series TV's mini-LED backlight display technology and Contrast Control Zones provide a high degree of precision, smoothness, uniformity, brightness, and illumination. All this on a FullView edge-to-edge glass display set on a T-pedestal stand designed for style and stability. Four HDMI ports and one USB let you connect multiple devices."
