2021 GMC Sierra Lease Deals and Prices
2456717
  • rucrazee2rucrazee2 Member Posts: 31
    rucrazee2 said:
    Hello! Could I please get the numbers for an SLT and Elevation, both 4x4 with 36/10 and 36/12 (does 39 change anything?), zip 52001
    Double or Crew Cab?
    Crew Cab
  • kyfdxkyfdx Moderator Posts: 268,308
    rucrazee2 said:
    Double or Crew Cab?
    Crew Cab
    ELEV: .00021 MF and 62% residual
    SLT: .00009 MF and 61% residual
    $250 customer incentive
    60% residual for 39/12 (either trim)
  • likes2drumlikes2drum Member Posts: 4
    Crew cab Denali 2020
    Crew Cab Denali 2021
    ZIP:14625
    Costco, current GM lessee
  • cansledcansled Member Posts: 10
    Good almost afternoon! Looking for MF and RES for AT4 Crew and Denali both 4x4 for 36/12 & 39/12 in 48453. Thanks.
    ZIP:14625
    2021
    .00069 MF
    64%/61% residual
    2020 discussion:
    https://forums.edmunds.com/discussion/58030/gmc/sierra-1500/2020-gmc-sierra-lease-deals-and-prices#latest
    AT4: .00009 MF and 61%/60% residual
    DEN: .00069 MF and 64%/61% residual
    $1250 customer incentive
    I have 2 different dealers in my area insisting 59% residual for 2021 AT4 Crew cab 4x4 for 36 months, 12000 miles. Any ideas?
    I'll guess they are reading a residual off of a chart that shows the 15K/yr number. And, forgetting to add 2% for 12K/yr.
    Just checked them again, and 61% is what we show.
  • M5elevateM5elevate Member Posts: 11
    Hello, can I please get the November MF, RV, and incentives on a 2021 GMC Sierra 1500 Elevation and AT4 4WD short cox crew cab 5.3L in 33186?
    24/10
  • MichaellMichaell Moderator Posts: 265,481
    24/10
    Elevation
    24/10 - .00011 and 70%
    36/10 - .00021 and 63%
    AT4
    .00021 and 70%
    .00009 and 62%
    $250 incentive
  • Krish12Krish12 Member Posts: 14
    Hi, I am looking for MF and Residual for Denali Crew and Denali both 4x4 for 36/12 & 39/12 in 95661. Thanks.
    .00069 and 64% / 61%
    $250 incentive
  • urnzway1urnzway1 Member Posts: 26
    Can I please get 36/12k Residual and MF for zip 28031 on the following models:
    2021 SLT Crew 4x4
    2021 AT4 Crew 4x4
    2021 Denali Crew 4x4
    2021 SLT Crew 4x4
    2021 AT4 Crew 4x4
    .00009 and 61%
    .00009 and 61%
    .00069 and 64%
    $250 incentive
  • crowdedstrcrowdedstr Member Posts: 11
    edited November 2020
    How about MF and residual for 2021 Sierra 1500 SLT 4x4 crew cab in 54568
    39 months/ 12k miles
    Thank you for your help!!
    .00009 and 60%
    $250 incentive
  • jbc8000jbc8000 Member Posts: 23
    Slt crew 4wd, 36/15k for zip 14784. Thanks
    .00009 MF and 59% residual
  • Funyes98Funyes98 Member Posts: 13
    Can I get lease rates for 2021 Crew Cab AT4
    24/12
    for 48316.
    24/12
    for 48316.
    .00021 MF and 69% residual
    One more please:
    24/12 & 36/12
    for 48316.
  • bsharinbsharin Member Posts: 11
    Can I please get the MF, Residual and incentives on a SLT, AT, and Denali 4x4 Crew Cab 36/12 in 32311
    Funyes98 said:
    One more please:
    24/12 & 36/12
    for 48316.
    .00042 and 70%
    .00069 and 44%
    $1250 incentive
    SLT / AT4 - .00009 and 61%
    Denali - .00069 and 64%
    $250 incentive
  • saviolasaviola Member Posts: 31
    Can I please get MF, Residual, and incentives if any on a 21 AT4 and Denali 4x4
    36/12k, 15k
    39/12k, 15k
    6.2 and Duramax in 92879
    36/12k, 15k
    39/12k, 15k
    15K/yr
    AT4: .00009 MF and 59%/58% residual
    DEN: .00069 MF and 62%/59% residual
  • MastazMastaz Member Posts: 12
    Hello there! RV, MF, and incentives for 24/10, 36/10, and 39/10 in zip 11946 please. Thank you!
    2021 Denali 4x4 crew sb
    2021 AT4 4x4 crew sb
  • kingkong827kingkong827 Member Posts: 15
    Hi, May I have the RV, MF, and incentives for 36/12 in zip 06073
    2021 Denali 4x4 crew Gas 6.2
    2021 Denali 4x4 cerw3.0 diesel
    AT4
    .00021 MF and 70% residual
    .00009 MF and 62%/61% residual
    Denali
    .00042 MF and 71% residual
    .00069 MF and 65%/62% residual
    .00069 MF and 64% residual
  • AggieATOAggieATO Member Posts: 23
    Settled in on the GMC. Could I please get the MF, residual and incentives for 36/12 in zip 75082. Crew cabs for all.
    21 SLT 3.0 diesel 2wd
    21 SLT 3.0 diesel 4wd
    21 Denali 3.0 2wd
    Thanks for all you guys do.
    21 Denali 3.0 2wd
    .00021 and 62%
    .00009 and 61%
    .00069 and 64%
    $250 incentive
  • Aframes1Aframes1 Member Posts: 12
    Hello, Can I get Residual and MF info on the following truck in the following locations
    2021 GMC AT4 4x4 Diesel
    24/15
    Zip code - 92024
    Zip Code - 81621
    Also any incentives etc
    24/15
    Zip code - 92024
    Zip Code - 81621
    .00021 and 68%
    .00009 and 59%
    $250 incentive
    Either CA or CO
    21 Denali 3.0 2wd
    .00021 and 62%
    .00009 and 61%
    .00069 and 64%
    $250 incentive
    Thanks! I thought that would be it but it seems the 4x4 Denali's are easier to find. Can you help with the numbers on the 4x4 version of the Denali above? Thank you!
    21 Denali 3.0 2wd
    .00021 and 62%
    .00009 and 61%
    .00069 and 64%
    $250 incentive
    Same as 2WD
    Can I please get the MF, Residual and incentives on a SLT 4x2 Crew Cab 39/12 in 32311
    .00021 MF and 60% residual
  • jlm5151jlm5151 Member Posts: 8
    2021 Sierra AT4 Crew Cab 4x4 36/12
    2021 Sierra Denali Crew Cab 36/12
    Zip- 43230 Thanks!
    Zip- 43230 Thanks!
  • Binks84Binks84 Member Posts: 4
    2021 crew cab elevation 4x4 5.3
    MF, residual 24/10, 24/12,36/10,36/12 for 64081
    24/12: .00011 MF and 69% residual
    36/12: .00021 MF and 62% residual
  • dannassdannass Member Posts: 9
    Hey there, can I please get the MF/ RV on a 2021 Sierra Denali Ultimate, 4x4 Crew Cab, 36/10, 48017. Thanks!
    .00069 and 65%
    $1250 incentive
  • OleUgly86OleUgly86 Member Posts: 4
    Can I get the MF/RV for a 2021 AT4 4x4 crew cab 10K/36 for zip 83701 please? Thanks!
    .00009 and 62%
    $250 incentives
  • jrayachito1986jrayachito1986 Member Posts: 33
    can you please share residual and money factor for 2021 Gmc Sierra 2500HD Crew Can Denali/AT4 4x4 regular box 6.6L 36/10 36/12 zip code 95901
    We only have the 2500 Denali numbers
    .00108 and 70%
    No incentives
  • GooteechevGooteechev Member Posts: 104
    2500 HD Denali Crew 4x4 diesel 97005 36/10. MF, RV any incentives.
    1500 Elevation Crew cab 4x4 4 cyl 36/10 MF, RV
