Visitor Agreement.
Definitely a few things I like more about the M2, but also many things I prefer on the Supra. The only real motivating reason would be that I just have to have a manual. And the reality is, as hard as it is to admit, don’t think I “have to have” the manual. Not that I wouldn’t consider it down the road, but just not a motivating enough reason right now.
Some cars I simply wouldn’t consider in an automatic...Miata is the most obvious one IMO. WRX. Civic Si or Type R (at least when they inevitably offer one). Mustang GT.
But the Supra has opened my eyes a bit to having fun in a car without necessarily having to shift your own gears.
Now recently, I took the LC to the dealer for an oil change and lube of the driveshaft. They came back with 1800 in recommended maintenance. Most of which was plugs (900) which I had already done somewhere else for much, much cheaper. They just go by the book and mileage without checking/thinking. I can kinda get not wanting to pull a plug and see the condition but they also recommended wipers (done and real easy to check that) multiple other fluids (again most easy to check and see that they are clean). Doesn’t start the relationship off well with the dealer.
RE: Tire rotations. I had a Beretta in college and took it to Firestone for an oil change and rotation. Time to pay, its pulled around and the front disc/rear drum set up leaves no doubt that due to the brake dust, the tires had not been rotated. Pointed this out and they tried to tell me that they actually take the tires off to rotate them. Umm no.
Have to admit, that was a creative answer.
A new one on me was that the drive shaft might also need lube. I saw that on a video from the Wizard or Wheeler Dealers, I can’t remember which.
I swear I heard him laughing as he drove away.☹️☹️☹️
When I was in law school back in the early '80s I was one of only a few car guys in my class. As a result, I often got called on for advice- and every now and then I would perform minor mechanical repairs and/or upgrades for my classmates(including installing a sound system for a delightfully eccentric young lady who could have passed for Debbie Harry's identical twin sister- but I digress...)
Anyway, one of my friends had a Mustang II(so did my girlfriend at the time; that particular model motivated me to study very hard- so that I would land a job that ensured I would never have to own or drive one ever again...) So one day my friend tells me that the car is stalling after it has been driven for 10-20 minutes. After 30 minutes or so it would fire up, run another 10-20 minutes and stall again. I tell him it could be anything from a ignition module that fails hot to a fuel system issue. I suggest taking it to a dealer or indie shop.
So... he takes it to his nearest Ford dealer. They change the fuel filter and "blow out the fuel lines." I told him that I hoped it worked, but that my guess was that whatever clogged the lines was still in the tank.
Two days later, the trusty steed stalls again. Back to the dealer it goes. This time they again blow out the lines and "install new EGR valve." I thought that call was a little sketchy, so I looked under the hood and found an EGR valve that looked like it had been on the car since it was new(Ford V8s of that vintage had an EGR valve assembly that was sandwiched between the carb and the intake manifold- I had dealt with them while doing my time in DIY mechanic purgatory servicing my parents' 1973 Bronco and 1974 Maverick). At this point I'm thinking the next thing they should do is drop the tank and clean it out.
Anyone care to guess what happened next? This time I decide to go back to the dealer with my friend; I tell him to ask to speak to the Service Manager and to politely explain that the car had stalled again and to ask why a new EGR valve was installed(As for me, I was going to act as if I was just the guy who was giving him a ride- I really wanted to hear what the guy would say.) Anyways... when we go back to the dealer the SM comes out and apologizes for the problem. He pops the hood and pokes around the air cleaner and intake manifold for a minute and then announces, "I'm sorry for the mistake- this car doesn't even have an EGR valve. I think what we need to do is drop the gas tank and clean it out." At this point I've decided that any landing you walk away from is a good one- if the SM wants to take the EGR valve off the bill because he thinks the car doesn't have one I'm not going to get in his way. Sometimes a failure cascade works to your advantage.
And yes, the car ran fine after the tank was cleaned. My girlfriend and I parted amicably- but not before I talked her into ditching the Mustang II for a new Accord coupe. My buddy and I both passed the Bar, thereby relegating future Mustang II ownership to the ash heap of history. And I also met my future wife, who permanently endeared herself to me by locating my first BMW: a 1973 Bavaria 3.0. Talk about living HAPPILY ever after...
As for the automatic discussion, as I'm pretty certain I've mentioned before, it just makes sense to me to get the auto these days (as long as it is a good one, such as the ZF or PDK) simply because it makes the car faster in almost all instances. People spend thousands trying to gain a small acceleration advantage, so why inhibit the car from the get-go?
So my current fun research obsession? What could I get to satisfy those car needs/desires at a significantly reduced rate? If you'd like, indulge me with your thoughts.
Utility car - let's say around $35-40k budget:
- 2018-2019 MDX - a sport hybrid model would be great, but so many more choices out there with the standard V6. At least Tech Package, but Advanced would be preferred.
- 2019-2020 CX-9
- 2017-2018 X5 35i or 40e
- 2017-2018 GLE
- Or maybe, push that budget just a bit...Mach E (considering $10k of tax incentives here in CO)
For the fun car, let's stick around $30k'ish:2025 BMW i5 - 2017 911 C4S - 2024 BMW 230i - 2025 MB GLE450e - 2024 Genesis GV60 - 2019 Cayman
I enjoy having some purpose in my searches though - this may not materialize into anything. It’s one thing when I’m unhappy with a car and desire a replacement. It’s another when I’m more curious as to what could be had for less. Sometimes I find something that I really appreciate and sometimes I realize what I have is actually worth the cost.
Do you throw cash at all these or just rolling financing up / down depending on the deal.
Oh and MDX tech is the minimum, anything else will feel sparsely equipped.
Great choices btw. I’m intrigued by the new MDX and the M240i has always been a favorite.
I’ve seen a lot of the new Tahoe/Yukons on the road and man, that thing is nice! Bigger than the previous gen which was already huge. The Tahoe is particularly attractive in Z71 trim.
Over on BaT it seems that some take driving an auto as an affront to their manhood resulting in comments like ‘as soon as I got that 10k mile all original 63 Split Window Vette, the first thing I’d do is drop a stick shift in”
The Supra was an indulgence generously allowed and encouraged by my wife - I have to remind myself that on my next fun car, I should get back to the more affordable level.
The Cayenne is kinda funny - when we discussed the reduced needs we have for a utility vehicle, we agreed we could be in the $35-40k range. Then we looked at the Cayenne and all of a sudden that budget went way up.
One thing is for sure - accepting it sure opens up a lot more possibilities for that fun car.
Do you miss the Volvo wagon at all? IIRC that was pretty loaded with the Bowers stereo.
And yes, I have thought about the utility and fun coming together...an X3 m40i comes to mind. When I test drove that, I remarked how much it felt like the Supra (to a certain extent of course). What other vehicles would you recommend as an “all-in-one?”
Geez, now you got me thinking...I could open up a garage space for the Leaf.
