I'm sure there some wonderful things it will do. I just never found out what they were.
Electric can openers were a huge thing when they first came out, everyone had to have one.....and people relied on canned foods a lot more in those days.....it looks like some people still do
They were like the latest state of the art invention, that everyone could afford. Now they just take up valuable real estate space on the counter. The one we had about 40 years ago was olive green to match the appliances.
The toaster was binned when this thing invaded our counter space.
@snakeweasel was right about drain cleaners being harmful to pipes. However, if your house was built in the late 60s and later the drain pipes are probably plastic, so, home drain cleaners will not harm them. Years ago ABS plastic (black in color) was used, today at least in my area they now want you to use PVC which is white in color and from what a few master plumbers have told me the PVC is a little stronger physically and it is cheaper. Kinda like the best of both worlds. Our resident plumber guy, @nyccarguy, might be able to provide more info about this but I know that plumbers in my are use PVC now. ABS is still OK but i was told that it is being phased out. @stickguy also provided good info when he said something like, ‘if the pipes are done right’, which to me means they are the proper size and have the proper slope so that it drains to the main vertical stack without backing up on improperly sloped horizontal runs.
Now I’ll put together both of what I just mentioned:
When my Son and I did our first flip, there was a wall that divided the kitchen from an all purpose room on the other side of the wall from the kitchen. Since we gutted both the kitchen and the all purpose room that had a washer and dryer along with a toilet and an 18 inch sink, we had a free hand to do what we wanted to do. The all purpose room would become a full bath with 5 foot shower pan, a toilet of course and a 42 inch vanity. The washer and dryer were moved to another spot in the house (that was a BIG job because a new drain line had to be installed for that. Supply lines are easy in comparison.
Like I said the wall was completely open on both sides and I noticed that the drain line for the small sink in the all purpose room had literally no slope. So we cut that out from the stack back to where the new vanity would be placed. One day when the next door neighbor came by to see how things were going, he was a DIYer of sorts himself and had the same house. He liked the idea that we were replacing the 1 1/2 copper drain line with plastic because those houses had a lot of problems with that sink drain because of the bad slope and everyone used a lot of drain cleaners over the years (house was built in the mid 60s). When I cut out the old copper drain line I could see that the wall thickness on the bottom 1/3 of the pipe was VERY thin compared to the rest of the pipe. At one point where I touched it, it wrinkled like aluminum foil and I’m not exaggerating. So, if a snake was ever put into that pipe it was a goner. I guess you could say we got to it just in time.
People look down at products today that are made of plastic but as far as I’m concerned plastic for drain lines is the best thing since sliced bread.
How many of you guys made it this far?
I also am a fan of the plastic (pex?) supply lines too. Just read a post about a local neighborhood where nearly all the houses are having pinhole leak problems in their copper water lines. that is not a good thing!
PVC is nice except in two story homes you can really hear the drain when someone flushes a toilet.
I read it all and got some useful information from it.....I think!
Don't you watch 'Holmes Inspection'?
Sometimes I feel so bad for those people, I have to change the channel for a while.
He was born just a few miles from me....too bad I didn't inherit some of his knowledge!
One guy even a new house where many of the drains were clogged up with debris.
As @tjc78 said, cast iron is good for higher end residential applications so you don't hear the toilet flush.
I’m waiting for the day they want to sign us up as flippers. I promise to watch my language.
When we did the addition they did a lot of work with pex and ended up with some interesting transitions between the two materials.
-Dishwasher installed. No drama. Very quiet. Pretty (I guess) for a dishwasher. First load...dishes came out clean and dry. That's all I ask for.
Talking to the installers (by the way, it took two of them), I guess there really is a shortage of appliances because of the inability to get parts to make them. This is been an ongoing issue for over 12 months, according to him. It's starting to ease a bit now, but he said they don't expect to see inventory levels get to normal levels until late Spring, early Summer.
https://www.dgmotoroilsettlement.com/?utm_source=basis&utm_medium=banner&utm_campaign=Dgoil
