1246424652467246924703236
    edited August 2021
    @andres3 said:
    "Notwithstanding the many studies over the years, in testimony before the Ohio Senate Highways and Transportation Committee on June 10, 2003, Julie Cirillo, Former Assistant Administrator and Chief Safety Officer for the Federal Motor Carrier Safety Administration (FMCSA), testified that "up to the present time there has been no evidence to alter Solomon’s original finding that variance from the mean operating speed is a major contributor to accidents"
    Seems to me it would serve you to read all the research and know when to throw out the "Australian" junk and propaganda like Julie Cirillo did.
    You of course do realize that variance both above and below the mean operating speed is a major contributor to accidents? Variance is deviation from the mean. You can be either faster or slower than the mean.
    It seems that you pick and choose what you want to believe based on the parts that you agree with and then just ignore the rest.
    I wish you many opportunities to see flashing red and blue lights in your rear view mirrors. I wish you many opportunities to plead your case about Solomon curves to traffic court judges :)
  • xwesxxwesx Member Posts: 18,066
    I said, Is that the same dishwasher? 'Yes".
    Does the door still make the same squeaking noise when you open and close it? "Yes".
    My son in law has tried to fix it multiple times.
    Me, buy a new one and put in on a credit card so I can pay the bill.
    It makes no sense to get a new kitchen but keep the worst thing about it.
    This house we're in here in Ohio has the squeakiest doors I've ever experienced. They are eerie, they creak so much! My son picked up some graphite spray to quiet them, which worked for about 12 hours or so, but they regained most of their noise quickly. I decided to buy a small bottle of bicycle chain/gear lubricant, as I was very impressed with how well it worked on my old bicycle at home. I just received the bottle yesterday, and I immediately went around to all the doors (interior and exterior) and added a tiny dab of the stuff.
    Silence. Blessed silence. I don't know how long it will last, but it's been more than 12 hours now. And, I have nearly a whole bottle left to add more as often as needed. :D
  • kyfdxkyfdx Moderator Posts: 273,094
    Question for Porsche mavens:
    If an early Cayman had 100K miles on the odometer, would you worry about the IMS issue?
    https://www.porscheofkingsautomall.com/used/Porsche/2007-Porsche-Cayman-for-sale-cincinnati-f8bdf80b0a0e09a9650e4014636d0eb6.htm
  • oldfarmer50oldfarmer50 Member Posts: 24,684
    edited August 2021
    Wouldn’t you assume the engine had been replaced by that mileage? From what I hear they don’t last that long. The price you pay for a high performance, highly stressed motor?
    I just finished working with my wife to change the oil and air filters in her Crosstrek. I added a Fumoto oil valve on it to facilitate future oil changes (should any be necessary under my ownership), which hopefully will make it far less messy since the under-engine plastic shield seems to be better at catching the oil as is supposed to drain versus anything actually useful. The Fumoto will eliminate that issue.
    Manufacturers seem to be getting better at their cabin air filter designs. The job on this car was the easiest yet: No screws, no difficult angles, no contortionist acts! Just drop the glove box open, reach behind, easily remove a plastic cover, and slide the filters out then in. Simple. All told, the work was well under an hour for all that and some convex mirrors for good measure.
  • Sandman6472Sandman6472 Member Posts: 7,346
    Golf going in Thursday for new spark plugs so we'll see what happens. Will have him check the brake fluid to see if a change is also needed. With the current chip situation and the probable delay of the Corolla Cross actually coming to market here in the USA, looking like the Golf will be staying a bit longer in the stable which isn't a big deal. The amount of driving I do is so small now, it'll take another year to get to 70K. And since I'm not an early adopter, getting the Cross in it's second year won't be an issue. And in the event that it's a bit too big for the garage, hoping the CH-R will be getting a refresh as that could be the winner though I'd rather it not be. Luckily my tires are all still in great shape and no leaks as of now. I still like it so maybe the best course is to just keep it another year and then revisit the situation and go from there. Hopefully the chip situation will be over with and there will be plenty of inventory.
  • jmonroe1jmonroe1 Member Posts: 9,903
    I presume you mounted those convex mirrors low enough to see if your newly installed Fumoto oil valve isn’t leaking. :s
  • sdasda Member Posts: 7,767
    Cheeky
    Base Cayman is 245 HP. I don't think it's highly stressed... lol
    Porsches aren't Ferraris. Not really known for needing new engines. ;)
  • tjc78tjc78 Member Posts: 17,595
    Lol I can’t even imagine my wife taking the car for an oil change at the mechanic let alone working on an oil change !!
    For the longest time Mrs. j didn’t even know cars required oil.
    Ha! I just say it needs service so my wife may not know what that entails!
  • ab348ab348 Member Posts: 20,774
    At least until the IMS fails.
  • fintailfintail Member Posts: 58,919
    Acura needs to bring back names for cars. Integra, Legend, Vigor - to me anyway, these have more equity than generic alphabet soup.
    Agreed
  • tifightertifighter Member Posts: 3,869
    edited August 2021
    You'll get varying opinions. The 07 has the bigger IMS bearing - it's more robust, but not replaceable like the earlier ones. For that money (I know the market is hot), I don't love the risk/reward quotient, personally.
    EDIT - I'm seeing BaT results that look better than that deal.
    LOL Of course! What else would I use them for? :D
    Also installed the hitch receiver and flat-4 wiring.
  • stickguystickguy Member Posts: 54,407
    I think my wife knows that when the wrench icon comes on with a “Service due” alert, it needs to go to the dealer. Who could tell her anything and she would have no clue.
    City parking garages suck. The RDX barely fit on the ramps and tight turns. I couldn’t imagine a car like a Tahoe not getting stuck.
    If I did this on any regular basis would have something like a Fit for in town duties
    Really got the wife on board with the plan to get the house listed and move. Which will involve getting rid of a ton of stuff. And much shopping for new stuff.
    A small truck of some sort is sounding like a perfect idea now for a 2nd car. Hopefully can make that work by year end. Though soon would be good if we try to fast(er) track the process of disposal.
    Are you keeping the Crosstrek? I thought it was for temporary use.
    My 175k mile used one drove fine. Original clutch.
    Edmunds boss just got a Santa Fe!
    The way my wife tells it, we're taking it to Alaska. Beyond that, I couldn't say. :(
    Do it! I can’t be the only sicko around here to do it twice during this madness!
    I’m happy to. Just need to find a deal that isn’t absurd, and something actually available. Should have ordered a Maverick last month. I think they are sold out until January at this point!
    Oh wait, you mean the house? Yeah, that is stressful right now. Probably better to sell since wife worries about all the junk. Right now it won’t matter. Buying, another story. I’m actually happy to rent temporarily, but those are apparently had to find too. No easy answers,
  • corvettecorvette Member Posts: 11,795
    Or catching fire. Can’t remember whether I posted or not, but I passed by a newer Silverado with its engine bay ablaze on an interstate in Illinois yesterday. Looked like the occupants got out safely and were observing from a distance.
    A full size pickup is worse than a Tahoe—ask me how I know. :o Hence the Prius for those situations. Also, the Tundra is averaging about 14 MPG on my road trip, regardless of whether I’m running regular fuel or a blend of corn juice. It only gets the rated 17 MPG highway if you keep it below 75 on the interstate.
  • MichaellMichaell Moderator Posts: 269,401
    Uh, wrong state.
    Santa Cruz!
    Flew to CA this morning to surprise my son and DIL at their baby shower. I am gobsmacked at how bad the traffic in and around LA is, even on a Saturday.
    I’m driving my moms ‘03 Sonata, and I’ve got to tell you, it runs great. Mostly highway miles today, then a trip from Oxnard to SD tomorrow night. Will cross 43,000 miles tomorrow, and the work my sister has done to it in the past couple of years has served it well. Helps to get driven more regularly, too. Got new tires on it a few weeks ago - the Michelin’s that were on it were 10 years old.
    I’ll post a pic of it tomorrow.
    I’ve read that while the values are staying strong and will even continue to go up a bit, inventory is growing slightly and bidding wars are calming.
    I’m sure that is still market dependent.
    Lumber prices are also falling so that should help new home builds.
  • benjaminhbenjaminh Member Posts: 6,844
    Why not just order a Maverick now and get it in January? Do you need something before then? And why the urgency about moving out of your house? Is there something you don't like about it?
    It sounds like she likes the Crosstek, not a bad thing. However, to be diplomatic or sort of, you’ve been told, sir.
    Michael, cash in your return flight ticket and drive the sonata home instead!
    Well, it would come in handy sooner. But can’t make something appear that doesn’t exist.
    The house, would be to cash in on the crazy market if it still exists. Grab the cash and take whatever time needed to find a replacement. Either order a new build for delivery next spring, or jump on a resale. Resales, much easier if local and not contingent. New build, there for builder meetings and keeping eye on it, but mostly cost certainty. No worries that next spring value is down and we get caught short $ wise.
    Also don’t have to worry about something expensive breaking!
    Are you driving it home?
    edited August 2021
    It sounds like she likes the Crosstrek, not a bad thing. However, to be diplomatic or sort of, you’ve been told, sir.
    Hahah; that I have!
    I told her that I don't mind her keeping it. She is torn between not having the expense and not having the car.... Tough choices in this life.
    edited August 2021
    Of course the problem with selling a house now to take advantage of the crazy market is that you are then thrust into that same crazy market since you need a new place to live. This happened to the neighbors across the street from me. They put their house on the market last month and ended up accepting an offer that was $120K over asking. But now they are realizing that any place they like is even more money. No luck with new builds either as their prices are equally crazy due to both the spike in building material pricing and overall demand. I occasionally watch a video from a couple that live in The Villages down in Florida and they were speaking of this recently. New build prices there are up well over $100K from earlier in the year, and few are available.
    This time last year a house 3 doors up from me went on the market due to a divorce. We were all astounded when it sold for $60K over asking. But that seems like a bargain now. The guy who bought it was moving here from Ontario and was unable to do so due to Covid lockdowns and the like, so it has sat empty until now. This week a 53' United Van Lines truck appeared and delivered all his household goods, though I'm not sure he is actually here yet. Still, given the way prices have gone and how he likely made out with the more recent sale of his property in Ontario, he probably made out like a bandit, even with carrying the place here for a year.
    Two houses up for sale around the corner and doubt they'll sit long. School starts Wednesday so if they're asking a decent price, sure they'll sell within a short period of time. Would love to put ours up but where to go and since we've always bought new construction, doubt that will change. Hopefully when the whole family gets together in October in Orlando for the kids delayed wedding party, some long range plans can be discussed. Think we'd head up to Central Florida if our middle child agrees to transfer. If she wants to buy in Miami, we ain't leaving South Florida. And since we've been here 34 years, we have accumulated a whole lot of "stuff", Stick can understand this! They'd have to come home to help us discard of stuff they no longer want. My siblings threw out my stuff without asking and I'm still a bit miffed to this day as I would've liked to have made that decision. I want to give them the chance to keep whatever they'd like and pitch the rest. Also, we could use the help as I'm just unable to do all that work.
    Uh, wrong state.
    Santa Cruz!
    Duh... Santa Fe wouldn't be worth mentioning, huh? :(
    @stickguy @oldfarmer50
    I don’t need the Sonata as a 3rd vehicle at the house, and I don’t have the time to drive it the 1100 miles back to Colorado.
    I still have first dibs on it, should I change my mind, however.
    The only thing it really needs is a double DIN head unit with CarPlay compatibility.
    edited August 2021
    When my grandma's place sold ~4 months ago with a bid about 100K over list, we were a little astounded. Today, the listing site estimates are all about 10% higher than that bid. It has to end sometime, although at least in most of the PNW anyway, I don't foresee a bubble pop (barring a financial cataclysm far beyond 2008), rather, just a slowing of growth rates. Even a 10% retraction would still set prices back less than a year. Here in Spokane, virtually everything has doubled in 5 years, and many have tripled in 10. Everyone still wants to live in this region.
    Big issue here is barely-regulated house-hoarding institutions looking to build an empire for what some see are coming times of new age serfdom, and parasitic flippers competing with regular buyers in the lower end of the market. Now that I am confident about my job here (didn't want to buy if things weren't going to be a good fit), I am entering the market, and know it is going to be a fight, with non-owner occupant buyerss being a sick problem.
    Stickguy’s problem is that he wants to relocate into a trendy location like Saratoga Springs where he’s competing with the horsey crowd who think nothing of paying $500k for a condo that looks like it was made out of shipping containers. If he’d consider going 20 miles in any direction he’d find the real upstate NY where houses are half the price and people are selling cheap to escape the taxes.
    Why not take it and sell it in your local area. I know a rust free CA car would command big bucks near me, especially in this market.
    My sister is using it regularly, so it still have some value to the family.
    Why not just give it to sis then? All this time you were just leading us on that we’d see it in your driveway! :@
  • carnaughtcarnaught Member Posts: 3,608
    @marcogallo1986, welcome back friend. So good to hear from you.
