1250925102512251425153236
  • xwesxxwesx Member Posts: 17,879
    I don't even have line of sight to a replacement...
    Oh, I thought you had another forksy on the way. I must have mixed up my posts; there were hundreds just in the time it took me to drive home from Oregon.
  • au1994au1994 Member Posts: 3,760
    edited October 2021
    The offer on the Outback is now up to $35,400. This is getting downright silly.
    If only you had a spare car laying around. Oh wait :open_mouth:
    And yes, its just silly. The X1 (46k, not xDrive) is up over $25k but like you, nothing out there to replace it with. Dealer has 1 X4 30i thats black over red for $55k. Price tells you its decently equipped but far from loaded and I’m not a fan of that color combo. White over red, I wouldn’t mind. Going the other direction, they have 1 440i convertible for $71k. Gulp.
  • kyfdxkyfdx Moderator Posts: 270,324
    2018 GTI
    Bought 02/20 with 13,800 miles
    Currently (20 months later) with 23,500 miles
    Offer from Carvana: $2000 more than I paid for it.
    2018 GTI
    Vroom is $3800 higher than Carvana: $5800 over what I paid for it.
    My grandmother (103 years old and still living independently btw) has an 89 Olds 98. Wonder what I could get for that?
  • sdasda Member Posts: 7,706
    2018 GTI
    Wow that would be tempting…only if a viable replacement was available.
    Ay... there's the rub..
  • 28firefighter28firefighter Member Posts: 9,906
    Should try CarMax. Crazy money.
    Carmax is just $500 under Vroom. There is a location about 30 minutes from me.
  • oldfarmer50oldfarmer50 Member Posts: 24,499
    I guess I’ve decided to not be in the car buying market for the foreseeable future. Prices are just too crazy. As things get worse I’m glad I made my last purchase in June of 2020 just before things got crazy.
    I want to replace my old cargo van but pick up trucks are out of this world. I’m looking to scoop up a pristine 2005 Ranger that is owned by a guy I know. It has a little over 50k miles. He’s looking to replace it with something he can take to Florida. I just hope he doesn’t change his mind because there’s nothing else out there that isn’t worn out junk or priced in the stratosphere.
  • ab348ab348 Member Posts: 20,568
    Take a good look underneath that Ranger. Their rear frame rails are notorious for rotting in the salt belt.
  • stickguystickguy Member Posts: 54,001
    At this point, get an absolutely base Maverick XL for 21.5. Better than crazy money for a beat up, high miles ranger or Colorado
  • andres3andres3 Member Posts: 14,126
    edited October 2021
    breld said:
    I'm sure you all remember the faceplates that could be removed to discourage theft. What a funny period...carrying a car stereo faceplate in your back pocket whilst walking around the mall.
    Later models had a "flip faceplate" where it looks like a removable face plate when it's backwards facing. Neat trick and does the job. The other trick is to bolt the back of the radio to the car frame so when a thief tries to pull it out they are thwarted.
    Kenwood and Pioneeer made the best built-in amps in their head units; pretty much as good as the cheaper separates out there.
    edited October 2021
    Leaf spring shackles too but this thing doesn’t have a spot of rust. It’s got two out of three things I look for: no rust, low milage and….I hope cheap. I doubt the third characteristic is possible these days but if I can get a low milage rust free truck I’ll be happy paying market value.
    Similar to this.
  • corvettecorvette Member Posts: 11,596
    I installed one of those with a motorized faceplate in my 1999.5 Jetta--I think it was a Kenwood--replacing the factory cassette head unit and the (Panasonic, I think) 8-disc changer I had installed with an adapter to interface using the buttons on the factory head unit. The adapter never worked 100% correctly, and I wanted the capability to burn a bunch of MP3 files to a data CD and have the head unit play them, which the Kenwood provided. Now, many new cars don't have an optical disc drive at all.
    don't be so sure unless you have been underneath it. Sarah N tuned recently inherited a 94ish Ranger out of New Hampshire. Actually looked just about perfect body wise. Good pain, no rust. But once she got to inspect the underneath, the frame had issues. Was going to IIRC pull the body and clean/restore the frame but it wasn't really in decent enough condition. Ended up finding a southern truck in the junkyard and is doing a frame swap to that one's frame.
    What Stick says is true. My brother owned 2 Rangers, and #2, a 2008, was perfect underneath in terms of the cab and box. But the frame rails around the rear springs and axle were Swiss cheese. He learned that a quick eyeball check was to look at whether the spare tire which mounts to the rear end of the frame under everything was still there. In trucks with frame rust they were all either hanging precariously or carried in the bed.
    Yeah, I saw that but her grandma’s truck was 11 years older. In reality you never know what you’ll find on an old used car but the owner of this particular truck goes to Florida every winter and either takes it down there or parks it in a garage up here. It sure doesn’t look like it’s seen a lot of salt.
    Anyway, I’ll have plenty of time to think about it as he’s not planning on selling until the spring. I’ve had good luck buying from older people they tend to take care of their stuff.
    Our recent model VW's and Audi's have relegated a CD player to the glove box; it's almost like putting the cup holder in the glovebox.
    Don't bring your chronic car buying vehicles to the Golden State of CA:
    https://calmatters.org/commentary/2021/10/will-speed-traps-return-to-california/
    That ticks me off just reading the article. Good perspective.
  • jmonroe1jmonroe1 Member Posts: 9,631
    I can vouch for that. I have an older toothbrush that I wash religiously twice a day. :o
    What is on the short (or long) list? Isn’t the lease up fairly soon?
    edited October 2021
    It’s up in June. So not soon soon but not far out. Close enough that I’d flip it now if it made sense.
    Top of the list is a Grand Cherokee 4xE. Tesla is there too, but I suspect the Jeep to be a much better value.
    Is a buy out at lease end being considered, especially since your wife likes it so much?
    Not really. She recognizes that for our purposes leasing makes more sense and therefore would prefer to get into something electric or PHEV.
    Also while the Outback is a good buy now at residual, once the market normalizes, it won’t be such a good used buy. At least that’s my take.
    In this market, buying out a lease has to be the better choice even if you hate the car. It’s the last place where the buyer can still win.
    Here’s today’s facepalm moment: I bought a floor jack and jack stands to rotate the tires on the Prius (they need a non-standard rotation pattern to wear optimally going forward, as somehow the left two tires have the most tread). Apparently if you don’t use an adapter on the designated lifting point along the pinch weld, this happens:
    Needless to say, I did not rotate the tires and ended up returning the jack and jack stands.
    The only silver lining is that I discovered three of the wheels were insanely overtorqued, such that I would not have been able to put the spare on in those positions using the tools in the trunk. The only one that was torqued correctly was the one Discount Tire repaired a few weeks ago. They’re now all torqued to 80 ft-lbs.
    I have it on good authority that the ZHP is at home in all weather conditions. 😉
    Yes. But why drive that in cold rain when I have the Jeep?
    Ouch! I hope that’s just a piece of trim that can be put back into place. I know you’ve gone all out fixing up that car. Who would design a car like that?
    Nope, that's the fender. Supposedly you can sometimes bend things back into place. The one on the passenger side is slightly out of alignment, as well, so I'm guessing I'm not the first one... This seems to be a common issue on unibody cars, I know my great aunt's Park Avenue had a similar issue, and 100percentjake on YouTube did, as well.
    Perhaps take a rubber mallet and gently tap it back in place?
    the E46 and contemporary model 5 series were both incredible cars. Mostly neglected now sadly, but timeless designs.
    that one is gorgeous too.
    Speaking of BMW, was out with the wife today and got behind a new X7 in a medium blue, and she made an unsolicited comment that "BMW has really nice blues". She does like blue cars. I resisted the temptation to tell her that I wanted an X3 when she picked the new RDX, which for some reason, that year did not come in blue.
    edited October 2021
    Well, that whole episode has made me want a pair of Quick Jacks (which aren't worth it given how little I'd use them) or an actual lift (same, plus I don't have room for it).
    I tried to tell the Prius I was sorry by giving it a hand wash and putting a second coat of Zaino on it.
  • MichaellMichaell Moderator Posts: 267,147
    Interesting discussions in the last 24 hours.
    Daughter has opined that she should sell her MINI, given that the prices are so favorable. I checked with Carvana, and they are offering over $11K for her car (2014 Countryman S ALL4 with roughly 51,000 miles).
    But, what to do as a replacement? She really wants a custom order Countryman SE (PHEV) - the local dealer is suggesting it would take 4-5 months to get one in.
    Unlike @breld, I'm not planning on buying a Tesla as an "interim" vehicle, and the household still needs a 2nd car.
    Aha!
    I know where there is an extra car in the family, that I could "borrow" for a short period. Yes, I'd have to fly to CA and drive it back to CO, but it would work splendidly as an extra car, while the girls use the Outback on a daily basis.
    When the new MINI comes in, we can pick it up and I'll drive the Sonata back to CA and give it back to my sister and her family.
    And, we're thinking we'll run the new MINI purchase through the LLC, to help with taxes.
    edited October 2021
    sounds like a lot of effort for a few months, but a lot cheaper than buying a used car!
    If they don't need it for the next 5 months, why does it have to go back?
    I wouldn't mind having a free car laying around that I could take. Sadly there are none in the family.
    but in your case, if you can get the purchase order locked in at MSRP, might as well take the inflated price on it (heck, maybe sell it private for more?) and bank the money until the new one comes in.
    edited October 2021
    Aha!
    If you had listened to me that Sonata would be sitting in your driveway right now. :( I have to say though, that’s a brilliant idea considering the car shortage.
    I wouldn’t give it back. Wasn’t it supposed to be yours anyway?
    Or, he could try jacking it back into place.
    edited October 2021
    More labor than money.
    Flight to CA (I’ve got points)
    3-4 tanks of gas
    Couple of nights in a hotel
    Food for the drive
    Reverse the order upon return.
    We don’t need a third car at the house.
    Just need to determine if my sister can do without it for a few months.
    Doesn’t seem all that great for a car with only 51k, no? What was that? About $40k new? That’s almost 57 cents/mi depreciation. I would think it should have a long life ahead of it.
    took longer than I expected, but got an Email from Ford last night. They delayed my Maverick build date. But, only by 1 week. From week of 10/25 to week of 11/1. Remains to be seen if this is the last adjustment.
    Considering the prices I've seen on other low mileage cars, that didn't seem great to me, either. Maybe, MINIs just aren't holding their value all that well?
    @Michaell Try Carmax. They are $3300 higher than Carvana on the GTI.
    I think it stickered for something like $38k, but I get your point.
