If they doubled the speed of the video it would still feel slow!
I wonder if a slightly quicker axle would have helped, to some degree. Mopar was still using its 225 slant six in 1983, in the Cordoba/Mirada, the Gran Fury/Diplomat, and, embarrassingly, the New Yorker 5th Avenue! It had a long stroke, something like 4.125" and tended to be known more for its low end torque than its desire to rev. Yet, they used a 2.94:1 with those cars.
Or, could they have just changed the shift points in the transmission, even? My '79 5th Ave will hold first until around 55 mph if I floor it from a standstill. Its gearing is even taller, using a 2.45:1 axle, but I dunno if that's really considered a huge difference. It's also a lot torquier though, so that might be part of why it can do that. So maybe with the 200-6, that's really all they could hope for from it?
Looking at the video, looks like it does 0-25 in about 5 seconds, 0-40 in about 12, and 0-60 in about 26-27? I tried counting it off in my head, and had come up with 0-40 in about 10, and 0-60 in about 22, but then went back and re-watched, and kept track of the time at the bottom, and realized I was being generous!
Back in college, one of my friends had a 1980 Accord hatchback. Automatic, and a/c, although the a/c didn't work. Figured I should mention it though because it still added weight, and if it was still connected, a bit of drag I guess. One day, with three of us on board, he stomped it and I timed it from 0-60 with a stopwatch, and it took about 26-27 seconds. While that's equally horrible, I'll cut the Accord some slack, because there were three of us on board. And that Accord, surprisingly, was a pretty good highway cruiser. Seemed to have no trouble maintaining 75-80 on the highway. That LTD in comparison seems like it would have trouble getting that high.
Was the big improvement with the LTD/Marquis mainly in the engine department, or was handling improved, as well? For instance, if you compared an '83 LTD to an '81-82 Granada, but both had the same 200 inline-6, would the LTD have been that much better of a car?
The 232 V6 started working its way into the Granada for '82, and was carried over to the LTD for '83. These earlier versions had 110-112 hp. I'm sure they weren't as good as the fuel-injected 232, which was putting out 119 hp by 1985, but they were probably a big jump over that 200 inline.
My 1985 Consumer Guide has a test of an '85 LTD, with the 232. They got 0-60 in 11.9 seconds. It stacked up fairly well to the Celebrity with the 2.8 2bbl V6 they tested (11.8 seconds) and even the Century Limited with the fuel-injected 125 hp 3.8 (11.5 seconds). They rated it as a "Best Buy", something the Celebrity and Century didn't get.
They summed up with "The midsized LTD is a pleasant car that does an excellent job of disguising its humble Fairmont origins. The suspension is supple, the V6 responsive, and the accommodations are comfortable.
Their main gripes were fuel economy (2 out of a possible 5), instruments/controls (2/5), and engine serviceability (2/5). For factors that I'd think are important, ride and handling, both were given a middling 3/5. However, the Century and Celebrity also scored 3/5 for ride and handling, so I guess that's about what you'd expect for this type of car.
I do remember my grandparents' '85 LTD overheating when it was about two years old. They traded it in the fall of '88 for an '89 Taurus LX, so they didn't keep it long enough for it to develop any serious, expensive issues. The '89 Taurus LX did have that same design V6, just mounted transverse and now with 140 hp, but they traded it in the fall of '93, on a '94 Taurus GL, which had the 3.0 Vulcan. So again, they didn't keep it long term, or to high miles. I do remember Granddad saying that it started stalling out every once in awhile. And Grandmom was getting pretty sick by that time and had to go to the doctor fairly often, so he wanted something that would be reliable.
The 3.0 Vulcan was supposed to be a good, durable engine, if not exactly a powerhouse. However, I remember that Taurus tended to smell like coolant fairly frequently, in later years so I'm guessing it did develop a slight leak. It just never got driven enough, I'm guessing, for it to ever amount to anything serious. It only had about 40,000 miles on it by the time it was 10 years old, and that's when Granddad decided to give up driving. He offered to give it to me, but I didn't really need it. Instead, it went to one of my cousins, and he and his wife drove it until around 2009 or 2010. I forget what finally did it in, but they didn't take very good care of it. I think they got it to around 80,000 miles or so. I'm thinking the engine was still okay, but there were other issues. Plus it had gotten into a few minor accidents here and there.
I wonder why Ford didn't just lop two cylinders off the 302 to come up with a V6, like what GM did (and Chrysler finally got around to doing)?
Out of all the Taurus problems, the heater core is one I didn’t have.
One universal truth on the 92-95 Taurus models is the 3.0 was much more reliable than the 3.8.
92-95 didn’t have the 3.0 DOHC did they?
89-91 SHO 3.0. 92-95 SHO(actually 3.0 and 3.2).
AMC 1
Chrysler 2
Ford 3
GM 14 with the most recent being a 2008
Ford- 2
GM-3
Chrysler(Jeep)- 1
AMC -2.
Chrysler - 3
GM - 2 (said nova and Opel Manta)
Ford - 2 (Contour and Mystique)
And a whole slew of imports!
And quite possible I missed a domestic in there.
Jeep (1)
I think that's it... Last one was purchased in 1980.
Isn't your Jeep a '75? It was owned by AMC at that time.
Ford is definitely #1 in my domestic list. I think I've had five, including my first vehicle, which I still have.
GM and Chrysler are each one, and... that's it. (The GM was my second vehicle, and I still have that one, too!)
10 GM
11 Mopar
One of these days I need to try something new
Total of 24 cars. I’ve bought 15 new Chevrolets since 1981 plus three two-year old Chevys. I bought one Chrysler and four Studebakers in that time. I will say I used to travel with work almost constantly so I’ve driven most makes and models as rentals.
I’m a consummate cheapskate. Still, I’ve only bought four new cars that were in the local dealer’s inventory (ordered one and did dealer trades for all remaining others) so I was specific about colors and options and always sought cars that I had pride of ownership in. Always kept them nice. Perhaps I’ve been lucky but I never once have bought an extended warranty.
GM - 5
2 vehicles in the 80's
12 in the 90's
5 in the '00s
2 in the '10s (The Ram in 2012 and inherited the Regal in 2017)
Maybe I need to pick up the slack!
Bought five in the eighties
Bought four in the nineties
Bought four in the 2000’s
Bought eleven in the 2010’s
Wow, how could I forget the SHO. Shame on me.
AMC - 0
Chrysler - 0
Ford - 5
GM - 5
I was given my parents’ old ‘77 Impala coupe in 1980 as a college graduation gift when they bought their new Monte Carlo so I guess I’ve had 25. Pretty sure the title didn’t transfer to me until I bought my new ‘81 Monte Carlo.
GM/ Other (AMC, Ford, Chrysler)
Years 77-79 2 / 1
1980s 5 / 2
1990s 1 / 3
2000s 6
Is that right?! Doesn't seem like enough. If correct, that's not bad. I still own a third of all the cars I have ever owned, and two of those buys weren't really keepers since one, a '73 F250, was a donor for my '76 F250, and the other, a 2008 Focus, I only had a few weeks while I did some reconditioning, then I gifted it to a friend. I didn't bother putting either one in my name.
Lemko and I have both joked, from time to time, that one of us should get a Ford product, just so we would have something we could put in the Ford show at Carlisle! He used to have a Grand Marquis, a 2006 I believe, but that's been gone for awhile now. I have a friend who went through two Mark V Diamond Jubilees, but he sold the last one a few years ago, so now, among my group of local car friends, we are now, alas, Ford-less.
I bought three Studebakers in the 2010’s and bought five used cars for my kids in the 2010’s. I only have two kids but both of them were involved in total accidents which resulted in me in buying two replacement cars.
3 (80s)
7 (90s)
6 (00s)
10 (10s)
1 (20s)
Got it mixed up, you had a 75 BMW(?). My bad.
garagewarehouse.If you are going Panther… my list
88-89 Town Car (Sig or Cartier)
82-83 Mark VI Signature or Designer series (2DR)
86-87 MGM 2DR
95-97 Town Car
04 Marauder
If you are going barge -
78 Mark V DJE
77 Continental Coupe or Sedan with the 460 (waterfall grill and Lincoln exclusive dash)
79 Continental Collectors Series Sedan or Mark V CS
90s: 1
00s: 3
10s: 4
All the same brand
A guy on the Panther forum has a Conti Diesel. It was featured on one of the YouTube channels. Interesting car.
It probably helps that it is just you and you've generally lived life in the "big city," but I wouldn't mind having owned that few cars.
