Visitor Agreement.
The 2 cycle is a Lawn Boy I brought in 1985. It's been sitting since 2009, long story. Was self propel but the trans is broken.
One of the 4 cycles is a John Deere I bought in 2009. Terrible mower, deck is floppy so it looses the cutting height and scalps the lawn when it does. Still runs, though.
Electric is from 2015 and still uses original batteries, only use it on part of the lawn.
Newest is a 2016 Honda used on the part of the lawn I don't use battery mower on.
You might want to make sure your Malibu is well protected.
Her 2007 Kia Optima will be detailed (by me) and be put up for sale private party or given to my son's girlfriend. The check engine light's been on for 5 or 6 years. Had it checked out. Gremlins or something. No big deal. Exterior is a bit rough. Clear coat is flaking off hood. Thought if I could get a hold of another hood, from the junk yard for a couple hundred, would be a good investment. Would make for another good whooptie in oldfarmers fleet. :-)
In NY a CEL would make it flunk inspection.
⁰ @oldfarmer50 said:
⁰⁰0⁰]
Thanks for the video. Thought about repairing the clear coat. But the more I thought about it, the more my head started to hurt . Would pretty much have to sand, paint (bright blue) and clear coat the whole hood. Would probably need to cut out a few steps for this beater.
On my baseball field the outfield is about 3 acres counting the sidelines and I mow it at least twice a week. The infield I mow three times a week. Of course, that is through the main growing season. Later in the year I might only mow each once a week.
I have a John Deere X730 (54" cut) as well as a smaller Cub Cadet tractor LX46 (46" cut).
I don't know how big my lawn at the house is but there have been times I have taken the smaller tractor home to do it.
I cut 2.5 acres every 7-10 days. I use a Cub Cadet Enforcer 54” and a Dixon 5424 42”. Both are commercial grade so I hope to never have to replace them.
I also have an EGO push mower and a Kobalt string trimmer. Everything else is Stihl commercial gas equipment- 2 chain saws, a backpack blower and a hedge trimmer.
On that clear coat fix, that looks like a lot of work. Basically, you are repainting the car. I remember back in 1966 helping a friend paint a 1953 Plymouth. We did it with paint brushes, outside under a shade tree. It actually came out half decent.
and if I get anything electric I want to get the whole shebang so I can just swap batteries around.
how do the mowers work? Same battery as say the weedwhacker, or do you need bigger one for that? Would be nice if you could just put 2 in the mower vs. 1 in the smaller equipment!
just had to drive around a few days then take it back and it sailed right through.
I have used the smaller battery from the string trimmer in the bigger leaf blower. It lasts long enough to do most jobs. And I have used the bigger battery in the string trimmer. That makes it heavier, and out of balance, but it will run forever.
I have 2 of the 2.5 AH batteries, used mostly on the string trimmer. Each battery runs about 40 minutes. In addition, I have 2 of the 5 AH batteries, which came with the chain saw and the leaf blower. I have, on a few occasions, ran down both batteries for the string trimmer, and used one of the big batteries.
The leaf blower is used regularly, I not only use it to clean off the driveway and sidewalk after mowing, I use it to blow grass and debris off the riding mower, and sometimes to dry my cars after washing them. The chain saw is used infrequently. It's handy to have when you really need it, but that doesn't come up very often around here.
All of my power tools(drills, impact wrench, etc.) are Makita.
I may eventually go with an electric ZTR, but I can afford to wait until they have significantly more range.
I want a battery midsized chain saw. I don’t really want or need a full sized one. And it might sit for years which wreaks havoc with gas powered ones. Battery one should be able to sit forever sans electron pack and be just fine.
An electric ZTR, well, yeah, not yet. That one is kind of like the fully electric car. I'm just not ready to go there, at least not yet.
I won’t buy self propelled. Esidcislky because my lawn is flat!
Oh yeah, if I end up back in snow country will likely get a battery powered snow blower too. That likely needs a big one.
Narrator, no concern showed for anyone who might have been hurt or injured.
I like the idea, have lots in common, can do things with neighbor friends....that is one thing I like about our Florida community.
I just thought I would throw that in as a counterpoint to the talk about blizzards.... (ducking and running for cover)
At this time of year we don't have to run the AC to cool the house at night.
Here is a picture of the left side of the same accident.
Speaking of all the lawn gear, this weekend I am going to buy a suite of Ryobi 18V/40V implements - mower, weedeater, hedge trimmer, maybe a leaf blower or pressure washer too. I already have a couple 18V batteries from my Ryobi orbital buffer, so I will just get one or two 40V batteries with tools and buy the others tool only. I don't have a huge yard (~7500 sq ft, much of it rock), so it should be more than sufficient.
this mayhem. May God rest their souls. That one semi that crashed into the
rear of the other semi early in the first video surely was a fatality...
It goes to Cincinnati for processing instead of Fresno or Tx.
My Ohio tax was filed on Ohio's online free site--since TT wanted to
charge me $25 extra for the privilege even though I purchased the
Federal and State version, but it doesn't include efiling the State.
TT likely err'd on the penalty for underpayment since they never asked
me if I had tax withheld for 2021 equal to what I owed in 2020.
I had to whiteout the penalty estimate and change my total due.
If the IRS finds I owe a penalty, they bill me at no charge.
BTW @driver100
"Taxes" is a 5-letter word.
He said he was stopping recording to see if he could help out anyone.
The story we got was that the renter was at a party that got out of hand.
We also had a car that was rented at another location, never returned, was reported stolen and was then dumped days later at the airport. The culprit tried to flee but was detained to at least pay for the additional use.
My favorite was the Audi Q3 that came back covered in mud with the bumper and fender smashed. The renter inquired if it was too late to purchase collision insurance.
Out of hand? Is that a bullet hole in the door? May want to check the trunk for a dead body.
Hello everyone. I am back after a five month haitus. Haven't read much except for page #2776.
Meanwhile my daughter has purchased a Tesla Model Y which will be delivered in June or July or maybe later this year. I
Yeah, that’s a bullet hole. I had to drive that to the repair facility and had to sit carefully since the window was also blown out and spread over the seats. No bodies that I know of.
You must not go to the right parties.
