1292429252927292929303236
  • au1994au1994 Member Posts: 3,773
    My wife wants an EV. In all reality it’s perfect for her. Longest she will ever drive is 70 miles to the shore.
    Only issue I have is, at home installing a 220V charger is a two beer job (DIY). At the shore it’s going cost some bucks as the panel is upstairs and they would need to fish the line down to the garage. Certainly not impossible…but a job. It would also need conduit ran down the block walls.
    2 beer job sounds about right. I’d drink 2 while the electrician did the work. Electrical work like that scares me.
  • laurasdadalaurasdada Member Posts: 5,285
    My company was an early-ish adaptor of installing chargers at the office. First a couple in the garage, that expanded. Then adding more to the surface lots, all Chargepoint and only available to tenants of the office park.
    Stick, likely the answer is Taycan.
  • stickguystickguy Member Posts: 54,120
    Taycan would require some serious budget gymnastics. An Ioniq5 or IQ4 is workable if I want. A Bolt is probably more in the sweet spot!
    for chargers, that is a hire a guy job. I don't mess with electricity beyond changing light fixtures or replacing a dimmer switch or outlet. This house is not too bad. The panel is in the basement right behind the garage but still some fishing required. the last house was perfect. The panel was on the garage wall right inside the garage. Exactly where the charger was needed. so would have required about 1 foot of wire to a new outlet, and just attached the charger to the wall and plug it in. simplest possible arrangement for that.
    edited April 2023
    I had the Mustang out today to get some routine maintenance done at the dealer. Oil, coolant, replace 8 year old battery before it strands me and a few minor recalls.
    While I was waiting I took a flyer and asked if I could order a stripper F-150 2 wheel drive with an 8’ bed or was that just available for fleets. The answer was: yes I can. $36k before taxes and maybe a 6 month wait. No discussion of any discounts but no mention of any dealer mark ups either.
    At this point it’s just a random thought since it would be the most expensive vehicle I’ve ever bought. Probably a poor choice for an occasional junk hauler.
  • tifightertifighter Member Posts: 3,849
    Yes, transmission, but what a presentation on great car-
    https://bringatrailer.com/listing/1991-porsche-928-s4-7/
  • MichaellMichaell Moderator Posts: 267,632
    I had to Mustang out today to get some routine maintenance done at the dealer. Oil, coolant, replace 8 year old battery before it strands me and a few minor recalls.
    You know, back in the day people bought trucks to be used as trucks. My dad bought his '70 Chevy C-10 new and used it as it was meant to be used - hauled lumber and tools in it, brought home fresh king crab from the airport in Santa Barbara for an Elks club event, towed a bass boat with it.
    The only fun it had was when I used it for a time-speed-distance rally with a buddy of mine when I was just out of HS. By far the largest vehicle in the rally.
    I doubt you could find a used truck in the same configuration for the same price, so I say go for it....
  • ab348ab348 Member Posts: 20,620
    You’re going to spend serious dollars on most any EV you buy. A thou or two for an electrician to install the proper charger is insignificant by comparison.
    Our local utility has a program where they will install the charger for free...
    Farmer, you could probably find a 6 YO one like with with a hard 100K on it, and still pay $25k for it. so might as well get new and not deal with someone else's problem (and the likely rot underneath).
    just get the 5.0 instead of the Ecoboost. Unless they still offer the NA 3.5l V6. pokey but cheaper.
    As I am spending your money, budget is not a concern. There, I hope that helps.
    can you live with a 6' bed? I built a short cab Ranger XL. 2WD. Added the basic goodies package ($1,100) to get power mirrors and cruise, the bed utility package (about $360) since it is useful, and CP360 since I think it is important for safety. That is about $650.
    as configured, about $31,500. drop all the options and sticker is in the mid-$29s.
    did a search. as expected, zero 4x2s up here. But, a few 4x4s at this price. get the cruise, etc. package, and probably good for you, deleted the rear seat! $32,600 MSRP. though probably worth the extra to get the big boy truck if you want the size.
    https://www.windowsticker.forddirect.com/windowsticker.pdf?token=oLru2kf6gASi+Vzq6Tk1is1TpB6yzYGTGMiEgIJNxZm6DnL8ix8tbdnwgCVyee03P9R61Z+Y/1mIvYNG+7CmjJu+H/a/x1uuu0anzu51ELF6jvYqr810glsO2kGeEBliJqIdq8I/abPzd7hmFzBijpDye9ElWm2gP9dicsDAm6Y=
  • xwesxxwesx Member Posts: 17,935
    I was thinking about putting in an additional A/C unit for our 2nd floor. The air handler would reside in the attic above the garage. But, getting another 220 line over there is very problematic. I had an HVAC contractor, who is also a licensed electrician look at it. He promised an estimate. It never came, and he never returned the calls I left for him... lol
    Figured I'd wire for an eventual car charger, as well, if I had it done. But, that's never happened. Getting ready to remodel the kitchen, now. If it turns out that we have to run a new line for that (small chance), I'll probably run a couple more for the extra A/C and charger, as that's on the same side of the house (opposite the electric box).
    Yeah, I'm looking at upgrading the electric service on our place in Ohio. It has a measly 100A service at that moment, and I at least want to upgrade it to a 200A (which, apparently, is considered the minimum these days, as 300A is not at all uncommon in new residential now). My son has rewired the entire house, and, after installing everything including three mini-split heat pumps, he said it is not only possible, but likely, that there could be times we overload the main breaker.
  • tjc78tjc78 Member Posts: 17,378
    Only way an EV makes it into our household is a decent lease.
  • kyfdxkyfdx Moderator Posts: 271,002
    @xwesx Yeah, they'd never put in 100A service now.
    And, it turns out we do need a new 40A wire for an electric cooktop (old one takes 30A), so no fun.
    Cooktop is at the opposite corner from where the panel is, in the basement. (all finished ceilings, down there). Going to be pricey, plus plenty of drywall repair, afterwards...
    Will they be equally generous when it comes time to install additional power plants -- you know, those things that run in the dark when the wind isn't blowing.
    What do you think? :wink:
    We've already had a massive rate increase for natural gas, and the same utility has made an application to increase electricity rates as well, later this year...
    Do the floor joists cross or run parallel? Is there insulation there? We have been finding that running some pex through the cavities to use as a fish tape, or just running flexible conduit, is extremely helpful for minimizing the intrusions. Even rewiring the entire house, I think my son has only needed to cut three holes.
    The repair needed for running the plumbing on one of the mini-splits is probably 4x the work as all of the electrical intrusions combined. He did an amazing job with it, and it looks quite professional, to boot!
    The stripper comes with a 3.3L Duratec V6 with 280hp. No race car but still 90hp more than my cargo van which weighs more so I would be happy with that.
    edited April 2023
    Local dealer let me know they got their first M2.
    It’s bigger but somehow has less room inside.
    I’d rather not. The problem is that they don’t really build single cab vehicles any more. Otherwise a modern Ranger would be ok I guess.
    Suddenly $15k for a 12 or 13 yo old style Ranger is looking more attractive.
    I like yours better.
    Murpheys Law.
    OK, I am just going to go out on a limb here, and say that you can to any cars and coffee, anywhere, and have the only one.
    https://bringatrailer.com/listing/custom-1960-ford-step-van-2001-dodge-ram-3500/
    and one for Farmer. single cab, long bed, check. No rust southern truck, check. HP, plenty.
    you want a real old school "mans" truck, this is probably it.
    https://bringatrailer.com/listing/1985-gmc-pickup-2/
    and, discovered this today at my local dealer. Sharp! If anyone wants to put a deposit down, I would be happy to shoot down and give it a test drive for you!
    noticeably absent is the actual adjusted price they want for it.
    https://www.mohawkhonda.com/inventory/new-2023-honda-civic-type-r-type-r-fwd-4d-hatchback-jhmfl5g48px001324/
    Yeah, that was the first thing I noticed as well.
    edited April 2023
    Murpheys Law.
    Would be cheaper to just cook using the fireplace.
    Ugh. Needs a spoilerectomy.
  • jmonroe1jmonroe1 Member Posts: 9,687
    Just to be on the safe side you otta make that a 4 or 5 beer job and chased with a couple bourbons.
    No, the joists are all running across.
    We have a steel I-beam, that runs the length of the house (drywalled in). So, a couple of holes to get into the I-beam cavity, then probably 4-5 pilot holes to look for blockages, etc. (52 feet from end to end), then 90 degrees to run between the joists, and hopefully, right up through the floor, after current cabinet demo.
    Figuring 100 feet of 8 gauge, and a new 40 amp breaker. Plus labor, then someone else to repair all of the drywall... then paint.
  • fintailfintail Member Posts: 58,783
    Might be "Private Collection Motors", I wonder if it was yet another BaT flip or a consignment. What a color, the 90s knew how to do blue.
    Also heavier. I absolutely despise the IP.
    you are overthinking this. just get a 100' extension cord and plug it in, shoot it out the window and back into the kitchen, and good to go.
    edited April 2023
    Tonight I checked out the 2016 JK Rubicon I was looking at. It drove very well and the price was reasonable but I was very disappointed to find that the OEM radio/NAV system had been replaced by a very mediocre Alpine head unit- which means no voice recognition and apparently no BT either- as a lightning cable was snaked from the rear of the radio to the console.
    Rats.
    Now you’re talking. That’s a great looking car.
    really sharp. given a choice I would absolutely take that. Going to cost more of course, at least at MSRP. also looks like the seats would be way more comfortable for normal shaped people!
    The addendum sticker for the Civic is just to the left of the Monroney in the first picture.
    Can't read it though.
    Wonder if I would be able to drive it if I just dropped in?
    I know you were joking, but could an actual option be to run plastic or metal conduit out from the panel along the outside of the house and then back inside to the cooktop location in order to handle the 8GA cable?
    Edmunds long-term wrap-up of the Civic Si seemed to leave them rather disappointed:
    https://www.edmunds.com/car-news/2022-honda-civic-si-long-term-test-wrap-up.html
    That makes 2 Hondas in a row (the new Accord being the other) that were underwhelming to them.
    I haven't brought that up, yet. But, definitely something to think about. I think it would have to be buried, though. (I am definitely not an electrician)
    I'd really like to run a new 200A panel to the garage, on the opposite end of the house (in front of the laundry/kitchen). That would give me the 40A for the cooktop, plus room for a car charger, and another A/C unit. That couldn't cost more than $10K, right?
    Lot of whining in there. I lost respect when their big issue was it has a manual. Woosies.
    edited April 2023
    They certainly have regressed from the halcyon days of Inside Line.
    Amazing that the performance hasn't changed over the 4 generations.
    Done…
    https://www.caranddriver.com/photos/g43554297/2024-acura-integra-type-s-revealed-gallery/
    @breld So are you on a list somewhere for one of these yet?
    Aaaaannnnddd one for @nyccarguy -
    https://bringatrailer.com/listing/2000-honda-prelude-29/
    This seems like a nice one.
