Visitor Agreement.
Not really. I play ball left handed but I’m right handed for everything else. Don’t say it, I’ve heard it before. Many times.
245/45 R19 95V front
275/40 R19 101V rear
I checked out Continental (OEM) and they were over $1500 out the door.
Next, I checked out Goodyear and they were $1295 out the door.
Finally, I checked out Michelin Primacy MXM4 and they ended up at $1392 out the door at Costco. They have a $150 rebate this month on any 4 Michelin tires. Also, all their installed tires have a 5 year road hazard warranty which the other 2 brands at tire dealerships did not.
So I decided on Michelin. The tire sizes are rare and difficult to get. Costco had to order them from 2 different plants due to lack of availability. 5-10 days is the time frame.
I prefer Michelins and I did not like the Continentals.
If the 'V' is the speed rating, that could be the reason.
I had the same size tires on my MKZ as the front tires on your car.
I would have done the same thing but I can’t think of anything I dislike more than buying those round black things for a car. For what they cost you’d think you were moving up in life but you’re just holding serve.
It’s not directly connected to the device. The current takes the path of least resistance. If you pulled an outlet out with a draw on it, the white wire wo> @abacomike said:
I’ve said it many times here… I’ve had the absolute best luck with Michelin tires. I would steer anyone in that direction
Ford dealer had a Mach I In the showroom. 66k or so. Sadly an automatic.
Big tires. Michelin pilot sport cup2s I think. Basically bald. I’m surprised they are even street legal.
My twin brother writes with his right hand, used to bat right at the plate, but throws a ball with his left hand. Go figure!🤪😜
I do everything with my right hand - and I mean EVERYTHING!!!🤓🤪😜
probably the only car I have ridden in that quick was my BILs 427 Cobra. But that had to contend with wheelspin, so probably would lose a drag race (at least a short one!)
weirdest part though, no roaring engine. just an electric motor whir.
also had the biggest center screen I have ever seen. I think it was bigger than the TV in my bedroom. Ginormous.
Overall, a very nice car - I prefer it over the Tesla.
These are also the two contenders for the A7 and/or M240, when the time comes. I'm not sure if Costco/BJs deals with Contis, though. And, I am leaning to the DWS06, from Tire Rack reviews/ratings.
Costco's model year search only goes back to 1998.
225/50-16?
For $97 more good move buying the Michelins over the Goodyears.....no doubt about it.
And no question the Michelins are a bargain at $100 less than the Continentals.
About 4 years ago the C250 had Continentals replaced with Michelin Pilots....no comparison, the Michelins are much better.
I didn't see the Size tab, so thanks for that.
Tires are 225/55/16.
Not much to choose from at Costco or Tire Rack.
Good choice on the Michelins. I've always had good luck with them. I've used
them since they were labelled as Sears Roadhandlers with inner tubes inside.
WHAT TIRE SIZE IS ON YOUR VEHICLE?
Ford equips your vehicle with one possible size during production. (Learn More)
Select an optional or custom size if appropriate.
Factory Tire Size Optional Tire Sizes Custom Tire Size
Factory Tire Size
16"
225/55-16
An Ontario couple says they've been hit with unexpected costs after their new electric vehicle's ability to sustain a charge is 'nowhere near' what was advertised.
"My wife took a job up in Barrie, Ont., and she has to commute 60 miles each way and we were paying over $1,000 in gas," Jack Fleming, of Etobicoke, Ont., told CTV News Toronto Monday.
Fleming said before buying an all-electric Volvo C40 Recharge, he checked the vehicle’s range, which was advertised as 250 miles on a full charge.
"Even if it didn't hit that if it hit 180 miles or 150 miles, we just need enough to drive 60 miles (120 miles round trip) with a bit of a safety margin, so she doesn’t have to worry she won’t make it home,” Fleming explained.
Fleming says he made the $72,000 purchase in November and that it wasn’t long after that he and his wife became concerned about the distance the car was travelling on each charge.
“We are only getting about 130 miles per charge – nowhere near what they’re advertising,” Fleming said. “That's like 60 per cent of what they are advertising.”
Full story: https://toronto.ctvnews.ca/ontario-couple-says-new-electric-vehicle-s-charge-capacity-nowhere-near-what-was-advertised-1.6379080
Volvo says they are working on making the range longer and faster charging!
Range anxiety is a big problem, and it seems....with good reason!
Perhaps more research was needed before making the purchase - there are lots of forums on the interwebs with posts from owners about actual range, not the "claimed" range from the manufacturer.
https://www.bobvila.com/articles/best-ceiling-fans/?utm_medium=social&utm_campaign=socialflow&utm_source=twitter
The interest in EV cars is waning, unless they come up with a solution to range anxiety, and actual range.
btw....not just cold weather will drain the battery, how about a 2 or 3 hour traffic delay, which can happen anywhere?
Good luck with making a choice @stickguy.
That info will convince you that your idea of a window box is the way to go.
FWIW, I’ll bet they are all connected the same way.
we do want one without a light kit since we have no need for that (the room has recessed lighting already).
Yep, hooking up a fan only unit greatly simplifies the installation for most home owners because there is only a black, white and green wire on the fan. The fun starts when a blue or purple or some other colored wire is supplied for the fan or the light as specified in the instructions. It’s amazing how one teenzy extra wire throws the average home owner for a loop when trying to connect this additional wire. Almost as much as when they try to replace a 3-way switch.
2013 LX 570 2016 LS 460
If that’s all it was I think more folks would buy EV’s.
Congrats! I like the idea of every other week. Seems easier to manage that the 2 or 3 day thing.
I know that at several stores where I shop there are an increasing number of employees my age on duty.
It isn't something I would buy....I sometimes get an undercarriage wash...once or twice a year.
People who live in areas of salted roads and streets should get under care washes at least once a week. Same for dusty or muddy areas. I have not come across car washes that offer that service.
Almost every automated car wash here in Colorado has the option for an undercarriage spray, to remove dirt or snow removal chemicals that may accumulate on the bottom of your car.
There are a lot of folks that have that attitude.
Now, when I wash my cars I put my hands all over it yet I’ve never caused a scratch but with my buffers I’ve removed a few. The first time I wash a car after bringing it home (new or used) is when the car and I get our biggest workout.
Like I’ve said before…if you REALLY want to know your car up front and personal, give it a detail job yourself.
I did plant the seed after putting the new truck in the garage finally, and mentioning that since we have the white and blue, just need a red car to be ready for the 4th of July!
