Visitor Agreement.
I've been told for years that "some" consumption is normal, and I believe it is. However, I've never had a new car, or a relitively new car that's used oil. All of the cars I've had that have used oil have had higher mileage. Consequently, I relate oil consumption with a worn engine. I suppose I would be alright with it if it doesn't get progresssively worse. I do plan to use the Maxlife, but in the 10-30 weight, because that's what's called for in my engine. I wouldn't just arbatrarily use a 10-40 without first trying the specified viscosity.
adc100
Undoubtedly consumption would be higher using a dino? Someone else posted earlier that switching to a syn in a high mileage engine causes more consumption. Why do these two statements sound like counterdictions?
I do admit to owning older cars. I have 3 vehicles, 2 purchased with around 60K, and one with 90K. But adding 3/4 to one quart per 3000 miles has been extremely consistent on all vehicles. It has not increased at all.
I switched one car over to Maxlife last January. I did notice a reduction in consumption. It took 5,000 miles to add a quart. I check and top off monthly, but I know the usage because every vehicle takes a different weight. A pure synthethic is about the same on the one vehicle I tried it in.
I however believe that since hydrocarbons is considered a significant pollutant, that the LEV, and ULEV standards clearly call for less oil consumption. That standard is newer than any of my current rides. I expect lower consumption with newer vehicles for that reason alone.
My experience with synthetics was that it doesn't consume quite much, but if it happens to leak, it goes all over. Big mess.
10W-40 was recommended because STP might affect hydraulic lifters since it thickens the oil. Better to try a heavier weight first.
Isuzu claims a quart every 1,000 miles is acceptable. I wish our Trooper didn't consume oil, but I am at peace with it.
Someone posted here a while back that it's not the consumption that indicates a problem, it's whether the rate of consumption INCREASES as the vehicle ages.
Doesn't appear to use any via burning but have about 4 seepage areas, rear seal, somewhere by the alternator, above oil pan etc. However, even these seepages do not amount to 1 quart in my 7,500 mile change cycle. Purchased at 57,000 converted to synthetic 10W30. Leaks were present before conversion.
I've leased a Lumina LS with the 3.1 for 3 years, this car never burn or leak oil, level always at the full mark even if I was following the extended maintenance schedule.
I was due for an oil change the last one before returning the car. Since I'm a cheap guy, I decided to put the cheapest oil I could find.
At canadian tire here you have basically 3 quality of dino, they are all showing the symbol required. So I put the cheapest one and ran the car for about 3200 miles and I was a quart low !!! That never happenned to me before and the car wasn't leaking.
I'm pretty sure that evaporation plays a big part, meaning that you have a steady consumption of crankcase fumes through the pcv system, on the other hand it consume the oil so slowly that it is almost unnoticeable.
My daughter did that on her car. Started by running it dry and when I reminded her to check oil, dumped in a quart at every oil change until she had two quarts too many in there. Oil light came on at idle, but was corrected with some STP, and the engine has 170K anyway, so it's essentially a beater.
This oil change is not listed in the manual.
Happy 4th everyone, enjoy , cherish and protect freedom!
I have browsed through few hundred meaages. still can not find a answer.
I have a 1999 Toyota and a 1999 Nissan. both have about 70K. I have been using castrol GTX for more then 2 years. but thinking about to switch to valvoline or valvoline maxlife. any suggestion?
Jinsong
Castrol is used by most Toyota dealers. If you read the back of the bottle, it states "Japanese wear test"
As stated, the key is how your vehicles are performing with Castrol. 3K oil changes are important with non-synthetic oil.
Maxlife is a very good oil with quite a lot of group 2+ or group 3 stock. Probably has a higher synthetic rate than most syn. blends which are about 10% synthetic.
Lots of people hate Castrol because Syntec is Group 3 and not real synthetic. I think this dislike has bled to other Castrol oils. Personally I think this is some slick reverse marketing on Mobil's part, but lots of folks take it very seriously. That being said, Maxlife is probably a better deal given the superior basestocks for not a lot of extra bucks as compared to Castrol dino.
As far as the Nissan is concerned, think it could easily go 4K.
i think the 3k is driven by Jiffy Lube Marketing.
Yeah 3k protects your engine, but so does changing at 2 k.
3k wastes a lot of oil in America
For those that are worrying about 3K oil changes depleting our World reserves, etc, please don't. As it stands, the left over petroleum from gasoline production is the stuff that motor oil is made from. Any that is not needed is now wasted. There is plenty of room to go 3K per oil change, considering that.
(I'm sorry--geling, not sludging)
Someone may want to try bothering them again-- Pennzoil has a new web page. SuperTech dino is actually produced by the old Specialty Petroleum blending plant in Shreveport. Johnny over on Bob's board has a lot of info. on all things Pennzoil.
On another subject: Edmunds Web Pages are a joke. Frequently they are so slow that I don't bother coming here. I would say to contact the Webmasters or the Host. But I have done that many times to no avail. Later guys.
