Visitor Agreement.
Those ain’t your ordinary pilot lights. What they burn in an hour you could heat your home forever. Maybe even your neighbor and his neighbor too.
No wonder why we have global warming. I doubt you’d find a tree hugger at that place.
JM, I don't know what shutoffs are at the box (I assume there is one) but I have a labelled shutoff for that line in the basement where all the gas lines disperse. All the lines have them, and conveniently, someone wrote in sharpie on the ceiling joists what each one controlled.
I have a gas fireplace. I have zero idea where the [non-permissible content removed] off is or if it has a pilot or not. Until today I never even knew you had to service them.
Fun fact @explorerx4 - my wife and I looked at the arcade for our wedding. We ended up getting married around the corner at The Renaissance attached to Tower City.
Mine has a shut off near the floor a few feet from the fireplace.
After I took that picture, a wedding party showed up to take pictures.
I guess a lot of them get pictures taken a day early.
There's probably a lot of tables and chairs on that floor today.
But, every time we shut it down, it seems to need a new thermocouple, the next fall... So, now, we just leave it lit all year.
2014 BMW 428i convertible, 2015 Honda CTX700D, 2025 Hyundai Tucson Limited.
That’s a big part of why my wife wants them serviced. They clean the glass inside and out and clean the inside of the fireplace as well.
As for wedding pics …. If I knew now how much of our wedding we would have missed, 100% we would have done pics before.
We missed 90% of our cocktail hour. At the end we finally told the guy “we have enough pictures”
To miss 90% of your cocktail hour tells me you were not feeling any pain. That’s the way to enjoy a wedding. I should have thought of that. I think I only missed 50%.
I received this for Father's day.
Enjoy! Ive had it and liked it very much.
Make it two in a row for Ferrari at Le Mans. The BMW hypercars weren’t a factor, but BMW Motorsport nabbed second place in LMGT3. If BMW or Mercedes-AMG can’t take the checker I’m happy with a Ferrari or Porsche win.
Last fall, I called to have the water flushed out of system.
This spring I got a card about scheduling to have everything turned on again.
I figured it couldn't be too hard and I could do it myself.
It went ok, although there were a couple of small leaks from some threaded plastic plugs.
There are 2 ball valves to control the water flow and just past them are the plastic plugs.
When I turned on the water at the ball valves, I had to thread in the plugs to stop the water draining out there. Still had a small drip from each one.
My next door neighbor has a system too and he said his was leaking but he found out how to stop the leaks.
He said there is a screw you turn and the plugs are basically dust covers.
Today, I took off the plugs and water started draining out and I didn't see any screw to turn.
Looked on the back side and guess what? There is a place to use a screwdriver to shut what turns out to be a drain flap. As soon as I did that, water stopped draining out.
Just screwed the plugs back in and now no leaks.
While I was doing this I heard a hissing noise and looked over at my neighbors house.
One of the drain valves had water spraying out a good 6 feet.
Rang thier doorbell but no answer, so I went over to where the leak was.
His drain valves have the screw slot on the front, so i gave the leaking one a quarter turn and the leak stopped.
I will have to check mine periodically to make sure there are no leaks.
You should charge him a nominal service fee since you didn’t have to travel very far.
FWIW, I had an irrigation system when I lived in SC in the mid 90’s but I didn’t have the gizmos you described.
Also, in your area, you'll definitely want a professional shutdown, where they used compressed air to remove the water from the system.
I always had mine shut down by. Pro with a big compressor. But most of the time I turn it on myself. Just crank the shut off lever and fire it up. And make sure all the heads come up and seem to be working. If something looks busted then I would call for maintenance. Usually not needed.
I do exactly the same as Stickguy.
Last year I had to take apart the vacuum breaker and glue on new threaded adapters because one cracked and it was pouring out water. I think when they took off the drain plug they broke it but I’d never be able to prove it
What a country.
I'm sure you heard the laughter coming from my neighbors as I attempted these adjustments/repairs as inevitably I ended up soaking wet...
I did have one for four years. When the heat went out due to a faulty boiler on a zero-degree day it did prove utterly useful.
Dropped in to say hello and, yes, 12 years post-transplant I'm still here.
After not buying a car for years, I sold my Miata (fun, but I needed space.
Landed an 07 Solara convertible. Not as much fun but it can be a year-round car. The speakers were blown so I replaced the whole stereo - backup camera and all. I'm liking it.
Fezo! Long time brother! Glad you are doing ok.
I can see the benefits to a “real” car convertible instead of a toy. I know my wife would appreciate that.
Not sure where the backflow would come from.
Hi Fezo! Glad you checked in.
About 2 minutes into it, I do a double-take. “Hey, that’s ME!” I said to Lucy the cat since there was nobody else here. Sure enough, there I was, along with 2 of my coworkers at the time walking along the sidewalk. I never knew about it and had never seen it. Wild.
Video makes me want to visit. You are not the center guy? Total guess.
RacingLine has some neat stuff for upgrading my TTS, but their local provider and/or the company can't even give a potential customer a quote and lead time!!!!!!!
I'm busy at work so I'd like to combine jobs for my shop to do all at once, even if it doesn't save me on labor because things are in different areas.
I see that now. The ladies man.
Pros don’t break things do they? That’s why I’ll risk breaking something myself rather than call a pro. So far it’s worked for me.
I told the story about a pro strong arming the shut off valve to the dishwasher while he did a warranty repair. That I noticed almost right away but almost breaking off the dishwasher stub on the disposal wasn’t noticed till a few days later when Mrs. j had to get something from under the sink and saw some water. Luckily I was able to use a small drain stopper like what was used for old time sinks to plug what was left of the disposal stub for the dishwasher drain hose. Then I installed a dishwasher branch tailpiece on the other bowl. Glad we had 2 bowls or I’d have been forced to scrap the disposal and put in a new one.
Like you said, you’d never be able to prove anything so you just have to live with the work of pros when they’re called in to fix something. It’s not just limited to having your car fixed by an outside pro.
My first visit to Nova Scotia was in September of '70, when I took my beloved '65 MGB (44 states, 8 provinces, many of which were scored on this trip from AZ and back) out to Neils Harbour on Cape Breton, simply because it was the farthest it was possible to drive on the North American mainland. Excellent trip, what with Anne Murray's Snowbird on the radio and all.
The visitor centre at the border, coming in from NB, made a lasting impression, with the pipers, plus all the beautifully cared-for lawns (a real improvement from the desert). I came up via the Twin Cities, Sudbury, Montreal and New England and returned to AZ on a southern route via Alabama and Texas.
Good times. Thanks for the memories
I pay for startup and shutdown. The cost is pretty nominal and there are always leaks and broken heads to deal with every spring.
Mrs Snakeweasel and I went some antiqueing today and when we left one shop this was parked next to us.
It was a different time, and I was there.
That car should have the original wheels, hub caps and whitewall tires. I saw at least 8 or 9 at the car cruise I went to this past Sunday and most were like they came off the line.
Those ‘57 Chevy’s sure do attract a crowd. ‘55 and ‘57 Chevy’s are the collector cars. My first car was a used ‘56 Chevy. Yes, I always seem to be one off. :'(
