Good luck with it and let us know what your brother thinks of it after he shakes it down for a few weeks.
I told him to do a PPI; not sure if he did or not. He is supposed to actually do the purchase on Monday.
Audi and BMW dealers on the cape offer basic fare: water/juice/soda and packaged snacks. Same dealers north of me (~equidistant to the Cape dealers) only water. I go over the bridge!
Is Toyota farming out their engine manufacturing to other factories?
Could be. Just the other day we saw where manufacturers lend their expertise to whom ever wants to pay for it.
Because everyone knows the peanut M&M is the superior candy
Fearing the worst, I was pleasantly surprised to be told everything is in great shape. 6mm on the front pads, 9mm on the rear, no unnatural scoring or other issues on the rotors.
Dodged a bullet.
That’s what Reese’s Pieces is for
Fixed up one of my fenders today. The rust was much more extensive than I originally thought. I couldn’t do the other side because I didn’t have enough rust inhibitor on hand.
Pics show after I chipped away all the bad rust, then after treating what remained, then after applying the wrap, and the finished exterior product. Also a shot of all the rust on the ground for good measure. As a last step, I’ll apply a rubber liner on the inner fender to seal it up.
Perfect way to make @oldfarmer50 feel at home.
Have you considered doing some hillbilly body work with foam and Bondo to close in that gap?
On mine, it is closed around the wheel (well, it would be closed if not rusted through), but open behind and in front. So one could reach up over the wheel well from under the truck.
Not shown in pics, but I needed a small bit of structure where the rust reached higher than the fender flare, so I used a piece of plastic and bondo. Close.
For the gap, that would be too big a spread of bondo and not hold up. Now spray foam on the other hand…
YIKES, that’s even worser than what @qbrozen had to work with. If I had any tears left after seeing his, you’d get some but I’m fresh out. :'(
The owner of this 7-series (I think) really tried to bougie it up. From the hip-hop exhibition at the Cincinnati Art Museum. They also have a Rodin exhibition and there is a great new country French restaurant about a half mile walk away in Eden Park.
What was done to that interior should be a fineable offense.
Taking about that restaurant makes me hungry. All I had for breakfast was a measly blueberry muffin but dinner will be great. I’ll be putting some baby backs on the grill. That’ll make everything right tonight.
I took the Ariya. Started fully charged and set the cruise around 75 on the way up. Arrived at CAM with 47% charge remaining, plugged into one of their Level 2 chargers. $0.35/kWh is quite spendy for an L2 charge, plus I got a $0.50 fee added onto the final tally because I'm not a member of the FLO network. $6.82 for a two hour, 35 minute charging session, which got me to 70% state of charge.
I drove closer to 80 on the return trip and would have made it to my house with about 14% remaining, but I decided to stop at one of the free L2 chargers in town to try to get a head start on charging it back up (it will take days with the L1 charger). Parked at the Crescent Hill Presbyterian Church with 12% remaining, made a lap around the Crescent Hill Reservoir and the neighborhood nearby, and got back in with a 22% charge, 2% of which was burned off on the trip home, so kind of a fool's errand, but at least I got my steps in.
My takeaway is that it's fairly tricky to plan a day trip that's outside of the vehicle's range and rely upon stopping for a couple of hours for an L2 charge at the destination. Definitely a good idea to look for a nearby DC fast charger as a backup (there are none along I-71 between Northern KY and Louisville).
There are barely any decent gas stations on 71, let alone EV chargers.
A friend brought his M1 and 3.0 CSL- the M1 won best of show, deservedly:
An M3 Lightweight:
A 2002 Turbo:
Don't see these too often:
Another friend's car- it's his daily:
The Club Sport:
did a walk through on the new house today, and it does have a 220 outlet in the garage. so any time I get a plug in, just need to get a charger and hang it on the wall and plug it on in.
Dealer in Nashville was willing to give them away. The higher trim level one (at whatever discount they were giving) would have been around $299/month, which seems a touch high, given what I've seen on the forums here, but not completely unreasonable. I believe it does, as I know you can search for nearby EV chargers, however, I have noticed that some of the EV chargers in its database are for places like a nearby Kia dealer, which may not really be open to the public that aren't customers. So, I'm planning any necessary or potential charging stops along my route manually using the Plugshare app.
