1316431653167316931703236
  • corvettecorvette Member Posts: 11,733
    A couple of interesting things now that I'm logged in on Nissan's financing page:
    1. Apparently, they do not offer the option to purchase EVs at the end of the lease, nor to buy them out.
    2. If you are over mileage, there is a $0.25 per mile penalty. But, if you purchase additional miles mid-lease (at least 30 days before lease maturity), the cost is only $0.10 per mile. So, you can really mile it up and then get a huge discount on the overage if you just pay for it 30+ days before lease end. I doubt I will go over 15k, but we'll see! Definitely an added incentive to keep the Maverick parked.
  • jmonroe1jmonroe1 Member Posts: 9,821
    sweet deal. I would definitely grab one of those at that price and flip the Acura.
    did a walk through on the new house today, and it does have a 220 outlet in the garage. so any time I get a plug in, just need to get a charger and hang it on the wall and plug it on in.
    I’m glad I’m not considering an EV of any type because my house was built in 1975 and the electric service at that time was only 100 AMPS. I’m pretty sure the code in these parts for a new build today is at least 200 AMPS.
    Of couse I could put in a Level 2 charger and make sure the electric dryer isn’t turned on or buy a gas dryer. When we moved in here the house had a gas line but we had an electric dryer so I had to run a 220 Volt line for that. So the choice is mine as to what I’d do if and when I go electric.
    Then again, I could always yank out the old panel and install a 200 AMP panel like we’ve done to a couple flips. The panel cost would only be about $125 bucks (our cost) so that’s not too bad since I never charge myself for labor.
    I don't think I ever posted the full details, but the "sign and drive" lease on my Ariya is $178.75 per month for an 18 month lease with 10k miles per year. Looking forward to keeping some miles off the Maverick!
    Hell, at that price I think I should buy one just so I can say I’m environmentally conscious. Plus, having a rolling spare ain’t a bad idea either.
    My small (under 1,200 square feet) house had one of those Federal-Pacific panels that would spontaneously combust, at the time I bought it. IIRC, got $1,000 credit from the seller to have it replaced, and I spent a little more and had the service upgraded to 200 amps. 100 would have probably been adequate, even with an EV charger, but I also used to live in a house in Lexington with 60 amp service, and if the central A/C, dryer, and maybe 1-2 more appliances were running, the master breaker for the entire house would trip, so it's nice to have some overhead.
    My parents moved from the Burgh to an up and coming suburb in 1956. Built a new 3 BR, 1 bath ranch that had a 60 AMP service and my Mother had a state of the art electric kitchen with cook top and built in oven. She was the envy of the neighborhood.
    We never had AC when I was growing up but not too long after I left they put a window box AC in their bedroom. Then one day my Dad got the bright idea to put a huge window box AC in the dining room window. I tried to talk him into spending a few more bucks and do central AC. They had the money to do it but opted for this humungous Sears unit that I think was 22,000 BTU’s which took a 220 Volt line that I installed for them and they were tickled pink. That beast cooled the entire house except the hall and bedrooms. It never once blew the main 60 AMP fuses but it was noisy. Yes that house had a fuse panel and it did till the house was sold.
  • suydamsuydam Member Posts: 5,190
    We may extend the dryer line out to the garage for the Blazer. We have a gas dryer, so it’s a cheap way to get the 240 volt to the garage. Haven’t driven it enough to charge it yet, and I’m going to see what it costs to charge at the fast chargers about a mile away from me.
    _____________________________________________________________________________________
    The down side of that is most electric dryers are connected to a 220 V, 30 AMP circuit and most Level 2 chargers require a minimum of 220 V, 40 amps, some even 50 amps. The 30 AMP circuit can be wired up to any Level 2 charger but it won't charge as fast as intended. However, it's still much better than charging with a 110 volt circuit.
    My guess is most people can live with transferring a 30 amp dryer circuit to a Level 2 charger, you just have to plan better.
  • oldfarmer50oldfarmer50 Member Posts: 24,628
    Yikes! I just read that the feds spent $8 billion and only built 7, yes seven EV chargers. At that rate it would take a million years to get to the 500k they promise.
    What’s up with that?
    Other than the panel would you have to install larger or additional electric lines to the house? My house only has 150 amp service and I was wondering what it would cost to upgrade.
    Don’t believe everything you read.
    https://www.washingtonpost.com/climate-solutions/2024/03/28/ev-charging-stations-slow-rollout/
    That depends on the utility and the area your house is in. Codes change over the years and that will dictate what service ampacity your utility uses for service entry cable in any given area. For instance, the house my parents built in 1956 had the original over head lines. 3 individual wires from the pole to the house. That type of connection is no longer used. Utilities switched over to triplex cable (3 wires twisted together) around here by the early 70’s. Triplex cable has better insulation so, believe it or not, the same size wire conductors can handle higher current. On top of that, I’ve found out that the cable from the mast head to the panel (which is the responsibility of the home owner) in my neighborhood was upsized by the electrician that wired our homes. So, in my case, I can replace a 100 amp panel with a 200 amp panel without the need for larger wires from the panel to the mast head.
    Once again you have to check what you need in your area. Note that I just talked about above ground service entrance cable. Underground service has a different applicable code but I’m willing to bet that you can upsize your panel and at worst only have to change the cable from the panel to the bottom side of the meter socket which is very easy to do.
    As usual, YMMV.
  • clm8clm8 Member Posts: 83
    I live in an older home with a 150 amp panel. I recently leased a Mustang Mach E. I had to purchase a different charger as the one from Ford was pulling too many amps for my 30 amp breaker. I didn't want to have to run a new wire to my detached garage. I was able to use the existing wire. The new charger I bought (less than $200), is configurable from 12 to 40 amps. I have mine set to I believe 24 amps. (I don't remember exactly). It improved my charging time dramatically from the 110 plug.
  • xwesxxwesx Member Posts: 18,015
    edited July 2024
    Okay, so the 2013 F250 is a done deal. My brother called this morning as he was driving it home. Now I'm definitely looking forward to the trip to Ohio!
    I would very much like to replace the 100A service in our house there with a 300A service, but I'm not sure I'm going to be able to overcome the "SO Factor" any time soon on that.
  • MichaellMichaell Moderator Posts: 268,669
    au1994 said:
    After spending a week with a Grand Cherokee L in Hawaii, I decided to make one more run at one. Worked it for about a day and a half but stacked up a bunch of incentives including a $2k loyalty and they got me out of the Wrangler lease early and avoided an inspection and disposition fee.
    It’s a Limited 4x4 model with only pano roof and tow package as options. Drives really nice and has all of the usually expected features at this price point.
    A fond fair well to the Wrangler. Largely trouble free for 3 years. A few recalls that were done at oil change intervals and one bad coolant pump for the battery. Enjoyed it but looking forward to having something a little more luxurious for a while.
    1st month down and with the incentives it ended up being close to a 1% lease like the olden days.
    Congrats! Love the color combo.
    au1994 said:
    Well…
    Gorgeous color combination! Nice work, @au1994 !
  • nyccarguynyccarguy Member Posts: 17,824
    au1994 said:
    Well…
    +1
    Nice Job @au1994
  • tjc78tjc78 Member Posts: 17,505
    Love the Jeep! Congrats
  • andres3andres3 Member Posts: 14,191
    Looking at the newer X3 M40i's .... I like them, they are similar to the GV70 from Genesis, just a bit faster/quicker, a bit better handling, better exhaust sound and noises, and both of them have some oddball styling choices, particularly in the interior, but the Genesis even more oddball to me.
    Found a '21 with 65K miles that might be right up my alley with the X3 M40i. Just need to see if they are willing to give a good price as the car does have a dozen little "cuts" about it, but I think I could live with it.
    One example is no HK audio. How much does BMW's base sound system suck?
    Another is the service records are good, they have no big holes, but they consistently lackadaisically got services a bit late, from 11.5K to 13K mile intervals. I give that a barely passing C- grade as at least they didn't miss one and the records prove it.
    @au1994, nice looking car. Good luck with it. So I guess this means no Maverick, right?
    @clm8 - was the Mach E this year? If so, let us know the date of purchase, and I'll put it on the punch list.
    @au1994 - great looking truck!
    Is there something in the air? How many punches have there been lately, including mine? I’m losing count!
    Gorgeous Jeep GC.
    edited July 2024
    Yes, got it in May. Its a 2023 Premium
    @andres3 - from my experience, the base BMW sound system does kinda suck. My loaded up X5 PHEV was missing it when they were cutting certain options due to chip shortages...the difference in sound quality was very apparent.
  • roadburnerroadburner Member Posts: 18,613
    More:
    The base system isn't as bad as it used to be. Bavsound offers upgrades to the speakers and subs for @$1,400.
    Gorgeous Jeep GC.
    You're not wrong. Quite a few punches in June. The Ariya that I just bought is now six spots behind on the list. Here's what I have so far:
    2024 punch list (total 23):
    01/03/24 carnaught 2024 Honda HR-V EX-L
    02/09/24 js06gv 2024 RAM 1500 Longhorn
    02/19/24 tifighter 2023 Honda Civic Type R
    02/20/24 qbrozen 2011 GMC Sierra SLE 4x4 124k
    02/28/24 oldfarmer50 2013 Ford F-150 XL RWD 8’ 3.7L 30k
    03/31/24 28firefighter 2015 Audi Q5 3.0 TDI 77k
    04/03/24 greg128 2020 Cadillac XT5 Premium 23k
    04/13/24 ronsteve 2021 VW Tiguan SE 4Motion 38k
    04/16/24 qbrozen 1998 Alfa Romeo 156 40k
    04/30/24 venture 2024 Subaru Legacy Sport
    05/12/24 rny421 2024 Mercedes GLC
    05/xx/24 clm8 2023 Ford Mustang Mach-E lease
    06/04/24 suydam 2024 Kia Sportage PHEV
    06/04/24 breld 2023 Audi A6 Allroad
    06/08/24 suydam 2024 Chevrolet Blazer EV 2LT
    06/14/24 benjaminh 2024 Subaru Outback
    06/18/24 corvette 2023 Nissan Ariya Engage AWD (lease)
    06/20/24 venture 2021 Subaru Legacy
    06/22/24 breld 2024 VW Taos (stepdaughter)
    06/25/24 tifighter 2024 Toyota Sienna Platinum AWD
    06/28/24 venture 2025 Subaru Forester
    06/28/24 xwesx 2013 Ford F250 Lariat 426k
    07/01/24 au1994 2024 Jeep Grand Cherokee L Limited
  • au1994au1994 Member Posts: 3,803
    Been a busy summer!
    That figure was verified in an interview with the Secretary of Transportation.🤯🤯
    au1994 said:
    Well…
    That is a great color combination.
    I got to drive a 2025 Camry hybrid today. From the cloth seats I assume it was an LE trim and FWD. it was very quiet and had decent power but I wasn’t able to fling it around as much as I might like. Otherwise you couldn’t tell it from the pure gasser version which no longer exists.
    My company must be buying every hybrid they can because a good percentage of the cars I moved today were hybrid versions. My guess is they are making a strong play for resale to people who are switching out of EVs but don’t want to go back to gas powered vehicles.
    May 18th, didn't realize you tracked the day of month.
    We take great pride in admiring the punch list that @corvette updates so diligently!
    Yes he has done a very good job right from the getgo. However, I think @corvette now has his eyes set on getting a company car. :o
    Ten punches in June. That's a solid performance, folks! Of course, @breld had to show us all up again by having 20% of them. :p
    Actually, we got the Kia in March. Lot of purchasing happening!
    au1994 said:
    Well…
    German vehicles and Jeeps; my preference for decades.
    Mercedes-Benz of Louisville had the twin of this AMG CLE 53 at Cars in the Commons on Saturday. I think it could be my next car. My bride was equally enamored- the only issue being the price. :(
  • 28firefighter28firefighter Member Posts: 9,951
    Congrats, @au1994 - looks great!
    Didn’t you have a Maverick on order, too? Are you planning to take it and flip it?
    I’m jealous of a garage with that much space.
    You had me at "garage."
    Ahem.
    I'll remind you that I started and maintained the punch list for a few years before I was promoted to moderator, at which point @corvette stepped up to take over the responsibilities.
    Having met him in person (at a wonderful dinner hosted by @breld, and also included @tifighter and @jpp75), I can tell you he's diligent about accuracy.
  • ventureventure Member Posts: 3,211
    He's not the only one. B)
    I think that indicates the recovery of the auto market and the return to price sanity more than an statistic I can think of.😎
    Thanks. I do have a Maverick on order but I will just let it go. Not confident there is enough money left to risk trying to flip.
    edited July 2024
    After not driving the BMW for a over a week due to baseball tournaments and a weekend getaway I finally tended to it after bringing it home with the coolant light on. This is what I find upon closer inspection.
    That stick is supposed to be floating.
  • kyfdxkyfdx Moderator Posts: 272,543
    edited July 2024
    @pensfan83 Yikes!
    You know, I replaced the whole cooling system, at one point? :/
    @pensfan83 Yikes!
    Yep, and I don't want to do that anytime soon. Took almost a half bottle of coolant to get it squared away and then I took it on a drive to the store. No drips, leaks, or coolant light so here's hoping it's been addressed. I did get a call back from the dealer but they thought I wanted to schedule an appointment for service so they put me through to the SA's mailbox again. That was Friday.
  • ab348ab348 Member Posts: 20,713
    I think I see the problem. Your rad cap is missing. It's understandable since the filler neck only has a single notch to allow the cap to stay in place. Poor design there. :D
    I think you’re right. In 2020 my daughter’s car died and they had to get a new one. Talk about at the dealers’s mercy then! Their local Toyota dealer required $1000 deposit just to test drive a RAV4 PHEV! I remember thinking, no one who doesn’t have to get a car is out there now.
    Of course the Toyota folks are still hiking their prices as though there was no competition. That’s why my neighbor bought a Hyundai Tucson PHEV a year ago and we got the Kia.
