Visitor Agreement.
1. Apparently, they do not offer the option to purchase EVs at the end of the lease, nor to buy them out.
2. If you are over mileage, there is a $0.25 per mile penalty. But, if you purchase additional miles mid-lease (at least 30 days before lease maturity), the cost is only $0.10 per mile. So, you can really mile it up and then get a huge discount on the overage if you just pay for it 30+ days before lease end. I doubt I will go over 15k, but we'll see! Definitely an added incentive to keep the Maverick parked.
I’m glad I’m not considering an EV of any type because my house was built in 1975 and the electric service at that time was only 100 AMPS. I’m pretty sure the code in these parts for a new build today is at least 200 AMPS.
Of couse I could put in a Level 2 charger and make sure the electric dryer isn’t turned on or buy a gas dryer. When we moved in here the house had a gas line but we had an electric dryer so I had to run a 220 Volt line for that. So the choice is mine as to what I’d do if and when I go electric.
Then again, I could always yank out the old panel and install a 200 AMP panel like we’ve done to a couple flips. The panel cost would only be about $125 bucks (our cost) so that’s not too bad since I never charge myself for labor.
Hell, at that price I think I should buy one just so I can say I’m environmentally conscious. Plus, having a rolling spare ain’t a bad idea either.
My parents moved from the Burgh to an up and coming suburb in 1956. Built a new 3 BR, 1 bath ranch that had a 60 AMP service and my Mother had a state of the art electric kitchen with cook top and built in oven. She was the envy of the neighborhood.
We never had AC when I was growing up but not too long after I left they put a window box AC in their bedroom. Then one day my Dad got the bright idea to put a huge window box AC in the dining room window. I tried to talk him into spending a few more bucks and do central AC. They had the money to do it but opted for this humungous Sears unit that I think was 22,000 BTU’s which took a 220 Volt line that I installed for them and they were tickled pink. That beast cooled the entire house except the hall and bedrooms. It never once blew the main 60 AMP fuses but it was noisy. Yes that house had a fuse panel and it did till the house was sold.
The down side of that is most electric dryers are connected to a 220 V, 30 AMP circuit and most Level 2 chargers require a minimum of 220 V, 40 amps, some even 50 amps. The 30 AMP circuit can be wired up to any Level 2 charger but it won't charge as fast as intended. However, it's still much better than charging with a 110 volt circuit.
My guess is most people can live with transferring a 30 amp dryer circuit to a Level 2 charger, you just have to plan better.
What’s up with that?
That depends on the utility and the area your house is in. Codes change over the years and that will dictate what service ampacity your utility uses for service entry cable in any given area. For instance, the house my parents built in 1956 had the original over head lines. 3 individual wires from the pole to the house. That type of connection is no longer used. Utilities switched over to triplex cable (3 wires twisted together) around here by the early 70’s. Triplex cable has better insulation so, believe it or not, the same size wire conductors can handle higher current. On top of that, I’ve found out that the cable from the mast head to the panel (which is the responsibility of the home owner) in my neighborhood was upsized by the electrician that wired our homes. So, in my case, I can replace a 100 amp panel with a 200 amp panel without the need for larger wires from the panel to the mast head.
Once again you have to check what you need in your area. Note that I just talked about above ground service entrance cable. Underground service has a different applicable code but I’m willing to bet that you can upsize your panel and at worst only have to change the cable from the panel to the bottom side of the meter socket which is very easy to do.
As usual, YMMV.
Other than the panel would you have to install larger or additional electric lines to the house? My house only has 150 amp service and I was wondering what it would cost to upgrade.
I live in an older home with a 150 amp panel. I recently leased a Mustang Mach E. I had to purchase a different charger as the one from Ford was pulling too many amps for my 30 amp breaker. I didn't want to have to run a new wire to my detached garage. I was able to use the existing wire. The new charger I bought (less than $200), is configurable from 12 to 40 amps. I have mine set to I believe 24 amps. (I don't remember exactly). It improved my charging time dramatically from the 110 plug.
I would very much like to replace the 100A service in our house there with a 300A service, but I'm not sure I'm going to be able to overcome the "SO Factor" any time soon on that.
It’s a Limited 4x4 model with only pano roof and tow package as options. Drives really nice and has all of the usually expected features at this price point.
A fond fair well to the Wrangler. Largely trouble free for 3 years. A few recalls that were done at oil change intervals and one bad coolant pump for the battery. Enjoyed it but looking forward to having something a little more luxurious for a while.
1st month down and with the incentives it ended up being close to a 1% lease like the olden days.
Nice Job @au1994
Love the Jeep! Congrats
Found a '21 with 65K miles that might be right up my alley with the X3 M40i. Just need to see if they are willing to give a good price as the car does have a dozen little "cuts" about it, but I think I could live with it.
One example is no HK audio. How much does BMW's base sound system suck?
Another is the service records are good, they have no big holes, but they consistently lackadaisically got services a bit late, from 11.5K to 13K mile intervals. I give that a barely passing C- grade as at least they didn't miss one and the records prove it.
@au1994 - great looking truck!
Gorgeous Jeep GC.
2024 punch list (total 23):
01/03/24 carnaught 2024 Honda HR-V EX-L
02/09/24 js06gv 2024 RAM 1500 Longhorn
02/19/24 tifighter 2023 Honda Civic Type R
02/20/24 qbrozen 2011 GMC Sierra SLE 4x4 124k
02/28/24 oldfarmer50 2013 Ford F-150 XL RWD 8’ 3.7L 30k
03/31/24 28firefighter 2015 Audi Q5 3.0 TDI 77k
04/03/24 greg128 2020 Cadillac XT5 Premium 23k
04/13/24 ronsteve 2021 VW Tiguan SE 4Motion 38k
04/16/24 qbrozen 1998 Alfa Romeo 156 40k
04/30/24 venture 2024 Subaru Legacy Sport
05/12/24 rny421 2024 Mercedes GLC
05/xx/24 clm8 2023 Ford Mustang Mach-E lease
06/04/24 suydam 2024 Kia Sportage PHEV
06/04/24 breld 2023 Audi A6 Allroad
06/08/24 suydam 2024 Chevrolet Blazer EV 2LT
06/14/24 benjaminh 2024 Subaru Outback
06/18/24 corvette 2023 Nissan Ariya Engage AWD (lease)
06/20/24 venture 2021 Subaru Legacy
06/22/24 breld 2024 VW Taos (stepdaughter)
06/25/24 tifighter 2024 Toyota Sienna Platinum AWD
06/28/24 venture 2025 Subaru Forester
06/28/24 xwesx 2013 Ford F250 Lariat 426k
07/01/24 au1994 2024 Jeep Grand Cherokee L Limited
My company must be buying every hybrid they can because a good percentage of the cars I moved today were hybrid versions. My guess is they are making a strong play for resale to people who are switching out of EVs but don’t want to go back to gas powered vehicles.
We take great pride in admiring the punch list that @corvette updates so diligently!
————————————————-Yes he has done a very good job right from the getgo. However, I think @corvette now has his eyes set on getting a company car.
Congrats, @au1994 - looks great!
Didn’t you have a Maverick on order, too? Are you planning to take it and flip it?
I’m jealous of a garage with that much space.
Ahem.
I'll remind you that I started and maintained the punch list for a few years before I was promoted to moderator, at which point @corvette stepped up to take over the responsibilities.
Having met him in person (at a wonderful dinner hosted by @breld, and also included @tifighter and @jpp75), I can tell you he's diligent about accuracy.
Thanks. I do have a Maverick on order but I will just let it go. Not confident there is enough money left to risk trying to flip.
After not driving the BMW for a over a week due to baseball tournaments and a weekend getaway I finally tended to it after bringing it home with the coolant light on. This is what I find upon closer inspection.
That stick is supposed to be floating.
You know, I replaced the whole cooling system, at one point?
Of course the Toyota folks are still hiking their prices as though there was no competition. That’s why my neighbor bought a Hyundai Tucson PHEV a year ago and we got the Kia.
