Honda Accord Accessories
Thatg's the guy you want. It might be pricey but believe me, it's worth it for a job done right.
But IMHO, the savings of buying it on line is offset by the cost of shipping. Wouldn't it just be easier to go to the local dealer's part desk and buy a bottle for $4??
anonymous, thanks for the tip, but I don't think I can find the time to take it to Clearwater.
treoster, I will call the lexus/mercedes dealers to see who they use. Thx.
I was wondering if anyone else has the tinted windows with the Desert Mist color (don't exactly know how it will look with this color).
Here are some pictures of our coupe .. they are kinda bad but it was rainy.cloudy at the time.
http://www.printroom.com/ViewAlbum.asp?userid=civicminded&album_id=126352
I need to have the sedan, but the coupe does look nice.
Does anyone know if this is a simple job or will modifications be required? The sizes appear the same. I read somewhere that the 2001-2002 radio is designed to fit ONLY the 2001-2002 Accords. Any input on this?
Thanks in advance!
Gary
I flipped through the ones available at tirerack, but there are so many styles, and so many sizes (18 inch ?!). I do prefer the 5-spoke style...
Can I easily put a 16" wheel on this car, even though the stock ones are 15"? Do I have to change tire sizes when I do this? Does anyone have a good link that might explain the repercussions of increasing the wheel size?
Appreciate any help and recommendations.
http://www.v6accord.com/forums/
I say "better" because you need to analyze and not take at face value the various posts to come to a solid conclusion. But the info is embedded there.
Since I've gone thru the threads myself, researched tirerack.com and tires.com and actually put on a 17" wheel & tire on our 03 EX, here are observations, suggestions and "words of wisdom" which you might consider:
1) Yes, you can easily "upsize" your rims/tires from 15" to 16" and even 17." Just remember that keeping the "rolling circumference" the same as the original is important. To know this, go to tirerack.com, pick out your original tire size and note "revolutions/mile." You can now pick any other tire size that's nearest to if not exactly the same as this rpm. This number is important to keep your fuel economy, odo, speedo and other tire revolution-dependent elements of the car the same.
2) Rule of thumb is that price, ride firmness, and road noise go up with tire diameter (i.e., from 15 to 16 or 17) and not necessarily so if you keep diameter same but the tire wider (e.g., from 205x65x15 to 215x60x15).
Decreasing, as tire diameter goes up (particularly with 17"), is the treadwear or lifespan of the tire.
3) Personally, the 17" is the largest size I'd recommend (and this would be tire size 215x50x17 and 215x55x16 for 16") because of price, treadwear and appearance considerations. Also, going beyond the 17" size increases your risk of bent rims/ripped sidewalls with normal driving.
4) Other than the obvious lug-pattern requirement, I cannot overemphasize the importance of the "offset" spec of your replacement wheel. The Accord's (and the Acura TL/CL's) offset number is 55mm. The rim sticks out more as this number decreases, say from 55 to 40mm.
Having the wrong offset can cause fender & strut rubbing and/or accelerated drivetrain wear due to stress on the components.
Bottom line, there's only so much offset difference you can accept on the replacement wheel, especially if you have occasional rear passengers. Based on the threads I mentioned, this would be a range of 55mm (original) to 45mm for a 7" wide, 17" rim.
Don't hold me on the 45mm, because "tire bulge" can still cause fender rub with this offset. The rim/tire combo I tried, a Konig Imagine 17" w/215x50x17 tire, had a 40mm offset and it looked ready to scrape with 2 passengers in back.
Thus, your best bet would be aftermarket rims that have a 55-47mm offset or better yet, the Honda/Acura OEMs.
Hope this helps.
YOu can enlarge to any size you wheel you want, my suggestion would be to stick with either 16" or 17" wheels. I wouldn't recommend going any larger unless you plan on buying more wheels, because you will bend them. If you have alot of potholes, I would recommend staying away from even 17" wheels from most makers. My friend recently purchased a set of 4 Mille Miglia 17" wheels for a 2002 Accord coupe from Tire Rack, and in about 5K miles, 3 wheels have been bent! Expensive! If you want 17" wheels, spend a bit more for better brands like BBS. Of course, whether or not 17" wheels will bend all depends on how you drive and how the roads around you are. Here in NJ, the roads suck, therefore wheels bend more easily.
THe basic repurcusions of changing wheel size, is 1) your speedo is going to be slightly off, by slightly I mean very slightly-something you probably will not even notice.
2) Larger wheels are generally going to mean a firmer ride, unless you find wheels that are considerably lighter, like Axis brand wheels, BBS, or Centerline. A lighter wheel will reduce unsprung weight which improves ride somewhat.
3) Handling will improve-a positive.
Typically you do have to change tire sizes.
For example if you have 205/65-15 tires on your car now and you want to increase to 16" wheels, your best bet would be to increase to 215/55-16(increase one increment in width and decrease 10mm in sidewall height). OVerall, this will bring your overall tire/wheel diameter the closest to what your stock is. If you want 17" wheels you can increase to either 215/50-17 or 225/45-17 tires.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item- =2401333202&category=10368
http://www.miata.net/garage/tirecalc.html
cheers....
I really don't like the wheel options for the Accord. I don't like the split spoke design too much. I do like the 15" alloys offered for the CRV though (the 5-spoke, not the split spoke). Hard to say what they would look like on the Accord coupe though. Tire Rack is pretty cool for that if you can find similar wheels on there to compare.
Do you happen to know any decent Canadian parts/accessories places? Either online or mail order?
There might still be a couple of 2002/2003 Acura TL 16" rims on Ebay, solid-5-spoke style. They're a perfect fit for your 03 Accord, exactly same specs.
The 1999-2001 Acura TL 16" rims will also fit perfectly but have split-spokes.
The 2 options above are relatively inexpensive on Ebay. Buy-now prices hover at $250-$300 for a set of 4 without tires.
Next notch, there are the 17" 5-solid-spoke rims from the Acura TL Type-S that would go for about $600 without tires, $900 with.
A word of caution on Tirerack.com/Tires.com/other online stores: choose your style first then call a rep on their 800 line to discuss offspec (should be 47-55mm). Tirerack doesn't show offspec #s in their gallery.
I want a ton of options installed and if I don't find a place equal to collegehillshonda.com I'll end up paying a ton with the dealer.
Any takers on opening a Honda parts place in Canada ala. collegehillshonda.??????????
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item- =2401828805&category=33748
Wheelmax.com or Victoriatire.com
They have more selections and cheaper than direct tire or tirerack.
Do any of you know if body-colored splash guards are offered anywhere for the '03 Accord?
I had the tips installed at the dealer when I purchased the car. I was a bit disappointed to see that one of them had fallen off. After finding the thing, I called my salesman and he stated that there was nothing he could do for me. Considering they installed it, and it obviosuly fell off, do you guys think they should be held liable for it. Any thoughts would be welcome. Thanks.
I spoke with the salesperson that I dealt with and he stated that there was nothing he could do. He said for one it may have been my fault, implying that I could have backed into a snow bank or that it was stolen. Even if I did back into a snow bank, I dont believe it should fall off, wouldnt you agree.
Im a little bit disappointed that I am having such a hard time with this. If worse comes to worse I will contact Honda , but that is the last thing I want to do.
The other thing you can try is using loktite and tightening it down enough to compress the pipe slightly... this should also prevent it from falling off.
I went to Best Buy and they tried selling me a set of high end speakers for my 98 Accord even though I was keeping the stock stereo. I'm glad I called Crutchfield because they recommended a better match on a lower end speaker that was much less expensive. I spent a little over $200 and they sound great. Quite an improvement, especially when listening to CDs.
Crutchfield also includes wiring harnesses so all you have to do is plug in the connectors and screw in the new speakers. I also purchased a door removal tool from Crutchfield (less than $10 I think) because on the 98 Accord you have to remove the inside of the doors to get to the speakers. Not sure if you have to remove the doors on the 03 Accords. You get detailed instructions with your shipment. I'm no mechanic and I installed all 4 speakers in less than an hour.
I have Polk 6 1/2" GXR6 in front and Alpine 6x9 3-ways (I don't remember the model) in the rear. Sound quality is MUCH better than stock. Much better clarity and much more bass. The sound quality is most noticeable when listening to CDs. Radio quality is somewhat improved. The only drawback I have noticed is on AM stations. Certain deep voices cause the tweeters to buzz on occasion. So if you listen to a lot of talk radio, I wouldn't waste the money on speakers. If you listen to a lot of CDs like I do, it's well worth it.
When you find one let us know. I have been checking the yahoo accord board for this item as well.
I am torn between attaching RCA jacks to the unit
http://www.logjamelectronics.com/piex3auxconv.html
or getting Honda's player. I have heard unconfirmed reports that the interface for the mp3 player is not that good (ie, song titles, artists, folder mgmt, etc) In other words if you want the 110th song on a disc full of mp3s you have to press next 110 times (as compared to pressing "next folder" 10 times.
Sure would like to hear from someone who has seen the player.
The dealer lists the cassette player as a $300 accessory, not including installation... Is there any way to install a stereo miniplug somewhere (for much less money) so I can just plug my MP3 player in and use it, rather than get the cassette player installed and use a cassette adapter? I found the plug on the bottom of the radio/AC unit where a cassette or CD changer would be plugged in, but I have no idea if I can just hook 3 wires to it (L/R/Ground) and buy a $5 jack at RadioShack.
And having looked at the manual and some installation instructions for the cassette deck, it seems like the different components (cassette, MP3 player, changer) send codes to the main radio which activate the "CD/AUX" button and tell it which component they are. If so, would it then be impossible to put a miniplug on, since the port wouldn't be activated by the radio? Anyone else having this problem?
I'm thinking to buy 17x7.0 rims for 2003 accord lx coupe. Should I use 225/45/17 or 235/45/17 tires on the rims above? Btw, offset is 40, I can't find offset 48-55. Thanks.
A 40mm offset will cause fender rubbing with 2 rear passengers or a loaded trunk and will accelerate wear of suspension parts.
Let me point you to a site selling reasonably priced 17" rims with a 48mm offset:
http://www.v6accord.com/forums/showthread.php?s=5f03a80483cb04cbf- 18ade2da47a9039&threadid=15880
As to the Yokohama Prodigy, couldn't find this on the tirerack site but you might consider the Yokohama Avid H4. Again, reasonably priced and the consumer reviews (click "Reviews") are generally favorable. Here's a link:
http://www.tirerack.com/tires/Compare1.jsp?compare=true&partN- umber=&make=&model=&clarifier=&price=&width=2- 35%2F&ratio=45&diameter=17&sortCode=&speedRating=- &qty=&stockMessage=&type=T&URL=&newCompare=tr- ue&prevprice=&frontTire=&frontLeftTire=&rearTire=- &rearLeftTire=&goWhere=%252Ftires%252FCompare1.jsp&Ad- dToUser=true&startIndex=40&sortValue=1&qty_345WR7CEC_- =4&qty_345WR75000_=4&qty_345YR7SPORTAS_=4&qty_345WR77- 000S_=4&qty_345WR7HTRPL_=4&qty_345WR7DBS2_=4&qty_345H- R7TA42_=4&qty_345HR7RE950_=4&qty_345HR7RSA_=4&qty_345- HR7XGT4P_=4
I answered my own question. I retrofitted my 2003 EXL with the homelink module for the V6 Accord and it works great! Piece of cake to install as well. The part number for the homelink module for those without the Navigation system(ie no built in microphone) is 39180-SDA-A32ZB. This is for the EXL with an ivory(looks beige to me) interior.
I guess some folks have 225x45x17 for that "low profile-" meaning-"thinner tire," look and/or to lower the car as you said. 4 points:
1) odometer reading will be slightly higher than it should be because they're smaller-diameter tires (tirerack measures this by a tire's "revolutions per mile") versus the original,
2) fuel economy will be slightly poorer,
3) with less sidewall, rims are more prone to damage as per my previous post,
4) "low profile" is actually determined by the "45" number or the tire's aspect ratio. It's the numerical relationship of the tire's sidewall height with its width. Thus, a wider tire is necessarily a taller tire, and
5) properly lowering the car requires changing the springs and eventually the shock absorbers ("struts"). "Fender gap," important to some, is also minimized this way.
Not many rim & tire stores are aware of proper rim & tire sizing, unfortunately.
I probably would have shopped around more if I had known the part number ahead of time but the customer service at the site was very helpful in answering all my questions and helping me locate the exact part I needed.(you don't need the whole console assembly only the small 2x2 piece in the middle)
