Honda Accord 2007 Maintenance and Repair
You were told wrong.
Your car will run similarly on 87 Octane as it will with 93 Octane. The only difference will be your fill up will cost you about $3 more!
Put regular in it, for sure, but premium won't cause a problem if you use it.
My 1998 accord has about 225,000 miles on it and i drive it on the highway very often and change the oil every 3k. and my question is do u think i can use a different type of oil like the synthetic oil as compared to regular since i drive on the highway 95% of the time.
Thank you,
i suppose going to a synthetic is going to give you longer change intervals.
i think in your situation, proper operation of the cooling system is important. you don't want to over-temp. i think that's much more important than conventional vs. synthetic when you are changing the oil so often, or highway vs. city.
http://www.royalpurple.com/homea/homea.html
I would recommend you research this motoroil/lubricant company. I have not been pointed to a better lubricant company yet. I had looked into and spent a lot of time on-line and asking different mechanics/race shops about using this product for day to day use and the companies overall reputation before moving over to them. Price was the only percieved issue. However the extended life to the drive train and less frequent oil change makes up for the cost.
I plan to keep my 07 until it doesn't work anymore so I see it as investing in my vehicles longevity. Some do not plan to keep their cars for extended periods of time so it may not be as cost effective for them.
I am at 5,400K on the odometer and just hit 30% oil life. When the time comes I will be using this brand for my new car as well. Even though the companies research shows the changes can be made less frequent I prefer to err on the side of caution so I will continue to follow Honda's recommendation for maintenance minmder but will use this product as the oil of choice.
You will usually have to order on-line or go to a race/performance shop to get their products. And the price is basically retail from what I have found. It is what it is.
Not sure if this helps you or anyone else on the forum.">link title
Is the weight of the oil the same as recommended my the manufacturer?
It is still the original Break-In Oil right now.
And the Royal Purple has varying wieghts/vicosities based on application purpose including Honda recommendation.
Sorry again about the miscommunication. Thanks for pointing it out. Hope this cleared everything up.
interesting.
they are making some real claims w.r.t. horsepower, torque, fuel economy, and emissions... they don't indicate how the figures were derived (i.e. the baseline or methodology).
the expected improvement along these dimensions for a honda accord is likely to be less I would think than that of a racing engine, and the benefits realized offset by the additional cost, but that's just a hunch.
I try to avoid paying attention to a companies own hype about their own product and prefer non-, potentially, biased information/sells technique. Afterall they are in business for reason, $$$.
And I am pretty sure they wouldn't remove their "evidence" from the site. I remember someone else I tol dabout these guys said they couldn't find it easily either, but it should be there somewhere
And you should be more than broken in by now. Previous posts here have some break-in details.
To sum it you need to (1.) go easy the first 500 miles and (2.) at some point a few thousand or so miles later take it to the redline. If you haven't redlined it you will probably want to before your first change. I
And if you never redline it I don't think it is going to send some type of curse on HONDA reliability although some have posted it is the last break-in procedure to make sure the scoring goes as high as possible under heavy engine load.
No reason to doubt what was posted about that. If you have a mechanic you trust I would recommend asking for their input. I assume it should match what people have posted on this forum.
Aside from the basic tail-light and trunk differences brought in '06 are most of the other replacement parts interchangeable from '03 until the present?
Engine, Suspension, Brakes, Electrical?
Just so I know if looking to swap components if I am able to look only at '06-'07 or if I can look back to '03 and forward.
I know their probably is not a blanket answer. Just looking for a general guideline or rule of thumb. I would always research thoroughly before actually purchasing anything but I just like things narrowed so I know where to not waste my time, and at the same time have all my options available in front of me.
Thanks to anyone who has advice, experience or an educated opinion.
Thanks again,
What I like to do before draining the oil and changing the filter is to run the car for a few minutes. This way, all the bearings will have a good coating of oil, so during the first start up, everything will have protection while the filter fills.
Mrbill
Let us know when your car DOES shift when floored.
This is a VERY common problem with 03-07 Accords; its a minor aggravation to me, but my 2006 has it too. Only at certain weather conditions/road conditions though.
My dad's 2005 happened to avoid it, but his 2003 had this rattle as well.
i tend to run a little bit of new oil through the engine with the oil pan drain-plug out.
i also like to also pre-fill my new filter with oil before putting it on. i'm not sure it gets oil to rotating parts faster, but it just seems like the right thing to do.
I think I've heard of people adding some shims (?) in the window track allowing less movement back and forth.
Check out the 2003-2006 maintenance and repair forum for a lot of helpful people as well (the 2003-2006 cars are practically identical to the 2007s so I'm not sure why this forum is completely seperate from those).
I posted about this problem and the dealer was able to fix it. I can't remember the specifics but it would be on the 2006 M & R thread. I think I posted the exact wording on the repair order. I'm not home right now or I could look it up.
As for the headliner issue... I also had that fixed because there was this horrendous cracking sound in cold weather. They were able to fix that by adding insulation to the headliner. All has been great since then.
The headliner was fixed after another trip.
I am considering going for Synthetic oil change but
Synthetic oil costs about double regular oil change based on the calls I made recently.
Is the oil change interval also double?
If I tried Synthetic and found it's cost double and yet i still have to go change oil almost the same amount of time then is it bad to switch from Synthetic back to regular oil?
Seems like it would be the same fix though - tightening up the run channels.
Thanks Tallman
It is not bad to switch back to regular. I use synthetic for superior startup lubrication (especially in the cold) very slightly better fuel economy and longer change intervals.
I know the Accord has a maintenance minder, but I would probably change at 20 or 30% with regular and will be comfortable going lower with the synthetic.
Anyway, just purchased the car on Saturday. While I noticed this problem at the dealer, I didn't think much of it. But now it is bothering me. Both of the rear windows make a grinding noise when I close them. It is usually the last third of the way up. I don't notice this noise when I lower them. The Drivers side rear window grinding is worse than the passenger side. Any thoughts on this?
AFAIK - yes. The maintenance minder in Hondas uses an algorithm that measures engine speed, temps, hours, et al to measure oil life and recommended service intervals.
It cannot tell the difference between dino and synthetic oil and since Hondas come with dino oil from the factory, that's what it uses as a basis.
Other manufacturers that use synthetic oil from the factory will create algorithms based on that parameter.
If you keep the minder schedule then your primary switch from Petro to Synth Oil is lower engine temp., greater film strength, lower thermal breakdown, (film strenght stays better longer)
Your decision to switch is probably going to come down to if you want to extend the interval (ignore the minder) and/or are fine justifying the cost for better quality product.
It would seem that way. Personally, its just too much darn fun (and excusable given the practical reason for doing so that one time) to floor it through a gear or two, say, on an empty onramp.
