Visitor Agreement.
I drove the car this morning and was impressed with the quality.
I made a counter offer and it was accepted. I look forward to putting many miles on the Echo.
Thanks again for the info.
Jack
I am in the process of buying a 2000 Echo with only 15K mi. It is a 5-speed. What is the general opinion as far as type of oil to use? My understanding has always been that synthetic will help with gas mileage and longevity of the car. However I have also heard stories of it eating gaskets as well... I want to do whatever it takes to make this car last. I love the Echo, and I want to be able to take the best care of it that I can. Any other tips? Also, do you guys recommend the RedLine MTL products for manual transmission fluid?
Thanks for your help,
Trey Bradshaw
treybrad@home.com
If you want to keep your engine clean, switch to the synthetic. It's clearly superior to the dino oil in every way and will cost you just a little extra (in comparison to any engine repair bill). If your warranty requires changing oil at the 7K-mile interval - do it. After the warranty expires you can safely extend the interval to 10-15K miles.
thanks.
on another note, i did get a 5 speed manual but haven't noticed it shifting stiff. i used to drive a nissan sentra and it stayed stiff for 4 years so i guess i'm used to it.
What I noticed in my first test drive was that there is hardly any travel in the clutch pedal, and I stalled it more often that I like to admit. (No, I'm not new to shifting, either--16 years in my present manual :^) I got used to it quickly, though, and didn't stall once in my second, 40mi test.
I paid a bit more than I wanted to, but I intend to keep the car for a long time and was getting tired of the sales games with other dealers. I ended up using stoneage.com, which farmed the request to autobytel. In about a week, we had worked-out what I wanted and the car was on its way. The process wasn't as smooth as it could have been, but it beat sitting in a showroom for 90 minutes while some doofus quoted MSRP higher than it should be or calling dealers and not even getting a call back.
And: I have a *line* of people (well, 2) waiting to my 1984 Honda Prelude.
I don't know what the Edmunds editors were smoking when they reviewed the Echo, but they kept saying "It might be OK in a congested area where streets are in bad shape, but here in LA where we coast around on open freeways..." Which parallel universe do they live in? 'Cause I live in the LA where it's congested, full of potholes, and freeways are rarely moving freely.
They are in SANTA MONICA, for cat's sake. Do they jump on the 10 and just whiz along? Please.
ROAD TEST: Toyota Echo
Page 4 of 6
Final-drive ratio. . . . . . . . . . .3.53:1
Gear Ratio Mph/1000 rpm Max. test speed
I 3.55 5.3 53 mph (6500 rpm)
II 1.90 9.8 64 mph (6500 rpm)
III 1.31 14.3 93 mph (6500 rpm)
IV 0.97 19.3 112 mph (5800 rpm)
V 0.82 22.9 112 mph (4900 rpm)
so this means i can go up to 91mph in 5th gear to stay <4000 rpm! how did they come up with 55mph? guess i don't have to worry.
Yes, I know what the book says and I know all the theories. I just thought you might like to know that at least one Toyota Master Technician thinks otherwise.
I've noticed several ECHOs around here (northern Virginia) being used by businesses. One of then seems to be a courier service. Hmmm.
Mine is performing flawlessy as I expected and I laugh at the SUVers as I cruise by the pumps.
I hope you all are well.
I have also noticed some surface rust in the trunk. No big deal, I will sand a little and paint the interior of the trunk.
Has anyone else experienced excessive chipping?
I am considering a bra, but am told that they are a real pain. As I understand it, they have to be taken off after it rains or when any dust is realized.
Has anyone had any luck using a bra on the Echo?
I really enjoy the Echo and everyone who has seen it is quite amazed at the amount of space both inside the car and in the trunk. It is efficient and fun to drive. It is much faster than I thought it would be.
If anyone has any thoughts on the chipping or especially the use of the bra, I would appreciate their opinions.
Jack
Good luck with your Echo!!
I love my ECHOs and have waxed on a regular basis, and kept them washed, and the salt rinsed off. One neighbor thinks I am obsessive...
Having taken a closer look, I am not sure that what I saw was rust. Dealer said he thought it was some kind of grease used to lubricate during assembly and it simply hardened. Looked a lot like specks of surface rust.
Love the Echo! I can deal with the chips. To this point, the car is everything that I hoped for.
Will purchase side molding and replace hub caps with "baby moons". I am sure most of you are too young to know what they are.
I will also have cruise installed and that should just about do it.
By the way, I insulated the air conditioning line even though the air was as cold or folder than that of my Oldsmobile.
I can't understand how the car will blow cold air with the air conditioner off and just the outside vent on, coupled with the lever pointed to the outside range. Does anyone know how this works?
Jack
By the way, I'm 23 years old and I know what baby moons are!!
It is my honest opinion that the paint on the Echo is a little more susceptible to damage than is normal. Jan bee, where did you get your bug deflector? I will try one as well.
I have a real issue. I insulated the entire line from the fire wall to the end. It included the metal line initially, the black rubber line and then the metal line just before entering at the bottom. When I feel the bottom of the metal line it feels hot. I do not want to insulate the bottom and keep the heat in if it will be detrimental.
Could anyone tell me how far I should have insulated the line before stopping? And will it harm anything to have insulated too far down?
Jack
My a/c has worked very well since wrapping it.
As far as the vent lever; if it is at the 'outside air'(rt hand)position and the fan off, air will flow into the cabin naturally. Make sure the temp control is set to the coldest position. When running the a/c on the highway, you'll find that you don't need to run the fan as hard as the airflow will be strong regardless.
I found this and posted a long time ago, but this probably bears repeating so everyone can benefit. The reason you feel cold air, even when the AC is "off", is that the AC is really on. If you have the lever in the 'windshield defrost' setting, and the fan on, the AC is really on, even though the green light isn't showing.
-Rob
I assumed that the air must have been on somehow. Not only because of the cold nature, but also because the engine would idle down slightly when I turned it on.
Kaz6, I insulated the large metal part with the nipple on it. I continued to insulate the rubber hose that was connected to it. I then continued to insulate where the rubber hose intersected more metal pipe at the very bottom. That is where it felt hot. At the very bottom.
So I only insulated one pipe, but I insulated it from the fire wall to where it ended.
Did you insulate the the whole length including both ends of the large metal and the rubber hose in between?
I can easily cut some of the bottom if I have gone too far.
Jack
I will try the web site that you gave me.
Thanks for the information.
Jack
Baby moons? Aren't those the type that cover only the middle of the wheel? Police cars used to use those back in the day
*hint on my age* One of the first cars I owned new was a Mazda Cosmo and I test drove the Le Car when it first hit our shores!!!
I was impressed this past winter with how my ECHO handled in the snow. I got stuck in white-out conditions one day. I drove especially slow but my ECHO stopped on a dime and took off just as well. I saw many MANY cars that couldn't even take off from a stop light. My only concern on that day was being run over by very large and impatient SUB drivers who chose to drive on sidewalks to get around the stuck cars that I was behind. Also, we went up to TV for a ski trip with a bunch of our friends. Out of all of our friends' cars (a total of 8 vehicles) only the ECHO and a 4WD pick up made it through the whole week long trip without a hitch! Many of our friends were quite pleased with the roominess of the ECHO as they'd have never made it to the mountains in their cars.
Another point I thought I'd mention is regarding the AC. I remember someone mentioning that the AC is much more effective and will not freeze up if you use recycled air as opposed to fresh. Just thought I'd mention it again in case it might help some of you.
Anyway, nice to be back after so many months and very nice to see that there have not been any terribly grave reports on the ECHO's performance.
Becuse they just cover the center of the rim you could see the black on the rim outlining the chrome. Besides, I really don't like the factory alternatives.
Concerning the AC, I will cut the insulation off all but the initial metal just to be sure.
Still can't find a bug shield. Toyotaguys have one, but it is not made by Toyota. Might have to go with the bra.
Toyotaguys also offered to send me the cruise package for $290.00. I would have to find someone to install it. Dealers around here don't offer aftermarket cruise.
Jack
I do have one question. Who do you consider to be the Echo's (both models - 2dr and 4dr) competition? Personally when I was looking for a new car, I looked at the 2000 Dodge Neon, the Chevrolet Cavalier, the Ford Focus, the Hyundai Accent, and the Kia Sephia among others.
Would love to have anyone stop by and compare the Echo they bought with another car they were looking at.
Hope to see you there.
I've put only 60 miles on it, and all's well. It looks huge sitting next to my wife's Protege :^). One oddity is that the dealer gave me a Goodyear warranty brochure, but the tires are Bridgestone.
Seafoam blue is a bit darker than I expected (I had never seen one in person, just pictures) and I like it.
I'm somewhat dismayed to read the recent posts about paint chips, but I'm not entirely surprised. The paint on the '90 Mazda Protege is thin (my impression is that Proteges are a bit more "upscale" now) and has chips on the front. Man, my ol' Prelude has excellent paint (no, haven't sold it yet). Something has to give on an inexpensive car, but I had hoped that top-notch paint had trickled down.
Any suggestions or similar experiences?
Don
Hearing you are please with the bug shield makes me more comfortable with ordering it.
About the widow weather shields. I have a black two door. How do you think the weather shields would look on black? Was it relatively easy to put them on? I would assume the tape was forgiving enough to let you move it a little if you were out of line.
I was a little dissapointed with "Toyota guys". I saw their add for cruise charging $260.00. When I em-ailed them for information they sent me back an em-ail saying the price was now $290.00. I also noticed that they changed their website price to $290.00. Not a big deal, but it annoyed me that they would do that.
Jack
