Nissan Maxima
13567174
  • gnlgnl Member Posts: 94
    Hi, I haven't posted for a long time on this board, but recently a problem has come up. I have a GLE, purchased in July. Lately the trunk has occasionally popped open unexpectedly while in the garage (i.e., we find it open when we go into the garage in the morning, when we know it was securely closed the night before). I remember a few comments about this on the Infiniti I30 board, and maybe here, don't recall.
    Anyway, has anyone else had this problem? Could it possibly be responding to neighbors' garage door openers or something? So far it has never happened while driving, but it's worrisome, nevertheless.
  • lsflsf Member Posts: 98
    Could it be that the key fob in making contact with something in your pocket...even when you're inside the house? I suppose you could see if you could get it (the car) reprogrammed and exchange your fob.
  • bigk200bigk200 Member Posts: 170
    EOM
  • warrenulwarrenul Member Posts: 50
    Make sure that when you exit the car that your knee doesn't accidently hit the door mounted trunk switch.
    Anyone, out of curosity, why is that you can lock the seat backs so that no one can get into the trunk, however, once your inside the car why can't a thief/valet parker/nosey wife just pop the trunk by using the switch? Last time I tried you didn't need a key or anything to activate the switch.
    I haven't tried this yet though, will the gas/trunk switch operate while the car is under way? Or is it speed sensitive, preventing any accidental openings.
  • gerhatgerhat Member Posts: 5
    I got the SE with everything except leather. I like all the SE touches such as spoiler, gauges and those handsome 17" rims.
    I agree with lsf, I've set off my panic alarm several times from inside the house when I shove my keys into my pocket; you're possibly just pushing the button on the FOB.
    Living in central NY, I think snow tires are required. I got 4 blizzaks on 5 spoke rims from tirerack. I find the 17" to be slippery and don't want to risk an ill-timed slip. Traction control is also very useful, just turn it off if you want to play spin-the-wheel.
    I got the new TCM and noticed no difference; still a very gentle shift from 1st to 2nd at full throttle.
    Best I've ever gotten on straight highway is 26mpg.
    I'm still waiting for the bumper clips and new brake pads. My brakes groan terribly. I got a large black scuff mark on the 1/2" wide upper bumper lip, but I'll make sure they don't repaint the entire bumper.
    It's amazing how Bush "trusts the people" except when it comes to counting or voting or..... probably anything else.
  • norbert444norbert444 Member Posts: 195
    It happened to me several times. I had the key chain in my pocket with the key fob on it, bent down (while in the garage) and the trunk popped open!! I also had the "lock" activated in a similar manner, and once I activated the panic button.
    It is possible that your key fob is too sensitive. You may take it apart and put it back together after some exploration - be creative if necessary.
    warrenul - you lock the seat release from the trunk side. You have to couple that with the disablement of the remote trunk lock, of course (that little switch on the trunk latch).
    Just my 2c.
  • maximizdmaximizd Member Posts: 18
    for the glove box lock info. Slowly but surely I will eliminate as much of the interior annoyances that I can myself, without the dealer infecting it any further!
  • jeffmaxse2kjeffmaxse2k Member Posts: 38
    I'll try it this afternoon.
    trusting people and having a hand recount done in heavily Democratic areas with people who may have motives are 2 different things. Right or wrong, certain conditions must be met in order for a hand recount to be valid...none of these conditions have been met in Florida. Just because the vote is close does not mean that laws are to changed please the Democratic party. Maybe it is the right thing to do but the right thing to do does not always fall under the law. But then again Al Gore believes that the Constitution is a living breathable document that can be changed by whoever happens to be in charge at a certain time in history...
    And you New Yorkers...how in the heck could you vote for Hillary???(If you did that is ) Ack!!
    Ok back to Max's....I also had the TCM replaced but I do feel a difference...while it is not totally dramatic, it is defintely a firmer shift into second.
    We've got Kennedy...can't complain about Hilary if we elect Teddy in this state. Anyway, Lazio was not much of a candidate (according to the press). Anyone else ready for an answer? As much as I disagree with the manual count in such a select grooup of counties, at this point let them be done with it and while they're at it count those ballots from the military! Then call it quits, whoever's still standing gets the (prize?). The next 4 years will be awful. 50% of the populace will claim it was robbed! Oh, is this the Max forum?
  • dukehouston2dukehouston2 Member Posts: 36
    Is there anyway to disable the horn from "honking" after I leave the car and lock it with the clicker??? Most systems beep or just blink the lights etc. If not now I know...
    Thanx...
    Duke
    Well, I'll check with what you guys said about possibly an oversensitive fob or something, but I doubt that's the problem since both my husband and I hang our keys on a peg near the door when we're in the house. Also the garage is downstairs but the main living part of our house is above that, seems like a long distance for the signals to work.
    warrenul, no, the unlocking trigger is NOT speed sensitive! Right after buying the car, I did accidentally open the trunk by hitting the button on the driver's side door by mistake. Fortunately we were coming up to a stop sign and could quickly get out and shut it, but there's nothing to prevent an accidental opening while you're moving on down the highway.
    Yes you can disable the horn from beeping...I did it but cant remember how off the top of my head....however it is done, it is right in the owners manual....getting home late at night and beeping the horn was not something I enjoyed doing(or my neighbors ) :)
    lsf......touche' :) I probably forgot about Kennedy as I have never voted for that slob in my life :) I see Hillary as a much bigger danger to America than Teddy ever will be...jmo.. And I'm not some right wing fanatical Republican...I'm actually registered a unenrolled(independent to other states) although I do tend to agree with Republicans regarding many issues but also disagree on other parts of their platform...I think due to the Republican majority in the House and Senate, GWB would have an easier time than Gore......but I agree half the country will be bent.
  • majohnsmajohns Member Posts: 16
    the instructions are on the back of the key FOB!!
    Saw this last week when Speed had an issue with his fob battery. I think if you hold down the lock and unlock functions simultaneously, you will shut off the horn.
    BTW, Mass. repubs are more liberal than southern demos, imo. ;)
  • boconnellboconnell Member Posts: 1
    Hi all,
    I have a y2k GXE 5speed. Couple of things - I am getting fairly consistent suspension squeak from the passanger side front and back suspensions. Any ideas on this befor I take it in to the dealer? Also, has anybody had any experience with the passanger air bag surface being a slightly different color (slightly) from the rest of the dash - and it's not the sun as the car is in the garage all day.
    Appreciate any help
    I just wanted to help....
  • gymshoegymshoe Member Posts: 80
    I have / had that problem...and my stinkin dealer fixed it by adjusting the strike plate. Now the door closes fine...but it is very obviously no longer aligned with the rest of the car.
    Make sure they DON'T do that as the fix.
    My dealer..adjusted the strike plate, caused the door to go out of alignment with the body, and now says ...oh..we have to send it to a body shop to get fixed.
    Pissing me off.
    I think there's some cars that get messed up on the line when putting that door on.
    -James
  • y2ksey2kse Member Posts: 104
    in the 5-speed forum. I can't post messages there right now, so I'm going to post this one here. Hopefully the problem will be resolved quickly so we 5-speeders can get back to our specific issues.
    I received the following e-mail from Chris Wardlaw, Edmunds.com's Editor-in-Chief, today:
    "We haven't forgotten you. We were unable to arrange a loan of a 2000 Maxima, but Nissan is supplying us with a 20th Anniversary 2001 Maxima in a couple of weeks. The only reason we're borrowing the car is to investigate this concern."
    This was my reply:
    "That's fantastic news. Perhaps we'll finally get to the bottom of this.
    Specifically, I'd suggest you test the vehicle for the following:
    1. Inability to hold rpm on an unloaded engine below 2800 rpm.
    2. Inability to maintain a steady speed in 1st gear between 1500 and 2500 rpm.
    3. Increasing/hanging rpm between shifts after accelerating rapidly to approximately 2500 rpm."
    Stay tuned!
    Never looked there, the ginko isn't working!!!
    Thanx, Now I don't announce myself when I arrive
    Duke
    Doh! majahns beat me to it..I dropped my keys in the lot leaving work today and when I picked them up I noticed the FOB instructions also! Heh...well now I remember how I did it :)
    Bruce, thats great news....I'll be watching as I'm still lusting for a 5 spd :)
    boconnell Not sure about suspension squeak but if you are talking engine mounts, I'm the right guy to talk to :) What color is your interior...I've notice on my frost that Im getting a square discolored box on my airbag on dash. Guess its a normal feature from Nissan as I remember seeing some posts about this many moons ago.
    Gym- Stuff like that makes me cringe on bring my car to the dealer.....
    lsf- You sir are correct...I am embarrased to call Celluci a Republican
    not.....
    Followed BigK's instructions and removed my latch assembly...the pulled out cylinder...than carefully pulled inner lock out of metal bracket
    here is where you have to be oh so careful...the little tumblers are not held in by anything...tilt to one side and out the come with the spring..(Yes I did it...ack!)
    Luckliy I was able to put all the tumblers and springs back in...taped up the metal bracket and reinserted the cylinder...of course I put it in backwards the first time.....take the cylinder out of the bracket, tumblers fall out again...kick the cat..(j/k) :)
    Finally get it all back together again and this thing is solid.....I mean that tumbler had zero play in it....put it back in car...toook a ride..."rattle, rattle, rattle" Arrrrggghhhh!!!
    Obviously the rattle is not coming from the lock....so...I guess the next time I bring the car in to fix the rattles that they say dont exist or blame on an unfixable lock, I can call their bluff. Dorrie...believe me..Crest is next :)
    All in all, you have to very very careful in doing this depending on your coordination level...I got very lucky as I usually screw this things up big time.
    thanks BigK Your instructions worked great..only wish it was the lock in mine :)
  • jamberjamber Member Posts: 21
    Well, I had the Nissan dealer's manager look at all the scuff marks on my Maxima (the guy in detail buffed my Maxima too much (see post #127)). The manager was very nice, and tomorrow, I will bring my Maxima in and they will replace my side moldings and replace my sunroof wind deflector (the manager said they are charging the negligent guy in detail for the parts!) I have to set up an appointment to have their body shop to take care of the burn marks from the buffer on the spoiler and the rear window frame. I questioned about the clear coat being damage by the negligent buffer, their detail manager said it was fine... I got my survey from Nissan and will include this story with it, so if in 5 years my paint starts to fade or peel I have something to back up my claim. but I may trade my Maxima in before that because...
    I just got my AutoWeeks buyers guide for 2001 and they listed the Maxima for a redesign in 2003. And they said the I30 will be redesigned as well and will be a rear wheel drive!!! So I guess this holds true for the Maxima as well??? Also AutoWeek had a review on the 2000 Maxima SE and they praised it... the only negative comments that I can recall is the power steering could not keep up in the slalom test, but the 17 inch Potenzas made up for it, and the styling was questionable...someone said it reminded them of a Neon? (they must have seen the GLE tail lights)
    Also I read that Nissan may bring back the Z in 2004 or 2005 and it may be built in the new factory in Mis.
    Anyway... I'm here in Florida (yes I voted correctly!) and it has been in the low 50's in the morning and I used my heated seat to take the chill off... they are great, a nice feature to have even down here on these chilly mornings... I would have to have them if I lived back on Long Island NY!
    I received a "VIP" card from my dealership, that entitles me to free car washes, 10% discounts on all part services and merchandise and other things like free gifts with every demo test drive... I'm not impressed... and I'm not going to have their detailing touch my car again! I always wash//wax my own cars by hand!
    I love this car, it is such a blast to drive!!
    I'm so glad I got it!
  • drtyler31drtyler31 Member Posts: 1
    Is Sherwood Green the least popular color? Has any one replaced their SE tailights?
    I found that the Cool Blue Headlights by Sylvania for 12.50 apiece are a pretty inexpensive way to upgrade the stock OEM lights that come with the 2K Max. Put out a much brighter, whiter light than the stock lamps. I was amazed at the difference...plus for onlt that short money, you won't feel so bad if one burns out early...
    Have any of you upgraded the stock lamps and with what? I sort of like the contrast between the new Cool Blues(really more white than blue) and the more yellow fogs
  • joenissanjoenissan Member Posts: 313
    The new Z will be out sometime next year as a 2002 model. It'll be a normally asp. 6 culinder woth more than 250HP, and be priced UNDER 30k.
    Joe
    That should read "Cylinder"
    The glove box also rattles because the latch assembly does not pull the glove box tightly against the (3) rubber stoppers. This is much harder to fix.
    The best solution would be to shorten the wire loop that the latch attaches to, but if you look at it, you will realize that this is not easy to do.
    On my car, I made some new rubber stoppers and replaced the factory ones. The glove box doesn't fit quite as flush with the rest of the dash, but at least it doesn't rattle anymore. No one notices the difference in fit except me. To anyone else, it looks completely normal.
    It sounds like the noise may be coming from that wire loop...thanks for the tip on the rubber stoppers..I will look at that tomorrow.
    thanks so much as always
    Jeff
  • iluvmaxiluvmax Member Posts: 33
    Is this true that the next max will have rear wheel drive?
    Chad for President!
    Well it is possible...when the Nissan Field guys were looking at my car they were talking to the SM of my dealership about something like that....talk was(is) that the Altima would be moving up in power and size to take take over the Maximas market segment and the Max would be moving up to be the Q45 sibling and compete in a more luxury dollar market. Could be bunk and all talk but I thought I saw those same sort of words on another board.
    I think its true. Go to Motortrend.com and click on "future cars". (or some link similar to that.) Then click on 2003 or 2004 and look for an entry regarding the Maxima.
  • gregg20gregg20 Member Posts: 17
    I bet it makes you wonder how you survived without those heated seats in sub 60 degree weather. Almost like Siberia down there in Alabama. LOL If we get a 50 degree day up here in 'Joisey', I may wear shorts to work and show off my chicken legs:)
    Gregg
  • bamadjbamadj Member Posts: 18
    Yup, I'm loving my heated seats and don't regret waiting for 'em! :) Well, we're feelin' the cold down here in Alabama... You can laugh at the temps I'm about to give, but it's cold for here... The high today is 42 and it's dipping into the low 20's and teens in the evenings. We have a freeze warning for tonight... OK, you northerners can quit laughing now. ;-)
    Off now before we get away from Maxima topics. Loving mine!!!!
    bamadj
    jamber, what's the deal with your car? I remember both of us being excited about getting our new Max's and now yours is mucked up because of the dealer buffing it. Did you ask them to buff it or what? Just curious because I pretty much got mine off the truck and they cleaned it, but didn't buff it to my knowledge. No scuff marks, misalignments or anything like that on mine. Can't say it won't creep up with rattles or such as many have posted. I'll wait my turn I guess... :)
    dj
    I replaced the stock headlight bulbs with some PIAA Super Plasma H4 bulbs. This was easy enough to do. Replacing the fogs are a lot more trouble, since you must remove the lower bumper protector (a screw, a bolt, and some plastic clips) and then another screw on the fog light housing. The light assembly must slide out of the from of the bumper, then just replace the bulb. I used PIAA SuperWhite H3 with stock wattage. Don't use overwattage bulbs, you'll fry your harness! Also don't touch the glass on the new bulb with your fingers or the bulb may burn out prematurely!
  • kyleknickskyleknicks Member Posts: 433
    how much were the upgrade PIAA's?? are they much brighter?
    I bought my GLE in August...the last thing on my mind was heated seats. Now that it's nearly thanksgiving here in New England...the leather is a little cold first thing in the morning. FOr the extra... what $500?... i wish i'd added the Meridien.
    I can understand. I "ordered" my car in September and we still had 90+ degree (and about 100% humidity) weather here. But, I know how cold it can be in winter even though I was sweating at the time... I am so thankful for mine!
    I'll be hot in the summer, but won't be using the heated seats. They're here for my comfort in the winter... The extra $470 was definitely worth it, and so was the month and a half wait ONLY because I wanted Meridian here in the south... That's OK, I'm smiling now... :)
    dj
    I know you are the seemingly "go-to" guy on this board, and that's too bad, seeing as we can't get straight talk from our dealers or service depts!! But your input is really appreciated! You're honest! Can you answer another question? My 2000 Bose--I've noticed on different stations that during a song, the audio will completely mute for about a second and then come back on. What could this be--the unit itself? I thought at first that it was the stations reception then I found that it happened on different channels. The sad part is, I've emailed Bose about this and other questions, and not a word back! Thanks!
  • cabowabodudecabowabodude Member Posts: 45
    While having a hard time sleeping one night. I put on the walkman and heard a guy with a web site about head lamps. Yes it is true this guy is a FREAK about head lamps. This guy can tell you ANYTHING about head lamps, (like upgrading) well you get my point. Here is his site WWW.betterheadlamps.com
    JoeNissan, I am taking my car in tomorrow morning to get the oil changed (I'm at about 875 miles, but want it changed before I get on the road for Thanksgiving).
    Do you recommend I have them re-torque the lug nuts to my front rotors or what? I was a little confused on some of the posts and want to get this issue resolved as well while I have my car there. Or should I just wait until I rotate my tires the first time?
    Thanks a bunch! (Of course, I hope you're reading this message board and haven't left us for Thanksgiving yet!) :-)
    dj
  • aaronw1aaronw1 Member Posts: 9
    I haven't really had the time to investigate this, but can the trunk be released either from the fob or from the pull handle in the drivers side door when the car is in motion? or even when it is in drive?
    on my y2k Gle, the disc changer stopped playing discs. When I push the CD/Chg button while playing on anything else (say FM), nothing happens. Unless if the CD is in the in-dash player, that one will play. But not any discs in the changer. By the way, there are 5 discs in the changer and the changer can be opened and the discs removed from the changer.
    I had some work done on the back bumper (the cover was replaced after damage). Could it be that something got disconnected and not reconnected? From the above, it appears that the changer has power to eject the cartridge with the CDs but otherwise it's dead.
  • sgrd0qsgrd0q Member Posts: 398
    joenissan, thanks for your input. As you advised me I tried letting go of the steering wheel in the middle lane on the highway and the car does indeed pull to the right. So I guess it is a wheel alignment issue that I need to address when I bring the car in for service. Do you know if it would be easy to fix the problem? Do you get many new Maximas with a wheel alignment problems? Again, thanks for your help.
  • L8_ApexL8_Apex Member Posts: 187
    I've had to remove a couple not-so-civil posts. This is a great topic which goes hundreds of informative, polite posts without requiring my intervention. I really appreciate it so I do regret having to remove these posts. Try to disagree with mutual respect, OK?
    ...oh, and one more thing, keep the political commentary to a minimum, OK?
    L8_Apex
    Sedans Host
  • si8si8 Member Posts: 1
    Looking for some feedback from new Maxima owners. I have a leased 4-Runner thats matured and I'm considering the Maxima SE w/ 5-speed, in merlot color. Not too interested in the 17inch wheels or the all power seating, but is it true that if I want a sunroof I must order these in the SE convience package? And what about the BOSE, is it worth the extra $900? I am looking for a better highway ride than the 4-Runner. Has anyone been converted from the Camry to a Maxima? I'm trying to decide on which one. Difficult to find a 5-speed without being fully loaded anywhere. Dealers try to talk me into Auto but I prefer 5-speed for the sports car feel. Any advice???
    yes !..Simple fix. Just have the dea;er align the car. It takes about 1/2 hr to do.
    Our dealership doesn't see too many because all our cars are done before delivery to our customers. The reason for this is the way the cars have to be "Cinched" down on the trucks for transit. the suspensiones are basically bottomed out in some cases which isn't good for the alignment.
    Joe
    Yes..I'd have them properly torque the lugs while it's in.
    The reason they become warped is because the lugs are overtightened, and usually NOT equally. So...what happens is the rotor, being unevenly tightened, heats up, and cools down in that same uneven manor, causing the warpage...Good luck.
    Joe
    As long as you're sure it's not the radio station cutting out...take it back to the dealer to be either repaired or replaced. That's NOT normal.
    Joe
    [Sorry everybody. The 5-speed forum isn't accepting posts again. Looks like I'm stuck with having to post over here temporarily.]
    I received the following communication from my Zone Rep today:
    "Sorry for the delay. I would like to schedule your vehicle at your convenience at a local LA dealership. I am free to schedule you any day after 11/29/00. I believe the closest dealership for you would be Performance Nissan in Duarte. Let me know what day would be good for you.
    I have talked to engineering, and to date, there is nothing new to do other than to confirm proper TPS adjustment."
    This was my reply:
    "Right now I'm available on either 11/30 or 12/1. The best thing for me would be to meet you at Performance Nissan first thing in the morning. Their Service Department opens at 7:00 am and I could meet you there at that time. If that's too early, perhaps 8:00 am would be better. I'd prefer not to run it any later than that. Performance Nissan's Service Department is also open on Saturday if that would work better for you.
    Thanks for checking with engineering. As I explained, adjusting the TPS on other 2000 Maxima 5-speeds has had absolutely no effect on the condition I have described to you except to make it worse. Furthermore, Nissan has steadfastly refused to look at evidence provided by independent mechanical and automotive engineers as to the true cause of the condition. Under the circumstances, I'd be satisfied with a written report from you evidencing the condition as I have described it along with a statement outlining Nissan's suggested remedy.
    My goal when we get together is to run three simple tests:
    1) Is the engine unloaded capable of maintaining rpm below approximately 2800 rpm without dropping to idle?
    2) Is it possible to maintain a constant speed in 1st gear in a range of approximately 1500 to 2500 rpm?
    3) Does engine rpm increase between shifts when accelerating aggressively to approximately 2500 rpm and then shifting normally?
    Let me know when you're available."
