As I drive in an urban crowded area, I have not tested the tires in tight 90 mph turns, I'll leave that to the experts. They are rated AA for traction, I think the LH's were rated A.
Time to lighten-up!
wil
The LH's are only $69 dollars at the RACK!. I am going to order a set very soon.
Airwolf1000
I've been participating with this group since last June. I came here because I had some fit/finish issues that dealers weren't addressing and got some help. It's been pretty positive stuff for the most part. At least I don't feel like the Lone Ranger with past issues and can empathize with others. Ad nauseum? Well for some maybe yes. I have had no painful side effects from scrolling past crap I don't want to read for the zillionth time. I am not a big fan of hacking up a late model car for 0.5 horsepower, but I don't get offended if others have at it. They wrote the check and can do what they want. I stay out of those threads.
Pat: you've got a job I would not want to do. You take a post at face value and have to make a decision. Tenure doesn't make anyone "more right" than a newcomer when it comes to choices of words. Like it or not Edmunds owns this server and can do whatever they want. If you can't take a chill pill and ignore a little trolling, put a web server up and start your own forum where you can delete posts with God-like authority. Otherwise get over it. Like some manager from the past once told me,"Yeah this country is a democracy, but that's all outside the door. In here I make the rules." Keep up the good work Pat! Delete this one too if you want, I promise I won't hold a grudge ;-D
I am going to get them installed locally.
Regards, Airwolf1000
http://www.edmunds.com/reviews/longterm/articles/44682/page022.html
They also say in the mag that the 2002 V6 is 210HP and you can order a Cougar S so I guess you have to take everything they say with a grain of salt.
Pat, keep up the good work... I feel you are playing by the rules...
Now my 2 cents.
I have been here since the beginning... I bought my car in sept of 1999... as you all know I have had many problems... some continue... I [non-permissible content removed]... I complain... I boil over and say things I regret...(recent remarks to Brian)
However... I take a deep breath, kick the dog ( not really I love them both), have a beer and realize, after all this is just a forum... a place for anyone and everyone to speak there minds...
some ...including myself sometimes get carried away.. forget what the place is all about.
The key is to realize when you have gone to far... said the wrong thing... made a personal attack... eat crow and say so... stand up and take the heat... I for one will respect you all the more..
enough said.
Kevin
Who still loves this damn car in spite of all his problems...
Did I mention that the moonroof has started to act up... sometimes not moving until you make multiple attempts at moving the switch....
One last thing.... don't all those ..... really get on your nerves.... I don't know why I do it... I think it has to do with stopping to think before I continue to type.... and I don't want anyone to cut me off before I'm finished.or... I just don't know when to shut up.. <:-) (tilt head to the left and smile)
tmeish: Been a lot of discussion here about the new V6. Most of the car rag & internet sites have info. which leads one to conclude that there is a new FoMoCo 3.3L, 250 HP, V6 coming around 2003 that will be used in Lincoln, Jaguar and Volvo. However with any future product rumor you never know exactly what will show up until it comes off the end of the production line so take the rumors lightly.
Personally, I think Mark did a fine job with the transmission. Kudos, Mark. Good Luck on your next venture
Looks like this will again be necessary. Can't wait to see what develops. (Pardon the drooling.)
Frankly, I have found them to be a great deal at 80 bucks a tire.
Airwolf1000
Just though I would add that tidbit.
Airwolf1000
You make a great teacher -- and an incredible asset to FMC.
Best Wishes in your new assignment. Ford must be workin on something exciting! Thanks again, Mark!
The current (well, 2002) V6 has been raised to 220 HP. So that would be upped to 242 using the 10% theory.
G-
I'd agree with Stan; it's probably not possible to get a color combo that's not in the order book. You can probably get special color combinations if you're placing a fleet order, but I'd imagine that that would require a significant volume of cars.
Mark -
Was also great to meet you in Irvine. The reflash put a grin back. It's not perfect but a lot better. You must have taken on a new assignment to get back to Alaska for those -40 trials yes?
See you in Wixxom
Truffle availability for '02 has been inexplicably reduced to one exterior color: The new Aspen Green metallic (code P5). Truffle is a sort of gray-green; it looked sharp with the black exterior & used to be available with both whites & both greens as well. I can't understand why they cut it back to one exterior color--it's like they don't even want to TRY to sell it. Guess it's obvious why I don't get paid to be a color consultant, huh?
Thomas, do you have the Light Graphite (42) or the Graphite/Charcoal (5W) in your vehicle?
Pat
Sedans Message Board
Pat
By the way, for anyone interested in BMW's comparison of AWD vs. FWD vs. RWD, check out:
http://www.bmwusa.com/welcome.cfm?code=Home
Then select Rear Wheel Drive from that main menu.
Best of luck in the future.
Regards - Brian.
What tire pressure does everybody use. The sticker says 30PSI all around. Has anyone experimented.
regards,
m. rankell
What do you mean by "I think the transmission could be a little more aggressive but i am not complaining."
I don't understand what you want.
Mark
I'd have to say stick with the manufacturers recommendation. However, if you live in the frostbelt, during the winter, adding a few psi can possibly protect your rim against those nasty potholes.
m. rankell
Thanks for pointing out BMW's discussion and coverage on car performance attributes. I believe the information contained there completely supports and reinforces the discussion that has taken place on this site for well over a year now. To my knowledge, the LS has simply been the only sedan that has embodied ALL of these attributes (other than BMW and perhaps Mercedes) in the US market.
FWD vehicles simply cannot lay a legitimate claim to the "sport sedan" moniker.
Tom
If anyone has experienced this same fault can you help this desperate and very disappointed owner. I am about ready to demand a replacement vehicle as so far the car has spent more than 10% of it's short 4 month life sitting in the dealer's garage!!
Stupid question, but has the dealer replaced the battery as part of their test or checked the ground circuit out?
