Thanks for any feed back.
frohrs
I think you should also replace the hydrolic slave cylinder while you are in there.
It is a 1999 Ranger ( 4CYL ) with 85,000 miles on it I would like to know what ALL I have to do with it to bring it up to TIP TOP SHARP? Today I am putting Plugs and Wires on it along with a new fuel filter.
I need all the help that you can gave me to have it like a NEW FORD RANGER.
When I mean everything that is right from the biggest thing down to the smallest thing that needs to be done .
I would like to know also who makes the VERY BEST AIR CLEANER?
Does the TORNADO really work? You hear all about it how you get 1 to 2 gallons per mile with it.
It still is not running right, so they are changed the Air Sensor. They believe that my K & N Air Filter left a piece of dirt into the Air Sensor and caused it to go bad.
They believe that the New Air Sensor will make it run like a New Engine once again.
Has anyone had this problem?
Could it be because it was in a accident before I brought it, that is all I know about it. But I found out that it had a Stainless Steel Exhaust system on it when it was NEW. But when I got it no longer had it on. So could the dirt got into the Air Sensor than and when I brought it 4 years ago? I never noticed it run bad until this Winter. Yes it has 85,000 miles on it.
My question is : The K & N Air Filter a bad filter?
Ford thinks they are, and feels that the K & N Filter was the cause of the Air Sensor to go bad. They feel that the paper filter is the best, and that it would not have let the dirt go through it, and caused the Air Sensor to go bad.
__________________
That said I've removed the K&N filters out of all my vehicles as they have shown no sign of improving over stock.
What, if anything, do you think I could pull out of the '83 truck and put it the '89 to make it this dashboard stuff work better?
(I already swapped seats; bed liner and slider rear window are coming up.
There is a wire harness with four wires, one wire is connected to the ignition core (via a metal clip) I am told that this wire is for the chimes when you turn the ignition on? The other three are connected to a plastic ring behind the steering wheel which I believe is for the air bag. The harness is still avaiable from Ford for $133.00 bucks. I have the part #.
Could it be the device that locks the steering wheel?? Please help I too have to disconnect the battery and am getting very tired of it. I want my truck back
Thanks for any help.
frohrs1
I too have put a new cylinder lock and key in my 95 Ranger but it won't shut off.
Please help!
frohrs
any ideas as to my problem?
Help will sure be welcome and appreciated!
Thx, Bob in NC
Good Luck.
Please help tired of disconnecting the battery:)
Seems like you have 2 sets of intake runners to each cylinder, controled by some kind of valve. And this valve is not opening correctly.
I had similar symtoms about 6 months ago (the engine had been misfiring for a while when I finally took care of it; it's my friend's ride), replaced the plugs with Autolite "double platinum" and new Motorcraft O.E. ignition wires. After replacing the plugs and wires and reconnecting the battery (clearing the CEL), it ran great for a few months, without any hint of misfiring. Good as new, I thought...
Recently, the misfiring started again as bad (or worse) than ever. I've checked the wires to make sure all was well-seated.
I have codes from the OBDII reader at Auto Zone:
P0304
P0171
P0174
The codes seem to tell a story of "something's wrong in the EFI/Fuel System, but I don't know what."
Before I start on an endless quest of replacing every component in the system starting with O2 sensors, does anyone have experience with these same problems, and the likely fixes?
This truck looks like crap but has been very reliable despite the abuse of continuing to run it while misfiring, and I'd like to eliminate the misfiring once and for all to make sure it continues to be reliable (and fuel efficient).
Thank you for sharing.
It needs a CA smog inspection, and I doubt it will pass like this.
I'm guessing it's time to replace O2 sensors. But I wonder if it's common that the electronic module that acts as a distributor cap goes bad, causing misfiring.
Is it common to use trial and error replacing these expensive parts?
98 Ranger XLT 4.0, 2wd, 5 speed auto. 198,000 miles.
Should have checked this first, a bad battery usually does not turn the 'red light' on. This indicates the battery is not receiving a charge, not that it is bad.
-No cabin filter on a Ranger, any year.
Ford that the truck starts at all, but sadly, I think you're fighting a losing battle. The problems with this truck will be endless, and probably culminate in engine failure, and likely rear end and transmission failure as well. The electrical gremlins will never end. I'd trade it in on something else as soon as possible if it were me.
-Rear differential.
-Front differential.
-Transmission.
-Brake fluid.
-Front bearings.
-All electronics.
I too am amazed it started at all, or even moved.
You might have one hope. Buy a similar wrecked truck, and start transferring things. Electronics for sure. I would think that in 2 weeks, the areas that you did not flush started to rust up big-time. And if you continue to have not opened up these things, the damage is daily getting worse. The differentials and transmission probably are gone. Remember, oil and all lub fluids are lighter than water and probably started coming out of these things. And they all have openings, even if only small vent holes. You got water into all of them.
In a Cadillac forum, a guy documented bringing a 2000 Deville back to life after a flood. He bought a wreck. He did extensive flushes of the engine and transmission. Also all electronic modules had to be switched out or replaced. He pulled all the electric wiring and cleaned all connectors. Of course the Deville had much more than your truck. He worked all one winter on this. Even then, the car set multiple 'check engine light' codes that he had to work one by one.
Have you learned not to loan your car? But, maybe, your friend is stepping up and paying for the damage?
Can anybody walk me through this?
best of luck!
