Ummm, which gasket? The A4 has lots of gaskets, some are a piece of cake to replace, some not so much. ;-)
Best Regards,
Shipo
SERP belt
valve cover gaskets
cam seal x4
timing belt
water pump
tensioners
Total cost of $1800 plus tax. Does that sound reasonable?
The water pump, timing belt, tensioners, etc don't need immediate attention, but they suggested that since they're already working on the engine, might as well take care of the other stuff.
In addition, I'm very curious why they think the cam seals are shot.
Best Regards,
Shipo
You may want to ascertain exactly where the leak is occuring "seeing for yourself" before investing in the fix.
Just a thought....
d
So, the question is, while you can use Regular, why would you want to? It's kind of one of those "fool's economy" things, while any given tank will cost less with Regular, your fuel costs per mile will actually be higher.
Best Regards,
Shipo
I am getting quoted a price of $310 for the mass airflow sensor and $320 for the valve cover gasket. Is this too much?
Would appreciate any help!
Visiting Host
Valve cover gasket is $36 parts + 1.4 hr labor.
Where I live (labor rates of $105 per hour) the MAF quote sounds like a good deal but the valve cover quote sounds way too high.
I'm only going by what you've told me and reading from a book, so use this info accordingly.
Visiting Host
The reason for replacement is that they can stretch and you won't get the right torque on them.
I have an 1998 Audi A4. I bought this from a dealer an year ago. It has 76000 miles on it. A month back i saw a problem in which the engine rpm used to shoot really high and the car speed used to go low. when i used to stop and park the car for few mins, the car used to drive normally. this happend couple of times over a period of two months. So, i took it to the mechanic to have it checked and the mechanic told everything was fine. I drove the car and went onto to the freeway and within 5miles my car broke with a major jerk noise and the check engine, brake , abs symbol came up. I was never able to start the vehicle again. The mechanic checked the vehicle and again said everything was fine with the vehicle. Thereafter the car used to drive normally but sometimes used to stop with abs, brake symbol coming up. I took the car to the dealer and he made spend 750$ and replaced a shifter chip in the triptronic unit. This didnt fix the issue. I am still seeing the failure. Also, now i am seeing the airbag symbol flashing. I took it to the dealer again, and he says he doesnt know what the problem is. Has anyone had the same issue? Any suggestions to fix the issue would be greatly appreciated.
Backgorund
My turn signals stopped working, meaning they would flash once and then nothing. Silly me thought that I could easily replace the flasher. i later found that the flasher is located behind the Hazzard button and I have to remove the face plate to change the switch, which is $40.
Tim
I have a 99 A4 which had the same problem. Assuming it's the same, the face plate can be removed with a flat or pointed pick. Place it right on the reveal between the face plate and dash, pull it straight out and you'll see the flasher/hazard unit. I opened my unit up and found out the spring making contact sometimes gets stuck in the closed position. I took a screwdriver and pulled it out and deformed it even more. It worked fine and saved $40. Hope this helps.
d
yep, read the codes and find out what's what. I wouldn't buy the car unless the seller fixes the problem.
I plan on buying a 2002 Audi A4 1.8T with 98,000 miles on it. Is there any mechanical problems that come with that year modle Audi? The car is in California and I live in Arkansas so i am unable to test drive it.
Keep us posted.
Best Regards,
Shipo
Good place to look is at Audi tech site at
http://www.audiforums.com/recalls-and-tsbs/make_AUDI/model_A4/year_2002/TSB.htm
But I did find mention of it here:
http://www.autosafety.org/article.php?scid=&did=948
Apparently you have to prove your case to get the warranty, so if you are buying used, that's not going to work in most cases.
The flasher is located within the emergency flasher on the center console. To remove the faceplate simply pry up one corner. There are six metal fastners that hold the faceplate to the console. Once you have the faceplate off use a flathead screwdriver to pry the flasher from the holder, actually this was very easy and I was concerned I might break something. Then you can simply unplug the old flasher and plug in the new one. The only challenge I had was that the six metal fastners that should be attached to the faceplate and snap to the center console all came loose. I had to super glue them back to the faceplate and then reattach it to the center console. So be aware that the little metal fastners, about the size of a staple but thicker, do slide off the center consol and should be glued to the faceplate. I will keep this blog open in case someone has any questions. I was concerned as to how to remove the faceplate without breaking it.
Tim
It is a shame an attorney and mediator had to get involved. I would have thought if you retained an attorney Audi would have gave in.
AD
my blades we not stopped completely, they were stuck and went back and forth a slight bit , they would stop and flicker a little again ...thought maybe it was the fuse but it wasn't...we put some wd40 in the wiper connection bolt(unsure of the technical name) and it started to works again
i went to the dealer and they said it is a common problem and the part would need replacement at about $ 450
hope this helps
i have had it for 4.5 years and have only done 21K miles.
the other day, the coolant was leaking. the garage have concluded that it is a crack in the short engine block. This is surely not down to wear and tear. Audi customer services are offering £1K towards a £7k bill. They do NOT accept it is a manufacturing fault, but will not tell me what caused it. Engine blocks do not just crack after 21K miles?
help would be greatly appreciated. Thank you.
It's offered bt Total Protection and is called "Supreme Coverage".
I'm generally satisfied with my car, though I just had a coolant leak at 36,000 miles and also had aaan ignition coil replaced after the 35,000 service.
2005.5 A4 - 35k miles - 2.0 Turbo Quattro
While on vacation this last week, I noticed the brake lights illuminating on the A4 as I walked out the door in the morning to take a ride. I found this severely odd - no light switches were turned on inside the vehicle and the car started, but barely. That day came and went without event.
However, a few days later as I attempted to take another drive, the battery was completely dead. I had my pops jump it and it started. The following evening, the battery was completely dead again. Had my pops jump again and the following morning it was completely dead once again.
So, I looked up the nearest Audi dealership in Wausau, Wisconsin and headed out for the nice 120 mile jaunt. Arrived mid-morning and explained the situation with the service manager. They couldn't find a problem after an hour messing around. I then let the manager know about the brakes lights being on that one morning. That was deal-sealer as the tech quickly found a faulty brake light switch.
My first question is why in the hell does a faulty brake light switch not cause some type of fault code??? I really found it odd that something as drastic as a piece of faulty circuitry that completely disables an engine can go unnoticed by the computer???
Anyhow, maybe this will help anybody that goes thru something like this in the future.
There was another thing I'd like some comments on. As I was talking with the service manager with the engine idling, he told me there is something wrong with my engine because it idles too loudly. I've never listened to an A4 engine, so I thought mine was normal. I was in a hurry that day to resume my vacation, so I told him I'd hold off until I return to Chicago, but he told me to definitely get it checked out because something's not right. Other than that, it runs good and I am getting around 34mpg's on my highway drives which is real good. Anybody have any concrete information on the engine that I can use before I make an appointment? I'm not sure a service manager would do much if I came in and said my engine was loud, ya know? Something specific would be appreciated.
