Honda Accord Accessories
I probably would have shopped around more if I had known the part number ahead of time but the customer service at the site was very helpful in answering all my questions and helping me locate the exact part I needed.(you don't need the whole console assembly only the small 2x2 piece in the middle)
Sorry for the confusion.
Does anyone have experience yet as to how to install a kill switch for the new Accord? Given the high ranking of Accord's theft rate, I hope to better protect mine.
The headunit is the entire audio system with the audio controls and CD/cassette slots on the dashboard side. Behind the system are the harness ports where the device plugs in. Removal of the headunit is needed to install the device. You can access removal & installation instructions by a web search; a site/forum out there will probably have the instructions.
2) The website literature suggests that the CD changer may not have to be inoperative as it talks about just using the "data port." This depends really on the port configuration on the 03's head unit, which I haven't personally seen. I have an idea that might help you determine this; email me.
I was just shocked at how much better my sound system sounded (new head unit and speakers) in my odyssey when I changed them out. I am hoping for a little better top-end when I add the amps and spkrs.
Is is as simple as just popping the old bulb out and popping the Silverstar's in? I thought I remember seeing a thread a while back that indicated some mod's were required to the [either] Silverstar's or the socket.
I'd appreciate your input.
I ordered mine directly from the Sylvania web site. They had a 1/2 off second pair offer. Cost me $84 for all 4 bulbs. Part number is 9006 for low beam and 9005 for high beam.
Look in your owners manual and it will tell you the procedure. My 2003 was slightly different than my 1998. Both exv6 models. On the 2003 the low beams went in from the wheel wells. The high beams could be reached from the top. Very easy to change. On the 98 both high and low beams were reached from the top. To reach the drivers side high beam, the air filter box needed to be unbolted and moved out of the way to provide access. 5 minute procedure after you have done it once. The low beams are the ones that you will use most of the time. So far I'm pleased with the improved lighting and the look!
Mind sharing the size code for both low and high beam bulbs for the 03 ?
Thanks much.
Same as 2002. 9006ST is the low beam and 9005ST is the high beam for the silverstars. 9005 and 9006 are standard numbers for bulbs that will fit. You can download the $10.00 per pair rebate form from sylvania.com. The rebate offer is valid until 6/30/03. The purchase price was $19.99 each at autozone. With the rebate you can upgrade for $60.00. Silverstars temperature is 4000K. Standard halogens run 2800-3200K. HID bulbs are around 3900-4100K. Daylight is 5400K. Silverstars output is white and lights up the road nicely. Looking at them head on does not seem to blind you but is somewhat easy on the eyes. A nice touch to the accord.
Krillin
Any thoughts on cheap ways to reduce the sway when cornering? We have a TL-S and that thing is great on corners (for obvious reasons of what's built in).
It took me awhile to get the bulb disconnected from the wiring, but once you can do that it is easy to remove the bulb by twisting it like 1/4 turn counter-clockwise.
Putting the new bulb in is as easy as placing it in the socket and twisting it 1/4 turn clockwise to lock it in place. Then connect the wiring to the bulb.
The main problem I had was that there isn't much room for you to stick your hands in. My suggestion is if you do it this way, wear long sleeves to prevent your arms from getting scratched up. Hope this helps...
Krillin
My black '00 Accord EX 4Dr has pretty much everything from foglights, spoiler, xenon HID, tinted windowns, premium sound, sport wheels, but I've been thinking about installing an in-dash LCD/DVD. The problem is they're pretty pricy. Has anyone installed LCDs on the headrests? Is it too complicated? I would appreciate your comments and ideas.
Thanks! JB
Also the reading seems to be subject to the car moving.
On the subject of speaker upgrades, Crutchfield offers rear 6x9s and a component set (woofer/tweeter) for the front. Anyone try these upgrades yet?
splash guard that is made to work with the aero kit??
Good Luck
(FYI, this will plug into the 2003 head unit and provide you with either female RCA jacks or mail sony headphone plug so you can attach either an MP3 player, kids dvd player, xfm radio, etc)
Usual disclaimers, no affiliation, just know a guy at work who used a previous version in his Odyssey van to connect the kid's dvd player so they can hear movies via the vehicle's stereo.
Hi there,
At one time you emailed LOGJAM ELECTRONICS to inquire about an AUX Input Converter for the 2003 Honda Accord. That item is finally available, and will be IN STOCK later this week. The part number is SNHOND3, and it will be listed at www.logjamelectronics.com as soon as it arrives in the warehouse. Final pricing, and product application information will be revealed as soon as they arrive, and will also be shown on the website.
If you still have interest, then please check it out!
If not, I am sorry to have bothered you. This is the only such email that you will receive.
Scott B. Helton
765-644-1251 ofc.
info@logjamelectronics.com
God Bless America!
Was interested in anyone who added a K&N air filter or AEM air intake (short or cold-air), or other minor engine modifications to the 2.3-liter. Ive had these on other cars (99 Prelude & 91 Accord), and found that while the acceleration isnt hugely improved, it did rev better at all rpms, did improve the top end pull slightly, and produced a little better mpg in regular driving.
Anyone? Anyone?
