-June 2024 Special Lease Deals-
Jeep Liberty: Problems & Solutions
Also, I notice what seemed to be a moaning, rubbing sound from the rear of the vehicle as I slowly drove in circles in the parking lot.
This has only happened in 4wd & only after the truck sat outside all night in cold & dampness.
Any idea on what may be wrong & if these symptoms match up with other complaints ?
The truck is kept in the garage each night, but sits outside all day.
First time I have noticed the symptoms.
Thanks in advance-
Did they ever find out the cause of your brake meltdown?
No more Mopar huh. Is Ford or GM in your future? I'm sure you'll find love and understanding at either company.
Renegaded, do you remember when new car warranties were 12 mos. or 12k miles?
I bought a Jeep Liberty 2002 V6 manual transmission in September 2002. Today I went for an oil change at the Local Wal Mart. The vehicle has 9984 miles. In the process of oil change, the technician discovered a loose screw in the transmission and as he tried to tighten it, the screw fell off and they called and told me that the engine is knocking and I should not drive it at all. The vehicle was immediately towed to the nearest jeep dealer and I will find out on Monday what is wrong with it. Does anyone had any problem similar to this.
Thanks in advance.
When engaging the parking brake on my Jeep, I pull up the lever while still in drive or rev. and allow the vehicle to creep to stop against the brake before shifting to park and then shutting off the engine. I have to ratchet the handle a full pull to keep the Jeep from creeping. Does it sound like it needs to be adjusted?
Make : JEEP Model : LIBERTY Year : 2003
Service Bulletin Num : 2100503A Date of Bulletin: AUG 01, 2003
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary: DELAYED OR TEMPORARY LOSS OF TRANSMISSION ENGAGEMENT AFTER INITIAL START UP ON VARIOUS MODELS INCLUDING THE 2004 PACIFICA, SEBRING CONVERTIBLE, SEBRING SEDAN, INTREPID AND 2003 SX2.0. *TT
Also the second is the brakes. I have only noticed this when the roads are wet. ex. When stopping at a red light for about 30 seconds, with the brake pressed then when light turn green, release brake press acceleration pedal a cracking noise comes from the brakes like they are sticking. Has anyone experienced any of these issues or is all this normal on the Liberty?
Shifting from neutral to drive or reverse has a delay on the 545RFE tranny. I read an article explaining something about the transmission fluid pump that needed to set the proper fluid level in the coupler. I also get the 'kick' if I don't wait. The rear differential has by construction a natural 'play' of ~1/4 of a turn on the drive shaft; by waiting a second, it retensions itself.
My concorde was built on June 28, 2002 at 0700 hours in Brampton. I opted for the Limited because rumor has it that they use lock washers instead of standard issue during assembly of this model.
Haven't found any loose gizmos on the garage floor so far. Might be true. Maybe your friend can comment on this urban legend.
He brought out the 2003 Liberty manual, about four inches thick, in which it clearly states the parking brake is not adjustable. The dealer stated when the cable stretches the cable must be replaced. I would not have believed it if I did not read the section provided.
Has anyone ever tried to set up a meeting with a Chrysler rep about this break problem! I have been trying for 2.5 months. Now I had eventually had a meeting set up yesterday afternoon and guess what... I had a phone call one hour before saying that he could not make it. Is Chrysler trying to avoid the problem? Now it may or may not be January before I can set up another potential meeting. Is it me or does Chrysler have crappy after sales customer service?
While I'm on the subject anyone have more news on this break moaning.. or am I moaning more than the breaks now?
If you cannot catch 'the' convenient park brake position by pulling on the lever to actuate the self tensioning mechanism, you will need to open and set your brake drums. But this is something very easy to do for a technician. The risk is that you don't have enough clearance when your brakes get hot, and they can grip if you seldom use the park brake. This normally occurs after a few winter seasons when the cables are full of salt, or when people use high pressure rincing under the vehicle that destroys the protection skirts at the ends of the cables.
Unfortunately dealers often use binary logic to stay away from maintenance. You have or don't have brakes.
The only time to switch between drivetrain modes is when the front wheels are turning at the same speed. In all curves, you need to go 'straight' over a very short distance. If not, you will hear the gears complain because the modes sequence is: 2Full time - 4Part time - 4Full time -+- 4LO. It would have made more driving sense to catch 4Full time mode directly. No one is perfect but I find this drivetrain more secure than what other manufacturers offer. It's real fun when you understand how it behaves. You just have to keep in mind that when there is no more dry pavement in front of you, it make no difference on a straight line but in a curve, an extra road width allowance is needed (assuming you accept to swing the truck around a little bit).
Over the last several monthes it has met or exceeded all of our expectations. My wife loves to drive the Liberty and likes the security that the full time 4wd offers. When we feel it's needed, we set it and forget it. So far so good. My read on the part vs full time question is that the part time option offers only a marginal advantage in slick situations without turns. The full time seems to offer the most universal advantage when negotiating streets and highways.
If there is a situation where this is catagorically not the case, then I would certainly be interested in that information.
Our purchase had plenty of deeply sought emotional appeal and without offering any apologies on that account, we are having a blast. You seem to feel the same about your Liberty so congratulations and good luck.
My feeling is that since I have all this potential for good and bad, it makes sense to learn what I can to max the positive and min the negative. I'm checking into some driving courses offered through 4x4 clubs that should provide some hands on education. Should be fun.
I know about the Jamboree. It's in Virginia. Do you really think it's worthwhile? I might do a local one first.
