Cars historically for years have always needed oil changes at a maximum of 3K miles, and for those that have owned diesels know that oil changes are particularly important because of the diesel by-products that end up in the oil. As technologies have improved over the years you can now generally get 5K miles on an oil change (with synthetics little longer). Some very high dollar cars with very tight engine clearances claim oil change periods of around 10K with synthetic oils and large oil pans containing large oil quantities. However, with oil and oil changes so in-expensive, makes no sense to take the risk and try to stretch mileage limits.
Anyone that has owned a car, or knows anyone that has had a car, know that multiple oil changes a year are required. That's why I think you'll find no legal arbitrator siding with you....they know THEY have to change THEIR oil, so do you. I also think it's a weak leg to stand on saying they never sent you a manual. If you could prove you were at the dealer every week demanding a manual, and have sent multiple letters to the dealership and Honda over the course of 2 years...you MIGHT have a case.
Because of the significant financial impact, this is certainly worth your time to pursue with Honda for some leniency financial assistance from them. Unfortunately I think you're going to be stuck with a VERY expensive repair bill, and need to figure out how to minimize the impact to you. If you can't find a sympathetic ear at Honda (and hence have to pay full list price and labor), I would suggest you look into whether you can find a similar model crashed/totalled vehicle at a junkyard, perhaps something that was hit from behind or the side......and investigate the cost of getting that engine and having it installed. I'm not sure I'd want anyone to try rebuilding my existing blown engine, as every moving part is probably scored pretty badly, with metal filings all over the place.
Another possibility is that you have them take it as-is on trade, and buy your replacement car from them.
Wow, best of luck in getting this resolved.
I had the part fail in my 03 EX AWD at 35K miles, so I just fell under the orginal warranty (whew!). I could have easily been on the "other side" of 36K.
This yields lower overhead costs, and ultimately lower new car prices (or so the theory is).
And when you stop to think about it compared to value of cars YEARS ago (of course uplifting for inflation), you can get a really nice set of cars to choose from in the less than 20K range.
If Honda parts 4 u is the same as http://www.fairhondapartsforyou.com then you can still order from them, since your name is still in the database. I used to buy from them too, and pick up in person.
Now, I buy from http://www.hondaacuraworld.com and pick up in person. They don't charge shipping, but do charge $5 handling per order. If a part is not listed on the website, give them a call and they will get it for you. They are in suburb of Buffalo, NY, so shipping to NE and Mid-atlantic should only take a day or two.
I found that the heat shield (atleast that is what I call it) on the top side (between converter and car body) has corroded away at the attachment points and is rattling on the catalytic converter.
I am hoping that the shield is available seperately from the converter as the shield appears to be a simple aluminum type sheet, and would be expected to be cheaper than an entire catalytic converter.
However, I have been unable to locate this part online at any parts sites.
Is anyione familiar with this part? Do I have the correct nomenclature? Can it be replaced without having to replace the entire catalytic converter?
If you want to look it up yourself on the Bernardi site, in the parts search section, choose "Electrical / Exhaust / Heater / Fuel" under "System", and "3. Exhaust Pipe" under "Component." RefNo #005_2 is the upper shield.
.... MNF
Brought car in to dealer. Honda dealer diagnosed engine light on as a need to replace:
throttle body
02 sensor,
fuel filler neck and cap
Total: just under $2,000 with tax!!!!!!
Dealer would not tell me/give me any info. about a service bulletin. Dealer called Honda and Honda said they would give me 25% off if I did the job in 4 days!!!!
Went home, called Honda and they gave me a case number and case manager (did not return calls for a week). Finally got a hold of him and he said the 25% discount was reasonable. I mentioned if this could be a defect/safety issue. After several more calls the result was: $500 total!!!!! Figure this?????
Anyway, it pays to complain. Did they actually repair/replace everything on the list? Your story reads like the dealer may have been piling on things to fix.
All the work was done. My local repair shop came up with other information from ALLDATA that mentions a failed fuel filter pipe and gas cap that binds for the 2002-2004 crv. defect code: 03214; symptom code: 03203.
Found this on another forum, thought you might find it helpful. If nothing else you can say your not alone.
Flag for Review
Feb 4, 2007
i just bought a 2007 cr-v ex-l and i'm having an issue with it. the air bag light has been coming on since the day i bought it. i have had it looked at and the service guy said that the computer code it came up with wasn't in the service manual so they called honda. honda said that they only had like 2 other vr-vs come up with the same code and they said it was the srs unit, and no signal to the passenger airbag. so they replaced the srs unit and told me that the light wouldn't come back on again. today the light came on again.... haven't talked to honda again cause its sunday. i was just wondering if anyone else on here has had the same problem??????
Reply »
Flag for Review
Feb 5, 2007
The sensor for the passenger side airbags needs to be replaced as well to rectify the problem. This was most likely the cause in the first place.
Please Help!
BTW: Thanks for your response regarding the throttle body sensor and fuel system cleaner.
I would think if this is how the CRV is built, it would call this out in the owners manual.
http://www.hondaautomotiveparts.com
specifically:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- - cgry1=CR-V&catcgry2=1999&catcgry3=5DR+LX+2WD&catcgry4=KA4AT&catcgry5=INSTRUMENT+- - GARNISH
and
http://www.handaaccessories.com/crvint01.html
question: does the socket have threads? i suspect it doesn't but not seeing it. what i would expect would hold it in is some form of metal clip.
now imagine, if it's to be attached with a screw or clip with a hole, then somehow you'd have to be able to unplug the accessory outlet and feed the wires through it.
another possibility (and i admit the exploded diagram above isn't that great for your inquiry, but those diagrams in general is really great), is that the socket itself is supposed to have plastic or metal collar with fingers that compress going into the hole that allow insertion and then hold the socket in the hole when they open up.
what i'd do is bring the vehicle down to the dealer and strike up a conversation with the parts counter person. tell him your accessory power socket is hanging out and ask if he'd take a look.
another idea is for you to go to a pull it place and look how it's supposed to be attached.
ok, it might help if you move the seats back and incline them back. then "fly upside down". but seriously, you got to get in there and see what you're dealing with, right?... i suggest a small mirror and a good flashlight. sometimes an extra pair of hands from the other side of the car help. good luck. :shades:
